Daniel Turcich
  1. Gotcha! Will take your advice on that Thank you!
  2. Hello, sorry if this has been answered somewhere else. I was just wondering how i upgrade my Orange Pi 5 running Arbmian 23.11.1 Bookworm w/ Linux 5.10.160-legacy-rk35xx to the latest Kernel. I tried using `sudo armbian-config` and updating via that with kernel upgrades unfrozen but it doesn't seem to work. Is there something I'm missing? Startup splash below: ___ ____ _ ____ / _ \| _ \(_) | ___| | | | | |_) | | |___ \ | |_| | __/| | ___) | \___/|_| |_| |____/ Welcome to Armbian 23.11.1 Bookworm with Linux 5.10.160-legacy-rk35xx System load: 4% Up time: 0 min Memory usage: 8% of 3.83G IP: 192.168.1.69 10.121.215.1 CPU temp: 40°C Usage of /: 6% of 57G RX today: 38.2 MiB
  3. I haven't had problems until now, I am using a rather dinky powersupply atm. It looks like they reccomend a 5v 4a but I assume that's not enough, they use USB-C as delivery. Any suggestions on what voltage and amperage I should look for? I will look into compiling from source using `6.5.#` kernel, I don't use a video out, only need it to act as a DNS and run some backends/ APIs I write.
  4. I am using my Orange Pi as a Pi-Hole and also to run a discord bot of mine I am having the issue with this repo where I can install packages with `pnpm install` will run and work fine, but when i move to use `pnpm compile` which uses Parcel to compile the codebase from TS and etc to workable JS, I run it and it starts that command and then the Putty terminal I use to remote into my OrangePi (which is on my LAN) from my Windows 11 machine gets a "remote connection terminated" which generally just happens when the remote restarts. Any idea why this may be happening?
