Hi everyone. FIrst of all, i need to thank this community, you need to be congratulated for the effort you all make to this project.
When i restart my router, the wlan0 of my opi zero 2 stops, no network with "nmcli dev wifi" appears. I've already tried restarting the service with "sudo systemctl restart NetworkManager", disable IPv6 and also installing latest armbian-firmware-full.deb, but it still the same. I'm only able to resolve it with a reboot. Previously I used Debian and this did not happen. I'm using this linux version (4.9.318-legacy-sun50iw9) because of compatibility with the SPI LCD TFT display that I'm using. From what I researched here on the forum, this seems to be related to drivers, but I didn't find the solution (if it exists for the version I'm using). Normally I would try another version, but I am unable to remove the SD card from the opi at the moment (the LCD is glued to the front of it), I would like to solve this just through the terminal. I will leave the armbianmonitor log below. thanks.
Network/firewall problem detected.
Trying fallback...
Network/firewall problem detected. Not able to upload debug info.
1
2 ### Activated 1 lzo zram swap devices with 482MB each.
3 ### Activated Armbian ramlog partition with lz4 compression
4
5 Mon Sep 25 10:14:12 AM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
6
7 ### dmesg:
8
9 [ 0.000000] Booting Linux on physical CPU 0x0
10 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
11 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
12 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
13 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
14 [ 0.000000] On node 0 totalpages: 262144
15 [ 0.000000] DMA zone: 4096 pages used for memmap
16 [ 0.000000] DMA zone: 0 pages reserved
17 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
18 [ 0.000000] psci: probing for conduit method from DT.
19 [ 0.000000] psci: PSCIv1.0 detected in firmware.
20 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
21 [ 0.000000] psci: Trusted OS migration not required
22 [ 0.000000] psci: SMC Calling Convention v1.0
23 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
24 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
25 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
26 [ 0.000000] Detected VIPT I-cache on CPU0
27 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
28 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
29 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
30 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
31 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
32 [ 0.000000] log_buf_len min size: 131072 bytes
33 [ 0.000000] log_buf_len: 524288 bytes
34 [ 0.000000] early log buf free: 129352(98%)
35 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
36 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
37 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
38 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
39 [ 0.000000] Virtual kernel memory layout:
40 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
41 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
42 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
43 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
44 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
45 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
46 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
47 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
48 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
49 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
50 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
51 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
52 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
53 [ 0.000000] Preemptible hierarchical RCU implementation.
54 [ 0.000000] Build-time adjustment of leaf fanout to 64.
55 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
56 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
57 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
58 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
59 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
60 [ 0.000225] Console: colour dummy device 80x25
61 [ 0.000240] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
62 [ 0.000249] pid_max: default: 32768 minimum: 301
63 [ 0.000446] Security Framework initialized
64 [ 0.000454] AppArmor: AppArmor disabled by boot time parameter
65 [ 0.000568] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
66 [ 0.000573] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
67 [ 0.001841] sched-energy: CPU device node has no sched-energy-costs
68 [ 0.001855] Invalid sched_group_energy for CPU0
69 [ 0.001863] CPU0: update cpu_capacity 1024
70 [ 0.008981] ASID allocator initialised with 32768 entries
71 [ 0.027980] BOOTEVENT: 27.964624: ON
72 [ 0.055930] Detected VIPT I-cache on CPU1
73 [ 0.055983] Invalid sched_group_energy for CPU1
74 [ 0.055987] CPU1: update cpu_capacity 1024
75 [ 0.055990] CPU1: Booted secondary processor [410fd034]
76 [ 0.079320] Detected VIPT I-cache on CPU2
77 [ 0.079359] Invalid sched_group_energy for CPU2
78 [ 0.079363] CPU2: update cpu_capacity 1024
79 [ 0.079366] CPU2: Booted secondary processor [410fd034]
80 [ 0.102723] Detected VIPT I-cache on CPU3
81 [ 0.102756] Invalid sched_group_energy for CPU3
82 [ 0.102759] CPU3: update cpu_capacity 1024
83 [ 0.102762] CPU3: Booted secondary processor [410fd034]
84 [ 0.102849] Brought up 4 CPUs
85 [ 0.102857] SMP: Total of 4 processors activated.
86 [ 0.102865] CPU features: detected feature: 32-bit EL0 Support
87 [ 0.102871] CPU features: detected feature: Kernel page table isolation (KPTI)
88 [ 0.106635] CPU: All CPU(s) started at EL1
89 [ 0.106656] alternatives: patching kernel code
90 [ 0.106835] Invalid sched_group_energy for CPU3
91 [ 0.106844] CPU3: update max cpu_capacity 1024
92 [ 0.106850] Invalid sched_group_energy for Cluster3
93 [ 0.106855] Invalid sched_group_energy for CPU2
94 [ 0.106860] Invalid sched_group_energy for Cluster2
95 [ 0.106865] Invalid sched_group_energy for CPU1
96 [ 0.106871] Invalid sched_group_energy for Cluster1
97 [ 0.106876] Invalid sched_group_energy for CPU0
98 [ 0.106881] Invalid sched_group_energy for Cluster0
99 [ 0.108304] devtmpfs: initialized
100 [ 0.112733] CPU1: update max cpu_capacity 1024
101 [ 0.143456] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
102 [ 0.143481] futex hash table entries: 1024 (order: 5, 131072 bytes)
103 [ 0.144142] xor: measuring software checksum speed
104 [ 0.176262] 8regs : 1933.200 MB/sec
105 [ 0.209641] 8regs_prefetch: 1720.800 MB/sec
106 [ 0.243028] 32regs : 2287.200 MB/sec
107 [ 0.276415] 32regs_prefetch: 1996.800 MB/sec
108 [ 0.276421] xor: using function: 32regs (2287.200 MB/sec)
109 [ 0.276480] atomic64_test: passed
110 [ 0.276486] pinctrl core: initialized pinctrl subsystem
111 [ 0.277668] NET: Registered protocol family 16
112 [ 0.278918] dump_class_init,861, success
113 [ 0.293134] cpuidle: using governor menu
114 [ 0.294564] sunxi iommu: irq = 8
115 [ 0.294891] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
116 [ 0.294909] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
117 [ 0.296309] DMA: preallocated 256 KiB pool for atomic allocations
118 [ 0.297693] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
119 [ 0.312065] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
120 [ 0.316111] iommu: Adding device 1c0e000.ve to group 0
121 [ 0.316665] iommu: Adding device 1c00000.vp9 to group 0
122 [ 0.328265] iommu: Adding device 1000000.disp to group 0
123 [ 0.329691] iommu: Adding device 1480000.g2d to group 0
124 [ 0.332912] iommu: Adding device csi0 to group 0
125 [ 0.333397] iommu: Adding device csi1 to group 0
126 [ 0.334620] iommu: Adding device 6600800.vind:scaler@0 to group 0
127 [ 0.334913] iommu: Adding device 6600800.vind:scaler@1 to group 0
128 [ 0.335223] iommu: Adding device 6600800.vind:scaler@2 to group 0
129 [ 0.335532] iommu: Adding device 6600800.vind:scaler@3 to group 0
130 [ 0.335833] iommu: Adding device 6600800.vind:scaler@4 to group 0
131 [ 0.336129] iommu: Adding device 6600800.vind:scaler@5 to group 0
132 [ 0.337214] iommu: Adding device vinc0 to group 0
133 [ 0.337719] iommu: Adding device vinc1 to group 0
134 [ 0.339189] iommu: Adding device 1420000.deinterlace to group 0
135 [ 0.381216] HugeTLB registered 2 MB page size, pre-allocated 0 pages
136 [ 0.437337] raid6: int64x1 gen() 391 MB/s
137 [ 0.494101] raid6: int64x1 xor() 362 MB/s
138 [ 0.550863] raid6: int64x2 gen() 591 MB/s
139 [ 0.607537] raid6: int64x2 xor() 513 MB/s
140 [ 0.664318] raid6: int64x4 gen() 840 MB/s
141 [ 0.721054] raid6: int64x4 xor() 629 MB/s
142 [ 0.777759] raid6: int64x8 gen() 964 MB/s
143 [ 0.834536] raid6: int64x8 xor() 655 MB/s
144 [ 0.891292] raid6: neonx1 gen() 648 MB/s
145 [ 0.948026] raid6: neonx1 xor() 641 MB/s
146 [ 1.004736] raid6: neonx2 gen() 975 MB/s
147 [ 1.061478] raid6: neonx2 xor() 819 MB/s
148 [ 1.118260] raid6: neonx4 gen() 1287 MB/s
149 [ 1.174969] raid6: neonx4 xor() 965 MB/s
150 [ 1.231719] raid6: neonx8 gen() 1323 MB/s
151 [ 1.288451] raid6: neonx8 xor() 991 MB/s
152 [ 1.288456] raid6: using algorithm neonx8 gen() 1323 MB/s
153 [ 1.288461] raid6: .... xor() 991 MB/s, rmw enabled
154 [ 1.288467] raid6: using intx1 recovery algorithm
155 [ 1.288648] pwm module init!
156 [ 1.292943] sunxi-pm debug v3.10
157 [ 1.294038] SCSI subsystem initialized
158 [ 1.294659] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
159 [ 1.294743] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
160 [ 1.294863] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
161 [ 1.295349] spi spi0: master is unqueued, this is deprecated
162 [ 1.295659] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
163 [ 1.296234] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
164 [ 1.296315] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
165 [ 1.296427] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
166 [ 1.296879] spi spi1: master is unqueued, this is deprecated
167 [ 1.297185] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
168 [ 1.297961] usbcore: registered new interface driver usbfs
169 [ 1.298051] usbcore: registered new interface driver hub
170 [ 1.298124] usbcore: registered new device driver usb
171 [ 1.298366] sunxi_i2c_adap_init()2522 - init
172 [ 1.298955] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
173 [ 1.299050] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
174 [ 1.299057] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
175 [ 1.299073] twi3 supply twi not found, using dummy regulator
176 [ 1.299150] twi_request_gpio()451 - [i2c3] init name: twi3
177 [ 1.299897] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
178 [ 1.299975] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
179 [ 1.299983] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
180 [ 1.299996] twi5 supply twi not found, using dummy regulator
181 [ 1.300097] twi_request_gpio()451 - [i2c5] init name: twi5
182 [ 1.300584] axp20x-i2c 5-0036: AXP20x variant AXP806 found
183 [ 1.319272] random: fast init done
184 [ 1.330453] axp20x-i2c 5-0036: AXP20X driver loaded
185 [ 1.330939] media: Linux media interface: v0.10
186 [ 1.331023] Linux video capture interface: v2.00
187 [ 1.331851] Advanced Linux Sound Architecture Driver Initialized.
188 [ 1.332584] Bluetooth: Core ver 2.22
189 [ 1.332657] NET: Registered protocol family 31
190 [ 1.332663] Bluetooth: HCI device and connection manager initialized
191 [ 1.332681] Bluetooth: HCI socket layer initialized
192 [ 1.332694] Bluetooth: L2CAP socket layer initialized
193 [ 1.332733] Bluetooth: SCO socket layer initialized
194 [ 1.333495] [DISP]disp_module_init
195 [ 1.334685] [DISP] parser_disp_init_para,line:1403:
196 [ 1.334694] of_property_read fb0_width fail
197 [ 1.334707] [DISP] disp_init,line:2215:
198 [ 1.334713] smooth display screen:0 type:4 mode:10
199 [ 1.352233] [DISP]disp_module_init finish
200 [ 1.353103] clocksource: Switched to clocksource arch_sys_counter
201 [ 1.353356] VFS: Disk quotas dquot_6.6.0
202 [ 1.353442] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
203 [ 1.354182] Console: switching to colour frame buffer device 240x67
204 [ 1.397407] NET: Registered protocol family 2
205 [ 1.397529] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
206 [ 1.416697] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
207 [ 1.416772] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
208 [ 1.416896] TCP: Hash tables configured (established 8192 bind 8192)
209 [ 1.416987] UDP hash table entries: 512 (order: 2, 16384 bytes)
210 [ 1.417016] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
211 [ 1.417337] NET: Registered protocol family 1
212 [ 1.417940] RPC: Registered named UNIX socket transport module.
213 [ 1.417945] RPC: Registered udp transport module.
214 [ 1.417948] RPC: Registered tcp transport module.
215 [ 1.417951] RPC: Registered tcp NFSv4.1 backchannel transport module.
216 [ 1.418220] Trying to unpack rootfs image as initramfs...
217 [ 2.172617] Freeing initrd memory: 17256K
218 [ 2.173741] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
219 [ 2.177671] audit: initializing netlink subsys (disabled)
220 [ 2.177758] audit: type=2000 audit(2.173:1): initialized
221 [ 2.178699] workingset: timestamp_bits=45 max_order=18 bucket_order=0
222 [ 2.189823] DLM installed
223 [ 2.191628] squashfs: version 4.0 (2009/01/31) Phillip Lougher
224 [ 2.191964] Registering sdcardfs 0.1
225 [ 2.192434] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
226 [ 2.194120] ntfs: driver 2.1.32 [Flags: R/W].
227 [ 2.200780] NET: Registered protocol family 38
228 [ 2.201137] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
229 [ 2.201276] io scheduler noop registered
230 [ 2.201285] io scheduler deadline registered
231 [ 2.201454] io scheduler cfq registered (default)
232 [ 2.203658] failed to get easy_light_used assign
233 [ 2.203667] failed to get normal led pin assign
234 [ 2.203673] failed to get standby led pin assign
235 [ 2.203678] failed to get standby led pin assign
236 [ 2.203683] these is zero number for gpio
237 [ 2.203688] gpio_init finish with uesd
238 [ 2.206901] uart uart0: get regulator failed
239 [ 2.207102] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
240 [ 2.207125] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
241 [ 2.207219] console [ttyS0] enabled
242 [ 2.208029] uart uart1: get regulator failed
243 [ 2.208216] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
244 [ 2.208918] uart uart5: get regulator failed
245 [ 2.209103] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
246 [ 2.210433] misc dump reg init
247 [ 2.211574] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
248 [ 2.211910] Unable to detect cache hierarchy for CPU 0
249 [ 2.225936] brd: module loaded
250 [ 2.234300] loop: module loaded
251 [ 2.234492] [NAND][NE] Not found valid nand node on dts
252 [ 2.235082] Get boot type cmd line fail
253 [ 2.235668] sunxi-bt soc@03000000:bt: Missing bt_power.
254 [ 2.235679] sunxi-bt soc@03000000:bt: bt_power_name ((null))
255 [ 2.235686] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
256 [ 2.235693] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
257 [ 2.235748] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
258 [ 2.235825] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
259 [ 2.236724] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
260 [ 2.236736] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
261 [ 2.236743] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
262 [ 2.236751] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
263 [ 2.236758] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
264 [ 2.236790] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
265 [ 2.236824] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
266 [ 2.236832] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
267 [ 2.236850] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
268 [ 2.237822] [ADDR_MGT] addr_mgt_probe: success.
269 [ 2.244731] tun: Universal TUN/TAP device driver, 1.6
270 [ 2.244743] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
271 [ 2.246912] gmac-power0: NULL
272 [ 2.246922] gmac-power1: NULL
273 [ 2.246928] gmac-power2: NULL
274 [ 2.247873] PPP generic driver version 2.4.2
275 [ 2.248154] PPP BSD Compression module registered
276 [ 2.248165] PPP Deflate Compression module registered
277 [ 2.248191] PPP MPPE Compression module registered
278 [ 2.248199] NET: Registered protocol family 24
279 [ 2.248232] PPTP driver version 0.8.5
280 [ 2.248602] usbcore: registered new interface driver r8152
281 [ 2.248676] usbcore: registered new interface driver asix
282 [ 2.248773] usbcore: registered new interface driver ax88179_178a
283 [ 2.248840] usbcore: registered new interface driver cdc_ether
284 [ 2.248903] usbcore: registered new interface driver net1080
285 [ 2.248970] usbcore: registered new interface driver cdc_subset
286 [ 2.249034] usbcore: registered new interface driver zaurus
287 [ 2.249123] usbcore: registered new interface driver cdc_ncm
288 [ 2.249130] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
289 [ 2.249487] get drv_vbus is fail, 84
290 [ 2.249497] get ehci0-controller, regulator_io is no nocare
291 [ 2.249813] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
292 [ 2.249819] [sunxi-ehci0]: Not init ehci0
293 [ 2.249954] get ehci1-controller, regulator_io is no nocare
294 [ 2.250171] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
295 [ 2.250230] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
296 [ 2.250258] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
297 [ 2.250976] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
298 [ 2.266480] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
299 [ 2.266873] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
300 [ 2.266883] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
301 [ 2.266890] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
302 [ 2.266898] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
303 [ 2.266904] usb usb1: SerialNumber: sunxi-ehci
304 [ 2.267826] hub 1-0:1.0: USB hub found
305 [ 2.267882] hub 1-0:1.0: 1 port detected
306 [ 2.268635] get drv_vbus is fail, 84
307 [ 2.268642] get ehci2-controller, regulator_io is no nocare
308 [ 2.268884] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
309 [ 2.268936] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
310 [ 2.268962] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
311 [ 2.269313] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
312 [ 2.279797] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
313 [ 2.280032] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
314 [ 2.280041] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
315 [ 2.280049] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
316 [ 2.280056] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
317 [ 2.280062] usb usb2: SerialNumber: sunxi-ehci
318 [ 2.280928] hub 2-0:1.0: USB hub found
319 [ 2.280977] hub 2-0:1.0: 1 port detected
320 [ 2.281647] get drv_vbus is fail, 84
321 [ 2.281655] get ehci3-controller, regulator_io is no nocare
322 [ 2.281903] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
323 [ 2.281955] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
324 [ 2.281979] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
325 [ 2.282294] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
326 [ 2.296448] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
327 [ 2.296651] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
328 [ 2.296659] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
329 [ 2.296667] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
330 [ 2.296674] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
331 [ 2.296681] usb usb3: SerialNumber: sunxi-ehci
332 [ 2.297536] hub 3-0:1.0: USB hub found
333 [ 2.297581] hub 3-0:1.0: 1 port detected
334 [ 2.298516] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
335 [ 2.298886] get drv_vbus is fail, 84
336 [ 2.298894] get ohci0-controller, regulator_io is no nocare
337 [ 2.299227] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
338 [ 2.299232] [sunxi-ohci0]: Not init ohci0
339 [ 2.299350] get ohci1-controller, regulator_io is no nocare
340 [ 2.299509] hci: request ohci1-controller gpio:80
341 [ 2.299586] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
342 [ 2.299637] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
343 [ 2.299662] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
344 [ 2.299740] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
345 [ 2.360641] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
346 [ 2.360652] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
347 [ 2.360659] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
348 [ 2.360666] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
349 [ 2.360673] usb usb4: SerialNumber: sunxi-ohci
350 [ 2.361541] hub 4-0:1.0: USB hub found
351 [ 2.361587] hub 4-0:1.0: 1 port detected
352 [ 2.362260] get drv_vbus is fail, 84
353 [ 2.362267] get ohci2-controller, regulator_io is no nocare
354 [ 2.362601] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
355 [ 2.362650] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
356 [ 2.362676] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
357 [ 2.362753] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
358 [ 2.420614] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
359 [ 2.420625] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
360 [ 2.420632] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
361 [ 2.420640] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
362 [ 2.420646] usb usb5: SerialNumber: sunxi-ohci
363 [ 2.421525] hub 5-0:1.0: USB hub found
364 [ 2.421575] hub 5-0:1.0: 1 port detected
365 [ 2.422259] get drv_vbus is fail, 84
366 [ 2.422267] get ohci3-controller, regulator_io is no nocare
367 [ 2.422597] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
368 [ 2.422646] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
369 [ 2.422671] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
370 [ 2.422754] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
371 [ 2.480615] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
372 [ 2.480625] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
373 [ 2.480632] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
374 [ 2.480640] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
375 [ 2.480646] usb usb6: SerialNumber: sunxi-ohci
376 [ 2.481502] hub 6-0:1.0: USB hub found
377 [ 2.481548] hub 6-0:1.0: 1 port detected
378 [ 2.482475] ohci-platform: OHCI generic platform driver
379 [ 2.483238] usbcore: registered new interface driver uas
380 [ 2.483411] usbcore: registered new interface driver usb-storage
381 [ 2.483521] usbcore: registered new interface driver ums-alauda
382 [ 2.483597] usbcore: registered new interface driver ums-cypress
383 [ 2.483666] usbcore: registered new interface driver ums-datafab
384 [ 2.483735] usbcore: registered new interface driver ums_eneub6250
385 [ 2.483806] usbcore: registered new interface driver ums-freecom
386 [ 2.483879] usbcore: registered new interface driver ums-isd200
387 [ 2.483950] usbcore: registered new interface driver ums-jumpshot
388 [ 2.484023] usbcore: registered new interface driver ums-karma
389 [ 2.484101] usbcore: registered new interface driver ums-onetouch
390 [ 2.484197] usbcore: registered new interface driver ums-realtek
391 [ 2.484276] usbcore: registered new interface driver ums-sddr09
392 [ 2.484349] usbcore: registered new interface driver ums-sddr55
393 [ 2.484422] usbcore: registered new interface driver ums-usbat
394 [ 2.484569] usb_serial_number:20080411
395 [ 2.485793] input: sunxi-keyboard as /devices/virtual/input/input0
396 [ 2.486377] usbcore: registered new interface driver xpad
397 [ 2.486522] usbcore: registered new interface driver usb_acecad
398 [ 2.486622] usbcore: registered new interface driver aiptek
399 [ 2.486706] usbcore: registered new interface driver gtco
400 [ 2.486783] usbcore: registered new interface driver hanwang
401 [ 2.486864] usbcore: registered new interface driver kbtab
402 [ 2.487331] axp2101_pek: axp2101-pek can not register without irq
403 [ 2.487354] axp2101-pek: probe of axp2101-pek.0 failed with error -22
404 [ 2.488835] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
405 [ 2.488902] sunxi-rtc rtc: RTC enabled
406 [ 2.489377] i2c /dev entries driver
407 [ 2.490183] lirc_dev: IR Remote Control driver registered, major 244
408 [ 2.490195] IR NEC protocol handler initialized
409 [ 2.490202] IR RC5(x/sz) protocol handler initialized
410 [ 2.490207] IR RC6 protocol handler initialized
411 [ 2.490213] IR JVC protocol handler initialized
412 [ 2.490218] IR Sony protocol handler initialized
413 [ 2.490224] IR SANYO protocol handler initialized
414 [ 2.490230] IR Sharp protocol handler initialized
415 [ 2.490236] IR MCE Keyboard/mouse protocol handler initialized
416 [ 2.490242] IR LIRC bridge handler initialized
417 [ 2.490247] IR XMP protocol handler initialized
418 [ 2.490771] sunxi_ir_startup: get ir protocol failed
419 [ 2.490814] 7040000.s_cir supply ir0 not found, using dummy regulator
420 [ 2.491018] Registered IR keymap rc_map_sunxi
421 [ 2.491417] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
422 [ 2.491650] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
423 [ 2.492626] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
424 [ 2.493253] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
425 [ 2.493950] sunxi cedar version 0.1
426 [ 2.494148] VE: install start!!!
