I'm having trouble booting my Orange Pi5 off an SD Armbian_26.5.1_Orangepi5_trixie_vendor_6.1.115_minimal.img. I just get a blank screen.
Older versions of Armbian do boot off an SD card, it also boots off NVME.
I do have an old version of U-Boot flashed on SPI (Thanks to Joshua Riek), which I use because it is compatible with my KingSpec NVME drives, other versions of U-Boot did not recognize KingSpec NVME, including Armbian versions of U-Boot. I last tested Armbian U-Boot about 6 months ago, it failed.
The Console log looks normal-ish right up to the point it just stops.
Console Log
DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
Manufacturer ID:0x1
CH0 RX Vref:28.5%, TX Vref:19.8%,20.8%
CH1 RX Vref:29.3%, TX Vref:20.8%,20.8%
CH2 RX Vref:28.5%, TX Vref:21.8%,21.8%
CH3 RX Vref:29.7%, TX Vref:22.8%,21.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09 (Aug 31 2024 - 15:22:22)
unknown raw ID 41 18 20
Trying to boot from MMC2
spl: partition error
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(7612223b82...) + OK
## Checking u-boot 0x00800000 ... sha256(642bfeda4e...) + OK
## Checking fdt-1 0x008d6c48 ... sha256(7b2c4c6dbe...) + OK
## Checking atf-2 0x000f0000 ... sha256(b2af21b504...) + OK
## Checking atf-3 0xff100000 ... sha256(70505bb764...) + OK
Jumping to U-Boot(0x00800000) via ARM Trusted Firmware(0x00040000)
Total: 266.68/489.129 ms
