Bas
  1. Thanks Roy, will take a look at that Xorg config file. As a webserver the OPI5 is pretty brilliant! As long as I leave de server running and don't log in with VNC and start doing heavy graphical Xorg stuff (or heavy JAVA stuff in VSC) it keeps working fine and stable. OPI5 with Ubuntu NodeJS server serves my iqthink.nl domain Site changes uploadable via FTP, very convenient Nginx reverse proxy server handles SSL and https It works extremely FAST, wow! I have an aluminium passively cooled OPI5 case, the thing is the size of a pack of cigarettes. See www.iqthink.nl ๐Ÿ™‚ Bas
  2. Totally understand your reply. My experience with Armbian has been very positive, especially WITHOUT hardware accel. In HW accelerated JR I regularly see segmentation faults in Xorg, which make me think whacky chinese mali code is the cause though I'm not sure. Shouldn't segmentation faults be a thing of the past anyway? It should not even be possible except for broken hardware... Bas
  3. Hello OPI5 users. Running Joshua Riek's Ubuntu distro, I keep getting stability issues. Perhaps because I keep using Xorg. Perhaps because hardware acceleration is buggy. In the past I used super stable Armbian OPI5 distro's without hardware acceleration. Infact I still use Armbian on another RK3588 box, I don't think it has EVER crashed, running docker, Mosquito, HomeAssistant, and a buch of other things. Now that my Orange Pi 5 gets a slightly more serious use as webserver, I really like to get rid of the unpredictable Xorg crashes, and gladly would sacrifice HW acceleration for stability. My situation is this: Using JR Ubuntu Because I want to use headless RealVNC (runs only under Xorg) for several devices I switched off Wayland Using a slightly hacked RealVNC server originating from Raspberry Pi Want to use OPI5 as a NodeJS + Nginx webserver serving Node apps now Any suggestions for a super stable uncrashable distro for the Opi5, for server use but with gui? I kind of hate to set everything up again, especially with the internal M.2 sata quirks, but I gotta have stability now. Hopefully I can ask a second question: is there an easy way to totally turn off HW acceleration in JR Ubuntu? Maybe I should try that first... Kind regards, Bas
  4. Hello people, Happily running Bookworm, because it was the mainstream download for OPI5 a few months ago, I now see that the main download for OPI is back to Jammy. Apart from hardware accceleration, Bookworm runs great for me. In fact HA is not crucial for my server usage, though it would be nice. Question: what is the reason the main OPI5 download is now back to Jammy in stead of Bookworm? And what would be the advantages of going back from Bookworm to Jammy? (Got the aluminium passively cooling case for the OPI5, so far it's been great, 10 minutes of stresstesting all 8 cores doesn't get above 70 degrees celsius. For reference my Meko 3588 box without any cooling reaches over 80 degrees. On that Mekobox I am running Portainer, Docker, HomeAssistant, MosquitoServer, very stable for months and months) Bas Hamstra
  5. Hello folks, I happily run Armbian Jammy XFCE on my much beloved Meko box (with at least SOME hardware accel) and Bookworm on Orange Pi 5. Both run excellent, but Jammy/xfce is a bit more snappy. probably because of partly harware accell. On the Meko R3588 4Gb box I installed Docker, Portainer, MQTT server container, Home Assistant container. All is well. I operate my boxes via RealVNC, so that it also will work seemlessly when VPN is active. The containers are so extremely light that they hardly take a few percent CPU. Home Assistant container takes 0,5Gig or so, MQTT server takes 0.1Gig. My first encounter with docker is very positive! Next I will try to add open VPN and SABNZB containers if possible. So...these containers got me thinking...can we run QEMU on Armbian? Probably not, but I have to ask: would it be possible to: have QEMU working on RK3588 Armbian Run for example a windows VM in QEMU? Even if it would be slow? Just playing and experimenting...never used XFCE before, it grows on me, very snappy and no-nonsense...! And with dark themes these UI's look a lot cooler in the first place IMO. PS: I don't get that my plastic Meko box doesn't get hot, without ANY active cooling. I did a stresstest for 4 minutes, all 8 cores maxed, and sensor temps reach eventually over 80 degrees. Where does the heat go? The box never gets really hot and when the stresstest ends sensor temps go straight back to 60/50s almost instantly. I quite LIKE it's completely silent and without moving parts. It's got an EXCELLENT built-in wifi adapter too! So good that I don't even bother to plug the ethernet cable in, that says it all. Maybe I'll start loving my 8Gig Opi5 more when I get a passively cooled aluminium case for it. But currently it has moving parts and NO built-in wifi and an ugly transparent case ๐Ÿ˜‰ Bas