427
428 [ 2.494344] cedar_ve: cedar-ve the get irq is 278
429 [ 2.494969] VE: get debugfs_mpp_root is NULL, please check mpp
430
431 [ 2.494982] VE: sunxi ve debug register driver failed!
432
433 [ 2.498225] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
434 [ 2.499513] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
435 [ 2.499874] Bluetooth: HCI UART driver ver 2.3
436 [ 2.499886] Bluetooth: HCI UART protocol H4 registered
437 [ 2.499892] Bluetooth: HCI UART protocol LL registered
438 [ 2.499897] Bluetooth: HCI UART protocol Three-wire (H5) registered
439 [ 2.504082] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
440 [ 2.504098] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
441 [ 2.504111] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
442 [ 2.504123] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
443 [ 2.504135] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
444 [ 2.504147] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
445 [ 2.504554] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
446 [ 2.504670] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
447 [ 2.504870] sunxi-mmc sdc0: No vmmc regulator found
448 [ 2.504877] sunxi-mmc sdc0: No vqmmc regulator found
449 [ 2.504884] sunxi-mmc sdc0: No vdmmc regulator found
450 [ 2.504890] sunxi-mmc sdc0: No vd33sw regulator found
451 [ 2.504898] sunxi-mmc sdc0: No vd18sw regulator found
452 [ 2.504904] sunxi-mmc sdc0: No vq33sw regulator found
453 [ 2.504910] sunxi-mmc sdc0: No vq18sw regulator found
454 [ 2.505647] sunxi-mmc sdc0: set host busy
455 [ 2.505745] sunxi-mmc sdc0: Got CD GPIO
456 [ 2.506111] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
457 [ 2.506147] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
458 [ 2.519790] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
459 [ 2.536685] sunxi-mmc sdc0: detmode:gpio irq
460 [ 2.536715] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
461 [ 2.539215] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
462 [ 2.540562] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
463 [ 2.540680] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
464 [ 2.540821] sunxi-mmc sdc1: No vmmc regulator found
465 [ 2.540828] sunxi-mmc sdc1: No vqmmc regulator found
466 [ 2.540834] sunxi-mmc sdc1: No vdmmc regulator found
467 [ 2.540840] sunxi-mmc sdc1: No vd33sw regulator found
468 [ 2.540846] sunxi-mmc sdc1: No vd18sw regulator found
469 [ 2.540852] sunxi-mmc sdc1: No vq33sw regulator found
470 [ 2.540859] sunxi-mmc sdc1: No vq18sw regulator found
471 [ 2.541310] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
472 [ 2.542581] sunxi-mmc sdc1: set host busy
473 [ 2.542659] mmc:failed to get gpios
474 [ 2.543780] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
475 [ 2.545044] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
476 [ 2.559846] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
477 [ 2.568166] mmc0: host does not support reading read-only switch, assuming write-enable
478 [ 2.570079] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
479 [ 2.570163] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
480 [ 2.570517] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
481 [ 2.570613] mmc0: new high speed SDXC card at address 0001
482 [ 2.571691] mmcblk0: mmc0:0001 SD16G 59.5 GiB
483 [ 2.573317] mmcblk0: p1
484 [ 2.576495] sunxi-mmc sdc1: detmode:manually by software
485 [ 2.578689] ledtrig-cpu: registered to indicate activity on CPUs
486 [ 2.579410] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
487 [ 2.580261] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
488 [ 2.580294] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
489 [ 2.582800] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
490 [ 2.584727] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
491 [ 2.585563] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
492 [ 2.586402] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
493 [ 2.586714] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
494 [ 2.586722] sunxi_emce_probe()590emce hw init failed!
495 [ 2.586749] emce: probe of emce failed with error -2
496 [ 2.587041] hidraw: raw HID events driver (C) Jiri Kosina
497 [ 2.587291] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
498 [ 2.587328] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
499 [ 2.591817] usbcore: registered new interface driver usbhid
500 [ 2.591824] usbhid: USB HID core driver
501 [ 2.593303] optee: probing for conduit method from DT.
502 [ 2.593319] optee: api uid mismatch
503 [ 2.593917] usbcore: registered new interface driver snd-usb-audio
504 [ 2.595507] [sunxi_hdmi_codec_init] driver and deivce register finished.
505 [ 2.597254] [sunxi_internal_codec_probe]:get audio avcc failed
506 [ 2.597292] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
507 [ 2.597527] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
508 [ 2.600081] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
509 [ 2.602045] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
510 [ 2.602059] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
511 [ 2.604441] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
512 [ 2.604466] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
513 [ 2.608609] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
514 [ 2.610037] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
515 [ 2.611906] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
516 [ 2.615014] pktgen: Packet Generator for packet performance testing. Version: 2.75
517 [ 2.615450] u32 classifier
518 [ 2.615456] Actions configured
519 [ 2.615469] Netfilter messages via NETLINK v0.30.
520 [ 2.615497] nfnl_acct: registering with nfnetlink.
521 [ 2.615834] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
522 [ 2.616081] ctnetlink v0.93: registering with nfnetlink.
523 [ 2.616896] xt_time: kernel timezone is -0000
524 [ 2.616922] IPVS: Registered protocols (TCP, UDP)
525 [ 2.617030] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
526 [ 2.617156] IPVS: Creating netns size=1928 id=0
527 [ 2.617288] IPVS: ipvs loaded.
528 [ 2.617296] IPVS: [rr] scheduler registered.
529 [ 2.617394] ipip: IPv4 and MPLS over IPv4 tunneling driver
530 [ 2.618098] gre: GRE over IPv4 demultiplexor driver
531 [ 2.618107] ip_gre: GRE over IPv4 tunneling driver
532 [ 2.619384] IPv4 over IPsec tunneling driver
533 [ 2.620321] ip_tables: (C) 2000-2006 Netfilter Core Team
534 [ 2.620601] arp_tables: arp_tables: (C) 2002 David S. Miller
535 [ 2.620666] Initializing XFRM netlink socket
536 [ 2.620699] IPsec XFRM device driver
537 [ 2.621546] NET: Registered protocol family 10
538 [ 2.623459] mip6: Mobile IPv6
539 [ 2.623498] ip6_tables: (C) 2000-2006 Netfilter Core Team
540 [ 2.624821] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
541 [ 2.626490] NET: Registered protocol family 17
542 [ 2.626534] NET: Registered protocol family 15
543 [ 2.626691] Bridge firewalling registered
544 [ 2.626840] Bluetooth: RFCOMM TTY layer initialized
545 [ 2.626857] Bluetooth: RFCOMM socket layer initialized
546 [ 2.626892] Bluetooth: RFCOMM ver 1.11
547 [ 2.626906] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
548 [ 2.626911] Bluetooth: BNEP filters: protocol multicast
549 [ 2.626925] Bluetooth: BNEP socket layer initialized
550 [ 2.626930] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
551 [ 2.626942] Bluetooth: HIDP socket layer initialized
552 [ 2.627033] l2tp_core: L2TP core driver, V2.0
553 [ 2.627049] l2tp_ppp: PPPoL2TP kernel driver, V2.0
554 [ 2.627055] 8021q: 802.1Q VLAN Support v1.8
555 [ 2.627255] sctp: Hash tables configured (bind 256/256)
556 [ 2.627867] Key type dns_resolver registered
557 [ 2.628009] Registered cp15_barrier emulation handler
558 [ 2.628022] Registered setend emulation handler
559 [ 2.628972] registered taskstats version 1
560 [ 2.640511] zswap: default zpool zbud not available
561 [ 2.640519] zswap: pool creation failed
562 [ 2.643399] Btrfs loaded, crc32c=crc32c-arm64-hw
563 [ 2.644156] HDMI 2.0 driver init start!
564 [ 2.644170] boot_hdmi=true
565 [ 2.644969] Can not find the node of esm
566 [ 2.644987] ERROR: pinctrl_get for HDMI2.0 DDC fail
567 [ 2.645072] Get hdmi_power0:vcc-hdmi
568 [ 2.645111] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
569 [ 2.645293] Get hdmi_power1:vdd-hdmi
570 [ 2.645315] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
571 [ 2.646873] hdmi_cec_init
572 [ 2.647368] [DISP] disp_device_attached,line:146:
573 [ 2.647377] attached ok, mgr0<-->device0, type=4
574 [ 2.647387] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
575 [ 2.647400] [DISP] disp_hdmi_set_mode,line:648:
576 [ 2.647404] hdmi_set_mode is null!
577 [ 2.650107] HDMI2.0 module init end
578 [ 2.661230] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
579 [ 2.664683] cpu cpu1: opp_list_debug_create_link: Failed to create link
580 [ 2.664695] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
581 [ 2.664726] cpu cpu2: opp_list_debug_create_link: Failed to create link
582 [ 2.664734] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
583 [ 2.664765] cpu cpu3: opp_list_debug_create_link: Failed to create link
584 [ 2.664772] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
585 [ 2.667109] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
586 [ 2.668077] get det_vbus is fail, 84
587 [ 2.668085] get id is fail, 84
588 [ 2.668561] sunxi-rtc rtc: setting system clock to 2023-09-25 13:13:54 UTC (1695647634)
589 [ 2.672307] ALSA device list:
590 [ 2.672316] #0: audiocodec
591 [ 2.672320] #1: sndahub
592 [ 2.672323] #2: sndhdmi
593 [ 2.674011] Freeing unused kernel memory: 3008K
594 [ 2.719116] random: systemd-udevd: uninitialized urandom read (16 bytes read)
595 [ 2.721130] random: systemd-udevd: uninitialized urandom read (16 bytes read)
596 [ 2.724240] random: systemd-udevd: uninitialized urandom read (16 bytes read)
597 [ 2.782715] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
598 [ 2.943236] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
599 [ 3.053189] HDMI cable is connected
600 [ 3.293196] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
601 [ 3.513560] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
602 [ 3.513569] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
603 [ 3.513574] usb 4-1: Product: Rapoo 2.4G Wireless Device
604 [ 3.513579] usb 4-1: Manufacturer: RAPOO
605 [ 3.521487] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
606 [ 3.522059] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
607 [ 3.528252] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
608 [ 3.583846] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
609 [ 3.587814] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
610 [ 3.645175] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
611 [ 4.175658] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
612 [ 5.121341] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
613 [ 5.121897] cgroup: cgroup2: unknown option "nsdelegate"
614 [ 5.142231] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
615 [ 5.142255] systemd[1]: Detected architecture arm64.
616 [ 5.143380] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
617 [ 5.160788] systemd[1]: Hostname set to <opi>.
618 [ 5.187977] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
619 [ 6.664171] (sd-execut[1456]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
620 [ 6.826549]
621 insmod_device_driver
622
623 [ 6.826799] device_chose finished 124!
624 [ 7.152531] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
625 [ 7.390712] systemd[1]: Queued start job for default target graphical.target.
626 [ 7.398290] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
627 [ 7.400498] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
628 [ 7.402728] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
629 [ 7.404079] systemd[1]: Created slice user.slice - User and Session Slice.
630 [ 7.404752] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
631 [ 7.405299] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
632 [ 7.405628] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
633 [ 7.406181] systemd[1]: Reached target slices.target - Slice Units.
634 [ 7.406565] systemd[1]: Reached target swap.target - Swaps.
635 [ 7.406884] systemd[1]: Reached target time-set.target - System Time Set.
636 [ 7.407367] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
637 [ 7.424824] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
638 [ 7.425902] systemd[1]: Listening on syslog.socket - Syslog Socket.
639 [ 7.426952] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
640 [ 7.427666] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
641 [ 7.429270] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
642 [ 7.430281] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
643 [ 7.431365] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
644 [ 7.433565] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
645 [ 7.434470] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
646 [ 7.438424] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
647 [ 7.442972] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
648 [ 7.447838] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
649 [ 7.449095] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
650 [ 7.450145] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
651 [ 7.458224] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
652 [ 7.463640] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
653 [ 7.469588] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
654 [ 7.476065] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
655 [ 7.483720] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
656 [ 7.493753] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
657 [ 7.505609] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
658 [ 7.513699] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
659 [ 7.521780] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
660 [ 7.523557] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
661 [ 7.533427] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
662 [ 7.539615] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
663 [ 7.545233] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
664 [ 7.555354] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
665 [ 7.557708] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
666 [ 7.560723] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
667 [ 7.563680] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
668 [ 7.567220] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
669 [ 7.570740] systemd[1]: modprobe@configfs.service: Deactivated successfully.
670 [ 7.571596] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
671 [ 7.574513] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
672 [ 7.575328] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
673 [ 7.575934] fuse init (API version 7.26)
674 [ 7.578913] systemd[1]: modprobe@drm.service: Deactivated successfully.
675 [ 7.579585] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
676 [ 7.584245] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
677 [ 7.603909] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
678 [ 7.607255] systemd[1]: modprobe@fuse.service: Deactivated successfully.
679 [ 7.608402] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
680 [ 7.609083] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
681 [ 7.627682] systemd[1]: modprobe@loop.service: Deactivated successfully.
682 [ 7.632223] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
683 [ 7.643261] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
684 [ 7.644042] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
685 [ 7.644053] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
686 [ 7.644258] spidev spi1.1: Deleting spi1.1
687 [ 7.644866] fbtft_device: GPIOS used by 'fb_st7735r':
688 [ 7.644872] fbtft_device: 'reset' = GPIO73
689 [ 7.644876] fbtft_device: 'dc' = GPIO70
690 [ 7.644887] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
691 [ 7.644893] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
692 [ 7.677124] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
693 [ 7.692328] WCN: marlin_init entry!
694 [ 7.693743] WCN: marlin_parse_dt reset gpio=211
695 [ 7.693754] WCN_ERR: gpio reset request err: 211
696 [ 7.693760] WCN: wcn config bt wake host
697 [ 7.694287] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
698 [ 7.694462] WCN: wcn config wifi wake host
699 [ 7.694483] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
700 [ 7.697753] sdiohal:sdiohal_init ok
701 [ 7.698681] WCN: marlin_probe ok!
702 [ 7.707661] mtty_probe init device addr: 0xffffffc009743700
703 [ 7.707871] -->rfkill_bluetooth_init
704 [ 7.708097] <--rfkill_bluetooth_init
705 [ 7.737223] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
706 [ 7.745823] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
707 [ 7.754294] WCN: start_marlin [MARLIN_WIFI]
708 [ 7.754310] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
709 [ 7.754313] WCN: the first power on start
710 [ 7.767251] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
711 [ 7.767919] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
712 [ 7.779068] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
713 [ 7.780247] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
714 [ 7.787054] systemd[1]: Starting systemd-sysusers.service - Create System Users...
715 [ 7.803925] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
716 [ 7.806506] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
717 [ 7.808844] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
718 [ 7.857375] systemd[1]: Finished systemd-sysusers.service - Create System Users.
719 [ 7.863816] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
720 [ 7.869863] WCN: marlin chip en pull up
721 [ 7.896530] sdiohal:sdiohal_scan_card
722 [ 7.896550] sunxi-wlan soc@03000000:wlan: bus_index: 1
723 [ 7.896603] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
724 [ 7.913180] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
725 [ 7.933965] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
726 [ 7.934818] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
727 [ 7.934866] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
728 [ 7.937397] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
729 [ 7.940513] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
730 [ 7.956522] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
731 [ 7.962872] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
732 [ 7.964962] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
733 [ 7.967564] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
734 [ 7.968346] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
735 [ 7.968438] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
736 [ 7.969151] mmc1: new ultra high speed SDR104 SDIO card at address 8800
737 [ 7.969623] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
738 [ 7.969916] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
739 [ 7.969939] WCN: marlin_scan_finish!
740 [ 7.969944] sdiohal:probe ok
741 [ 7.970002] sdiohal:scan end!
742 [ 7.970010] WCN: then marlin start to download
743 [ 7.970035] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
744 [ 7.970722] systemd[1]: Mounting tmp.mount - /tmp...
745 [ 7.976973] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
746 [ 7.996649] systemd[1]: Mounted tmp.mount - /tmp.
747 [ 7.998972] systemd[1]: Reached target local-fs.target - Local File Systems.
748 [ 8.004304] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
749 [ 8.010521] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
750 [ 8.016247] systemd[1]: Starting console-setup.service - Set console font and keymap...
751 [ 8.022617] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
752 [ 8.035416] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
753 [ 8.041679] systemd[1]: Starting ufw.service - Uncomplicated firewall...
754 [ 8.044570] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
755 [ 8.079969] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
756 [ 8.089589] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
757 [ 8.094069] systemd[1]: Finished console-setup.service - Set console font and keymap.
758 [ 8.099049] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
759 [ 8.102140] systemd[1]: Received SIGRTMIN+20 from PID 1419 (plymouthd).
760 [ 8.106775] systemd[1]: Finished ufw.service - Uncomplicated firewall.
761 [ 8.109875] systemd[1]: Reached target network-pre.target - Preparation for Network.
762 [ 8.120853] WCN: combin_img 0 marlin_firmware_write finish and successful
763 [ 8.121037] WCN: marlin_start_run read reset reg val:0x1
764 [ 8.121041] WCN: after do marlin_start_run reset reg val:0x0
765 [ 8.121252] WCN: s_marlin_bootup_time=8121247426
766 [ 8.126767] WCN: clock mode: TSX
767 [ 8.126963] WCN: marlin_write_cali_data sync init_state:0x1a0f50
768 [ 8.153464] WCN: marlin_write_cali_data sync init_state:0x1a0f50
769 [ 8.180042] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
770 [ 8.180049] WCN: sdio_config bt_wake_host trigger:[high]
771 [ 8.180053] WCN: sdio_config irq:[inband]
772 [ 8.180056] WCN: sdio_config wl_wake_host trigger:[high]
773 [ 8.180060] WCN: sdio_config wake_host_level_duration_time:[20ms]
774 [ 8.180063] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
775 [ 8.180068] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
776 [ 8.180420] WCN: marlin_write_cali_data finish
777 [ 8.180599] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
778 [ 8.184298] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
779 [ 8.186570] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
780 [ 8.187145] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
781 [ 8.187683] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
782 [ 8.206808] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
783 [ 8.230273] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
784 [ 8.233417] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
785 [ 8.260159] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
786 [ 8.286681] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
787 [ 8.313421] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
788 [ 8.313431] WCN: marlin_bind_verify confuse data: 0x8badefa1b12bbe26aeffa8d1a5c07
789 [ 8.313451] WCN: marlin_bind_verify verify data: 0xccd7f963c19581907680f88f2044f687
790 [ 8.313993] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
791 [ 8.340033] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
792 [ 8.340041] sdiohal:sdiohal_runtime_get entry
793 [ 8.340206] WCN: get_cp2_version entry!
794 [ 8.342041] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
795 [ 8.342164] WCN: switch_cp2_log - close entry!
796 [ 8.343330] WCN: WCND at cmd read:OK
797 [ 8.343500] WCN: then marlin download finished and run ok
798 [ 8.343507] WCN: start_loopcheck
799 [ 8.358103] WCN: get_board_ant_num [one_ant]
800 [ 8.358115] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
801 [ 8.419895] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
802 [ 8.425761] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
803 [ 8.432774] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
804 [ 8.478091] zram: Added device: zram0
805 [ 8.479072] zram: Added device: zram1
806 [ 8.480095] zram: Added device: zram2
807 [ 8.515448] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
808 [ 8.516740] zswap: can't enable, initialization failed
809 [ 8.523294] systemd[1]: Starting networking.service - Raise network interfaces...
810 [ 8.550425] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
811 [ 8.575402] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
812 [ 8.583681] zram0: detected capacity change from 0 to 506396672
813 [ 8.643939] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
814 [ 8.684828] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
815 [ 8.687032] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
816 [ 8.688075] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
817 [ 8.690095] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
818 [ 9.171003] systemd[1]: Finished networking.service - Raise network interfaces.
