hammsandwich21
  1. My TV does not do DTS passthrough, so I am wondering if I can use the USB-C to HDMI for video to my TV, and the HDMI port for audio to my AVR (my AVR is old and cannot handle 4K). I currently have this cabeled up, and I have video working out the USB-C port, but I cannot get audio (from OS or Kodi) out of the HDMI port. The OS sees the connections: root@orangepi:~# cat /sys/devices/platform/display-subsystem/drm/card0/card0-DP-1/edid | edid-decode edid-decode (hex): 00 ff ff ff ff ff ff 00 4c 2d 24 09 00 00 00 00 2c 15 01 03 80 10 09 78 0a ee 91 a3 54 4c 99 26 0f 50 54 bd ef 80 71 4f 81 c0 81 00 81 80 95 00 a9 c0 b3 00 01 01 02 3a 80 18 71 38 2d 40 58 2c 45 00 a0 5a 00 00 00 1e 66 21 56 aa 51 00 1e 30 46 8f 33 00 a0 5a 00 00 00 1e 00 00 00 fd 00 18 4b 0f 51 17 00 0a 20 20 20 20 20 20 00 00 00 fc 00 53 41 4d 53 55 4e 47 0a 20 20 20 20 20 01 f3 02 03 1f f1 47 90 04 05 03 20 22 07 23 09 07 07 83 01 00 00 e2 00 0f 67 03 0c 00 20 00 b8 2d 01 1d 80 18 71 1c 16 20 58 2c 25 00 a0 5a 00 00 00 9e 01 1d 00 72 51 d0 1e 20 6e 28 55 00 a0 5a 00 00 00 1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 a0 5a 00 00 00 18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 c6 ---------------- Block 0, Base EDID: EDID Structure Version & Revision: 1.3 Vendor & Product Identification: Manufacturer: SAM Model: 2340 Made in: week 44 of 2011 Basic Display Parameters & Features: Digital display Maximum image size: 16 cm x 9 cm Gamma: 2.20 RGB color display First detailed timing is the preferred timing Color Characteristics: Red : 0.6396, 0.3300 Green: 0.2998, 0.5996 Blue : 0.1503, 0.0595 White: 0.3125, 0.3291 Established Timings I & II: IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz Apple : 640x480 66.667 Hz 4:3 35.000 kHz 30.240 MHz DMT 0x05: 640x480 72.809 Hz 4:3 37.861 kHz 31.500 MHz DMT 0x06: 640x480 75.000 Hz 4:3 37.500 kHz 31.500 MHz DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz DMT 0x0a: 800x600 72.188 Hz 4:3 48.077 kHz 50.000 MHz DMT 0x0b: 800x600 75.000 Hz 4:3 46.875 kHz 49.500 MHz Apple : 832x624 74.551 Hz 4:3 49.726 kHz 57.284 MHz DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz DMT 0x11: 1024x768 70.069 Hz 4:3 56.476 kHz 75.000 MHz DMT 0x12: 1024x768 75.029 Hz 4:3 60.023 kHz 78.750 MHz DMT 0x24: 1280x1024 75.025 Hz 5:4 79.976 kHz 135.000 MHz Apple : 1152x870 75.062 Hz 192:145 68.681 kHz 100.000 MHz Standard Timings: DMT 0x15: 1152x864 75.000 Hz 4:3 67.500 kHz 108.000 MHz DMT 0x55: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz DMT 0x1c: 1280x800 59.810 Hz 16:10 49.702 kHz 83.500 MHz DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz DMT 0x2f: 1440x900 59.887 Hz 16:10 55.935 kHz 106.500 MHz DMT 0x53: 1600x900 60.000 Hz 16:9 60.000 kHz 108.000 MHz (RB) DMT 0x3a: 1680x1050 59.954 Hz 16:10 65.290 kHz 146.250 MHz Detailed Timing Descriptors: DTD 1: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (160 mm x 90 mm) Hfront 88 Hsync 44 Hback 148 Hpol P Vfront 4 Vsync 5 Vback 36 Vpol P DTD 2: 1366x768 59.790 Hz 683:384 47.712 kHz 85.500 MHz (160 mm x 90 mm) Hfront 70 Hsync 143 Hback 213 Hpol P Vfront 3 Vsync 3 Vback 24 Vpol P Display Range Limits: Monitor ranges (GTF): 24-75 Hz V, 15-81 kHz H, max dotclock 230 MHz Display Product Name: 'SAMSUNG' Extension blocks: 1 Checksum: 0xf3 ---------------- Block 1, CTA-861 Extension Block: Revision: 3 Underscans IT Video Formats by default Basic audio support Supports YCbCr 4:4:4 Supports YCbCr 4:2:2 Native detailed modes: 1 Video Data Block: VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (native) VIC 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz VIC 5: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 3: 720x480 59.940 Hz 16:9 31.469 kHz 27.000 MHz VIC 32: 1920x1080 24.000 Hz 16:9 27.000 kHz 74.250 MHz VIC 34: 1920x1080 30.