Hello,
Solution to run a pcm5102a module on a BPi M2 Zero board (Allwinner H2+/H3).
Becarfull , the connection is different compared to the GPIO 40 of the Raspberry !
Wiring of the DAC on GPIO40 of the BPi M2 Zero:
SCLK (not connected)
BCK on CON2-P27 (PA19-EINT19)
LCK on CON2-P28 (PA18-EINT18)
DIN on CON2-P40 (PA20-EINT20)
VIN (5v) on CON2-P02 or CON2-P04
GND on CON2-P06
Image linux Armbian used :
Armbian_22.11.0-trunk_Bananapim2zero_bullseye_edge_6.0.9.img
Enabled i2s via overlay :
Create a file sun8i-h3-I2S-out.dts containing the text of the discussion indicated above /boot/overlay-user
The contents of sun8i-h3-I2S-out.dts should look like:
/dts-v1/;
/plugin/;
compatible = "allwinner,sun8i-h3";
fragment@0 {
target-path = "/soc/i2s@1c22000";
__overlay__ {
status = "okay";
fragment@1 {
target-path = "/";
__overlay__ {
pcm5102a: pcm5102a {
#sound-dai-cells = <0>;
compatible = "ti,pcm5102a";
pcm510x,format = "i2s";
fragment@2 {
target = <&i2s0>;
__overlay__ {
status = "okay";
pinctrl-0 = <&i2s0_pins>;
sound-dai = <&pcm5102a>;
pinctrl-names = "default";
fragment@3 {
target-path = "/";
__overlay__ {
sound_i2s {
compatible = "simple-audio-card";
simple-audio-card,name = "I2S-master";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,format = "i2s";
status = "okay";
simple-audio-card,cpu {
sound-dai = <&i2s0>;
simple-audio-card,codec {
Launch the command :
armbian-add-overlay ./sun8i-h3-I2S-out.dts
The sun8i-h3-I2S-out.dtbo file is created
The /boot/armbianEnv.txt file is modified, now you should find the line "user_overlays=sun8i-h3-I2S-out"
reboot BPi M2 Zero
The aplay -l command verifies the presence of the pcm5102a DAC.
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: I2Smaster [I2S-master], device 0: 1c22000.i2s-pcm5102a-hifi pcm5102a-hifi-0 [1c22000.i2s-pcm5102a-hifi pcm5102a-hifi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: sun9ihdmi [sun9i-hdmi], device 0: SUN9I-HDMI PCM i2s-hifi-0 [SUN9I-HDMI PCM i2s-hifi-0]
Subdevices: 1/1
Thanks to everyone who writes in the forums otherwise I wouldn't have been able to get the whole thing working.
For information, works very well with Logitech Media Server and the Squeezlite player (and certainly others but I haven't tried).