819 [ 9.972783] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
820 [ 10.065081] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
821 [ 10.280879] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
822 [ 10.699203] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
823 [ 10.709665] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
824 [ 10.771758] sunxi-bt soc@03000000:bt: set block: 0
825 [ 10.791280] bluetooth_set_power: start_block=0
826 [ 10.791289] WCN: start_marlin [MARLIN_BLUETOOTH]
827 [ 10.791298] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
828 [ 10.791302] WCN: marlin have open, GNSS is closed
829 [ 10.791308] bluetooth_set_power: end_block=0
830 [ 10.801157] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
831 [ 11.015993] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
832 [ 11.035604] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
833 [ 11.035729] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
834 [ 11.036178] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
835 [ 11.052983] systemd[1]: Starting brltty.service - Braille Device Support...
836 [ 11.058965] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
837 [ 11.065165] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
838 [ 11.071992] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
839 [ 11.078964] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
840 [ 11.088671] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
841 [ 11.089344] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
842 [ 11.092894] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
843 [ 11.093819] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
844 [ 11.096164] systemd[1]: modprobe@loop.service: Deactivated successfully.
845 [ 11.096864] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
846 [ 11.098548] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
847 [ 11.098734] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
848 [ 11.150318] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
849 [ 11.150966] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
850 [ 11.151697] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
851 [ 11.624444] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
852 [ 11.768801] zram1: detected capacity change from 0 to 52428800
853 [ 11.824933] systemd[1]: Started brltty.service - Braille Device Support.
854 [ 11.844101] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
855 [ 15.812101] systemd[1]: systemd-rfkill.service: Deactivated successfully.
856 [ 15.870180] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
857 [ 15.876418] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
858 [ 15.938006] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
859 [ 19.478345] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
860 [ 19.484761] systemd[1]: Starting systemd-journald.service - Journal Service...
861 [ 19.754529] systemd-journald[1924]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
862 [ 19.754550] systemd-journald[1924]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
863 [ 19.761899] systemd[1]: Started systemd-journald.service - Journal Service.
864 [ 19.808239] systemd-journald[1924]: Received client request to flush runtime journal.
865 [ 20.043035] IPVS: Creating netns size=1928 id=1
866
867 ### armbian-release:
868
869 # PLEASE DO NOT EDIT THIS FILE
870 BOARD=orangepizero2
871 BOARD_NAME="Orange Pi Zero2"
872 BOARDFAMILY=sun50iw9
873 BUILD_REPOSITORY_URL=https://github.com/armbian/build
874 BUILD_REPOSITORY_COMMIT=ac829eb6
875 LINUXFAMILY=sun50iw9
876 ARCH=arm64
877 IMAGE_TYPE=stable
878 BOARD_TYPE=conf
879 INITRD_ARCH=arm
880 KERNEL_IMAGE_TYPE=Image
881 FORCE_BOOTSCRIPT_UPDATE=yes
882 VENDOR=Armbian
883 BOOTSCRIPT_FORCE_UPDATE="yes"
884 BOOTSCRIPT_DST="boot.cmd"
885 VERSION=23.8.1
886 REVISION=23.8.1
887 BRANCH=legacy
888
889 ### boot environment:
890
891 verbosity=1
892 console=serial
893 #disp_mode=1080p60
894 #fb0_width=1280
895 #fb0_height=720
896 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
897 rootfstype=ext4
898 overlays=spi-spidev
899 param_spidev_spi_bus=1
900 param_spidev_spi_cs=1
901 extraargs=fbcon=map:1
902 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
903
904 ### lsusb:
905
906 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
907 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
908 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
909 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
910 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
911 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
912 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
913
914 ### lscpu:
915
916 Architecture: aarch64
917 CPU op-mode(s): 32-bit, 64-bit
918 Byte Order: Little Endian
919 CPU(s): 4
920 On-line CPU(s) list: 0-3
921 Vendor ID: ARM
922 Model name: Cortex-A53
923 Model: 4
924 Thread(s) per core: 1
925 Core(s) per cluster: 4
926 Socket(s): -
927 Cluster(s): 1
928 Stepping: r0p4
929 CPU(s) scaling MHz: 100%
930 CPU max MHz: 1512.0000
931 CPU min MHz: 480.0000
932 BogoMIPS: 48.00
933 Flags: fp asimd aes pmull sha1 sha2 crc32
934
935 ### cpuinfo:
936
937 processor : 0
938 BogoMIPS : 48.00
939 Features : fp asimd aes pmull sha1 sha2 crc32
940 CPU implementer : 0x41
941 CPU architecture: 8
942 CPU variant : 0x0
943 CPU part : 0xd03
944 CPU revision : 4
945
946 processor : 1
947 BogoMIPS : 48.00
948 Features : fp asimd aes pmull sha1 sha2 crc32
949 CPU implementer : 0x41
950 CPU architecture: 8
951 CPU variant : 0x0
952 CPU part : 0xd03
953 CPU revision : 4
954
955 processor : 2
956 BogoMIPS : 48.00
957 Features : fp asimd aes pmull sha1 sha2 crc32
958 CPU implementer : 0x41
959 CPU architecture: 8
960 CPU variant : 0x0
961 CPU part : 0xd03
962 CPU revision : 4
963
964 processor : 3
965 BogoMIPS : 48.00
966 Features : fp asimd aes pmull sha1 sha2 crc32
967 CPU implementer : 0x41
968 CPU architecture: 8
969 CPU variant : 0x0
970 CPU part : 0xd03
971 CPU revision : 4
972
973
974 ### meminfo:
975
976 MemTotal: 989056 kB
977 MemFree: 798616 kB
978 MemAvailable: 885636 kB
979 Buffers: 15588 kB
980 Cached: 78536 kB
981 SwapCached: 0 kB
982 Active: 65408 kB
983 Inactive: 49780 kB
984 Active(anon): 21248 kB
985 Inactive(anon): 656 kB
986 Active(file): 44160 kB
987 Inactive(file): 49124 kB
988 Unevictable: 0 kB
989 Mlocked: 0 kB
990 SwapTotal: 494524 kB
991 SwapFree: 494524 kB
992 Dirty: 2748 kB
993 Writeback: 0 kB
994 AnonPages: 21120 kB
995 Mapped: 24344 kB
996 Shmem: 828 kB
997 Slab: 32928 kB
998 SReclaimable: 9116 kB
999 SUnreclaim: 23812 kB
1000 KernelStack: 2560 kB
1001 PageTables: 1056 kB
1002 NFS_Unstable: 0 kB
1003 Bounce: 0 kB
1004 WritebackTmp: 0 kB
1005 CommitLimit: 989052 kB
1006 Committed_AS: 79260 kB
1007 VmallocTotal: 263061440 kB
1008 VmallocUsed: 0 kB
1009 VmallocChunk: 0 kB
1010 CmaTotal: 16384 kB
1011 CmaFree: 7468 kB
1012 HugePages_Total: 0
1013 HugePages_Free: 0
1014 HugePages_Rsvd: 0
1015 HugePages_Surp: 0
1016 Hugepagesize: 2048 kB
1017
1018 ### virtual memory:
1019
1020 vm.admin_reserve_kbytes = 8192
1021 vm.block_dump = 0
1022 vm.compact_unevictable_allowed = 1
1023 vm.dirty_background_bytes = 0
1024 vm.dirty_background_ratio = 10
1025 vm.dirty_bytes = 0
1026 vm.dirty_expire_centisecs = 3000
1027 vm.dirty_ratio = 20
1028 vm.dirtytime_expire_seconds = 43200
1029 vm.dirty_writeback_centisecs = 500
1030 vm.extfrag_threshold = 500
1031 vm.extra_free_kbytes = 0
1032 vm.hugepages_treat_as_movable = 0
1033 vm.hugetlb_shm_group = 0
1034 vm.laptop_mode = 0
1035 vm.legacy_va_layout = 0
1036 vm.lowmem_reserve_ratio = 256 32
1037 vm.max_map_count = 65530
1038 vm.min_free_kbytes = 3937
1039 vm.mmap_min_addr = 4096
1040 vm.mmap_rnd_bits = 18
1041 vm.mmap_rnd_compat_bits = 11
1042 vm.nr_hugepages = 0
1043 vm.nr_overcommit_hugepages = 0
1044 vm.nr_pdflush_threads = 0
1045 vm.oom_dump_tasks = 1
1046 vm.oom_kill_allocating_task = 0
1047 vm.overcommit_kbytes = 0
1048 vm.overcommit_memory = 0
1049 vm.overcommit_ratio = 50
1050 vm.page-cluster = 0
1051 vm.panic_on_oom = 0
1052 vm.percpu_pagelist_fraction = 0
1053 vm.stat_interval = 1
1054 vm.swappiness = 100
1055 vm.user_reserve_kbytes = 30004
1056 vm.vfs_cache_pressure = 100
1057 vm.watermark_scale_factor = 10
1058
1059 ### ip addr:
1060
1061 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
1062 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
1063 inet XXX.XXX.0.1/8 scope host lo
1064 valid_lft forever preferred_lft forever
1065 inet6 ::1/128 scope host noprefixroute
1066 valid_lft forever preferred_lft forever
1067 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
1068 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
1069 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
1070 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
1071 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
1072 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
1073 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
1074 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
1075 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
1076 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
1077 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
1078 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
1079 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
1080 link/tunnel6 :: brd ::
1081 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
1082 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
1083 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
1084 link/tunnel6 :: brd ::
1085 11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
1086 link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
1087
1088 ### partitions:
1089
1090 major minor #blocks name
1091
1092 179 0 62410752 mmcblk0
1093 179 1 61763584 mmcblk0p1
1094 253 0 494528 zram0
1095 253 1 51200 zram1
1096
1097 ### df:
1098
1099 udev 466M 0 466M 0% /dev
1100 tmpfs 97M 2.1M 95M 3% /run
1101 /dev/mmcblk0p1 58G 5.7G 52G 10% /
1102 tmpfs 483M 0 483M 0% /dev/shm
1103 tmpfs 5.0M 0 5.0M 0% /run/lock
1104 tmpfs 483M 4.0K 483M 1% /tmp
1105 /dev/zram1 47M 2.4M 41M 6% /var/log
1106
1107 ### lsblk:
1108
1109 NAME FSTYPE SIZE MOUNTPOINT UUID
1110 mmcblk0 59.5G
1111 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
1112 zram1 50M /var/log
1113 zram2 0B
1114
1115 ### zramctl:
1116
1117 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
1118 /dev/zram1 lz4 50M 2.4M 565.1K 932K 4 /var/log
1119 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
1120
1121 ### mtab:
1122
1123 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
1124 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
1125 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
1126
1127 ### mmc0:0001 info:
1128
1129 manfid: 0x0000fe
1130 cid: fe3432534431364720000000690091f5
1131 fwrev: 0x0
1132 csd: 400e00325b590001dc277f800a40008b
1133 ocr: 0x00200000
1134 type: SD
1135 date: 01/2009
1136 hwrev: 0x2
1137 dsr: 0x404
1138 serial: 0x00000069
1139 erase_size: 512
1140 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
1141 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
1142 scr: 0285808300000000
1143 oemid: 0x3432
1144 preferred_erase_size: 4194304
1145 name: SD16G
1146
1147 ### Boot system health:
1148
1149 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
1150 10:14:14 1512 MHz 1.17 39% 19% 13% 0% 6% 0% 50.0 °C 0/5
1151 10:14:14 1512 MHz 1.17 94% 31% 28% 0% 34% 0% 47.9 °C 0/5
1152 10:14:15 1512 MHz 1.17 100% 29% 55% 1% 14% 0% 47.9 °C 0/5
1153 10:14:15 1512 MHz 1.17 99% 32% 59% 1% 6% 0% 50.0 °C 0/5
1154 10:14:15 1512 MHz 1.17 96% 31% 34% 1% 29% 0% 50.0 °C 0/5
1155
1156 ### Activated 1 lzo zram swap devices with 482MB each.
1157 ### Activated Armbian ramlog partition with lz4 compression
1158
1159 Mon Sep 25 11:53:07 AM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
1160
1161 ### dmesg:
1162
1163 [ 0.000000] Booting Linux on physical CPU 0x0
1164 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
1165 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
1166 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
1167 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
1168 [ 0.000000] On node 0 totalpages: 262144
1169 [ 0.000000] DMA zone: 4096 pages used for memmap
1170 [ 0.000000] DMA zone: 0 pages reserved
1171 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
1172 [ 0.000000] psci: probing for conduit method from DT.
1173 [ 0.000000] psci: PSCIv1.0 detected in firmware.
1174 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
1175 [ 0.000000] psci: Trusted OS migration not required
1176 [ 0.000000] psci: SMC Calling Convention v1.0
1177 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
1178 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
1179 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
1180 [ 0.000000] Detected VIPT I-cache on CPU0
1181 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
1182 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
1183 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
1184 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
1185 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
1186 [ 0.000000] log_buf_len min size: 131072 bytes
1187 [ 0.000000] log_buf_len: 524288 bytes
1188 [ 0.000000] early log buf free: 129352(98%)
1189 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
1190 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
1191 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
1192 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
1193 [ 0.000000] Virtual kernel memory layout:
1194 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
1195 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
1196 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
1197 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
1198 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
1199 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
1200 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
1201 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
1202 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
1203 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
1204 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
1205 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
1206 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
1207 [ 0.000000] Preemptible hierarchical RCU implementation.
1208 [ 0.000000] Build-time adjustment of leaf fanout to 64.
1209 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
1210 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
1211 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
1212 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
1213 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
1214 [ 0.000213] Console: colour dummy device 80x25
1215 [ 0.000228] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
1216 [ 0.000237] pid_max: default: 32768 minimum: 301
1217 [ 0.000434] Security Framework initialized
1218 [ 0.000442] AppArmor: AppArmor disabled by boot time parameter
1219 [ 0.000561] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
1220 [ 0.000567] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
1221 [ 0.001842] sched-energy: CPU device node has no sched-energy-costs
1222 [ 0.001857] Invalid sched_group_energy for CPU0
1223 [ 0.001864] CPU0: update cpu_capacity 1024
1224 [ 0.008938] ASID allocator initialised with 32768 entries
1225 [ 0.027948] BOOTEVENT: 27.933457: ON
1226 [ 0.055888] Detected VIPT I-cache on CPU1
1227 [ 0.055944] Invalid sched_group_energy for CPU1
1228 [ 0.055947] CPU1: update cpu_capacity 1024
1229 [ 0.055951] CPU1: Booted secondary processor [410fd034]
1230 [ 0.079275] Detected VIPT I-cache on CPU2
1231 [ 0.079313] Invalid sched_group_energy for CPU2
1232 [ 0.079316] CPU2: update cpu_capacity 1024
1233 [ 0.079319] CPU2: Booted secondary processor [410fd034]
1234 [ 0.102675] Detected VIPT I-cache on CPU3
1235 [ 0.102708] Invalid sched_group_energy for CPU3
1236 [ 0.102711] CPU3: update cpu_capacity 1024
1237 [ 0.102714] CPU3: Booted secondary processor [410fd034]
1238 [ 0.102794] Brought up 4 CPUs
1239 [ 0.102802] SMP: Total of 4 processors activated.
1240 [ 0.102810] CPU features: detected feature: 32-bit EL0 Support
1241 [ 0.102816] CPU features: detected feature: Kernel page table isolation (KPTI)
1242 [ 0.106583] CPU: All CPU(s) started at EL1
1243 [ 0.106605] alternatives: patching kernel code
1244 [ 0.106777] Invalid sched_group_energy for CPU3
1245 [ 0.106787] CPU3: update max cpu_capacity 1024
1246 [ 0.106792] Invalid sched_group_energy for Cluster3
1247 [ 0.106797] Invalid sched_group_energy for CPU2
1248 [ 0.106803] Invalid sched_group_energy for Cluster2
1249 [ 0.106807] Invalid sched_group_energy for CPU1
1250 [ 0.106813] Invalid sched_group_energy for Cluster1
1251 [ 0.106818] Invalid sched_group_energy for CPU0
1252 [ 0.106823] Invalid sched_group_energy for Cluster0
1253 [ 0.108245] devtmpfs: initialized
1254 [ 0.112692] CPU1: update max cpu_capacity 1024
1255 [ 0.143351] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
1256 [ 0.143380] futex hash table entries: 1024 (order: 5, 131072 bytes)
1257 [ 0.144036] xor: measuring software checksum speed
1258 [ 0.176245] 8regs : 1933.200 MB/sec
1259 [ 0.209624] 8regs_prefetch: 1720.800 MB/sec
1260 [ 0.243010] 32regs : 2287.200 MB/sec
1261 [ 0.276398] 32regs_prefetch: 1935.600 MB/sec
1262 [ 0.276403] xor: using function: 32regs (2287.200 MB/sec)
1263 [ 0.276463] atomic64_test: passed
1264 [ 0.276469] pinctrl core: initialized pinctrl subsystem
1265 [ 0.277635] NET: Registered protocol family 16
1266 [ 0.278886] dump_class_init,861, success
1267 [ 0.296463] cpuidle: using governor menu
1268 [ 0.297922] sunxi iommu: irq = 8
1269 [ 0.298242] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
1270 [ 0.298259] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
1271 [ 0.299679] DMA: preallocated 256 KiB pool for atomic allocations
1272 [ 0.301067] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
1273 [ 0.315448] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
1274 [ 0.319394] iommu: Adding device 1c0e000.ve to group 0
1275 [ 0.319896] iommu: Adding device 1c00000.vp9 to group 0
1276 [ 0.331325] iommu: Adding device 1000000.disp to group 0
1277 [ 0.332744] iommu: Adding device 1480000.g2d to group 0
1278 [ 0.335961] iommu: Adding device csi0 to group 0
1279 [ 0.336420] iommu: Adding device csi1 to group 0
1280 [ 0.337642] iommu: Adding device 6600800.vind:scaler@0 to group 0
1281 [ 0.337941] iommu: Adding device 6600800.vind:scaler@1 to group 0
1282 [ 0.338242] iommu: Adding device 6600800.vind:scaler@2 to group 0
1283 [ 0.338532] iommu: Adding device 6600800.vind:scaler@3 to group 0
1284 [ 0.338818] iommu: Adding device 6600800.vind:scaler@4 to group 0
1285 [ 0.339122] iommu: Adding device 6600800.vind:scaler@5 to group 0
1286 [ 0.340053] iommu: Adding device vinc0 to group 0
1287 [ 0.340603] iommu: Adding device vinc1 to group 0
1288 [ 0.342058] iommu: Adding device 1420000.deinterlace to group 0
1289 [ 0.384529] HugeTLB registered 2 MB page size, pre-allocated 0 pages
1290 [ 0.440807] raid6: int64x1 gen() 392 MB/s
1291 [ 0.497436] raid6: int64x1 xor() 362 MB/s
1292 [ 0.554273] raid6: int64x2 gen() 591 MB/s
1293 [ 0.611040] raid6: int64x2 xor() 512 MB/s
1294 [ 0.667771] raid6: int64x4 gen() 840 MB/s
1295 [ 0.724552] raid6: int64x4 xor() 629 MB/s
1296 [ 0.781384] raid6: int64x8 gen() 965 MB/s
1297 [ 0.838120] raid6: int64x8 xor() 655 MB/s
1298 [ 0.894922] raid6: neonx1 gen() 648 MB/s
1299 [ 0.951679] raid6: neonx1 xor() 641 MB/s
1300 [ 1.008469] raid6: neonx2 gen() 976 MB/s
1301 [ 1.065251] raid6: neonx2 xor() 819 MB/s
1302 [ 1.122039] raid6: neonx4 gen() 1287 MB/s
1303 [ 1.178809] raid6: neonx4 xor() 966 MB/s
1304 [ 1.235591] raid6: neonx8 gen() 1324 MB/s
1305 [ 1.292359] raid6: neonx8 xor() 991 MB/s
1306 [ 1.292365] raid6: using algorithm neonx8 gen() 1324 MB/s
1307 [ 1.292370] raid6: .... xor() 991 MB/s, rmw enabled
1308 [ 1.292375] raid6: using intx1 recovery algorithm
1309 [ 1.292510] pwm module init!
1310 [ 1.296809] sunxi-pm debug v3.10
1311 [ 1.297909] SCSI subsystem initialized
1312 [ 1.298536] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
1313 [ 1.298618] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
1314 [ 1.298739] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
1315 [ 1.299257] spi spi0: master is unqueued, this is deprecated
1316 [ 1.299566] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
1317 [ 1.300133] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
1318 [ 1.300213] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
1319 [ 1.300329] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
1320 [ 1.300793] spi spi1: master is unqueued, this is deprecated
1321 [ 1.301098] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
1322 [ 1.301944] usbcore: registered new interface driver usbfs
1323 [ 1.302032] usbcore: registered new interface driver hub
1324 [ 1.302103] usbcore: registered new device driver usb
1325 [ 1.302262] sunxi_i2c_adap_init()2522 - init
1326 [ 1.302818] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
1327 [ 1.302909] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
1328 [ 1.302917] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
1329 [ 1.302932] twi3 supply twi not found, using dummy regulator
1330 [ 1.303008] twi_request_gpio()451 - [i2c3] init name: twi3
1331 [ 1.303783] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
1332 [ 1.303866] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
1333 [ 1.303873] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
1334 [ 1.303887] twi5 supply twi not found, using dummy regulator
1335 [ 1.303965] twi_request_gpio()451 - [i2c5] init name: twi5
1336 [ 1.304443] axp20x-i2c 5-0036: AXP20x variant AXP806 found
1337 [ 1.323141] random: fast init done
1338 [ 1.334361] axp20x-i2c 5-0036: AXP20X driver loaded
1339 [ 1.334857] media: Linux media interface: v0.10
1340 [ 1.334941] Linux video capture interface: v2.00
1341 [ 1.335668] Advanced Linux Sound Architecture Driver Initialized.