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 7: 1440x480i 59.940 Hz 16:9 15.734 kHz 27.000 MHz Audio Data Block: Linear PCM: Max channels: 2 Supported sample rates (kHz): 48 44.1 32 Supported sample sizes (bits): 24 20 16 Speaker Allocation Data Block: FL/FR - Front Left/Right Video Capability Data Block: YCbCr quantization: No Data RGB quantization: No Data PT scan behavior: No Data IT scan behavior: Supports both over- and underscan CE scan behavior: Supports both over- and underscan Vendor-Specific Data Block (HDMI), OUI 00-0C-03: Source physical address: 2.0.0.0 Supports_AI DC_36bit DC_30bit DC_Y444 Maximum TMDS clock: 225 MHz Detailed Timing Descriptors: DTD 3: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz (160 mm x 90 mm) Hfront 88 Hsync 44 Hback 148 Hpol P Vfront 2 Vsync 5 Vback 15 Vpol P Vfront +0.5 Odd Field Vfront 2 Vsync 5 Vback 15 Vpol P Vback +0.5 Even Field DTD 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz (160 mm x 90 mm) Hfront 110 Hsync 40 Hback 220 Hpol P Vfront 5 Vsync 5 Vback 20 Vpol P DTD 5: 720x480 59.940 Hz 3:2 31.469 kHz 27.000 MHz (160 mm x 90 mm) Hfront 16 Hsync 62 Hback 60 Hpol N Vfront 9 Vsync 6 Vback 30 Vpol N Checksum: 0xc6 root@orangepi:~# cat /sys/devices/platform/display-subsystem/drm/card0/card0-/edid | edid-decode card0-DP-1/ card0-HDMI-A-1/ card0-Writeback-1/ root@orangepi:~# cat /sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/edid | edid-decode edid-decode (hex): 00 ff ff ff ff ff ff 00 3d cb 89 0c 00 00 00 00 00 16 01 03 80 10 09 78 0a ee 91 a3 54 4c 99 26 0f 50 54 bd ef 80 71 4f 81 c0 81 00 81 80 95 00 a9 c0 b3 00 01 01 02 3a 80 18 71 38 2d 40 58 2c 45 00 a0 5a 00 00 00 1e 66 21 56 aa 51 00 1e 30 46 8f 33 00 a0 5a 00 00 00 1e 00 00 00 fc 00 44 54 52 2d 35 30 2e 34 0a 20 20 20 20 00 00 00 fd 00 18 4b 0f 51 11 00 0a 20 20 20 20 20 20 01 8d 02 03 39 f1 47 90 04 05 03 20 22 07 38 09 7f 07 0f 7f 07 17 07 50 3f 06 c0 4d 02 00 57 06 00 5f 7e 01 67 54 00 83 4f 00 00 6c 03 0c 00 12 00 b8 2d c0 00 00 00 00 e2 00 0f 01 1d 80 18 71 1c 16 20 58 2c 25 00 a0 5a 00 00 00 9e 01 1d 00 72 51 d0 1e 20 6e 28 55 00 a0 5a 00 00 00 1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 a0 5a 00 00 00 18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 cd ---------------- Block 0, Base EDID: EDID Structure Version & Revision: 1.3 Vendor & Product Identification: Manufacturer: ONK Model: 3209 Made in: 2012 Basic Display Parameters & Features: Digital display Maximum image size: 16 cm x 9 cm Gamma: 2.20 RGB color display First detailed timing is the preferred timing Color Characteristics: Red : 0.6396, 0.3300 Green: 0.2998, 0.5996 Blue : 0.1503, 0.0595 White: 0.3125, 0.3291 Established Timings I & II: IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz Apple : 640x480 66.667 Hz 4:3 35.000 kHz 30.240 MHz DMT 0x05: 640x480 72.809 Hz 4:3 37.861 kHz 31.500 MHz DMT 0x06: 640x480 75.000 Hz 4:3 37.500 kHz 31.500 MHz DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz DMT 0x0a: 800x600 72.188 Hz 4:3 48.077 kHz 50.000 MHz DMT 0x0b: 800x600 75.000 Hz 4:3 46.875 kHz 49.500 MHz Apple : 832x624 74.551 Hz 4:3 49.726 kHz 57.284 MHz DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz DMT 0x11: 1024x768 70.069 Hz 4:3 56.476 kHz 75.000 MHz DMT 0x12: 1024x768 75.029 Hz 4:3 60.023 kHz 78.750 MHz DMT 0x24: 1280x1024 75.025 Hz 5:4 79.976 kHz 135.000 MHz Apple : 1152x870 75.062 Hz 192:145 68.681 kHz 100.000 MHz Standard Timings: DMT 0x15: 1152x864 