YurikS
  1. ARMBIAN 5.41 user-built Debian GNU/Linux 9 (stretch) 4.14.34-sunxi, Orange Pi Zero board. Very limited Debian installed, wifi doesn't work. I found lines install xradio_wlan /bin/false install 8189es /bin/false in /etc/modprobe.d/blacklist.conf and removed it. In /etc/modules-load.d/modules.conf I added the lines 8189es xradio_wlan. No help, wi-fi didn't work, nothing about xradio or wifi in dmesg. I figured out that there was no drivers (modules) for wifi. Found this article https://linux-sunxi.org/Wifi I execute the commands from the article, section RTL8189ES / RTL8189ETV The driver has its own repository: git clone https://github.com/jwrdegoede/rtl8189ES_linux.git cd rtl8189ES_linux make -j4 ARCH=arm CROSS_COMPILE=arm-linux-gnu- KSRC=../linux This is what it says root@its-02-o:~# git clone https://github.com/jwrdegoede/rtl8189ES_linux.git Cloning into 'rtl8189ES_linux'... remote: Enumerating objects: 2565, done. remote: Counting objects: 100% (807/807), done. remote: Compressing objects: 100% (413/413), done. remote: Total 2565 (delta 432), reused 670 (delta 385), pack-reused 1758. Receiving objects: 100% (2565/2565), 7.29 MiB | 2.32 MiB/s, done. Resolving deltas: 100% (1476/1476), done. root@its-02-o:~# cd rtl8189ES_linux root@its-02-o:~/rtl8189ES_linux# make -j4 ARCH=arm CROSS_COMPILE=arm-linux-gnu- KSRC=../linux make ARCH=arm CROSS_COMPILE=arm-linux-gnu- -C ../linux M=/root/rtl8189ES_linux modules make[1]: *** ../linux: No such file or directory. Stop. Makefile:2292: recipe for target 'modules' failed make: *** [modules] Error 2 root@its-02-o:~/rtl8189ES_linux# What am I doing wrong? How do I install WiFi modules (drivers)? And the following is in the dmesg vcc-wifi: disabling What is this wifi power disabling? How do I turn it on? Googling didn't help, I couldn't find anything clear about vcc-wifi: disabling Don't suggest installing a new/other Debian. Important software works on it (everything works over LAN), you just need to enable wi-fi. Translated with www.DeepL.com/Translator (free version) ARMBIAN 5.41 user-built Debian GNU/Linux 9 (stretch) 4.14.34-sunxi, плата Orange Pi Zero. Очень какой-то урезаный Debian установлен, не работает Wi-Fi. Нашел в файле /etc/modprobe.d/blacklist.conf строки install xradio_wlan /bin/false install 8189es /bin/false, удалил. В файле /etc/modules-load.d/modules.conf добавил строки 8189es xradio_wlan. Не помогло, wi-fi не заработал, в dmesg ничего про xradio или wifi нет. Понял что нет драйверов (модулей) Wi-Fi. Нашел такую статью https://linux-sunxi.org/Wifi Выполняю комманды из статьи, раздел RTL8189ES / RTL8189ETV Driver has its own repository: git clone https://github.com/jwrdegoede/rtl8189ES_linux.git cd rtl8189ES_linux make -j4 ARCH=arm CROSS_COMPILE=arm-linux-gnu- KSRC=../linux Вот что пишет root@its-02-o:~# git clone https://github.com/jwrdegoede/rtl8189ES_linux.git Cloning into 'rtl8189ES_linux'... remote: Enumerating objects: 2565, done. remote: Counting objects: 100% (807/807), done. remote: Compressing objects: 100% (413/413), done. remote: Total 2565 (delta 432), reused 670 (delta 385), pack-reused 1758 Receiving objects: 100% (2565/2565), 7.29 MiB | 2.32 MiB/s, done. Resolving deltas: 100% (1476/1476), done. root@its-02-o:~# cd rtl8189ES_linux root@its-02-o:~/rtl8189ES_linux# make -j4 ARCH=arm CROSS_COMPILE=arm-linux-gnu- KSRC=../linux make ARCH=arm CROSS_COMPILE=arm-linux-gnu- -C ../linux M=/root/rtl8189ES_linux modules make[1]: *** ../linux: No such file or directory. Stop. Makefile:2292: recipe for target 'modules' failed make: *** [modules] Error 2 root@its-02-o:~/rtl8189ES_linux# Что не так делаю? Как установить модули (драйвера) WiFi? А вот такое в dmesg есть vcc-wifi: disabling Что это питание wifi отключено? Как включить? Гугление не помогло, не нашел ничего внятного про vcc-wifi: disabling Не предлагайте установить новый/другой Debian. На нем работает работает важный софт (по LAN все работает), нужно просто включить wi-fi. Если можно на русском. Английский только с переводчиком :-(