1342 [ 1.336426] Bluetooth: Core ver 2.22
1343 [ 1.336493] NET: Registered protocol family 31
1344 [ 1.336499] Bluetooth: HCI device and connection manager initialized
1345 [ 1.336516] Bluetooth: HCI socket layer initialized
1346 [ 1.336528] Bluetooth: L2CAP socket layer initialized
1347 [ 1.336566] Bluetooth: SCO socket layer initialized
1348 [ 1.337339] [DISP]disp_module_init
1349 [ 1.338520] [DISP] parser_disp_init_para,line:1403:
1350 [ 1.338529] of_property_read fb0_width fail
1351 [ 1.338541] [DISP] disp_init,line:2215:
1352 [ 1.338546] smooth display screen:0 type:4 mode:10
1353 [ 1.355947] [DISP]disp_module_init finish
1354 [ 1.356888] clocksource: Switched to clocksource arch_sys_counter
1355 [ 1.357129] VFS: Disk quotas dquot_6.6.0
1356 [ 1.357217] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
1357 [ 1.357965] Console: switching to colour frame buffer device 240x67
1358 [ 1.401241] NET: Registered protocol family 2
1359 [ 1.401365] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
1360 [ 1.417139] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
1361 [ 1.417212] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
1362 [ 1.417336] TCP: Hash tables configured (established 8192 bind 8192)
1363 [ 1.417423] UDP hash table entries: 512 (order: 2, 16384 bytes)
1364 [ 1.417451] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
1365 [ 1.417772] NET: Registered protocol family 1
1366 [ 1.418326] RPC: Registered named UNIX socket transport module.
1367 [ 1.418331] RPC: Registered udp transport module.
1368 [ 1.418336] RPC: Registered tcp transport module.
1369 [ 1.418339] RPC: Registered tcp NFSv4.1 backchannel transport module.
1370 [ 1.418579] Trying to unpack rootfs image as initramfs...
1371 [ 2.172813] Freeing initrd memory: 17256K
1372 [ 2.173902] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
1373 [ 2.177824] audit: initializing netlink subsys (disabled)
1374 [ 2.177911] audit: type=2000 audit(2.173:1): initialized
1375 [ 2.178866] workingset: timestamp_bits=45 max_order=18 bucket_order=0
1376 [ 2.190066] DLM installed
1377 [ 2.191956] squashfs: version 4.0 (2009/01/31) Phillip Lougher
1378 [ 2.192295] Registering sdcardfs 0.1
1379 [ 2.192766] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
1380 [ 2.194332] ntfs: driver 2.1.32 [Flags: R/W].
1381 [ 2.201080] NET: Registered protocol family 38
1382 [ 2.201448] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
1383 [ 2.201597] io scheduler noop registered
1384 [ 2.201605] io scheduler deadline registered
1385 [ 2.201769] io scheduler cfq registered (default)
1386 [ 2.203715] failed to get easy_light_used assign
1387 [ 2.203726] failed to get normal led pin assign
1388 [ 2.203731] failed to get standby led pin assign
1389 [ 2.203736] failed to get standby led pin assign
1390 [ 2.203742] these is zero number for gpio
1391 [ 2.203746] gpio_init finish with uesd
1392 [ 2.206782] uart uart0: get regulator failed
1393 [ 2.207027] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
1394 [ 2.207051] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
1395 [ 2.207127] console [ttyS0] enabled
1396 [ 2.207945] uart uart1: get regulator failed
1397 [ 2.208135] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
1398 [ 2.208892] uart uart5: get regulator failed
1399 [ 2.209082] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
1400 [ 2.210652] misc dump reg init
1401 [ 2.211842] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
1402 [ 2.212179] Unable to detect cache hierarchy for CPU 0
1403 [ 2.226192] brd: module loaded
1404 [ 2.234375] loop: module loaded
1405 [ 2.234564] [NAND][NE] Not found valid nand node on dts
1406 [ 2.235154] Get boot type cmd line fail
1407 [ 2.235732] sunxi-bt soc@03000000:bt: Missing bt_power.
1408 [ 2.235742] sunxi-bt soc@03000000:bt: bt_power_name ((null))
1409 [ 2.235749] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
1410 [ 2.235756] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
1411 [ 2.235812] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
1412 [ 2.235884] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
1413 [ 2.236710] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
1414 [ 2.236721] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
1415 [ 2.236728] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
1416 [ 2.236736] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
1417 [ 2.236743] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
1418 [ 2.236772] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
1419 [ 2.236806] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
1420 [ 2.236814] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
1421 [ 2.236832] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
1422 [ 2.237851] [ADDR_MGT] addr_mgt_probe: success.
1423 [ 2.244289] tun: Universal TUN/TAP device driver, 1.6
1424 [ 2.244298] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
1425 [ 2.246294] gmac-power0: NULL
1426 [ 2.246303] gmac-power1: NULL
1427 [ 2.246310] gmac-power2: NULL
1428 [ 2.247346] PPP generic driver version 2.4.2
1429 [ 2.247633] PPP BSD Compression module registered
1430 [ 2.247643] PPP Deflate Compression module registered
1431 [ 2.247670] PPP MPPE Compression module registered
1432 [ 2.247679] NET: Registered protocol family 24
1433 [ 2.247712] PPTP driver version 0.8.5
1434 [ 2.248074] usbcore: registered new interface driver r8152
1435 [ 2.248149] usbcore: registered new interface driver asix
1436 [ 2.248259] usbcore: registered new interface driver ax88179_178a
1437 [ 2.248326] usbcore: registered new interface driver cdc_ether
1438 [ 2.248388] usbcore: registered new interface driver net1080
1439 [ 2.248447] usbcore: registered new interface driver cdc_subset
1440 [ 2.248510] usbcore: registered new interface driver zaurus
1441 [ 2.248604] usbcore: registered new interface driver cdc_ncm
1442 [ 2.248611] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
1443 [ 2.248973] get drv_vbus is fail, 84
1444 [ 2.248982] get ehci0-controller, regulator_io is no nocare
1445 [ 2.249246] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
1446 [ 2.249252] [sunxi-ehci0]: Not init ehci0
1447 [ 2.249365] get ehci1-controller, regulator_io is no nocare
1448 [ 2.249538] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
1449 [ 2.249595] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
1450 [ 2.249622] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
1451 [ 2.250274] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
1452 [ 2.263582] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
1453 [ 2.263843] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
1454 [ 2.263852] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
1455 [ 2.263860] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
1456 [ 2.263867] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
1457 [ 2.263874] usb usb1: SerialNumber: sunxi-ehci
1458 [ 2.264739] hub 1-0:1.0: USB hub found
1459 [ 2.264787] hub 1-0:1.0: 1 port detected
1460 [ 2.265472] get drv_vbus is fail, 84
1461 [ 2.265480] get ehci2-controller, regulator_io is no nocare
1462 [ 2.265725] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
1463 [ 2.265777] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
1464 [ 2.265802] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
1465 [ 2.266086] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
1466 [ 2.276904] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
1467 [ 2.277135] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
1468 [ 2.277144] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
1469 [ 2.277152] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
1470 [ 2.277159] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
1471 [ 2.277165] usb usb2: SerialNumber: sunxi-ehci
1472 [ 2.278004] hub 2-0:1.0: USB hub found
1473 [ 2.278047] hub 2-0:1.0: 1 port detected
1474 [ 2.278715] get drv_vbus is fail, 84
1475 [ 2.278723] get ehci3-controller, regulator_io is no nocare
1476 [ 2.278968] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
1477 [ 2.279019] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
1478 [ 2.279044] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
1479 [ 2.279340] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
1480 [ 2.290234] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
1481 [ 2.290420] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
1482 [ 2.290429] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
1483 [ 2.290436] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
1484 [ 2.290444] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
1485 [ 2.290450] usb usb3: SerialNumber: sunxi-ehci
1486 [ 2.291318] hub 3-0:1.0: USB hub found
1487 [ 2.291367] hub 3-0:1.0: 1 port detected
1488 [ 2.292292] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
1489 [ 2.292658] get drv_vbus is fail, 84
1490 [ 2.292666] get ohci0-controller, regulator_io is no nocare
1491 [ 2.293007] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
1492 [ 2.293013] [sunxi-ohci0]: Not init ohci0
1493 [ 2.293128] get ohci1-controller, regulator_io is no nocare
1494 [ 2.293289] hci: request ohci1-controller gpio:80
1495 [ 2.293363] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
1496 [ 2.293413] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
1497 [ 2.293439] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
1498 [ 2.293518] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
1499 [ 2.354426] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
1500 [ 2.354438] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
1501 [ 2.354445] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
1502 [ 2.354452] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
1503 [ 2.354459] usb usb4: SerialNumber: sunxi-ohci
1504 [ 2.355317] hub 4-0:1.0: USB hub found
1505 [ 2.355364] hub 4-0:1.0: 1 port detected
1506 [ 2.356047] get drv_vbus is fail, 84
1507 [ 2.356055] get ohci2-controller, regulator_io is no nocare
1508 [ 2.356390] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
1509 [ 2.356438] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
1510 [ 2.356464] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
1511 [ 2.356541] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
1512 [ 2.414401] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
1513 [ 2.414412] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
1514 [ 2.414420] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
1515 [ 2.414427] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
1516 [ 2.414434] usb usb5: SerialNumber: sunxi-ohci
1517 [ 2.415308] hub 5-0:1.0: USB hub found
1518 [ 2.415355] hub 5-0:1.0: 1 port detected
1519 [ 2.416037] get drv_vbus is fail, 84
1520 [ 2.416046] get ohci3-controller, regulator_io is no nocare
1521 [ 2.416372] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
1522 [ 2.416422] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
1523 [ 2.416452] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
1524 [ 2.416529] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
1525 [ 2.474400] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
1526 [ 2.474410] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
1527 [ 2.474418] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
1528 [ 2.474425] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
1529 [ 2.474432] usb usb6: SerialNumber: sunxi-ohci
1530 [ 2.475298] hub 6-0:1.0: USB hub found
1531 [ 2.475343] hub 6-0:1.0: 1 port detected
1532 [ 2.476263] ohci-platform: OHCI generic platform driver
1533 [ 2.477022] usbcore: registered new interface driver uas
1534 [ 2.477190] usbcore: registered new interface driver usb-storage
1535 [ 2.477275] usbcore: registered new interface driver ums-alauda
1536 [ 2.477351] usbcore: registered new interface driver ums-cypress
1537 [ 2.477424] usbcore: registered new interface driver ums-datafab
1538 [ 2.477496] usbcore: registered new interface driver ums_eneub6250
1539 [ 2.477573] usbcore: registered new interface driver ums-freecom
1540 [ 2.477650] usbcore: registered new interface driver ums-isd200
1541 [ 2.477721] usbcore: registered new interface driver ums-jumpshot
1542 [ 2.477792] usbcore: registered new interface driver ums-karma
1543 [ 2.477869] usbcore: registered new interface driver ums-onetouch
1544 [ 2.477958] usbcore: registered new interface driver ums-realtek
1545 [ 2.478037] usbcore: registered new interface driver ums-sddr09
1546 [ 2.478108] usbcore: registered new interface driver ums-sddr55
1547 [ 2.478191] usbcore: registered new interface driver ums-usbat
1548 [ 2.478340] usb_serial_number:20080411
1549 [ 2.479564] input: sunxi-keyboard as /devices/virtual/input/input0
1550 [ 2.480203] usbcore: registered new interface driver xpad
1551 [ 2.480364] usbcore: registered new interface driver usb_acecad
1552 [ 2.480452] usbcore: registered new interface driver aiptek
1553 [ 2.480528] usbcore: registered new interface driver gtco
1554 [ 2.480605] usbcore: registered new interface driver hanwang
1555 [ 2.480693] usbcore: registered new interface driver kbtab
1556 [ 2.481153] axp2101_pek: axp2101-pek can not register without irq
1557 [ 2.481176] axp2101-pek: probe of axp2101-pek.0 failed with error -22
1558 [ 2.482643] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
1559 [ 2.482710] sunxi-rtc rtc: RTC enabled
1560 [ 2.483183] i2c /dev entries driver
1561 [ 2.484007] lirc_dev: IR Remote Control driver registered, major 244
1562 [ 2.484018] IR NEC protocol handler initialized
1563 [ 2.484025] IR RC5(x/sz) protocol handler initialized
1564 [ 2.484030] IR RC6 protocol handler initialized
1565 [ 2.484036] IR JVC protocol handler initialized
1566 [ 2.484041] IR Sony protocol handler initialized
1567 [ 2.484047] IR SANYO protocol handler initialized
1568 [ 2.484053] IR Sharp protocol handler initialized
1569 [ 2.484059] IR MCE Keyboard/mouse protocol handler initialized
1570 [ 2.484064] IR LIRC bridge handler initialized
1571 [ 2.484070] IR XMP protocol handler initialized
1572 [ 2.484595] sunxi_ir_startup: get ir protocol failed
1573 [ 2.484637] 7040000.s_cir supply ir0 not found, using dummy regulator
1574 [ 2.484818] Registered IR keymap rc_map_sunxi
1575 [ 2.485206] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
1576 [ 2.485444] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
1577 [ 2.486430] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
1578 [ 2.487074] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
1579 [ 2.487772] sunxi cedar version 0.1
1580 [ 2.487968] VE: install start!!!
1581
1582 [ 2.488154] cedar_ve: cedar-ve the get irq is 278
1583 [ 2.488790] VE: get debugfs_mpp_root is NULL, please check mpp
1584
1585 [ 2.488807] VE: sunxi ve debug register driver failed!
1586
1587 [ 2.492026] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
1588 [ 2.493331] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
1589 [ 2.493695] Bluetooth: HCI UART driver ver 2.3
1590 [ 2.493706] Bluetooth: HCI UART protocol H4 registered
1591 [ 2.493712] Bluetooth: HCI UART protocol LL registered
1592 [ 2.493718] Bluetooth: HCI UART protocol Three-wire (H5) registered
1593 [ 2.498055] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
1594 [ 2.498079] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
1595 [ 2.498099] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
1596 [ 2.498122] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
1597 [ 2.498140] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
1598 [ 2.498152] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
1599 [ 2.498522] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
1600 [ 2.498625] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
1601 [ 2.498822] sunxi-mmc sdc0: No vmmc regulator found
1602 [ 2.498829] sunxi-mmc sdc0: No vqmmc regulator found
1603 [ 2.498836] sunxi-mmc sdc0: No vdmmc regulator found
1604 [ 2.498842] sunxi-mmc sdc0: No vd33sw regulator found
1605 [ 2.498848] sunxi-mmc sdc0: No vd18sw regulator found
1606 [ 2.498855] sunxi-mmc sdc0: No vq33sw regulator found
1607 [ 2.498861] sunxi-mmc sdc0: No vq18sw regulator found
1608 [ 2.499542] sunxi-mmc sdc0: set host busy
1609 [ 2.499650] sunxi-mmc sdc0: Got CD GPIO
1610 [ 2.500017] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
1611 [ 2.500052] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
1612 [ 2.513611] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1613 [ 2.530461] sunxi-mmc sdc0: detmode:gpio irq
1614 [ 2.530595] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1615 [ 2.533100] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1616 [ 2.533807] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
1617 [ 2.533916] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
1618 [ 2.534055] sunxi-mmc sdc1: No vmmc regulator found
1619 [ 2.534062] sunxi-mmc sdc1: No vqmmc regulator found
1620 [ 2.534069] sunxi-mmc sdc1: No vdmmc regulator found
1621 [ 2.534075] sunxi-mmc sdc1: No vd33sw regulator found
1622 [ 2.534081] sunxi-mmc sdc1: No vd18sw regulator found
1623 [ 2.534088] sunxi-mmc sdc1: No vq33sw regulator found
1624 [ 2.534094] sunxi-mmc sdc1: No vq18sw regulator found
1625 [ 2.534875] sunxi-mmc sdc1: set host busy
1626 [ 2.534959] mmc:failed to get gpios
1627 [ 2.535163] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1628 [ 2.535258] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
1629 [ 2.537725] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1630 [ 2.550295] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1631 [ 2.561346] mmc0: host does not support reading read-only switch, assuming write-enable
1632 [ 2.563205] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
1633 [ 2.563280] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
1634 [ 2.563558] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
1635 [ 2.563650] mmc0: new high speed SDXC card at address 0001
1636 [ 2.564765] mmcblk0: mmc0:0001 SD16G 59.5 GiB
1637 [ 2.566296] mmcblk0: p1
1638 [ 2.566959] sunxi-mmc sdc1: detmode:manually by software
1639 [ 2.569167] ledtrig-cpu: registered to indicate activity on CPUs
1640 [ 2.569901] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
1641 [ 2.570752] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
1642 [ 2.570783] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1643 [ 2.573287] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1644 [ 2.575096] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
1645 [ 2.575106] sunxi_emce_probe()590emce hw init failed!
1646 [ 2.575133] emce: probe of emce failed with error -2
1647 [ 2.575228] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
1648 [ 2.575408] hidraw: raw HID events driver (C) Jiri Kosina
1649 [ 2.576075] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
1650 [ 2.576936] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
1651 [ 2.577793] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
1652 [ 2.577841] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
1653 [ 2.579927] usbcore: registered new interface driver usbhid
1654 [ 2.579937] usbhid: USB HID core driver
1655 [ 2.581469] optee: probing for conduit method from DT.
1656 [ 2.581482] optee: api uid mismatch
1657 [ 2.582016] usbcore: registered new interface driver snd-usb-audio
1658 [ 2.583647] [sunxi_hdmi_codec_init] driver and deivce register finished.
1659 [ 2.585342] [sunxi_internal_codec_probe]:get audio avcc failed
1660 [ 2.585381] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
1661 [ 2.585630] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
1662 [ 2.588135] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
1663 [ 2.590112] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
1664 [ 2.590125] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
1665 [ 2.592459] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
1666 [ 2.592485] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
1667 [ 2.596456] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
1668 [ 2.598249] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
1669 [ 2.600150] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
1670 [ 2.603089] pktgen: Packet Generator for packet performance testing. Version: 2.75
1671 [ 2.603526] u32 classifier
1672 [ 2.603533] Actions configured
1673 [ 2.603592] Netfilter messages via NETLINK v0.30.
1674 [ 2.603647] nfnl_acct: registering with nfnetlink.
1675 [ 2.603996] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
1676 [ 2.604247] ctnetlink v0.93: registering with nfnetlink.
1677 [ 2.605014] xt_time: kernel timezone is -0000
1678 [ 2.605038] IPVS: Registered protocols (TCP, UDP)
1679 [ 2.605147] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
1680 [ 2.605271] IPVS: Creating netns size=1928 id=0
1681 [ 2.605401] IPVS: ipvs loaded.
1682 [ 2.605409] IPVS: [rr] scheduler registered.
1683 [ 2.605506] ipip: IPv4 and MPLS over IPv4 tunneling driver
1684 [ 2.606212] gre: GRE over IPv4 demultiplexor driver
1685 [ 2.606220] ip_gre: GRE over IPv4 tunneling driver
1686 [ 2.607609] IPv4 over IPsec tunneling driver
1687 [ 2.608486] ip_tables: (C) 2000-2006 Netfilter Core Team
1688 [ 2.608765] arp_tables: arp_tables: (C) 2002 David S. Miller
1689 [ 2.608830] Initializing XFRM netlink socket
1690 [ 2.608865] IPsec XFRM device driver
1691 [ 2.609703] NET: Registered protocol family 10
1692 [ 2.611651] mip6: Mobile IPv6
1693 [ 2.611691] ip6_tables: (C) 2000-2006 Netfilter Core Team
1694 [ 2.613001] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
1695 [ 2.614688] NET: Registered protocol family 17
1696 [ 2.614730] NET: Registered protocol family 15
1697 [ 2.614888] Bridge firewalling registered
1698 [ 2.615022] Bluetooth: RFCOMM TTY layer initialized
1699 [ 2.615040] Bluetooth: RFCOMM socket layer initialized
1700 [ 2.615072] Bluetooth: RFCOMM ver 1.11
1701 [ 2.615087] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
1702 [ 2.615092] Bluetooth: BNEP filters: protocol multicast
1703 [ 2.615105] Bluetooth: BNEP socket layer initialized
1704 [ 2.615111] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
1705 [ 2.615123] Bluetooth: HIDP socket layer initialized
1706 [ 2.615216] l2tp_core: L2TP core driver, V2.0
1707 [ 2.615230] l2tp_ppp: PPPoL2TP kernel driver, V2.0
1708 [ 2.615236] 8021q: 802.1Q VLAN Support v1.8
1709 [ 2.615435] sctp: Hash tables configured (bind 256/256)
1710 [ 2.616036] Key type dns_resolver registered
1711 [ 2.616177] Registered cp15_barrier emulation handler
1712 [ 2.616190] Registered setend emulation handler
1713 [ 2.617224] registered taskstats version 1
1714 [ 2.628757] zswap: default zpool zbud not available
1715 [ 2.628764] zswap: pool creation failed
1716 [ 2.631550] Btrfs loaded, crc32c=crc32c-arm64-hw
1717 [ 2.632312] HDMI 2.0 driver init start!
1718 [ 2.632327] boot_hdmi=true
1719 [ 2.633141] Can not find the node of esm
1720 [ 2.633159] ERROR: pinctrl_get for HDMI2.0 DDC fail
1721 [ 2.633247] Get hdmi_power0:vcc-hdmi
1722 [ 2.633286] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
1723 [ 2.633458] Get hdmi_power1:vdd-hdmi
1724 [ 2.633480] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
1725 [ 2.635080] hdmi_cec_init
1726 [ 2.635565] [DISP] disp_device_attached,line:146:
1727 [ 2.635574] attached ok, mgr0<-->device0, type=4
1728 [ 2.635585] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
1729 [ 2.635598] [DISP] disp_hdmi_set_mode,line:648:
1730 [ 2.635602] hdmi_set_mode is null!