75.000 Hz 4:3 67.500 kHz 108.000 MHz DMT 0x55: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz DMT 0x1c: 1280x800 59.810 Hz 16:10 49.702 kHz 83.500 MHz DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz DMT 0x2f: 1440x900 59.887 Hz 16:10 55.935 kHz 106.500 MHz DMT 0x53: 1600x900 60.000 Hz 16:9 60.000 kHz 108.000 MHz (RB) DMT 0x3a: 1680x1050 59.954 Hz 16:10 65.290 kHz 146.250 MHz Detailed Timing Descriptors: DTD 1: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (160 mm x 90 mm) Hfront 88 Hsync 44 Hback 148 Hpol P Vfront 4 Vsync 5 Vback 36 Vpol P DTD 2: 1366x768 59.790 Hz 683:384 47.712 kHz 85.500 MHz (160 mm x 90 mm) Hfront 70 Hsync 143 Hback 213 Hpol P Vfront 3 Vsync 3 Vback 24 Vpol P Display Product Name: 'DTR-50.4' Display Range Limits: Monitor ranges (GTF): 24-75 Hz V, 15-81 kHz H, max dotclock 170 MHz Extension blocks: 1 Checksum: 0x8d ---------------- Block 1, CTA-861 Extension Block: Revision: 3 Underscans IT Video Formats by default Basic audio support Supports YCbCr 4:4:4 Supports YCbCr 4:2:2 Native detailed modes: 1 Video Data Block: VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz (native) VIC 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz VIC 5: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 3: 720x480 59.940 Hz 16:9 31.469 kHz 27.000 MHz VIC 32: 1920x1080 24.000 Hz 16:9 27.000 kHz 74.250 MHz VIC 34: 1920x1080 30.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 7: 1440x480i 59.940 Hz 16:9 15.734 kHz 27.000 MHz Audio Data Block: Linear PCM: Max channels: 2 Supported sample rates (kHz): 192 176.4 96 88.2 48 44.1 32 Supported sample sizes (bits): 24 20 16 Linear PCM: Max channels: 8 Supported sample rates (kHz): 192 176.4 96 88.2 48 44.1 32 Supported sample sizes (bits): 24 20 16 AC-3: Max channels: 8 Supported sample rates (kHz): 48 44.1 32 Maximum bit rate: 640 kb/s DTS: Max channels: 8 Supported sample rates (kHz): 48 44.1 Maximum bit rate: 1536 kb/s One Bit Audio: Max channels: 6 Supported sample rates (kHz): 44.1 Audio Format Code dependent value: 0x00 Enhanced AC-3 (DD+): Max channels: 8 Supported sample rates (kHz): 48 44.1 DTS-HD: Max channels: 8 Supported sample rates (kHz): 192 176.4 96 88.2 48 44.1 Audio Format Code dependent value: 0x01 MAT (MLP): Max channels: 8 Supported sample rates (kHz): 192 96 48 Supports only Dolby TrueHD Speaker Allocation Data Block: FL/FR - Front Left/Right LFE1 - Low Frequency Effects 1 FC - Front Center BL/BR - Back Left/Right RLC/RRC - Rear Left/Right of Center (Deprecated) Vendor-Specific Data Block (HDMI), OUI 00-0C-03: Source physical address: 1.2.0.0 Supports_AI DC_36bit DC_30bit DC_Y444 Maximum TMDS clock: 225 MHz Video latency: Unknown Audio latency: Unknown Interlaced video latency: Unknown Interlaced audio latency: Unknown Video Capability Data Block: YCbCr quantization: No Data RGB quantization: No Data PT scan behavior: No Data IT scan behavior: Supports both over- and underscan CE scan behavior: Supports both over- and underscan Detailed Timing Descriptors: DTD 3: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz (160 mm x 90 mm) Hfront 88 Hsync 44 Hback 148 Hpol P Vfront 2 Vsync 5 Vback 15 Vpol P Vfront +0.5 Odd Field Vfront 2 Vsync 5 Vback 15 Vpol P Vback +0.5 Even Field DTD 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz (160 mm x 90 mm) Hfront 110 Hsync 40 Hback 220 Hpol P Vfront 5 Vsync 5 Vback 20 Vpol P DTD 5: 720x480 59.940 Hz 3:2 31.469 kHz 27.000 MHz (160 mm x 90 mm) Hfront 16 Hsync 62 Hback 60 Hpol N Vfront 9 Vsync 6 Vback 30 Vpol N Checksum: 0xcd
  2. @amazingfate - do you have any plans to try to build a Kodi 20 package for your repo?
