TheFlash
  1. SOLVED: Booted with Armbian from SD Card sudo mount /dev/nvme0n1p2 /mnt sudo mount /dev/nvme0n1p1 /mnt/boot sudo mount --bind /dev /mnt/dev sudo mount --bind /proc /mnt/proc sudo mount --bind /sys /mnt/sys sudo chroot /mnt armbian-config -> system -> Other and changed kernel exit sudo umount /mnt/dev sudo umount /mnt/proc sudo umount /mnt/sys sudo umount /mnt/boot sudo umount /mnt shutdown now Removed SD, start and all fine
  2. Degin: MounlAng root Tile syslel ... Degan: munning escrapusr cucad-lop ... uonc. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. done. Geve up waiting for root file system device. Cowmon problems: ⁃ Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=db80a2ac-ec37-4fda-91db-92604becfcce does not exist. Dropping to a shell! BusyBox v1.30.1 (Ubuntu 1:1.30.1-7ubuntu3.1) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) Hello, i got this error after System Upgrade to the latest version. Looks like i need to revert back the kernel cause it doesn`t see my nvme ssd.
  3. Hi, i have tried armbian-config -> System -> Other but doesn`t work
