Talb T
  1. Hi Igor, I was not pushing. And not pushing you! 🙂 Sorry for the misleading. I was asking only info. I was not aware about you are a sw donator at Armbian for Orange PI board. For your info, I understand the strong effort of sw donators. Since not able in sw development, I already donated money to Armbian (I used Armbian high quality OS for my previous board: odroid xu4) and Zoneminder (a suirvellance tool I'm using) . Even if I didn't ask them for anything. And it's true also in this case: I was not pushing/asking for a solution, but, since I saw It's a known issue, I was asking if it will be resolved with the release of the new kernel. In any case I appreciated your very fast answer. And you were helpful: I understood the last kernel already have compiled drive for RTL8811AU and used it! thanks
  2. ok, Igor, thanks a lot. Now wifi is working. I have a wifi odroid adapter and wanted to check/reuse it if working too on the new Orange PI 5 board. After the positive check I came back to the faster ethernet connection. 🙂 For the nekozaki's workaround I will investigate deeper. Anyway, if i'm correct, in the next armbian image with OrangePi5 the kernel vdso issue should be solved. Correct? thanks
  3. thanks, Igor. You are right. I installed the wifi adapter through sudo armbian-config and then wifi section, manage wireless networking, And module is working now. Anyway, Igor, even if I follow the workaround by nekozaki I'm stiil not able to build. For my curiosity, is the workaround not worKing? thanks
  4. hi, trying to compile wifi driver RTL8811AU on Orange PI 5, Armbian_22.11.4_Orangepi5_jammy_22.04_legacy_5.10.110_xfce_desktop. sudo git clone https://github.com/morrownr/8821au-20210708.git cd 8821au-20210708 sudo ./install-driver.sh I receive an error. Trying to investigate: lsb_release -a Distributor ID: Ubuntu Description: Ubuntu 22.04.2 LTS Release: 22.04 Codename: jammy uname -r 5.10.110-rockchip-rk3588 First, missing python2 and solved with sudo apt-get install python2 Then issue with modpost. Not existing. So, trying: cd /usr/src/linux-headers-5.10.110-rockchip-rk3588 sudo make modules_prepare answering to a lot of questions with the default, then scripts/Makefile.build:423: warning: overriding recipe for target 'modules.order' Makefile:1518: warning: ignoring old recipe for target 'modules.order' make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/vdso.lds', needed by 'arch/arm64/kernel/vdso/vdso.so.dbg'. Stop. make: *** [arch/arm64/Makefile:194: vdso_prepare] Error 2 i'm not an expert. What's wrong , please? thanks