  6. Hoi Nico, thanks for the link. So far I tried from the offical Armbian download page: Latest bookworm --> very good experience out of the box but the HW accel ppa's don't work. Apart from youtube/movies/games it's very SWIFT for "normal" office and server stuff Latest Jammy --> not a nice experience for me, seems incomplete OOB and laggy I have a preference to stay on the offical Armbian bandwagon so I might try the rolling Jammy XFCE (built one month later) next to see how that goes. On the other hand I am very curious of the perfomance difference with Monka's link. So thanks again Nico! Bas
  7. For my Mekotronics R58 mini PC I downloaded and installed latest Armbian build "bookworm". When I want to execute the suggested scripts to add Mali PPA's for hardware acceleration, I get the error "no release file" for these PPA's. What to do? Wait until it gets solved? Download and install Jammy in stead? Would the PPA's then work without error? Or is there another workaround? Thanks for any pointers! Bas
  8. Are there any other Mekotronics R58 mini users out there? I like this box a lot and Armbian runs great on it, I would very much like to share expereriences with other users and learn from each other. At this point Armbian is downloadable for this board on this site. And it has recent updates too. Some specs: I have the Mekotronics R58 mini plastic version (there is also metal box that has better cooling but same internals) RK3588 8 core Rockchip CPU 4Gb RAM File System transferred to 120Gb SSD with armbian-config Measured it uses 2.1 watt during idle I seem to have everything working except HW acceleration. On the download page it says to execute some PPA scripts (to add repositories) but these fail And everything works rather GREAT very nice silent mini PC Should I wait till subsequent updates will fix HW acceleration? Or run the provided scripts? But alas, these scripts run into errors like below. E: De pakketbron 'https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release' heeft geen Release-bestand. N: Bijwerken van de pakketlijst uit een dergelijke pakketbron kan niet veilig gebeuren en is daarom standaard uitgezet. N: Zie de man-pagina apt-secure(8) voor details over het aanmaken van een pakketbron en over de configuratie langs gebruikerskant. E: De pakketbron 'https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu bookworm Release' heeft geen Release-bestand. N: Bijwerken van de pakketlijst uit een dergelijke pakketbron kan niet veilig gebeuren en is daarom standaard uitgezet. N: Zie de man-pagina apt-secure(8) voor details over het aanmaken van een pakketbron en over de configuratie langs gebruikerskant. Do you use R58? Let's help each other! Bas
  9. But Nico, with respect to hardware acceleration when I try to install the PPA's I get errors like this: E: De pakketbron 'https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release' heeft geen Release-bestand. No release file therefore rejected as not secure. Any ideas? Is there a switch I can use? Anyway I think the R58 is SO much better than the RPI5 that in fact we deserve our own forum. - Crazy fast board - 2.1 watt idle - Does not run hot, and my plastic box has not even a fan - Therefore super quiet operation - Support for SATA ssd is default there - Fast enough for HD games and 4K media (if only we had accelerated HW, but previous versions and Android already proved it) Compare that to RPI5, without fan it gets dangerously hot even when idle. And should we wait another 5 years for HD media to really REALLY work? But eh...main question is above, getting HW accell working... At the same time I must confess that a stable and supported linux is my first prio. Armbian runs excellent even without it. But of course youtube movie playback would be nice...! Bas
