downunder52
  1. I had the same problem and solved it by using the other HDMI port on opi5+. Good luck
  2. Hi I have been trying to install root file on btrfs using armbian-config from sd card to nvme The process completed successfully but cannot boot. (Note that I have also modified armbianEnv.txt from etx4 to btrfs) The same process works on ext4 Appreciate if someone can give some pointer to get this working
