Nycki
  1. This post from February 2025 claims that RP5 and RPMini are supported: https://www.armbian.com/newsflash/armbian-v25-2/ however, I can't find them on the downloads page. I also don't currently own an RPMini, I am tempted to buy one but I wanted to make sure it was supported first. What's the state of support right now?
  2. I noticed there's a community overlay module that adds a "first boot" script which, among other things, allows you to connect to wifi without ever connecting a monitor or keyboard. But, this overlap doesn't seem to come with the current raspberry pi 4b image (Armbian_23.5.1_Rpi4b_jammy_current_6.1.29.img). I tried downloading the build script, but I don't see an option to enable overlays in that either. Is this supported at this time? Also, I know I could just use raspbian if I want this feature, but I'm hoping to work with armbian because I want my build process to be reproducible on other boards.
  3. Thank you Igor, that worked! The complete fix was as simple as: sudo rm -rf ~/.local/share/containers sudo apt install podman uidmap slirp4netns and now I can run rootless containers with podman!
  4. Using release Armbian_23.5.1_Rpi4b_jammy_current_6.1.29 on a Raspberry Pi 4b. From a clean install: $ sudo apt update $ sudo apt upgrade $ sudo apt install podman $ podman run --rm docker.io/library/hello-world Error: command required for rootless mode with multiple IDs: exec: "newuidmap": executable file not found in $PATH Podman runs fine with sudo, so for now I can use that as a workaround, but it would be nice to run rootless containers for dev environments. There is a related issue on the official podman repo, but the solutions there don't seem to apply to armbian. https://github.com/containers/podman/issues/9271