  10. Hi Nico, I basically followed this: https://raspberrypi.stackexchange.com/questions/121199/realvnc-server-on-ubuntu-20-10-arm64-on-raspberry-pi-4 The crucial part is this: $ sudo dpkg --add-architecture armhf $ sudo dpkg --print-foreign-architectures $ sudo apt update $ sudo apt install libx11-6 Download the next 10 files from https://github.com/raspberrypi/firmware ... opt/vc/lib libbcm_host.so libvcos.so libmmal.so libmmal_core.so libmmal_components.so libmmal_util.so libmmal_vc_client.so libchiq_arm.so libvcsm.so libcontainers.so These 10 files above need to be copied to /usr/lib. $ sudo apt install gdebi $ sudo gdebi VNC-Server-6.7.2-Linux-ARM.deb $ sudo systemctl enable vncserver-x11-serviced.service $ sudo systemctl enable vncserver-virtuald.service $ sudo systemctl start vncserver-x11-serviced.service $ sudo systemctl start vncserver-virtuald.service $ sudo vnclicensewiz Important: to download VNC-Server to RealVNC, and download the Raspberry Pi ARM version important of type armhf there are 2 flavors. You have to solve a couple of security policy issues, RealVNC will tell you how. But when it in the end works, it works pretty brilliantly!! From my laptop I can login to Windows NUC, or R58 Armbian box. Same from Ipad mini. What is also great: I did a couple of Watt measurements today: Latest Armbian does 2.1 watt idle that's crazy gooed! Isn't that even better than RPI4? When VNC server is active it goes to 4 Watt, some media browsing can go to 10 Watt. Pretty impressive. Performance is on par with my Dell I5 6300U laptop at least in the old Octane 2 javascript test. But I bet proper hardware accell can do even a lot better. Bas
  11. So after the total reinstall of Armbian, I lost the work to get RealVNC server working. I remember it costed me a day of searching and trying back then... So last time I got RealVNC server working on Arm it costed me a day, but today only a couple of hours. In fact I am typing this via VNC on my laptop dialled in to the Mekotronics R58 Works great. Anyone interested how? Bas
  12. Ok figured it out, just downloaded the R58 image and it works and looks great. But Mali support doesn't seem to work, the post install scripts provided seem to fail halfway. As-is performance isn't bad, anyway. As a general point: I find it a bit difficult to find the proper forum where I can at least get in contact with fellow R58 users. I mean: there IS an Armbian image for download for this board. And it's fairly recent too (28 sep) and Monka is the maintainer. So there is at least some form of maintenance. But which forum to exchange experience and help each other Mekotronics R58? Bas
  13. Hello people, Half a year ago I flashed Armbian to to Mekotronics R58 plastic box, which was then an unofficial version. It's been on the shelf a while. Now I see new Armbian versions for download. I plugged in my device and did an update/upgrade. See Neofetch result below. My question is: is there any reason to completely flash the new version? Or am I already fine? It seems kernal versions are the same! Everything works fine and looks awesome including RealVNC for which I had some work to do. Therefore I am a bit reluctant to ditch the current version. Couple of minor issues I have are can't get Samba working and boot from SSD. Bas rock@r58 โ—ข๐Ÿญซโ—ฃ -------- โ—ขโ—ค โ—ฅโ—ฃ OS: Armbian (23.8.1) aarch64 โ—ขโ—ค โ—ฅโ—ฃ OS Mod: AfterburnerMOD WIP โ—ขโ—ค โ—ฅโ—ฃ Host: Hugsun RK3588 MINIPC LP4x V1.0 And โ—ขโ—ค ๐Ÿญ‰๐Ÿฌน๐Ÿฌพ โ—ฅโ—ฃ Kernel: 5.10.110-rockchip-rk3588 โ—ขโ—ค ๐Ÿญ…โ–ˆ๐Ÿญ โ—ฅโ—ฃ Uptime: 3 mins โ—ขโ—ค โ–ˆโ–ˆโ–ˆ โ—ฅโ—ฃ Packages: 1952 (dpkg), 24 (flatpak) โ—ขโ—ค ๐Ÿญ‹โ–ˆโ–ˆโ–ˆ๐Ÿญ€ โ—ฅโ—ฃ Shell: bash 5.1.16 โ—ขโ–ˆโ—ค ๐Ÿญ…โ–ˆโ–ˆโ–ˆ๐Ÿญ โ—ฅโ–ˆโ—ฃ Resolution: 1920x1080 @ 60.00Hz โ—ขโ–ˆโ—ค ๐Ÿฌ ๐Ÿญ„โ–ˆโ–ˆโ–ˆโ–ˆโ–ˆ๐Ÿญ ๐Ÿฌž โ—ฅโ–ˆโ—ฃ DE: GNOME 42.9 โ—ขโ–ˆโ—ค ๐Ÿญ‹โ–Œ๐Ÿญˆ๐Ÿญ†๐Ÿญ‚โ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆ๐Ÿญ๐Ÿญ‘๐Ÿฌฝโ–๐Ÿญ€ โ—ฅโ–ˆโ—ฃ WM: Mutter โ—ขโ–ˆโ—ค ๐Ÿญ…โ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆ๐Ÿญ โ—ฅโ–ˆโ—ฃ WM Theme: Adwaita โ—ขโ–ˆโ—ค โ–ˆโ–ˆโ–ˆ๐Ÿญž๐ŸฌŽโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆโ–ˆ๐ŸฌŽ๐Ÿญ“โ–ˆโ–ˆโ–ˆ โ—ฅโ–ˆโ—ฃ Theme: Yaru-dark [GTK2/3] ๐Ÿญฎโ–ˆโ—ค ๐Ÿญ’๐Ÿญก๐Ÿญ˜ ๐Ÿญฃ๐Ÿฎ‚๐Ÿฎ…๐Ÿญซ๐Ÿฎ…๐Ÿฎ‚๐Ÿญ˜ ๐Ÿญฃ๐Ÿญ–๐Ÿญ โ—ฅโ–ˆ๐Ÿญฌ Icons: ubuntu-mono-dark [GTK2/3] โ—ขโ–ˆ โ–ˆ โ–ˆ โ–ˆโ—ฃ Terminal: gnome-terminal โ—ขโ–ˆโ–ˆโ—ฃ โ—ข๐Ÿญก ๐Ÿญ–โ—ฃ โ—ขโ–ˆโ–ˆโ—ฃ CPU: (8) @ 1.800GHz โ—ขโ–ˆโ–ˆโ–ˆโ–ˆ๐Ÿญ๐Ÿญ‘๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿญ†๐Ÿญ‚๐Ÿญ ๐Ÿญ— ๐Ÿญข๐Ÿญ•๐Ÿญ๐Ÿญ‘๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿฌญ๐Ÿญ†๐Ÿญ‚โ–ˆโ–ˆโ–ˆโ–ˆโ—ฃ Memory: 1696MiB / 3735MiB
ร—
ร—
