clockfort
  1. I have OPi 5 plus, not the 5B, but I'm not running into the issue you're describing, the Coral shows up fine. I can think of two possible issues, though: - Did you already know that the Google Coral doesn't show up under a sensible USB device ID until you perform an inference for the first time ( https://github.com/google-coral/edgetpu/issues/536 ) ? It presents as USB device ID "1a6e:089a Global Unichip Corp." until you touch it, and then transforms into "18d1:9302 Google Inc." - The Google Coral takes a ton of power over USB, especially if you're using libedgetpu1-max instead of libedgetpu1-std. Maybe your 5V supply isn't beefy enough? $ dmesg | tail -n 3 [ 7830.308924] usb 6-1.4: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd [ 7830.326474] usb 6-1.4: New USB device found, idVendor=1a6e, idProduct=089a, bcdDevice= 1.00 [ 7830.326485] usb 6-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0 $ lsusb -s 006:003 Bus 006 Device 003: ID 1a6e:089a Global Unichip Corp. $ sudo lsusb -vs 006:003 Bus 006 Device 003: ID 1a6e:089a Global Unichip Corp. Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.10 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 9 idVendor 0x1a6e Global Unichip Corp. idProduct 0x089a bcdDevice 1.00 iManufacturer 0 iProduct 0 iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x001b bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 896mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 0 bInterfaceClass 254 Application Specific Interface bInterfaceSubClass 1 Device Firmware Update bInterfaceProtocol 2 iInterface 0 Device Firmware Upgrade Interface Descriptor: bLength 9 bDescriptorType 33 bmAttributes 7 Will Not Detach Manifestation Tolerant Upload Supported Download Supported wDetachTimeout 1000 milliseconds wTransferSize 256 bytes bcdDFUVersion 1.01 Binary Object Store Descriptor: bLength 5 bDescriptorType 15 wTotalLength 0x0016 bNumDeviceCaps 2 USB 2.0 Extension Device Capability: bLength 7 bDescriptorType 16 bDevCapabilityType 2 bmAttributes 0x00000006 BESL Link Power Management (LPM) Supported SuperSpeed USB Device Capability: bLength 10 bDescriptorType 16 bDevCapabilityType 3 bmAttributes 0x00 wSpeedsSupported 0x000c Device can operate at High Speed (480Mbps) Device can operate at SuperSpeed (5Gbps) bFunctionalitySupport 2 Lowest fully-functional device speed is High Speed (480Mbps) bU1DevExitLat 10 micro seconds bU2DevExitLat 2047 micro seconds Device Status: 0x0000 (Bus Powered) I'm on this version of armbian if it matters $ cat /etc/armbian-image-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi5-plus BOARD_NAME="Orange Pi 5 Plus" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=bfc8271 VERSION=23.08.0-trunk LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=wip INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= VENDOR=Armbian REVISION=23.08.0-trunk BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" IMAGE_UUID=698fa7a2-04c2-4922-ba21-4832ce7d3c13
