Post of the day:
For now I have 8 X88Pro 10 (4GB RAM / 32GB ROM) and 8 High Speed SD Cards (128GB Sandisk Extreme Pro)
4 of them will not have desktop ( 1 for flightradar24 ADS-B receiver / 2 for Home Assistant (my and my sister's house) / 1 for WebSDR)
2 of them will be spares (or to tinker for patches, I want them in the long run to be retrogaming boxes )
2 of them will have desktop (at least X running) for two magic mirrors
For the tests I have done, going over Kernel 5.15.X (not checked for long time Kernels between 5.16 and 5.18), the 5.19.X Kernel (latest edge kernel) the HDMI at boot works but if sleep is enabled (screen sleep and not whole TV box sleep), Wake-up is broken, I need to SSH and literally kill lightDM to restore the HDMi to working order, but X and Lightdm aren't frozen, because i can run on the display minetest or glxgears via ssh using DISPLAY=:0 app and I have no error opening the app (normally you have an error at launch saying you cant open X).
Here is the dmesg:
[61671.395705] ------------[ cut here ]------------
[61671.395736] [CRTC:37:crtc-0] vblank wait timed out
[61671.395829] WARNING: CPU: 1 PID: 6903 at drivers/gpu/drm/drm_atomic_helper.c:1540 drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290
[61671.395863] Modules linked in: brcmfmac brcmutil cfg80211 hantro_vpu(C) rockchip_vdec(C) gpio_ir_recv v4l2_vp9 joydev snd_soc_spdif_tx hci_uart btqca rc_core v4l2_h264 btrtl videobuf2_dma_contig rockchip_rga v4l2_mem2mem btbcm videobuf2_dma_sg btintel videobuf2_memops videobuf2_v4l2 videobuf2_common bluetooth snd_soc_rk3328 videodev snd_soc_hdmi_codec mc snd_soc_rockchip_i2s snd_soc_rockchip_spdif snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core rfkill snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd soundcore cpufreq_dt lz4hc lz4 zram ip_tables x_tables autofs4 dwmac_rk stmmac_platform stmmac pcs_xpcs dw_hdmi_i2s_audio lima dw_hdmi_cec gpu_sched drm_shmem_helper gpio_syscon adc_keys
[61671.396115] CPU: 1 PID: 6903 Comm: Xorg Tainted: G WC 5.19.16-rockchip64 #22.08.6
[61671.396126] Hardware name: Rockchip RK3318 BOX (DT)
[61671.396134] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[61671.396144] pc : drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290
[61671.396156] lr : drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290
[61671.396167] sp : ffff80000da939b0
[61671.396172] x29: ffff80000da939b0 x28: 0000000000000000 x27: 0000000000028c77
[61671.396188] x26: ffff000006958000 x25: 0000000000000000 x24: 0000000000000001
[61671.396204] x23: 0000000000000038 x22: 0000000000000001 x21: ffff00002556e800
[61671.396219] x20: ffff000006908080 x19: 0000000000000000 x18: 0000000000000001
[61671.396235] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000002844
[61671.396250] x14: ffff80000da93760 x13: 00000000ffffffea x12: ffff800009bc3f90
[61671.396267] x11: 0000000000000003 x10: 0000000000051a10 x9 : ffff800009bb7930
[61671.396282] x8 : 000000000000c660 x7 : c000000100000844 x6 : ffff800009b8d090
[61671.396300] x5 : ffff8000f4f92000 x4 : 0000000000000000 x3 : 0000000000000001
[61671.396315] x2 : 0000000000000000 x1 : 6fe815759e855200 x0 : 0000000000000000
[61671.396331] Call trace:
[61671.396337] drm_atomic_helper_wait_for_vblanks.part.23+0x274/0x290
[61671.396350] drm_atomic_helper_commit_tail_rpm+0x64/0x80
[61671.396363] commit_tail+0xa4/0x198
[61671.396374] drm_atomic_helper_commit+0x160/0x370
[61671.396385] drm_atomic_commit+0xac/0xe0
[61671.396395] drm_atomic_helper_dirtyfb+0x190/0x2d0
[61671.396405] drm_mode_dirtyfb_ioctl+0x174/0x240
[61671.396415] drm_ioctl_kernel+0xc0/0x178
[61671.396429] drm_ioctl+0x23c/0x448
[61671.396439] __arm64_sys_ioctl+0xa8/0xe8
[61671.396454] invoke_syscall+0x44/0x108
[61671.396468] el0_svc_common.constprop.3+0x94/0xf8
[61671.396478] do_el0_svc+0x2c/0xb8
[61671.396487] el0_svc+0x20/0x50
[61671.396500] el0t_64_sync_handler+0x98/0xc0
[61671.396510] el0t_64_sync+0x170/0x174
[61671.396522] ---[ end trace 0000000000000000 ]---
If you want me to check kernels mods to see if Kernels 6.X has working HDMI (all my boxes have the same problem of possible HDMI timing) or test other things, I can do it if full linux images or simply compiled kernel images are provided.
In the near future (need to get better at compiling the X86 kernel before), I could end up only requesting the patches or write my own patches and compile myself the patches to test
