aht2000
  1. I read somewhere that if I erase the eMMC, the box will be forced to switch to Maskrom. I erased the eMMC using the multitool, and then restarted the box with reset button pressed then released, and connected through USB to laptop and it was detected by AndroidTool as Maskrom, and was able to flash the original Android image using FactoryTool
  2. Thank you for your response. So, seems that if I cannot perform a HW modification, then I am stuck with Armbian on this box, and no way to go back. Few points that come to my mind: This support that I need in uboot cannot be enabled for example by building the armbian image with some specified flags? If I made a backup using multitool from the original Android image, is there a way to extract from it the uboot, and override the existing one? I have a new identical box from which I was able to dump its existing Android image using a tool called rkdumper. I think it dumped a uboot.img (will need to double check). Can I overwrite somehow the current armbian uboot with this img using multiboot?
  3. I have an H96Max RK3318 box which I flashed with Armbian. Is there a way to switch back to Android (original firmware). With the original firmware, pressing the reset button at power connection would take the box into recovery mode. This is not the case for Armbian, so not sure how I can flash back Android on this box?
  4. I had a V11 and was able to get Bluetooth to work by performing the following steps: 1) run sudo rk3318-config and accept all defaults. 2) Create the following symbolic link: sudo ln -s /lib/firmware/brcm/BCM43342.hcd /lib/firmware/brcm/BCM.hcd 3) Reboot sudo reboot
  5. Thank you very much. Yes it did. After creating the symbolic link, Bluetooth is now working successfully and I am able to pair and connect to my Airpods.
  6. This is an old thread. I made some progress by running the rk3318-config and accepting the default. Using bluetoothctl I see it works, and I can scan on. However, either it scans very few devices or none. Following is the dmesg outcome. It complains about a missing patch for BCM43342A. How can I add this patch? dmesg | grep -i blue [ 10.361265] Bluetooth: Core ver 2.22 [ 10.361501] NET: Registered PF_BLUETOOTH protocol family [ 10.361514] Bluetooth: HCI device and connection manager initialized [ 10.361545] Bluetooth: HCI socket layer initialized [ 10.361559] Bluetooth: L2CAP socket layer initialized [ 10.361607] Bluetooth: SCO socket layer initialized [ 10.432142] Bluetooth: HCI UART driver ver 2.3 [ 10.432184] Bluetooth: HCI UART protocol H4 registered [ 10.432193] Bluetooth: HCI UART protocol BCSP registered [ 10.432374] Bluetooth: HCI UART protocol LL registered [ 10.432397] Bluetooth: HCI UART protocol ATH3K registered [ 10.432489] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 10.432863] Bluetooth: HCI UART protocol Intel registered [ 10.435956] Bluetooth: HCI UART protocol Broadcom registered [ 10.436076] Bluetooth: HCI UART protocol QCA registered [ 10.436085] Bluetooth: HCI UART protocol AG6XX registered [ 10.441003] Bluetooth: HCI UART protocol Marvell registered [ 10.820901] Bluetooth: hci0: BCM: chip id 83 [ 10.821724] Bluetooth: hci0: BCM: features 0x0f [ 10.823414] Bluetooth: hci0: BCM43342A [ 10.823458] Bluetooth: hci0: BCM (001.002.003) build 0000 [ 10.823836] Bluetooth: hci0: BCM: firmware Patch file not found, tried: [ 10.823862] Bluetooth: hci0: BCM: 'brcm/BCM.rockchip,rk3318-box.hcd' [ 10.823869] Bluetooth: hci0: BCM: 'brcm/BCM.hcd' [ 18.309192] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 18.309238] Bluetooth: BNEP filters: protocol multicast [ 18.309273] Bluetooth: BNEP socket layer initialized [ 18.357504] Bluetooth: MGMT ver 1.22 [ 56.740638] Bluetooth: RFCOMM TTY layer initialized [ 56.740700] Bluetooth: RFCOMM socket layer initialized [ 56.740747] Bluetooth: RFCOMM ver 1.11 The outcome link from armbianmonitor -u is: https://paste.armbian.com/qusikoqege
