winnt5
  1. What can we do now? Only waiting? https://dietpi.com/forum/t/rk3399-hdmi-output-and-usb-3-0-not-working-with-linux-6-1/17776/43
  2. After searching, I know kernel 6.5 rc2 is released before this bug appears. According to my tests, probably these two commits caused the problem. usb: dwc3: don't reset device side if dwc3 was configured as host-only Revert "usb: dwc3: core: Enable AutoRetry feature in the controller"
  3. Do you test it on NanoPC T4? I downloaded Minimal CLI image from https://www.armbian.com/nanopc-t4/ , which uses 6.1 kernel.
  4. After recent kernel update, USB3.0 ports no longer work, There is an error printed in kernel log. [ 2.826383] phy phy-ff800000.phy.6: phy poweron failed --> -110 [ 2.827119] dwc3 fe900000.usb: error -ETIMEDOUT: failed to initialize core [ 2.827881] dwc3: probe of fe900000.usb failed with error -110 I found this issue in NanoPC T4, but it might also appear in other RK3399 boards. lsusb didn't show any USB3.0 controller. Confirmed this isn't my hardware's problem, another board have this issue too. dwc3.txt
