vanbinsbergen
  1. @1-igor i just got this message: sudo flash_eraseall /dev/mtd0 flash_eraseall has been replaced by `flash_erase <mtddev> 0 0`; please use it Erasing 16384 Kibyte @ 0 -- 100 % complete it worked, but its updated
  2. I couldn't ping the pi anymore so i hook it up to HDMI. There i see the initramfs prompt What's up with that guys?? When i type df i only see /dev /run Broken m.2 sata?
  3. Well guys, Boot environment had the wrong id. That's for one. Its booting from SD now with system on sata. I'll do it with that setup. Thanks for looking in. You may delete this post if you like as it doesn't contain that much info
  4. And this is 'the panic mode' i talked about. Actually its emergency mode. This happens after enabeling sata in config and using the installer with; boot from sd, system on sata. Tuesday i'm getting a keyboard so i can check out the logs
  5. Nope, sorry mate, don't have one
  6. No, when I did that i landed in 'panic mode'
  7. Guys, i'm new. I enabled the sata module in armbian-config then i did sudo dd bs=1M if=/path/your/armbian.img of=/dev/sda status=progress && sudo sync overlays=opi5-sata is in mnt/boot/armbianEnv.txt Without the sd, the orangepi boots in initramfs. I've added a screenshot with the shell output on hdmi. I can boot from SD but that's not what i need. Any thoughts whats going on?
