Timo12357
  1. Did just that and now I have armbian 24.2.1 Thank you !
  2. So 24.2.1 does not require Bookworm to upgrade?
  3. armbian.list: deb http://mirrors.dotsrc.org/armbian-apt/ bullseye main bullseye-utils bullseye-desktop armbian-config says "No other kernels available"
  4. Here you go: https://paste.armbian.com/dodovukexe
  5. I disabled Armbian kernel upgrades to stay at Armbian 23.11.1 until Armbian 24 stabilizes. Yesterday I unfroze the kernel upgrades to upgrade to 24.2.1. I run: apt update apt upgrade apt dist-upgrade Apt update says All packages are up to date. shows nothing. What did I miss?
  6. Bookworm 6.1 kernel Cinnamon terminal is unusable. The terminal screen flickers and the written text blinks with the cursor blink. Occasionally the terminal goes black. I am using an ancient 1024x768 screen. Is this the root cause, or is the terminal broken in Cinnamon?
  7. Apt lists Armbian 23.8.3 as upgradable but refuses to upgrade. According to apt-cache the base files for 23.8.3 have not been updated for Orangepi3-lts. Is this the case or do I have a local problem with my install? --------------- # apt-cache policy base-files base-files: Installed: 23.8.1-bullseye Candidate: 23.8.1-bullseye Version table: *** 23.8.1-bullseye 500 500 http://apt.armbian.com bullseye/main arm64 Packages 100 /var/lib/dpkg/status 11.1+deb11u8 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages
  8. My system boots from EMMC and the entire system is on EMMC. I make a nightly clone of the entire system to an SD card for backup purposes. For some reason the system sees both the EMMC and the SD when I try to boot it from the clone, and chooses the EMMC. Is there a way to force the system to boot from the SD card?
  9. I just run an "sudo apt upgrade" and my 22.05 system was upgraded to 23.8.1 As a result WiFi stopped working. The wireless interface disappeared and can not be configured with armbian-config. On the positive side it seems like the load bug is now fixed, load can now be 0.0.0 at its lowest as opposed to 1.1.1 before. is there a way to revert back to the old kernel with Armbian?
  10. Orangepi 3 LTS lost wifi after upgrade to this release.