1731 [ 2.637248] HDMI2.0 module init end
1732 [ 2.648351] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
1733 [ 2.651812] cpu cpu1: opp_list_debug_create_link: Failed to create link
1734 [ 2.651824] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
1735 [ 2.651859] cpu cpu2: opp_list_debug_create_link: Failed to create link
1736 [ 2.651867] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
1737 [ 2.651897] cpu cpu3: opp_list_debug_create_link: Failed to create link
1738 [ 2.651904] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
1739 [ 2.654207] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
1740 [ 2.655096] get det_vbus is fail, 84
1741 [ 2.655103] get id is fail, 84
1742 [ 2.655576] sunxi-rtc rtc: setting system clock to 2023-09-25 14:52:49 UTC (1695653569)
1743 [ 2.659337] ALSA device list:
1744 [ 2.659345] #0: audiocodec
1745 [ 2.659349] #1: sndahub
1746 [ 2.659352] #2: sndhdmi
1747 [ 2.661025] Freeing unused kernel memory: 3008K
1748 [ 2.706769] random: systemd-udevd: uninitialized urandom read (16 bytes read)
1749 [ 2.708870] random: systemd-udevd: uninitialized urandom read (16 bytes read)
1750 [ 2.711780] random: systemd-udevd: uninitialized urandom read (16 bytes read)
1751 [ 2.783214] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
1752 [ 2.943730] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
1753 [ 3.040328] HDMI cable is connected
1754 [ 3.293593] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
1755 [ 3.514094] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
1756 [ 3.514104] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
1757 [ 3.514109] usb 4-1: Product: Rapoo 2.4G Wireless Device
1758 [ 3.514113] usb 4-1: Manufacturer: RAPOO
1759 [ 3.521911] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
1760 [ 3.522440] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
1761 [ 3.528055] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
1762 [ 3.584346] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
1763 [ 3.588361] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
1764 [ 3.644493] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
1765 [ 4.173433] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
1766 [ 5.101534] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
1767 [ 5.102087] cgroup: cgroup2: unknown option "nsdelegate"
1768 [ 5.122256] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
1769 [ 5.122280] systemd[1]: Detected architecture arm64.
1770 [ 5.123378] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
1771 [ 5.140746] systemd[1]: Hostname set to <opi>.
1772 [ 5.168066] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
1773 [ 6.722904] (sd-execut[1458]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
1774 [ 6.826941]
1775 insmod_device_driver
1776
1777 [ 6.827189] device_chose finished 124!
1778 [ 7.129729] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
1779 [ 7.369172] systemd[1]: Queued start job for default target graphical.target.
1780 [ 7.376823] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
1781 [ 7.379020] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
1782 [ 7.381318] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
1783 [ 7.382600] systemd[1]: Created slice user.slice - User and Session Slice.
1784 [ 7.383253] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
1785 [ 7.383868] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
1786 [ 7.384202] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
1787 [ 7.384756] systemd[1]: Reached target slices.target - Slice Units.
1788 [ 7.385090] systemd[1]: Reached target swap.target - Swaps.
1789 [ 7.385389] systemd[1]: Reached target time-set.target - System Time Set.
1790 [ 7.385902] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
1791 [ 7.403268] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
1792 [ 7.404433] systemd[1]: Listening on syslog.socket - Syslog Socket.
1793 [ 7.405388] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
1794 [ 7.406056] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
1795 [ 7.407727] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
1796 [ 7.408673] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
1797 [ 7.409695] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
1798 [ 7.411938] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
1799 [ 7.412834] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
1800 [ 7.416821] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
1801 [ 7.421468] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
1802 [ 7.426487] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
1803 [ 7.427699] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
1804 [ 7.428681] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
1805 [ 7.436271] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
1806 [ 7.441910] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
1807 [ 7.447703] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
1808 [ 7.454201] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
1809 [ 7.461600] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
1810 [ 7.470060] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
1811 [ 7.478698] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
1812 [ 7.486727] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
1813 [ 7.496520] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
1814 [ 7.498007] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
1815 [ 7.511229] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
1816 [ 7.517677] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
1817 [ 7.523815] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
1818 [ 7.525336] fuse init (API version 7.26)
1819 [ 7.536260] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
1820 [ 7.538668] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
1821 [ 7.541222] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
1822 [ 7.544423] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
1823 [ 7.549066] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
1824 [ 7.553679] systemd[1]: modprobe@configfs.service: Deactivated successfully.
1825 [ 7.554461] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
1826 [ 7.557916] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
1827 [ 7.558773] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
1828 [ 7.603516] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
1829 [ 7.612080] systemd[1]: modprobe@drm.service: Deactivated successfully.
1830 [ 7.627612] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
1831 [ 7.632507] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
1832 [ 7.640673] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
1833 [ 7.641758] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
1834 [ 7.641769] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
1835 [ 7.641965] spidev spi1.1: Deleting spi1.1
1836 [ 7.642784] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
1837 [ 7.643217] fbtft_device: GPIOS used by 'fb_st7735r':
1838 [ 7.643224] fbtft_device: 'reset' = GPIO73
1839 [ 7.643228] fbtft_device: 'dc' = GPIO70
1840 [ 7.643242] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
1841 [ 7.643247] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
1842 [ 7.644283] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
1843 [ 7.665419] systemd[1]: modprobe@fuse.service: Deactivated successfully.
1844 [ 7.680927] WCN: marlin_init entry!
1845 [ 7.682109] WCN: marlin_parse_dt reset gpio=211
1846 [ 7.682120] WCN_ERR: gpio reset request err: 211
1847 [ 7.682125] WCN: wcn config bt wake host
1848 [ 7.682626] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
1849 [ 7.682867] WCN: wcn config wifi wake host
1850 [ 7.682900] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
1851 [ 7.686401] sdiohal:sdiohal_init ok
1852 [ 7.687690] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
1853 [ 7.690160] WCN: marlin_probe ok!
1854 [ 7.692178] systemd[1]: modprobe@loop.service: Deactivated successfully.
1855 [ 7.693023] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
1856 [ 7.696210] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
1857 [ 7.699361] mtty_probe init device addr: 0xffffffc009a62f00
1858 [ 7.702980] -->rfkill_bluetooth_init
1859 [ 7.703219] <--rfkill_bluetooth_init
1860 [ 7.746330] WCN: start_marlin [MARLIN_WIFI]
1861 [ 7.746344] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
1862 [ 7.746348] WCN: the first power on start
1863 [ 7.753319] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
1864 [ 7.759541] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
1865 [ 7.760731] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
1866 [ 7.767285] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
1867 [ 7.768094] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
1868 [ 7.774614] systemd[1]: Starting systemd-sysusers.service - Create System Users...
1869 [ 7.790586] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
1870 [ 7.793206] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
1871 [ 7.808935] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
1872 [ 7.844542] systemd[1]: Finished systemd-sysusers.service - Create System Users.
1873 [ 7.851045] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
1874 [ 7.863660] WCN: marlin chip en pull up
1875 [ 7.893670] sdiohal:sdiohal_scan_card
1876 [ 7.893692] sunxi-wlan soc@03000000:wlan: bus_index: 1
1877 [ 7.893746] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
1878 [ 7.910290] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1879 [ 7.931090] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
1880 [ 7.932031] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
1881 [ 7.932076] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1882 [ 7.934615] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1883 [ 7.937717] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1884 [ 7.953107] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
1885 [ 7.953636] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
1886 [ 7.955164] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
1887 [ 7.961258] systemd[1]: Mounting tmp.mount - /tmp...
1888 [ 7.967862] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
1889 [ 7.973982] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
1890 [ 7.974741] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
1891 [ 7.974807] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
1892 [ 7.975417] mmc1: new ultra high speed SDR104 SDIO card at address 8800
1893 [ 7.975947] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
1894 [ 7.976137] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
1895 [ 7.976159] WCN: marlin_scan_finish!
1896 [ 7.976164] sdiohal:probe ok
1897 [ 7.976179] sdiohal:scan end!
1898 [ 7.976185] WCN: then marlin start to download
1899 [ 7.976214] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
1900 [ 7.991119] systemd[1]: Mounted tmp.mount - /tmp.
1901 [ 7.993310] systemd[1]: Reached target local-fs.target - Local File Systems.
1902 [ 7.998567] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
1903 [ 8.004446] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
1904 [ 8.010353] systemd[1]: Starting console-setup.service - Set console font and keymap...
1905 [ 8.015562] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
1906 [ 8.041808] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
1907 [ 8.051646] systemd[1]: Starting ufw.service - Uncomplicated firewall...
1908 [ 8.056330] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
1909 [ 8.061917] systemd[1]: Finished console-setup.service - Set console font and keymap.
1910 [ 8.107595] WCN: combin_img 0 marlin_firmware_write finish and successful
1911 [ 8.107769] WCN: marlin_start_run read reset reg val:0x1
1912 [ 8.107773] WCN: after do marlin_start_run reset reg val:0x0
1913 [ 8.107983] WCN: s_marlin_bootup_time=8107975260
1914 [ 8.111812] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
1915 [ 8.113960] WCN: clock mode: TSX
1916 [ 8.114174] WCN: marlin_write_cali_data sync init_state:0x1a0f50
1917 [ 8.119656] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
1918 [ 8.123269] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
1919 [ 8.126534] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
1920 [ 8.128442] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
1921 [ 8.129410] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
1922 [ 8.134094] systemd[1]: Finished ufw.service - Uncomplicated firewall.
1923 [ 8.137291] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
1924 [ 8.137872] systemd[1]: Reached target network-pre.target - Preparation for Network.
1925 [ 8.140733] WCN: marlin_write_cali_data sync init_state:0x1a0f50
1926 [ 8.167217] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
1927 [ 8.167226] WCN: sdio_config bt_wake_host trigger:[high]
1928 [ 8.167229] WCN: sdio_config irq:[inband]
1929 [ 8.167233] WCN: sdio_config wl_wake_host trigger:[high]
1930 [ 8.167241] WCN: sdio_config wake_host_level_duration_time:[20ms]
1931 [ 8.167244] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
1932 [ 8.167249] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
1933 [ 8.167615] WCN: marlin_write_cali_data finish
1934 [ 8.167904] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
1935 [ 8.193884] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
1936 [ 8.207431] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
1937 [ 8.210652] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
1938 [ 8.220528] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
1939 [ 8.247169] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
1940 [ 8.273851] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
1941 [ 8.300524] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
1942 [ 8.300534] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a117df30c640a9405a3d69
1943 [ 8.300550] WCN: marlin_bind_verify verify data: 0x16d6ab91e1d71b3ae4604f224021aa
1944 [ 8.301247] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
1945 [ 8.327207] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
1946 [ 8.327216] sdiohal:sdiohal_runtime_get entry
1947 [ 8.327429] WCN: get_cp2_version entry!
1948 [ 8.329113] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
1949 [ 8.329144] WCN: switch_cp2_log - close entry!
1950 [ 8.330472] WCN: WCND at cmd read:OK
1951 [ 8.330551] WCN: then marlin download finished and run ok
1952 [ 8.330557] WCN: start_loopcheck
1953 [ 8.344877] WCN: get_board_ant_num [one_ant]
1954 [ 8.344888] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
1955 [ 8.405967] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
1956 [ 8.411352] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
1957 [ 8.419183] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
1958 [ 8.486413] zram: Added device: zram0
1959 [ 8.487193] zram: Added device: zram1
1960 [ 8.488112] zram: Added device: zram2
1961 [ 8.496220] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
1962 [ 8.504088] systemd[1]: Starting networking.service - Raise network interfaces...
1963 [ 8.521937] zswap: can't enable, initialization failed
1964 [ 8.580851] zram0: detected capacity change from 0 to 506396672
1965 [ 8.586326] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
1966 [ 8.603653] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
1967 [ 8.668634] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
1968 [ 8.685418] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
1969 [ 8.687924] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
1970 [ 8.688982] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
1971 [ 8.689622] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
1972 [ 9.128629] systemd[1]: Finished networking.service - Raise network interfaces.
1973 [ 9.763740] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
1974 [ 9.890189] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
1975 [ 10.028067] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
1976 [ 10.654680] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
1977 [ 10.654923] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
1978 [ 10.655554] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
1979 [ 10.667241] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
1980 [ 10.677764] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
1981 [ 10.684938] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
1982 [ 10.698026] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
1983 [ 10.702064] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
1984 [ 10.702944] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
1985 [ 10.707530] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
1986 [ 10.708623] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
1987 [ 10.711708] systemd[1]: modprobe@loop.service: Deactivated successfully.
1988 [ 10.712834] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
1989 [ 10.714975] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
1990 [ 10.715235] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
1991 [ 10.774342] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
1992 [ 10.779309] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
1993 [ 10.780190] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
1994 [ 10.792320] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
1995 [ 10.811076] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
1996 [ 10.857080] sunxi-bt soc@03000000:bt: set block: 0
1997 [ 10.873938] bluetooth_set_power: start_block=0
1998 [ 10.873950] WCN: start_marlin [MARLIN_BLUETOOTH]
1999 [ 10.873960] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
2000 [ 10.873965] WCN: marlin have open, GNSS is closed
2001 [ 10.873970] bluetooth_set_power: end_block=0
2002 [ 10.922196] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
2003 [ 11.094722] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
2004 [ 11.100559] systemd[1]: Starting brltty.service - Braille Device Support...
2005 [ 11.626231] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
2006 [ 11.768144] zram1: detected capacity change from 0 to 52428800
2007 [ 11.859100] systemd[1]: Started brltty.service - Braille Device Support.
2008 [ 11.873324] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
2009 [ 15.857495] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
2010 [ 15.863476] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
2011 [ 15.925725] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
2012 [ 15.937064] systemd[1]: systemd-rfkill.service: Deactivated successfully.
2013 [ 19.597599] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
2014 [ 19.604154] systemd[1]: Starting systemd-journald.service - Journal Service...
2015 [ 19.884029] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
2016 [ 19.884051] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
2017 [ 19.891164] systemd[1]: Started systemd-journald.service - Journal Service.
2018 [ 19.938167] systemd-journald[1921]: Received client request to flush runtime journal.
2019 [ 20.306857] IPVS: Creating netns size=1928 id=1
2020
2021 ### armbian-release:
2022
2023 # PLEASE DO NOT EDIT THIS FILE
2024 BOARD=orangepizero2
2025 BOARD_NAME="Orange Pi Zero2"
2026 BOARDFAMILY=sun50iw9
2027 BUILD_REPOSITORY_URL=https://github.com/armbian/build
2028 BUILD_REPOSITORY_COMMIT=ac829eb6
2029 LINUXFAMILY=sun50iw9
2030 ARCH=arm64
2031 IMAGE_TYPE=stable
2032 BOARD_TYPE=conf
2033 INITRD_ARCH=arm
2034 KERNEL_IMAGE_TYPE=Image
2035 FORCE_BOOTSCRIPT_UPDATE=yes
2036 VENDOR=Armbian
2037 BOOTSCRIPT_FORCE_UPDATE="yes"
2038 BOOTSCRIPT_DST="boot.cmd"
2039 VERSION=23.8.1
2040 REVISION=23.8.1
2041 BRANCH=legacy
2042
2043 ### boot environment:
2044
2045 verbosity=1
2046 console=serial
2047 #disp_mode=1080p60
2048 #fb0_width=1280
2049 #fb0_height=720
2050 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
2051 rootfstype=ext4
2052 overlays=spi-spidev
2053 param_spidev_spi_bus=1
2054 param_spidev_spi_cs=1
2055 extraargs=fbcon=map:1
2056 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
2057
2058 ### lsusb:
2059
2060 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
2061 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
2062 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
2063 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
2064 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
2065 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
2066 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
2067
2068 ### lscpu:
2069
2070 Architecture: aarch64
2071 CPU op-mode(s): 32-bit, 64-bit
2072 Byte Order: Little Endian
2073 CPU(s): 4
2074 On-line CPU(s) list: 0-3
2075 Vendor ID: ARM
2076 Model name: Cortex-A53
2077 Model: 4
2078 Thread(s) per core: 1
2079 Core(s) per cluster: 4
2080 Socket(s): -
2081 Cluster(s): 1
2082 Stepping: r0p4
2083 CPU(s) scaling MHz: 100%
2084 CPU max MHz: 1512.0000
2085 CPU min MHz: 480.0000
2086 BogoMIPS: 48.00
2087 Flags: fp asimd aes pmull sha1 sha2 crc32
2088
2089 ### cpuinfo:
2090
2091 processor : 0
2092 BogoMIPS : 48.00
2093 Features : fp asimd aes pmull sha1 sha2 crc32
2094 CPU implementer : 0x41
2095 CPU architecture: 8
2096 CPU variant : 0x0
2097 CPU part : 0xd03
2098 CPU revision : 4
2099
2100 processor : 1
2101 BogoMIPS : 48.00
2102 Features : fp asimd aes pmull sha1 sha2 crc32
2103 CPU implementer : 0x41
2104 CPU architecture: 8
2105 CPU variant : 0x0
2106 CPU part : 0xd03
2107 CPU revision : 4
2108
2109 processor : 2
2110 BogoMIPS : 48.00
2111 Features : fp asimd aes pmull sha1 sha2 crc32
2112 CPU implementer : 0x41
2113 CPU architecture: 8
2114 CPU variant : 0x0
2115 CPU part : 0xd03
2116 CPU revision : 4
2117
2118 processor : 3
2119 BogoMIPS : 48.00
2120 Features : fp asimd aes pmull sha1 sha2 crc32
2121 CPU implementer : 0x41
2122 CPU architecture: 8
2123 CPU variant : 0x0
2124 CPU part : 0xd03
2125 CPU revision : 4
2126
2127
2128 ### meminfo:
2129
2130 MemTotal: 989056 kB
2131 MemFree: 795972 kB
2132 MemAvailable: 885620 kB
2133 Buffers: 15732 kB
2134 Cached: 81084 kB
2135 SwapCached: 0 kB
2136 Active: 65604 kB
2137 Inactive: 52188 kB
2138 Active(anon): 21192 kB
2139 Inactive(anon): 652 kB
2140 Active(file): 44412 kB
2141 Inactive(file): 51536 kB
2142 Unevictable: 0 kB
2143 Mlocked: 0 kB
2144 SwapTotal: 494524 kB
2145 SwapFree: 494524 kB
2146 Dirty: 5340 kB
2147 Writeback: 0 kB
2148 AnonPages: 21100 kB
2149 Mapped: 24592 kB
2150 Shmem: 824 kB
2151 Slab: 33012 kB
2152 SReclaimable: 9044 kB
2153 SUnreclaim: 23968 kB
2154 KernelStack: 2528 kB
2155 PageTables: 1060 kB
2156 NFS_Unstable: 0 kB
2157 Bounce: 0 kB
2158 WritebackTmp: 0 kB
2159 CommitLimit: 989052 kB
2160 Committed_AS: 80292 kB
2161 VmallocTotal: 263061440 kB
2162 VmallocUsed: 0 kB
2163 VmallocChunk: 0 kB
2164 CmaTotal: 16384 kB
2165 CmaFree: 7468 kB
2166 HugePages_Total: 0
2167 HugePages_Free: 0
2168 HugePages_Rsvd: 0
2169 HugePages_Surp: 0
2170 Hugepagesize: 2048 kB
2171
2172 ### virtual memory:
2173
2174 vm.admin_reserve_kbytes = 8192
2175 vm.block_dump = 0
2176 vm.compact_unevictable_allowed = 1
2177 vm.dirty_background_bytes = 0
2178 vm.dirty_background_ratio = 10
2179 vm.dirty_bytes = 0
2180 vm.dirty_expire_centisecs = 3000
2181 vm.dirty_ratio = 20
2182 vm.dirtytime_expire_seconds = 43200
2183 vm.dirty_writeback_centisecs = 500
2184 vm.extfrag_threshold = 500
2185 vm.extra_free_kbytes = 0
2186 vm.hugepages_treat_as_movable = 0
2187 vm.hugetlb_shm_group = 0
2188 vm.laptop_mode = 0
2189 vm.legacy_va_layout = 0
2190 vm.lowmem_reserve_ratio = 256 32
2191 vm.max_map_count = 65530
2192 vm.min_free_kbytes = 3937
2193 vm.mmap_min_addr = 4096
2194 vm.mmap_rnd_bits = 18
2195 vm.mmap_rnd_compat_bits = 11
2196 vm.nr_hugepages = 0
2197 vm.nr_overcommit_hugepages = 0
2198 vm.nr_pdflush_threads = 0
2199 vm.oom_dump_tasks = 1
2200 vm.oom_kill_allocating_task = 0
2201 vm.overcommit_kbytes = 0
2202 vm.overcommit_memory = 0
2203 vm.overcommit_ratio = 50
2204 vm.page-cluster = 0
2205 vm.panic_on_oom = 0
2206 vm.percpu_pagelist_fraction = 0
2207 vm.stat_interval = 1
2208 vm.swappiness = 100
2209 vm.user_reserve_kbytes = 30004
2210 vm.vfs_cache_pressure = 100
2211 vm.watermark_scale_factor = 10
2212
2213 ### ip addr:
2214
2215 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
2216 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2217 inet XXX.XXX.0.1/8 scope host lo
2218 valid_lft forever preferred_lft forever
2219 inet6 ::1/128 scope host noprefixroute
2220 valid_lft forever preferred_lft forever
2221 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
2222 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
2223 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
2224 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
2225 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
2226 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
2227 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
2228 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
2229 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
2230 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
2231 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
2232 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
2233 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
2234 link/tunnel6 :: brd ::
2235 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
2236 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
2237 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
2238 link/tunnel6 :: brd ::
2239 11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
2240 link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
2241
2242 ### partitions:
2243
2244 major minor #blocks name
2245
2246 179 0 62410752 mmcblk0
2247 179 1 61763584 mmcblk0p1
2248 253 0 494528 zram0
2249 253 1 51200 zram1
2250
2251 ### df:
2252
2253 udev 466M 0 466M 0% /dev
2254 tmpfs 97M 900K 96M 1% /run
2255 /dev/mmcblk0p1 58G 5.7G 52G 10% /
2256 tmpfs 483M 0 483M 0% /dev/shm
2257 tmpfs 5.0M 0 5.0M 0% /run/lock
2258 tmpfs 483M 4.0K 483M 1% /tmp
2259 /dev/zram1 47M 4.8M 39M 11% /var/log
2260
2261 ### lsblk:
2262
2263 NAME FSTYPE SIZE MOUNTPOINT UUID
2264 mmcblk0 59.5G
2265 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
2266 zram1 50M /var/log
2267 zram2 0B
2268
2269 ### zramctl:
2270
2271 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
2272 /dev/zram1 lz4 50M 4.8M 1.4M 1.8M 4 /var/log
2273 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
2274
2275 ### mtab:
2276
2277 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
2278 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
2279 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
2280
2281 ### mmc0:0001 info:
2282
2283 manfid: 0x0000fe
2284 cid: fe3432534431364720000000690091f5
2285 fwrev: 0x0
2286 csd: 400e00325b590001dc277f800a40008b
2287 ocr: 0x00200000
2288 type: SD
2289 date: 01/2009
2290 hwrev: 0x2
2291 dsr: 0x404
2292 serial: 0x00000069
2293 erase_size: 512
2294 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
2295 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
2296 scr: 0285808300000000
2297 oemid: 0x3432
2298 preferred_erase_size: 4194304
2299 name: SD16G
2300
2301 ### Boot system health:
2302
2303 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
2304 11:53:09 1512 MHz 1.25 39% 19% 13% 0% 7% 0% 48.2 °C 0/5
2305 11:53:10 1512 MHz 1.25 97% 21% 45% 2% 28% 0% 48.2 °C 0/5
2306 11:53:10 1512 MHz 1.25 100% 29% 50% 0% 19% 0% 48.9 °C 0/5
2307 11:53:11 1512 MHz 1.25 96% 20% 23% 0% 50% 0% 48.9 °C 0/5
2308 11:53:11 1512 MHz 1.25 99% 27% 40% 1% 30% 0% 48.9 °C 0/5
2309
2310 ### Activated 1 lzo zram swap devices with 482MB each.
