Hello, when i installed the helios64 initially i had the problem with the fans spinning at 100% (or really loud) and i solved it somehow. It was working fine with the fans spinning for one second when starting and shutting down the device. Now i finally updated the NAS with
sudo apt update
sudo apt upgrade
sudo omv-release-upgrade
sudo reboot
	and after the reboot the fans are now spinning really loud again all the time. Is anyone aware of an easy solution or a quick fix?
	Someone else had the same problem at https://forum.openmediavault.org/index.php?thread%2F42550-fans-go-on-full-and-stay-there-after-doing-an-update-in-omv-web-control-panel-he%2F= but it seems he either did not solve it or he just forgot to report back. I'm not sure if
	is related to my problem.
	alking about changing the fans but mentions the PWM Fan control again. On reddit
	someone mentions these settings again. I checked and my fancontrol settings seem to be identically or pretty close. In another reddit thread
	it was mentioned to "I went to armbian-config => System => CPU, set minimum and maximum CPU speed at 1200000 and set "governor" to "performance".". But its just "Fan too loud" and not "Fan spinning at 100%"
	So, i wanted to ask you guys if you know a fix for that problem 😕
