Antonio Mignolli
  1. Please, use chat GPT when you know exactly what you're doing With Type=oneshot Restart is NOT allowed. One shot services exit immediately, so "restart" makes no sense. Consider removing the post, it could lead to misinformation
  2. Hi all. I solved it, indeed, by "drastically" recompile wireguard-tools with a modification (makes sense, IMHO). https://github.com/WireGuard/wireguard-tools/pull/19 Basically, I am telling wireguard to keep trying reconnection according to configuration (environment variable WG_ENDPOINT_RESOLUTION_RETRIES), and don't modify this behaviour when some error types occur (EAI_NONAME or EAI_FAIL). I just noticed there is another modification, maybe even better, here: https://github.com/WireGuard/wireguard-tools/pull/18
  3. Hi all, I am running armbian bookworm on a nanopi r6c (rk3588). At boot, wireguard does not resolve the endpoint (strange, because it runs after network-online.target) and instead of keep trying, it gives up. If I manually restart it, all is good. Attached screenshots show the different behaviour in a raspberry pi (rpi4 as hostname) running raspios, where it keeps trying to resolve the endpoint, and nanopi r6c not retrying. I will recompile kernel to enable wireguard debug (or is there a quicker way?)