2311 ### Activated Armbian ramlog partition with lz4 compression
2312
2313 Mon Sep 25 12:17:53 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
2314
2315 ### dmesg:
2316
2317 [ 0.000000] Booting Linux on physical CPU 0x0
2318 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
2319 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
2320 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
2321 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
2322 [ 0.000000] On node 0 totalpages: 262144
2323 [ 0.000000] DMA zone: 4096 pages used for memmap
2324 [ 0.000000] DMA zone: 0 pages reserved
2325 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
2326 [ 0.000000] psci: probing for conduit method from DT.
2327 [ 0.000000] psci: PSCIv1.0 detected in firmware.
2328 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
2329 [ 0.000000] psci: Trusted OS migration not required
2330 [ 0.000000] psci: SMC Calling Convention v1.0
2331 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
2332 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
2333 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
2334 [ 0.000000] Detected VIPT I-cache on CPU0
2335 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
2336 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
2337 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
2338 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
2339 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
2340 [ 0.000000] log_buf_len min size: 131072 bytes
2341 [ 0.000000] log_buf_len: 524288 bytes
2342 [ 0.000000] early log buf free: 129352(98%)
2343 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
2344 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
2345 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
2346 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
2347 [ 0.000000] Virtual kernel memory layout:
2348 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
2349 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
2350 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
2351 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
2352 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
2353 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
2354 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
2355 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
2356 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
2357 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
2358 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
2359 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
2360 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
2361 [ 0.000000] Preemptible hierarchical RCU implementation.
2362 [ 0.000000] Build-time adjustment of leaf fanout to 64.
2363 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
2364 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
2365 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
2366 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
2367 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
2368 [ 0.000211] Console: colour dummy device 80x25
2369 [ 0.000227] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
2370 [ 0.000235] pid_max: default: 32768 minimum: 301
2371 [ 0.000433] Security Framework initialized
2372 [ 0.000442] AppArmor: AppArmor disabled by boot time parameter
2373 [ 0.000560] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
2374 [ 0.000567] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
2375 [ 0.001839] sched-energy: CPU device node has no sched-energy-costs
2376 [ 0.001854] Invalid sched_group_energy for CPU0
2377 [ 0.001861] CPU0: update cpu_capacity 1024
2378 [ 0.008953] ASID allocator initialised with 32768 entries
2379 [ 0.027923] BOOTEVENT: 27.909457: ON
2380 [ 0.055902] Detected VIPT I-cache on CPU1
2381 [ 0.055955] Invalid sched_group_energy for CPU1
2382 [ 0.055959] CPU1: update cpu_capacity 1024
2383 [ 0.055962] CPU1: Booted secondary processor [410fd034]
2384 [ 0.079289] Detected VIPT I-cache on CPU2
2385 [ 0.079327] Invalid sched_group_energy for CPU2
2386 [ 0.079330] CPU2: update cpu_capacity 1024
2387 [ 0.079333] CPU2: Booted secondary processor [410fd034]
2388 [ 0.102692] Detected VIPT I-cache on CPU3
2389 [ 0.102726] Invalid sched_group_energy for CPU3
2390 [ 0.102729] CPU3: update cpu_capacity 1024
2391 [ 0.102732] CPU3: Booted secondary processor [410fd034]
2392 [ 0.102813] Brought up 4 CPUs
2393 [ 0.102820] SMP: Total of 4 processors activated.
2394 [ 0.102829] CPU features: detected feature: 32-bit EL0 Support
2395 [ 0.102835] CPU features: detected feature: Kernel page table isolation (KPTI)
2396 [ 0.106595] CPU: All CPU(s) started at EL1
2397 [ 0.106617] alternatives: patching kernel code
2398 [ 0.106790] Invalid sched_group_energy for CPU3
2399 [ 0.106800] CPU3: update max cpu_capacity 1024
2400 [ 0.106806] Invalid sched_group_energy for Cluster3
2401 [ 0.106811] Invalid sched_group_energy for CPU2
2402 [ 0.106816] Invalid sched_group_energy for Cluster2
2403 [ 0.106821] Invalid sched_group_energy for CPU1
2404 [ 0.106827] Invalid sched_group_energy for Cluster1
2405 [ 0.106831] Invalid sched_group_energy for CPU0
2406 [ 0.106837] Invalid sched_group_energy for Cluster0
2407 [ 0.108257] devtmpfs: initialized
2408 [ 0.112702] CPU1: update max cpu_capacity 1024
2409 [ 0.143397] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
2410 [ 0.143418] futex hash table entries: 1024 (order: 5, 131072 bytes)
2411 [ 0.144078] xor: measuring software checksum speed
2412 [ 0.176236] 8regs : 1933.200 MB/sec
2413 [ 0.209615] 8regs_prefetch: 1720.800 MB/sec
2414 [ 0.243003] 32regs : 2287.200 MB/sec
2415 [ 0.276391] 32regs_prefetch: 1935.600 MB/sec
2416 [ 0.276396] xor: using function: 32regs (2287.200 MB/sec)
2417 [ 0.276457] atomic64_test: passed
2418 [ 0.276463] pinctrl core: initialized pinctrl subsystem
2419 [ 0.277631] NET: Registered protocol family 16
2420 [ 0.278774] dump_class_init,861, success
2421 [ 0.293110] cpuidle: using governor menu
2422 [ 0.294521] sunxi iommu: irq = 8
2423 [ 0.294837] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
2424 [ 0.294855] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
2425 [ 0.296242] DMA: preallocated 256 KiB pool for atomic allocations
2426 [ 0.297632] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
2427 [ 0.311994] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
2428 [ 0.316021] iommu: Adding device 1c0e000.ve to group 0
2429 [ 0.316543] iommu: Adding device 1c00000.vp9 to group 0
2430 [ 0.328258] iommu: Adding device 1000000.disp to group 0
2431 [ 0.329710] iommu: Adding device 1480000.g2d to group 0
2432 [ 0.332989] iommu: Adding device csi0 to group 0
2433 [ 0.333518] iommu: Adding device csi1 to group 0
2434 [ 0.334714] iommu: Adding device 6600800.vind:scaler@0 to group 0
2435 [ 0.335018] iommu: Adding device 6600800.vind:scaler@1 to group 0
2436 [ 0.335334] iommu: Adding device 6600800.vind:scaler@2 to group 0
2437 [ 0.335638] iommu: Adding device 6600800.vind:scaler@3 to group 0
2438 [ 0.335948] iommu: Adding device 6600800.vind:scaler@4 to group 0
2439 [ 0.336250] iommu: Adding device 6600800.vind:scaler@5 to group 0
2440 [ 0.337321] iommu: Adding device vinc0 to group 0
2441 [ 0.337809] iommu: Adding device vinc1 to group 0
2442 [ 0.339300] iommu: Adding device 1420000.deinterlace to group 0
2443 [ 0.381178] HugeTLB registered 2 MB page size, pre-allocated 0 pages
2444 [ 0.437369] raid6: int64x1 gen() 391 MB/s
2445 [ 0.494025] raid6: int64x1 xor() 362 MB/s
2446 [ 0.550749] raid6: int64x2 gen() 590 MB/s
2447 [ 0.607545] raid6: int64x2 xor() 512 MB/s
2448 [ 0.664291] raid6: int64x4 gen() 840 MB/s
2449 [ 0.721006] raid6: int64x4 xor() 629 MB/s
2450 [ 0.777779] raid6: int64x8 gen() 964 MB/s
2451 [ 0.834480] raid6: int64x8 xor() 655 MB/s
2452 [ 0.891289] raid6: neonx1 gen() 648 MB/s
2453 [ 0.947984] raid6: neonx1 xor() 641 MB/s
2454 [ 1.004732] raid6: neonx2 gen() 976 MB/s
2455 [ 1.061457] raid6: neonx2 xor() 819 MB/s
2456 [ 1.118189] raid6: neonx4 gen() 1286 MB/s
2457 [ 1.174947] raid6: neonx4 xor() 965 MB/s
2458 [ 1.231666] raid6: neonx8 gen() 1323 MB/s
2459 [ 1.288431] raid6: neonx8 xor() 984 MB/s
2460 [ 1.288437] raid6: using algorithm neonx8 gen() 1323 MB/s
2461 [ 1.288442] raid6: .... xor() 984 MB/s, rmw enabled
2462 [ 1.288447] raid6: using intx1 recovery algorithm
2463 [ 1.288624] pwm module init!
2464 [ 1.292929] sunxi-pm debug v3.10
2465 [ 1.294013] SCSI subsystem initialized
2466 [ 1.294627] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
2467 [ 1.294705] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
2468 [ 1.294822] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
2469 [ 1.295322] spi spi0: master is unqueued, this is deprecated
2470 [ 1.295630] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
2471 [ 1.296201] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
2472 [ 1.296283] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
2473 [ 1.296400] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
2474 [ 1.296844] spi spi1: master is unqueued, this is deprecated
2475 [ 1.297148] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
2476 [ 1.297931] usbcore: registered new interface driver usbfs
2477 [ 1.298022] usbcore: registered new interface driver hub
2478 [ 1.298095] usbcore: registered new device driver usb
2479 [ 1.298376] sunxi_i2c_adap_init()2522 - init
2480 [ 1.298937] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
2481 [ 1.299028] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
2482 [ 1.299036] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
2483 [ 1.299051] twi3 supply twi not found, using dummy regulator
2484 [ 1.299127] twi_request_gpio()451 - [i2c3] init name: twi3
2485 [ 1.299888] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
2486 [ 1.299967] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
2487 [ 1.299974] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
2488 [ 1.299990] twi5 supply twi not found, using dummy regulator
2489 [ 1.300065] twi_request_gpio()451 - [i2c5] init name: twi5
2490 [ 1.300552] axp20x-i2c 5-0036: AXP20x variant AXP806 found
2491 [ 1.319041] random: fast init done
2492 [ 1.330217] axp20x-i2c 5-0036: AXP20X driver loaded
2493 [ 1.330704] media: Linux media interface: v0.10
2494 [ 1.330790] Linux video capture interface: v2.00
2495 [ 1.331581] Advanced Linux Sound Architecture Driver Initialized.
2496 [ 1.332328] Bluetooth: Core ver 2.22
2497 [ 1.332427] NET: Registered protocol family 31
2498 [ 1.332433] Bluetooth: HCI device and connection manager initialized
2499 [ 1.332451] Bluetooth: HCI socket layer initialized
2500 [ 1.332463] Bluetooth: L2CAP socket layer initialized
2501 [ 1.332502] Bluetooth: SCO socket layer initialized
2502 [ 1.338283] [DISP]disp_module_init
2503 [ 1.339468] [DISP] parser_disp_init_para,line:1403:
2504 [ 1.339477] of_property_read fb0_width fail
2505 [ 1.339488] [DISP] disp_init,line:2215:
2506 [ 1.339494] smooth display screen:0 type:4 mode:10
2507 [ 1.356890] [DISP]disp_module_init finish
2508 [ 1.357753] clocksource: Switched to clocksource arch_sys_counter
2509 [ 1.357992] VFS: Disk quotas dquot_6.6.0
2510 [ 1.358136] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
2511 [ 1.358889] Console: switching to colour frame buffer device 240x67
2512 [ 1.402311] NET: Registered protocol family 2
2513 [ 1.402441] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
2514 [ 1.414671] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
2515 [ 1.414744] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
2516 [ 1.414866] TCP: Hash tables configured (established 8192 bind 8192)
2517 [ 1.414952] UDP hash table entries: 512 (order: 2, 16384 bytes)
2518 [ 1.414982] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
2519 [ 1.415288] NET: Registered protocol family 1
2520 [ 1.415831] RPC: Registered named UNIX socket transport module.
2521 [ 1.415836] RPC: Registered udp transport module.
2522 [ 1.415839] RPC: Registered tcp transport module.
2523 [ 1.415842] RPC: Registered tcp NFSv4.1 backchannel transport module.
2524 [ 1.416090] Trying to unpack rootfs image as initramfs...
2525 [ 2.170062] Freeing initrd memory: 17256K
2526 [ 2.171184] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
2527 [ 2.175097] audit: initializing netlink subsys (disabled)
2528 [ 2.175153] audit: type=2000 audit(2.170:1): initialized
2529 [ 2.176062] workingset: timestamp_bits=45 max_order=18 bucket_order=0
2530 [ 2.187177] DLM installed
2531 [ 2.189044] squashfs: version 4.0 (2009/01/31) Phillip Lougher
2532 [ 2.189384] Registering sdcardfs 0.1
2533 [ 2.189856] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
2534 [ 2.191393] ntfs: driver 2.1.32 [Flags: R/W].
2535 [ 2.197821] NET: Registered protocol family 38
2536 [ 2.198201] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
2537 [ 2.198330] io scheduler noop registered
2538 [ 2.198338] io scheduler deadline registered
2539 [ 2.198506] io scheduler cfq registered (default)
2540 [ 2.200317] failed to get easy_light_used assign
2541 [ 2.200328] failed to get normal led pin assign
2542 [ 2.200333] failed to get standby led pin assign
2543 [ 2.200338] failed to get standby led pin assign
2544 [ 2.200343] these is zero number for gpio
2545 [ 2.200347] gpio_init finish with uesd
2546 [ 2.203754] uart uart0: get regulator failed
2547 [ 2.203954] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
2548 [ 2.203975] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
2549 [ 2.204067] console [ttyS0] enabled
2550 [ 2.204950] uart uart1: get regulator failed
2551 [ 2.205145] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
2552 [ 2.205881] uart uart5: get regulator failed
2553 [ 2.206067] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
2554 [ 2.207328] misc dump reg init
2555 [ 2.208772] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
2556 [ 2.209114] Unable to detect cache hierarchy for CPU 0
2557 [ 2.223698] brd: module loaded
2558 [ 2.231879] loop: module loaded
2559 [ 2.232069] [NAND][NE] Not found valid nand node on dts
2560 [ 2.232664] Get boot type cmd line fail
2561 [ 2.233251] sunxi-bt soc@03000000:bt: Missing bt_power.
2562 [ 2.233261] sunxi-bt soc@03000000:bt: bt_power_name ((null))
2563 [ 2.233268] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
2564 [ 2.233275] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
2565 [ 2.233333] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
2566 [ 2.233404] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
2567 [ 2.234235] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
2568 [ 2.234247] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
2569 [ 2.234255] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
2570 [ 2.234262] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
2571 [ 2.234269] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
2572 [ 2.234300] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
2573 [ 2.234341] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
2574 [ 2.234349] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
2575 [ 2.234367] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
2576 [ 2.235492] [ADDR_MGT] addr_mgt_probe: success.
2577 [ 2.242110] tun: Universal TUN/TAP device driver, 1.6
2578 [ 2.242120] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
2579 [ 2.244105] gmac-power0: NULL
2580 [ 2.244115] gmac-power1: NULL
2581 [ 2.244121] gmac-power2: NULL
2582 [ 2.245221] PPP generic driver version 2.4.2
2583 [ 2.245504] PPP BSD Compression module registered
2584 [ 2.245515] PPP Deflate Compression module registered
2585 [ 2.245540] PPP MPPE Compression module registered
2586 [ 2.245550] NET: Registered protocol family 24
2587 [ 2.245582] PPTP driver version 0.8.5
2588 [ 2.245943] usbcore: registered new interface driver r8152
2589 [ 2.246022] usbcore: registered new interface driver asix
2590 [ 2.246115] usbcore: registered new interface driver ax88179_178a
2591 [ 2.246187] usbcore: registered new interface driver cdc_ether
2592 [ 2.246250] usbcore: registered new interface driver net1080
2593 [ 2.246314] usbcore: registered new interface driver cdc_subset
2594 [ 2.246385] usbcore: registered new interface driver zaurus
2595 [ 2.246477] usbcore: registered new interface driver cdc_ncm
2596 [ 2.246484] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
2597 [ 2.246843] get drv_vbus is fail, 84
2598 [ 2.246852] get ehci0-controller, regulator_io is no nocare
2599 [ 2.247115] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
2600 [ 2.247121] [sunxi-ehci0]: Not init ehci0
2601 [ 2.247248] get ehci1-controller, regulator_io is no nocare
2602 [ 2.247431] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
2603 [ 2.247488] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
2604 [ 2.247515] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
2605 [ 2.248121] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
2606 [ 2.261108] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
2607 [ 2.261394] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
2608 [ 2.261403] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2609 [ 2.261411] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
2610 [ 2.261418] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
2611 [ 2.261425] usb usb1: SerialNumber: sunxi-ehci
2612 [ 2.262279] hub 1-0:1.0: USB hub found
2613 [ 2.262325] hub 1-0:1.0: 1 port detected
2614 [ 2.263019] get drv_vbus is fail, 84
2615 [ 2.263027] get ehci2-controller, regulator_io is no nocare
2616 [ 2.263264] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
2617 [ 2.263314] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
2618 [ 2.263339] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
2619 [ 2.263631] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
2620 [ 2.274444] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
2621 [ 2.274652] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
2622 [ 2.274661] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2623 [ 2.274668] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
2624 [ 2.274675] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
2625 [ 2.274682] usb usb2: SerialNumber: sunxi-ehci
2626 [ 2.275540] hub 2-0:1.0: USB hub found
2627 [ 2.275583] hub 2-0:1.0: 1 port detected
2628 [ 2.276255] get drv_vbus is fail, 84
2629 [ 2.276263] get ehci3-controller, regulator_io is no nocare
2630 [ 2.276507] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
2631 [ 2.276558] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
2632 [ 2.276586] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
2633 [ 2.276883] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
2634 [ 2.287763] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
2635 [ 2.287950] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
2636 [ 2.287959] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2637 [ 2.287966] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
2638 [ 2.287974] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
2639 [ 2.287980] usb usb3: SerialNumber: sunxi-ehci
2640 [ 2.288840] hub 3-0:1.0: USB hub found
2641 [ 2.288883] hub 3-0:1.0: 1 port detected
2642 [ 2.289803] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
2643 [ 2.290200] get drv_vbus is fail, 84
2644 [ 2.290208] get ohci0-controller, regulator_io is no nocare
2645 [ 2.290541] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
2646 [ 2.290546] [sunxi-ohci0]: Not init ohci0
2647 [ 2.290664] get ohci1-controller, regulator_io is no nocare
2648 [ 2.290836] hci: request ohci1-controller gpio:80
2649 [ 2.290912] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
2650 [ 2.290964] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
2651 [ 2.290989] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
2652 [ 2.291111] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
2653 [ 2.351931] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
2654 [ 2.351941] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2655 [ 2.351948] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
2656 [ 2.351956] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
2657 [ 2.351963] usb usb4: SerialNumber: sunxi-ohci
2658 [ 2.352841] hub 4-0:1.0: USB hub found
2659 [ 2.352886] hub 4-0:1.0: 1 port detected
2660 [ 2.353559] get drv_vbus is fail, 84
2661 [ 2.353568] get ohci2-controller, regulator_io is no nocare
2662 [ 2.353898] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
2663 [ 2.353953] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
2664 [ 2.353978] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
2665 [ 2.354069] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
2666 [ 2.411931] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
2667 [ 2.411941] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2668 [ 2.411948] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
2669 [ 2.411956] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
2670 [ 2.411963] usb usb5: SerialNumber: sunxi-ohci
2671 [ 2.412833] hub 5-0:1.0: USB hub found
2672 [ 2.412878] hub 5-0:1.0: 1 port detected
2673 [ 2.413565] get drv_vbus is fail, 84
2674 [ 2.413573] get ohci3-controller, regulator_io is no nocare
2675 [ 2.413910] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
2676 [ 2.413960] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
2677 [ 2.413986] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
2678 [ 2.414065] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
2679 [ 2.471929] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
2680 [ 2.471939] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
2681 [ 2.471947] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
2682 [ 2.471954] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
2683 [ 2.471961] usb usb6: SerialNumber: sunxi-ohci
2684 [ 2.472806] hub 6-0:1.0: USB hub found
2685 [ 2.472849] hub 6-0:1.0: 1 port detected
2686 [ 2.473771] ohci-platform: OHCI generic platform driver
2687 [ 2.474527] usbcore: registered new interface driver uas
2688 [ 2.474694] usbcore: registered new interface driver usb-storage
2689 [ 2.474789] usbcore: registered new interface driver ums-alauda
2690 [ 2.474870] usbcore: registered new interface driver ums-cypress
2691 [ 2.474939] usbcore: registered new interface driver ums-datafab
2692 [ 2.475007] usbcore: registered new interface driver ums_eneub6250
2693 [ 2.475076] usbcore: registered new interface driver ums-freecom
2694 [ 2.475158] usbcore: registered new interface driver ums-isd200
2695 [ 2.475234] usbcore: registered new interface driver ums-jumpshot
2696 [ 2.475307] usbcore: registered new interface driver ums-karma
2697 [ 2.475380] usbcore: registered new interface driver ums-onetouch
2698 [ 2.475481] usbcore: registered new interface driver ums-realtek
2699 [ 2.475559] usbcore: registered new interface driver ums-sddr09
2700 [ 2.475631] usbcore: registered new interface driver ums-sddr55
2701 [ 2.475702] usbcore: registered new interface driver ums-usbat
2702 [ 2.475853] usb_serial_number:20080411
2703 [ 2.477083] input: sunxi-keyboard as /devices/virtual/input/input0
2704 [ 2.477700] usbcore: registered new interface driver xpad
2705 [ 2.477853] usbcore: registered new interface driver usb_acecad
2706 [ 2.477944] usbcore: registered new interface driver aiptek
2707 [ 2.478024] usbcore: registered new interface driver gtco
2708 [ 2.478124] usbcore: registered new interface driver hanwang
2709 [ 2.478201] usbcore: registered new interface driver kbtab
2710 [ 2.478668] axp2101_pek: axp2101-pek can not register without irq
2711 [ 2.478691] axp2101-pek: probe of axp2101-pek.0 failed with error -22
2712 [ 2.480181] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
2713 [ 2.480245] sunxi-rtc rtc: RTC enabled
2714 [ 2.480724] i2c /dev entries driver
2715 [ 2.481555] lirc_dev: IR Remote Control driver registered, major 244
2716 [ 2.481567] IR NEC protocol handler initialized
2717 [ 2.481573] IR RC5(x/sz) protocol handler initialized
2718 [ 2.481579] IR RC6 protocol handler initialized
2719 [ 2.481585] IR JVC protocol handler initialized
2720 [ 2.481590] IR Sony protocol handler initialized
2721 [ 2.481596] IR SANYO protocol handler initialized
2722 [ 2.481602] IR Sharp protocol handler initialized
2723 [ 2.481608] IR MCE Keyboard/mouse protocol handler initialized
2724 [ 2.481614] IR LIRC bridge handler initialized
2725 [ 2.481619] IR XMP protocol handler initialized
2726 [ 2.482153] sunxi_ir_startup: get ir protocol failed
2727 [ 2.482194] 7040000.s_cir supply ir0 not found, using dummy regulator
2728 [ 2.482379] Registered IR keymap rc_map_sunxi
2729 [ 2.482775] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
2730 [ 2.483007] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
2731 [ 2.483989] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
2732 [ 2.484611] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
2733 [ 2.485311] sunxi cedar version 0.1
2734 [ 2.485516] VE: install start!!!