  7. I am new to this. I have an H96Max Android TV box which I flashed successfully with Armbian 23.02.2 Bullseye with Linux 5.15.93-rockchip64the latest armbian image. Wifi is running fine. However, I failed to activate bluetooth. I read several post around the same topic with no luck. I am attaching several logs I collected and hope it can clarify more the case, so someone can help resolving this. =============================================== root@rk3318-box:/# dmesg | egrep -i 'blue|firm' [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 6.838446] Bluetooth: Core ver 2.22 [ 6.838756] NET: Registered PF_BLUETOOTH protocol family [ 6.838775] Bluetooth: HCI device and connection manager initialized [ 6.838804] Bluetooth: HCI socket layer initialized [ 6.838821] Bluetooth: L2CAP socket layer initialized [ 6.838868] Bluetooth: SCO socket layer initialized [ 9.513260] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43342-sdio.rockchip,rk3318-box.bin failed with error -2 [ 9.525849] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43342-sdio.rockchip,rk3318-box.txt failed with error -2 [ 9.693623] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43342/1 wl0: Oct 18 2016 17:43:42 version 6.25.134.25 (r662387) FWID 01-281dd9d9 [ 38.183427] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 38.183447] Bluetooth: BNEP filters: protocol multicast [ 38.183468] Bluetooth: BNEP socket layer initialized ========================= root@rk3318-box:/# rfkill ID TYPE DEVICE SOFT HARD 0 wlan phy0 unblocked unblocked ============================================= root@rk3318-box:/# systemctl status bluetooth ● bluetooth.service - Bluetooth service Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2023-03-05 19:55:27 +04; 28min ago Docs: man:bluetoothd(8) Main PID: 1867 (bluetoothd) Status: "Running" Tasks: 1 (limit: 4587) Memory: 2.5M CPU: 97ms CGroup: /system.slice/bluetooth.service └─1867 /usr/libexec/bluetooth/bluetoothd Mar 05 19:55:27 rk3318-box systemd[1]: Starting Bluetooth service... Mar 05 19:55:27 rk3318-box bluetoothd[1867]: Bluetooth daemon 5.55 Mar 05 19:55:27 rk3318-box systemd[1]: Started Bluetooth service. Mar 05 19:55:27 rk3318-box bluetoothd[1867]: Starting SDP server Mar 05 19:55:27 rk3318-box bluetoothd[1867]: Bluetooth management interface 1.21 initialized =============================== root@rk3318-box:/# bluetoothctl Agent registered [bluetooth]# power on No default controller available ========================= root@rk3318-box:/# lsmod ========================= Module Size Used by bnep 32768 2 ir_nec_decoder 20480 0 nft_chain_nat 16384 4 xt_MASQUERADE 20480 1 nf_nat 49152 2 nft_chain_nat,xt_MASQUERADE nft_counter 16384 3 xt_state 16384 0 xt_conntrack 16384 1 nf_conntrack 163840 4 xt_conntrack,nf_nat,xt_state,xt_MASQUERADE nf_defrag_ipv6 24576 1 nf_conntrack nf_defrag_ipv4 16384 1 nf_conntrack nft_compat 20480 2 nf_tables 212992 15 nft_compat,nft_counter,nft_chain_nat nfnetlink 20480 2 nft_compat,nf_tables lz4hc 16384 0 lz4 16384 0 brcmfmac 385024 0 brcmutil 28672 1 brcmfmac cfg80211 876544 1 brcmfmac snd_soc_spdif_tx 16384 1 hantro_vpu 118784 0 rockchip_vdec 32768 0 gpio_ir_recv 16384 0 rc_core 57344 3 gpio_ir_recv,ir_nec_decoder snd_soc_hdmi_codec 24576 1 snd_soc_rockchip_spdif 16384 2 v4l2_h264 16384 2 rockchip_vdec,hantro_vpu snd_soc_rk3328 16384 1 rockchip_rga 28672 0 videobuf2_vmalloc 20480 1 hantro_vpu snd_soc_simple_card 24576 4 snd_soc_simple_card_utils 28672 1 snd_soc_simple_card rockchip_iep 20480 0 snd_soc_rockchip_i2s 24576 4 snd_soc_rockchip_pcm 16384 1 snd_soc_rockchip_i2s snd_soc_core 262144 8 snd_soc_spdif_tx,snd_soc_rockchip_pcm,snd_soc_hdmi_codec,snd_soc_rockchip_spdif,snd_soc_rk3328,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card videobuf2_dma_sg 24576 1 rockchip_rga videobuf2_dma_contig 24576 3 rockchip_vdec,hantro_vpu,rockchip_iep v4l2_mem2mem 40960 4 rockchip_vdec,hantro_vpu,rockchip_rga,rockchip_iep videobuf2_memops 20480 3 videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_dma_sg videobuf2_v4l2 32768 5 rockchip_vdec,hantro_vpu,rockchip_rga,rockchip_iep,v4l2_mem2mem videobuf2_common 65536 10 rockchip_vdec,videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,rockchip_iep,v4l2_mem2mem,videobuf2_memops snd_pcm_dmaengine 20480 1 snd_soc_core videodev 262144 7 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,rockchip_iep,v4l2_mem2mem snd_pcm 131072 3 snd_soc_hdmi_codec,snd_soc_core,snd_pcm_dmaengine mc 61440 6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem snd_timer 40960 1 snd_pcm snd 94208 12 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm cpufreq_dt 20480 0 soundcore 16384 1 snd zram 40960 3 btusb 65536 0 btrtl 24576 1 btusb btbcm 28672 1 btusb btintel 40960 1 btusb bluetooth 638976 11 btrtl,btintel,btbcm,bnep,btusb rfkill 36864 6 bluetooth,cfg80211 sunrpc 581632 1 ip_tables 32768 0 x_tables 49152 5 xt_conntrack,nft_compat,xt_state,ip_tables,xt_MASQUERADE autofs4 49152 2 dwmac_rk 28672 0 stmmac_platform 24576 1 dwmac_rk stmmac 237568 2 stmmac_platform,dwmac_rk dw_hdmi_cec 16384 0 pcs_xpcs 24576 1 stmmac dw_hdmi_i2s_audio 16384 0 lima 61440 0 gpu_sched 40960 1 lima gpio_syscon 20480 1 adc_keys 16384 0
