j0ta
25 -
On RK3568 the Panfrost driver needs the clk-scmi kernel module to be loaded. But is not build in 6.18 / 6.19 otherwise we get [ 13.370681] panfrost fde60000.gpu: get clock failed -517 [ 13.370717] panfrost fde60000.gpu: clk init failed -517 [ 13.485723] panfrost fde60000.gpu: get clock failed -517 [ 13.485761] panfrost fde60000.gpu: clk init failed -517 [ 13.503876] panfrost fde60000.gpu: get clock failed -517 [ 13.503918] panfrost fde60000.gpu: clk init failed -517 Thanks !
Armbian-Base-Files doesn't build for bullseye
j0ta replied to j0ta's topic in Software, Applications, Userspace
Ok it builds now for bullseye it seems it will be available on 24.5 Thanks all ! Cheers -
The armbian-base-files was removed from the beta repositories when 23.11.x-truck was moved from the beta repository to the main repository that was the last armbian-base-files produced for bullseye -
Hi guys! The armbian-base-files hasn't been generated since v23.11.1 (Beta repositories) which is crippling new versions for bullseye users any plan to generated it again ? Thanks ! https://github.com/armbian/build/pull/5192 https://forum.armbian.com/events/event/33-weekly-developers-meetup/?do=findComment&comment=48
No idea, I guess we are at the good willing of rpardini the board maintainer, (I've had to fix myself the nvme not booting without sd card using armbian spl)
hey @usual user tomorrow I'll give a try if nvme boots with the 2023.07.02-00034 if not I'll give a try on your u-boot the problem I have with nvme is present in this thread (there's video) I've no idea what's going wrong
confirmed @Gergő Koszta U-Boot SPL 2023.07.02-00034-g2717ce87b0 (Aug 18 2023 - 09:35:34 +0000) U-Boot phase U-Boot Just installed it is compatible with armbian bullseye the board boots well, hopefully this u-boot will fix the nvme boot problem I have. Later I'll comment when I've got some free time to make a new installation of the system Cheers !
I've notice it while moving files via gftp in ssh2 the network speed transfer is really slow (1GB port used)
The board is the Odroid-M1, sorry I thought you were familiar with the issue The following videos demonstrate the board being able to boot from sd but not booting from mtd flash sd-boot.mp4 mtd-flash-nvme.mp4 after-mtd-flash-no-boot.mp4 boots-again-if-put-sd.mp4
Ok @rpardini I've received my usb to uart It's the first time doing such How do I get the SPI logs after running the mtd flash spi and system nvme and poweroff ? Following these to connect the board to the usb uart on Putty Thanks !