2735
2736 [ 2.485702] cedar_ve: cedar-ve the get irq is 278
2737 [ 2.486319] VE: get debugfs_mpp_root is NULL, please check mpp
2738
2739 [ 2.486334] VE: sunxi ve debug register driver failed!
2740
2741 [ 2.489573] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
2742 [ 2.490885] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
2743 [ 2.491279] Bluetooth: HCI UART driver ver 2.3
2744 [ 2.491291] Bluetooth: HCI UART protocol H4 registered
2745 [ 2.491297] Bluetooth: HCI UART protocol LL registered
2746 [ 2.491302] Bluetooth: HCI UART protocol Three-wire (H5) registered
2747 [ 2.495501] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
2748 [ 2.495517] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
2749 [ 2.495530] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
2750 [ 2.495542] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
2751 [ 2.495555] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
2752 [ 2.495572] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
2753 [ 2.495970] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
2754 [ 2.496084] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
2755 [ 2.496282] sunxi-mmc sdc0: No vmmc regulator found
2756 [ 2.496289] sunxi-mmc sdc0: No vqmmc regulator found
2757 [ 2.496295] sunxi-mmc sdc0: No vdmmc regulator found
2758 [ 2.496301] sunxi-mmc sdc0: No vd33sw regulator found
2759 [ 2.496308] sunxi-mmc sdc0: No vd18sw regulator found
2760 [ 2.496314] sunxi-mmc sdc0: No vq33sw regulator found
2761 [ 2.496320] sunxi-mmc sdc0: No vq18sw regulator found
2762 [ 2.497017] sunxi-mmc sdc0: set host busy
2763 [ 2.497119] sunxi-mmc sdc0: Got CD GPIO
2764 [ 2.497501] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
2765 [ 2.497535] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
2766 [ 2.511099] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2767 [ 2.528131] sunxi-mmc sdc0: detmode:gpio irq
2768 [ 2.528165] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2769 [ 2.530678] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2770 [ 2.532042] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
2771 [ 2.532176] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
2772 [ 2.532317] sunxi-mmc sdc1: No vmmc regulator found
2773 [ 2.532324] sunxi-mmc sdc1: No vqmmc regulator found
2774 [ 2.532330] sunxi-mmc sdc1: No vdmmc regulator found
2775 [ 2.532336] sunxi-mmc sdc1: No vd33sw regulator found
2776 [ 2.532342] sunxi-mmc sdc1: No vd18sw regulator found
2777 [ 2.532349] sunxi-mmc sdc1: No vq33sw regulator found
2778 [ 2.532355] sunxi-mmc sdc1: No vq18sw regulator found
2779 [ 2.532736] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2780 [ 2.533061] sunxi-mmc sdc1: set host busy
2781 [ 2.533143] mmc:failed to get gpios
2782 [ 2.533427] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
2783 [ 2.535221] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2784 [ 2.547830] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2785 [ 2.558892] mmc0: host does not support reading read-only switch, assuming write-enable
2786 [ 2.560754] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
2787 [ 2.560830] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
2788 [ 2.560973] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
2789 [ 2.561064] mmc0: new high speed SDXC card at address 0001
2790 [ 2.562158] mmcblk0: mmc0:0001 SD16G 59.5 GiB
2791 [ 2.563656] mmcblk0: p1
2792 [ 2.564494] sunxi-mmc sdc1: detmode:manually by software
2793 [ 2.566675] ledtrig-cpu: registered to indicate activity on CPUs
2794 [ 2.567419] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
2795 [ 2.568269] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
2796 [ 2.568310] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2797 [ 2.570817] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
2798 [ 2.572739] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
2799 [ 2.573579] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
2800 [ 2.574441] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
2801 [ 2.574713] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
2802 [ 2.574720] sunxi_emce_probe()590emce hw init failed!
2803 [ 2.574746] emce: probe of emce failed with error -2
2804 [ 2.575045] hidraw: raw HID events driver (C) Jiri Kosina
2805 [ 2.575289] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
2806 [ 2.575327] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
2807 [ 2.580189] usbcore: registered new interface driver usbhid
2808 [ 2.580198] usbhid: USB HID core driver
2809 [ 2.581715] optee: probing for conduit method from DT.
2810 [ 2.581728] optee: api uid mismatch
2811 [ 2.582253] usbcore: registered new interface driver snd-usb-audio
2812 [ 2.583847] [sunxi_hdmi_codec_init] driver and deivce register finished.
2813 [ 2.585637] [sunxi_internal_codec_probe]:get audio avcc failed
2814 [ 2.585677] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
2815 [ 2.585942] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
2816 [ 2.588500] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
2817 [ 2.590538] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
2818 [ 2.590551] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
2819 [ 2.592790] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
2820 [ 2.592813] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
2821 [ 2.596752] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
2822 [ 2.598160] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
2823 [ 2.600018] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
2824 [ 2.603083] pktgen: Packet Generator for packet performance testing. Version: 2.75
2825 [ 2.603504] u32 classifier
2826 [ 2.603511] Actions configured
2827 [ 2.603523] Netfilter messages via NETLINK v0.30.
2828 [ 2.603549] nfnl_acct: registering with nfnetlink.
2829 [ 2.603885] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
2830 [ 2.604138] ctnetlink v0.93: registering with nfnetlink.
2831 [ 2.604987] xt_time: kernel timezone is -0000
2832 [ 2.605012] IPVS: Registered protocols (TCP, UDP)
2833 [ 2.605123] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
2834 [ 2.605253] IPVS: Creating netns size=1928 id=0
2835 [ 2.605383] IPVS: ipvs loaded.
2836 [ 2.605391] IPVS: [rr] scheduler registered.
2837 [ 2.605488] ipip: IPv4 and MPLS over IPv4 tunneling driver
2838 [ 2.606202] gre: GRE over IPv4 demultiplexor driver
2839 [ 2.606212] ip_gre: GRE over IPv4 tunneling driver
2840 [ 2.607545] IPv4 over IPsec tunneling driver
2841 [ 2.608494] ip_tables: (C) 2000-2006 Netfilter Core Team
2842 [ 2.608770] arp_tables: arp_tables: (C) 2002 David S. Miller
2843 [ 2.608838] Initializing XFRM netlink socket
2844 [ 2.608870] IPsec XFRM device driver
2845 [ 2.609700] NET: Registered protocol family 10
2846 [ 2.611853] mip6: Mobile IPv6
2847 [ 2.611892] ip6_tables: (C) 2000-2006 Netfilter Core Team
2848 [ 2.613162] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
2849 [ 2.615363] NET: Registered protocol family 17
2850 [ 2.615406] NET: Registered protocol family 15
2851 [ 2.615566] Bridge firewalling registered
2852 [ 2.615697] Bluetooth: RFCOMM TTY layer initialized
2853 [ 2.615713] Bluetooth: RFCOMM socket layer initialized
2854 [ 2.615745] Bluetooth: RFCOMM ver 1.11
2855 [ 2.615759] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
2856 [ 2.615764] Bluetooth: BNEP filters: protocol multicast
2857 [ 2.615778] Bluetooth: BNEP socket layer initialized
2858 [ 2.615784] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
2859 [ 2.615797] Bluetooth: HIDP socket layer initialized
2860 [ 2.615884] l2tp_core: L2TP core driver, V2.0
2861 [ 2.615900] l2tp_ppp: PPPoL2TP kernel driver, V2.0
2862 [ 2.615906] 8021q: 802.1Q VLAN Support v1.8
2863 [ 2.616104] sctp: Hash tables configured (bind 256/256)
2864 [ 2.616687] Key type dns_resolver registered
2865 [ 2.616828] Registered cp15_barrier emulation handler
2866 [ 2.616841] Registered setend emulation handler
2867 [ 2.617802] registered taskstats version 1
2868 [ 2.629196] zswap: default zpool zbud not available
2869 [ 2.629204] zswap: pool creation failed
2870 [ 2.632039] Btrfs loaded, crc32c=crc32c-arm64-hw
2871 [ 2.632775] HDMI 2.0 driver init start!
2872 [ 2.632791] boot_hdmi=true
2873 [ 2.633610] Can not find the node of esm
2874 [ 2.633629] ERROR: pinctrl_get for HDMI2.0 DDC fail
2875 [ 2.633715] Get hdmi_power0:vcc-hdmi
2876 [ 2.633754] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
2877 [ 2.633931] Get hdmi_power1:vdd-hdmi
2878 [ 2.633956] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
2879 [ 2.635580] hdmi_cec_init
2880 [ 2.636048] [DISP] disp_device_attached,line:146:
2881 [ 2.636057] attached ok, mgr0<-->device0, type=4
2882 [ 2.636067] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
2883 [ 2.636080] [DISP] disp_hdmi_set_mode,line:648:
2884 [ 2.636084] hdmi_set_mode is null!
2885 [ 2.638146] HDMI2.0 module init end
2886 [ 2.649346] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
2887 [ 2.652771] cpu cpu1: opp_list_debug_create_link: Failed to create link
2888 [ 2.652782] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
2889 [ 2.652814] cpu cpu2: opp_list_debug_create_link: Failed to create link
2890 [ 2.652822] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
2891 [ 2.652852] cpu cpu3: opp_list_debug_create_link: Failed to create link
2892 [ 2.652859] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
2893 [ 2.655207] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
2894 [ 2.656131] get det_vbus is fail, 84
2895 [ 2.656139] get id is fail, 84
2896 [ 2.656631] sunxi-rtc rtc: setting system clock to 2023-09-25 15:17:35 UTC (1695655055)
2897 [ 2.660427] ALSA device list:
2898 [ 2.660434] #0: audiocodec
2899 [ 2.660438] #1: sndahub
2900 [ 2.660441] #2: sndhdmi
2901 [ 2.662096] Freeing unused kernel memory: 3008K
2902 [ 2.708138] random: systemd-udevd: uninitialized urandom read (16 bytes read)
2903 [ 2.710072] random: systemd-udevd: uninitialized urandom read (16 bytes read)
2904 [ 2.713113] random: systemd-udevd: uninitialized urandom read (16 bytes read)
2905 [ 2.782119] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
2906 [ 2.944603] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
2907 [ 3.044494] HDMI cable is connected
2908 [ 3.294463] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
2909 [ 3.514909] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
2910 [ 3.514918] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
2911 [ 3.514923] usb 4-1: Product: Rapoo 2.4G Wireless Device
2912 [ 3.514928] usb 4-1: Manufacturer: RAPOO
2913 [ 3.522735] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
2914 [ 3.523135] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
2915 [ 3.528604] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
2916 [ 3.585698] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
2917 [ 3.590146] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
2918 [ 3.646478] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
2919 [ 4.191576] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
2920 [ 5.116950] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
2921 [ 5.117505] cgroup: cgroup2: unknown option "nsdelegate"
2922 [ 5.137834] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
2923 [ 5.137866] systemd[1]: Detected architecture arm64.
2924 [ 5.139125] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
2925 [ 5.156504] systemd[1]: Hostname set to <opi>.
2926 [ 5.183760] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
2927 [ 6.640306] (sd-execut[1458]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
2928 [ 6.827825]
2929 insmod_device_driver
2930
2931 [ 6.828068] device_chose finished 124!
2932 [ 7.127061] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
2933 [ 7.365547] systemd[1]: Queued start job for default target graphical.target.
2934 [ 7.372711] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
2935 [ 7.374948] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
2936 [ 7.377204] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
2937 [ 7.378599] systemd[1]: Created slice user.slice - User and Session Slice.
2938 [ 7.379271] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
2939 [ 7.379830] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
2940 [ 7.380160] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
2941 [ 7.380639] systemd[1]: Reached target slices.target - Slice Units.
2942 [ 7.380944] systemd[1]: Reached target swap.target - Swaps.
2943 [ 7.381324] systemd[1]: Reached target time-set.target - System Time Set.
2944 [ 7.381840] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
2945 [ 7.398961] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
2946 [ 7.400065] systemd[1]: Listening on syslog.socket - Syslog Socket.
2947 [ 7.400994] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
2948 [ 7.401758] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
2949 [ 7.403353] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
2950 [ 7.404341] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
2951 [ 7.405470] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
2952 [ 7.407607] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
2953 [ 7.408607] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
2954 [ 7.412518] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
2955 [ 7.417120] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
2956 [ 7.422120] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
2957 [ 7.423287] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
2958 [ 7.424224] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
2959 [ 7.432188] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
2960 [ 7.437584] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
2961 [ 7.443303] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
2962 [ 7.449716] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
2963 [ 7.457266] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
2964 [ 7.465871] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
2965 [ 7.475426] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
2966 [ 7.488350] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
2967 [ 7.495482] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
2968 [ 7.496895] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
2969 [ 7.507167] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
2970 [ 7.513093] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
2971 [ 7.518779] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
2972 [ 7.523221] fuse init (API version 7.26)
2973 [ 7.530103] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
2974 [ 7.532552] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
2975 [ 7.534813] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
2976 [ 7.537693] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
2977 [ 7.541476] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
2978 [ 7.545846] systemd[1]: modprobe@configfs.service: Deactivated successfully.
2979 [ 7.547023] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
2980 [ 7.549690] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
2981 [ 7.550392] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
2982 [ 7.552720] systemd[1]: modprobe@drm.service: Deactivated successfully.
2983 [ 7.553388] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
2984 [ 7.562554] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
2985 [ 7.577023] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
2986 [ 7.578523] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
2987 [ 7.602460] systemd[1]: modprobe@fuse.service: Deactivated successfully.
2988 [ 7.624772] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
2989 [ 7.632528] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
2990 [ 7.633381] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
2991 [ 7.633393] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
2992 [ 7.633582] spidev spi1.1: Deleting spi1.1
2993 [ 7.634599] fbtft_device: GPIOS used by 'fb_st7735r':
2994 [ 7.634607] fbtft_device: 'reset' = GPIO73
2995 [ 7.634611] fbtft_device: 'dc' = GPIO70
2996 [ 7.634623] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
2997 [ 7.634629] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
2998 [ 7.638405] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
2999 [ 7.656012] systemd[1]: modprobe@loop.service: Deactivated successfully.
3000 [ 7.656785] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
3001 [ 7.659107] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
3002 [ 7.673950] WCN: marlin_init entry!
3003 [ 7.675259] WCN: marlin_parse_dt reset gpio=211
3004 [ 7.675269] WCN_ERR: gpio reset request err: 211
3005 [ 7.675274] WCN: wcn config bt wake host
3006 [ 7.675777] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
3007 [ 7.675923] WCN: wcn config wifi wake host
3008 [ 7.675946] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
3009 [ 7.679404] sdiohal:sdiohal_init ok
3010 [ 7.680423] WCN: marlin_probe ok!
3011 [ 7.689223] mtty_probe init device addr: 0xffffffc03b686f00
3012 [ 7.689416] -->rfkill_bluetooth_init
3013 [ 7.689618] <--rfkill_bluetooth_init
3014 [ 7.714683] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
3015 [ 7.720905] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
3016 [ 7.721982] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
3017 [ 7.732239] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
3018 [ 7.733223] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
3019 [ 7.741392] WCN: start_marlin [MARLIN_WIFI]
3020 [ 7.741412] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
3021 [ 7.741416] WCN: the first power on start
3022 [ 7.747227] systemd[1]: Starting systemd-sysusers.service - Create System Users...
3023 [ 7.768939] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
3024 [ 7.772395] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
3025 [ 7.802956] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
3026 [ 7.816492] systemd[1]: Finished systemd-sysusers.service - Create System Users.
3027 [ 7.845127] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
3028 [ 7.857896] WCN: marlin chip en pull up
3029 [ 7.884532] sdiohal:sdiohal_scan_card
3030 [ 7.884553] sunxi-wlan soc@03000000:wlan: bus_index: 1
3031 [ 7.884614] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
3032 [ 7.904468] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3033 [ 7.921956] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
3034 [ 7.922803] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
3035 [ 7.922920] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3036 [ 7.925453] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3037 [ 7.928540] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3038 [ 7.940265] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
3039 [ 7.942334] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
3040 [ 7.944519] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3041 [ 7.948376] systemd[1]: Mounting tmp.mount - /tmp...
3042 [ 7.957194] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
3043 [ 7.957973] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
3044 [ 7.958056] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
3045 [ 7.958670] mmc1: new ultra high speed SDR104 SDIO card at address 8800
3046 [ 7.959237] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
3047 [ 7.959428] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
3048 [ 7.959447] WCN: marlin_scan_finish!
3049 [ 7.959450] sdiohal:probe ok
3050 [ 7.959497] sdiohal:scan end!
3051 [ 7.959503] WCN: then marlin start to download
3052 [ 7.959525] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
3053 [ 7.980615] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
3054 [ 7.985643] systemd[1]: Mounted tmp.mount - /tmp.
3055 [ 7.988355] systemd[1]: Reached target local-fs.target - Local File Systems.
3056 [ 7.993461] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
3057 [ 7.998743] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
3058 [ 8.004337] systemd[1]: Starting console-setup.service - Set console font and keymap...
3059 [ 8.009607] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
3060 [ 8.020955] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
3061 [ 8.028067] systemd[1]: Starting ufw.service - Uncomplicated firewall...
3062 [ 8.031494] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
3063 [ 8.065241] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
3064 [ 8.077433] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
3065 [ 8.084326] systemd[1]: Finished console-setup.service - Set console font and keymap.
3066 [ 8.091032] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
3067 [ 8.097665] systemd[1]: Finished ufw.service - Uncomplicated firewall.
3068 [ 8.109390] WCN: combin_img 0 marlin_firmware_write finish and successful
3069 [ 8.109562] WCN: marlin_start_run read reset reg val:0x1
3070 [ 8.109566] WCN: after do marlin_start_run reset reg val:0x0
3071 [ 8.109773] WCN: s_marlin_bootup_time=8109768635
3072 [ 8.114785] WCN: clock mode: TSX
3073 [ 8.115021] WCN: marlin_write_cali_data sync init_state:0x1a0f50
3074 [ 8.141405] WCN: marlin_write_cali_data sync init_state:0x1a0f50
3075 [ 8.155222] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
3076 [ 8.157585] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
3077 [ 8.158802] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
3078 [ 8.162103] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
3079 [ 8.164954] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
3080 [ 8.165457] systemd[1]: Reached target network-pre.target - Preparation for Network.
3081 [ 8.168116] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
3082 [ 8.168126] WCN: sdio_config bt_wake_host trigger:[high]
3083 [ 8.168129] WCN: sdio_config irq:[inband]
3084 [ 8.168132] WCN: sdio_config wl_wake_host trigger:[high]
3085 [ 8.168138] WCN: sdio_config wake_host_level_duration_time:[20ms]
3086 [ 8.168142] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
3087 [ 8.168148] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
3088 [ 8.168533] WCN: marlin_write_cali_data finish
3089 [ 8.168740] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
3090 [ 8.194691] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
3091 [ 8.212239] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
3092 [ 8.221342] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
3093 [ 8.247979] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
3094 [ 8.274697] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
3095 [ 8.301395] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
3096 [ 8.301405] WCN: marlin_bind_verify confuse data: 0x8badefa1b12bbe26aeffa8d1a5c07
3097 [ 8.301421] WCN: marlin_bind_verify verify data: 0xccd7f963c19581907680f88f2044f687
3098 [ 8.301957] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
3099 [ 8.328091] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
3100 [ 8.328099] sdiohal:sdiohal_runtime_get entry
3101 [ 8.328272] WCN: get_cp2_version entry!
3102 [ 8.330032] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
3103 [ 8.330069] WCN: switch_cp2_log - close entry!
3104 [ 8.331459] WCN: WCND at cmd read:OK
3105 [ 8.331968] WCN: then marlin download finished and run ok
3106 [ 8.331979] WCN: start_loopcheck
3107 [ 8.345667] WCN: get_board_ant_num [one_ant]
3108 [ 8.345678] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
3109 [ 8.406865] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
3110 [ 8.412188] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
3111 [ 8.422605] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
3112 [ 8.473090] zram: Added device: zram0
3113 [ 8.474165] zram: Added device: zram1
3114 [ 8.475510] zram: Added device: zram2
3115 [ 8.511484] zswap: can't enable, initialization failed
3116 [ 8.512812] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
3117 [ 8.521326] systemd[1]: Starting networking.service - Raise network interfaces...
3118 [ 8.560988] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
3119 [ 8.574225] zram0: detected capacity change from 0 to 506396672
3120 [ 8.576780] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
3121 [ 8.650334] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
3122 [ 8.663742] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
3123 [ 8.666032] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
3124 [ 8.667282] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
3125 [ 8.667702] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
3126 [ 9.139019] systemd[1]: Finished networking.service - Raise network interfaces.
3127 [ 9.974376] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
3128 [ 10.034288] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
3129 [ 10.270974] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
3130 [ 10.719968] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
3131 [ 10.731951] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
3132 [ 10.797388] sunxi-bt soc@03000000:bt: set block: 0
3133 [ 10.820915] bluetooth_set_power: start_block=0
3134 [ 10.820927] WCN: start_marlin [MARLIN_BLUETOOTH]
3135 [ 10.820936] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
3136 [ 10.820941] WCN: marlin have open, GNSS is closed
3137 [ 10.820947] bluetooth_set_power: end_block=0
3138 [ 10.843784] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
3139 [ 10.959171] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
3140 [ 10.959468] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
3141 [ 10.960277] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
3142 [ 10.966890] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
3143 [ 10.974768] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
3144 [ 10.983934] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
3145 [ 10.992794] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
3146 [ 10.997628] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
3147 [ 10.998777] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
3148 [ 11.003515] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
3149 [ 11.004860] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
3150 [ 11.009415] systemd[1]: modprobe@loop.service: Deactivated successfully.
3151 [ 11.010418] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
3152 [ 11.013885] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
3153 [ 11.014193] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
3154 [ 11.051694] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
3155 [ 11.052227] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
3156 [ 11.068227] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
3157 [ 11.070263] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
3158 [ 11.076378] systemd[1]: Starting brltty.service - Braille Device Support...
3159 [ 11.622057] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
3160 [ 11.766120] zram1: detected capacity change from 0 to 52428800
3161 [ 11.821739] systemd[1]: Started brltty.service - Braille Device Support.
3162 [ 11.840742] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
3163 [ 15.854019] systemd[1]: systemd-rfkill.service: Deactivated successfully.
3164 [ 15.869877] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
3165 [ 15.898811] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
3166 [ 15.959002] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
3167 [ 19.658844] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
3168 [ 19.665165] systemd[1]: Starting systemd-journald.service - Journal Service...
3169 [ 19.940069] systemd-journald[1922]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
3170 [ 19.940091] systemd-journald[1922]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
3171 [ 19.947202] systemd[1]: Started systemd-journald.service - Journal Service.
3172 [ 19.993653] systemd-journald[1922]: Received client request to flush runtime journal.
3173 [ 20.245138] IPVS: Creating netns size=1928 id=1
3174
3175 ### armbian-release:
3176
3177 # PLEASE DO NOT EDIT THIS FILE
3178 BOARD=orangepizero2
3179 BOARD_NAME="Orange Pi Zero2"
3180 BOARDFAMILY=sun50iw9
3181 BUILD_REPOSITORY_URL=https://github.com/armbian/build
3182 BUILD_REPOSITORY_COMMIT=ac829eb6
3183 LINUXFAMILY=sun50iw9
3184 ARCH=arm64
3185 IMAGE_TYPE=stable
3186 BOARD_TYPE=conf
3187 INITRD_ARCH=arm
3188 KERNEL_IMAGE_TYPE=Image
3189 FORCE_BOOTSCRIPT_UPDATE=yes
3190 VENDOR=Armbian
3191 BOOTSCRIPT_FORCE_UPDATE="yes"
3192 BOOTSCRIPT_DST="boot.cmd"
3193 VERSION=23.8.1
3194 REVISION=23.8.1
3195 BRANCH=legacy
3196
3197 ### boot environment:
3198
3199 verbosity=1
3200 console=serial
3201 #disp_mode=1080p60
3202 #fb0_width=1280
3203 #fb0_height=720
3204 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
3205 rootfstype=ext4
3206 overlays=spi-spidev
3207 param_spidev_spi_bus=1
3208 param_spidev_spi_cs=1
3209 extraargs=fbcon=map:1
3210 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
3211
3212 ### lsusb:
3213
3214 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
3215 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
3216 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
3217 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
3218 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
3219 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
3220 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
3221
3222 ### lscpu:
3223
3224 Architecture: aarch64
3225 CPU op-mode(s): 32-bit, 64-bit
3226 Byte Order: Little Endian
3227 CPU(s): 4
3228 On-line CPU(s) list: 0-3
3229 Vendor ID: ARM
3230 Model name: Cortex-A53
3231 Model: 4
3232 Thread(s) per core: 1
3233 Core(s) per cluster: 4
3234 Socket(s): -
3235 Cluster(s): 1
3236 Stepping: r0p4
3237 CPU(s) scaling MHz: 100%
3238 CPU max MHz: 1512.0000
3239 CPU min MHz: 480.0000
3240 BogoMIPS: 48.00
3241 Flags: fp asimd aes pmull sha1 sha2 crc32
3242
3243 ### cpuinfo:
3244
3245 processor : 0
3246 BogoMIPS : 48.00
3247 Features : fp asimd aes pmull sha1 sha2 crc32
3248 CPU implementer : 0x41
3249 CPU architecture: 8
3250 CPU variant : 0x0
3251 CPU part : 0xd03
3252 CPU revision : 4
3253
3254 processor : 1
3255 BogoMIPS : 48.00
3256 Features : fp asimd aes pmull sha1 sha2 crc32
3257 CPU implementer : 0x41
3258 CPU architecture: 8
3259 CPU variant : 0x0
3260 CPU part : 0xd03
3261 CPU revision : 4
3262
3263 processor : 2
3264 BogoMIPS : 48.00
3265 Features : fp asimd aes pmull sha1 sha2 crc32
3266 CPU implementer : 0x41
3267 CPU architecture: 8
3268 CPU variant : 0x0
3269 CPU part : 0xd03
3270 CPU revision : 4
3271
3272 processor : 3
3273 BogoMIPS : 48.00
3274 Features : fp asimd aes pmull sha1 sha2 crc32
3275 CPU implementer : 0x41
3276 CPU architecture: 8
3277 CPU variant : 0x0
3278 CPU part : 0xd03
3279 CPU revision : 4
3280
3281
3282 ### meminfo:
3283
3284 MemTotal: 989056 kB
3285 MemFree: 794528 kB
3286 MemAvailable: 885284 kB
3287 Buffers: 15604 kB
3288 Cached: 82092 kB
3289 SwapCached: 0 kB
3290 Active: 66392 kB
3291 Inactive: 53084 kB
3292 Active(anon): 21848 kB
3293 Inactive(anon): 656 kB
3294 Active(file): 44544 kB
3295 Inactive(file): 52428 kB
3296 Unevictable: 0 kB
3297 Mlocked: 0 kB
3298 SwapTotal: 494524 kB
3299 SwapFree: 494524 kB
3300 Dirty: 6072 kB
3301 Writeback: 0 kB
3302 AnonPages: 21644 kB
3303 Mapped: 24364 kB
3304 Shmem: 824 kB
3305 Slab: 33156 kB
3306 SReclaimable: 9216 kB
3307 SUnreclaim: 23940 kB
3308 KernelStack: 2560 kB
3309 PageTables: 1032 kB
3310 NFS_Unstable: 0 kB
3311 Bounce: 0 kB
3312 WritebackTmp: 0 kB
3313 CommitLimit: 989052 kB
3314 Committed_AS: 77888 kB
3315 VmallocTotal: 263061440 kB
3316 VmallocUsed: 0 kB
3317 VmallocChunk: 0 kB
3318 CmaTotal: 16384 kB
3319 CmaFree: 7468 kB
3320 HugePages_Total: 0
3321 HugePages_Free: 0
3322 HugePages_Rsvd: 0
3323 HugePages_Surp: 0
3324 Hugepagesize: 2048 kB
3325
3326 ### virtual memory:
3327
3328 vm.admin_reserve_kbytes = 8192
3329 vm.block_dump = 0
3330 vm.compact_unevictable_allowed = 1
3331 vm.dirty_background_bytes = 0
3332 vm.dirty_background_ratio = 10
3333 vm.dirty_bytes = 0
3334 vm.dirty_expire_centisecs = 3000
3335 vm.dirty_ratio = 20
3336 vm.dirtytime_expire_seconds = 43200
3337 vm.dirty_writeback_centisecs = 500
3338 vm.extfrag_threshold = 500
3339 vm.extra_free_kbytes = 0
3340 vm.hugepages_treat_as_movable = 0
3341 vm.hugetlb_shm_group = 0
3342 vm.laptop_mode = 0
3343 vm.legacy_va_layout = 0
3344 vm.lowmem_reserve_ratio = 256 32
3345 vm.max_map_count = 65530
3346 vm.min_free_kbytes = 3937
3347 vm.mmap_min_addr = 4096
3348 vm.mmap_rnd_bits = 18
3349 vm.mmap_rnd_compat_bits = 11
3350 vm.nr_hugepages = 0
3351 vm.nr_overcommit_hugepages = 0
3352 vm.nr_pdflush_threads = 0
3353 vm.oom_dump_tasks = 1
3354 vm.oom_kill_allocating_task = 0
3355 vm.overcommit_kbytes = 0
3356 vm.overcommit_memory = 0
3357 vm.overcommit_ratio = 50
3358 vm.page-cluster = 0
3359 vm.panic_on_oom = 0
3360 vm.percpu_pagelist_fraction = 0
3361 vm.stat_interval = 1
3362 vm.swappiness = 100
3363 vm.user_reserve_kbytes = 29999
3364 vm.vfs_cache_pressure = 100
3365 vm.watermark_scale_factor = 10
3366
3367 ### ip addr:
3368
3369 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
3370 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
3371 inet XXX.XXX.0.1/8 scope host lo
3372 valid_lft forever preferred_lft forever
3373 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
3374 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
3375 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
3376 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
3377 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
3378 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
3379 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
3380 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
3381 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
3382 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
3383 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
3384 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
3385 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
3386 link/tunnel6 :: brd ::
3387 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
3388 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
3389 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
3390 link/tunnel6 :: brd ::
3391 11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
3392 link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
3393
3394 ### partitions:
3395
3396 major minor #blocks name
3397
3398 179 0 62410752 mmcblk0
3399 179 1 61763584 mmcblk0p1
3400 253 0 494528 zram0
3401 253 1 51200 zram1
3402
3403 ### df:
3404
3405 udev 466M 0 466M 0% /dev
3406 tmpfs 97M 884K 96M 1% /run
3407 /dev/mmcblk0p1 58G 5.7G 52G 10% /
3408 tmpfs 483M 0 483M 0% /dev/shm
3409 tmpfs 5.0M 0 5.0M 0% /run/lock
3410 tmpfs 483M 4.0K 483M 1% /tmp
3411 /dev/zram1 47M 5.8M 38M 14% /var/log
3412
3413 ### lsblk:
3414
3415 NAME FSTYPE SIZE MOUNTPOINT UUID
3416 mmcblk0 59.5G
3417 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
3418 zram1 50M /var/log
3419 zram2 0B
3420
3421 ### zramctl:
3422
3423 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
3424 /dev/zram1 lz4 50M 5.6M 1.6M 2M 4 /var/log
3425 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
3426
3427 ### mtab:
3428
3429 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
3430 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
3431 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
3432
3433 ### mmc0:0001 info:
3434
3435 manfid: 0x0000fe
3436 cid: fe3432534431364720000000690091f5
3437 fwrev: 0x0
3438 csd: 400e00325b590001dc277f800a40008b
3439 ocr: 0x00200000
3440 type: SD
3441 date: 01/2009
3442 hwrev: 0x2
3443 dsr: 0x404
3444 serial: 0x00000069
3445 erase_size: 512
3446 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
3447 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
3448 scr: 0285808300000000
3449 oemid: 0x3432
3450 preferred_erase_size: 4194304
3451 name: SD16G
3452
3453 ### Boot system health:
3454
3455 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
3456 12:17:55 1512 MHz 1.17 39% 19% 13% 0% 6% 0% 50.2 °C 0/5
3457 12:17:55 1512 MHz 1.17 92% 22% 22% 2% 45% 0% 50.2 °C 0/5
3458 12:17:56 1512 MHz 1.17 99% 40% 53% 1% 3% 0% 50.2 °C 0/5
3459 12:17:56 1512 MHz 1.17 100% 33% 59% 1% 5% 0% 49.4 °C 0/5
3460 12:17:57 1512 MHz 1.17 92% 23% 28% 0% 38% 0% 49.4 °C 0/5
3461
3462 ### Activated 1 lzo zram swap devices with 482MB each.
3463 ### Activated Armbian ramlog partition with lz4 compression
3464
3465 ### Activated 1 lzo zram swap devices with 482MB each.
3466 ### Activated Armbian ramlog partition with lz4 compression
3467
3468 Mon Sep 25 02:17:34 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
3469
3470 ### dmesg:
3471
3472 [ 0.000000] Booting Linux on physical CPU 0x0
3473 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
3474 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
3475 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
3476 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
3477 [ 0.000000] On node 0 totalpages: 262144
3478 [ 0.000000] DMA zone: 4096 pages used for memmap
3479 [ 0.000000] DMA zone: 0 pages reserved
3480 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
3481 [ 0.000000] psci: probing for conduit method from DT.
3482 [ 0.000000] psci: PSCIv1.0 detected in firmware.
3483 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
3484 [ 0.000000] psci: Trusted OS migration not required
3485 [ 0.000000] psci: SMC Calling Convention v1.0
3486 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
3487 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
3488 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
3489 [ 0.000000] Detected VIPT I-cache on CPU0
3490 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
3491 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
3492 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
3493 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
3494 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
3495 [ 0.000000] log_buf_len min size: 131072 bytes
3496 [ 0.000000] log_buf_len: 524288 bytes
3497 [ 0.000000] early log buf free: 129352(98%)
3498 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
3499 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
3500 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
3501 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
3502 [ 0.000000] Virtual kernel memory layout:
3503 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
3504 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
3505 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
3506 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
3507 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
3508 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
3509 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
3510 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
3511 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
3512 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
3513 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
3514 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
3515 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
3516 [ 0.000000] Preemptible hierarchical RCU implementation.
3517 [ 0.000000] Build-time adjustment of leaf fanout to 64.
3518 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
3519 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
3520 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
3521 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
3522 [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
3523 [ 0.000223] Console: colour dummy device 80x25
3524 [ 0.000237] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
3525 [ 0.000245] pid_max: default: 32768 minimum: 301
3526 [ 0.000441] Security Framework initialized
3527 [ 0.000449] AppArmor: AppArmor disabled by boot time parameter
3528 [ 0.000563] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
3529 [ 0.000569] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
3530 [ 0.001849] sched-energy: CPU device node has no sched-energy-costs
3531 [ 0.001863] Invalid sched_group_energy for CPU0
3532 [ 0.001871] CPU0: update cpu_capacity 1024
3533 [ 0.008959] ASID allocator initialised with 32768 entries
3534 [ 0.027939] BOOTEVENT: 27.924665: ON
3535 [ 0.055908] Detected VIPT I-cache on CPU1
3536 [ 0.055961] Invalid sched_group_energy for CPU1
3537 [ 0.055964] CPU1: update cpu_capacity 1024
3538 [ 0.055967] CPU1: Booted secondary processor [410fd034]
3539 [ 0.079292] Detected VIPT I-cache on CPU2
3540 [ 0.079328] Invalid sched_group_energy for CPU2
3541 [ 0.079331] CPU2: update cpu_capacity 1024
3542 [ 0.079334] CPU2: Booted secondary processor [410fd034]
3543 [ 0.102694] Detected VIPT I-cache on CPU3
3544 [ 0.102727] Invalid sched_group_energy for CPU3
3545 [ 0.102731] CPU3: update cpu_capacity 1024
3546 [ 0.102733] CPU3: Booted secondary processor [410fd034]
3547 [ 0.102813] Brought up 4 CPUs
3548 [ 0.102821] SMP: Total of 4 processors activated.
3549 [ 0.102829] CPU features: detected feature: 32-bit EL0 Support
3550 [ 0.102835] CPU features: detected feature: Kernel page table isolation (KPTI)
3551 [ 0.106604] CPU: All CPU(s) started at EL1
3552 [ 0.106626] alternatives: patching kernel code
3553 [ 0.106803] Invalid sched_group_energy for CPU3
3554 [ 0.106813] CPU3: update max cpu_capacity 1024
3555 [ 0.106818] Invalid sched_group_energy for Cluster3
3556 [ 0.106823] Invalid sched_group_energy for CPU2
3557 [ 0.106829] Invalid sched_group_energy for Cluster2
3558 [ 0.106834] Invalid sched_group_energy for CPU1
3559 [ 0.106840] Invalid sched_group_energy for Cluster1
3560 [ 0.106845] Invalid sched_group_energy for CPU0
3561 [ 0.106850] Invalid sched_group_energy for Cluster0
3562 [ 0.108277] devtmpfs: initialized
3563 [ 0.112711] CPU1: update max cpu_capacity 1024
3564 [ 0.143411] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
3565 [ 0.143432] futex hash table entries: 1024 (order: 5, 131072 bytes)
3566 [ 0.144088] xor: measuring software checksum speed
3567 [ 0.176249] 8regs : 1933.200 MB/sec
3568 [ 0.209628] 8regs_prefetch: 1720.800 MB/sec
3569 [ 0.243016] 32regs : 2287.200 MB/sec
3570 [ 0.276403] 32regs_prefetch: 1935.600 MB/sec
3571 [ 0.276409] xor: using function: 32regs (2287.200 MB/sec)
3572 [ 0.276469] atomic64_test: passed
3573 [ 0.276476] pinctrl core: initialized pinctrl subsystem
3574 [ 0.277649] NET: Registered protocol family 16
3575 [ 0.278817] dump_class_init,861, success
3576 [ 0.293122] cpuidle: using governor menu
3577 [ 0.294524] sunxi iommu: irq = 8
3578 [ 0.294861] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
3579 [ 0.294879] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
3580 [ 0.296271] DMA: preallocated 256 KiB pool for atomic allocations
3581 [ 0.297666] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
3582 [ 0.312044] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
3583 [ 0.316075] iommu: Adding device 1c0e000.ve to group 0
3584 [ 0.316634] iommu: Adding device 1c00000.vp9 to group 0
3585 [ 0.328200] iommu: Adding device 1000000.disp to group 0
3586 [ 0.329618] iommu: Adding device 1480000.g2d to group 0
3587 [ 0.332832] iommu: Adding device csi0 to group 0
3588 [ 0.333308] iommu: Adding device csi1 to group 0
3589 [ 0.334535] iommu: Adding device 6600800.vind:scaler@0 to group 0
3590 [ 0.334833] iommu: Adding device 6600800.vind:scaler@1 to group 0
3591 [ 0.335141] iommu: Adding device 6600800.vind:scaler@2 to group 0
3592 [ 0.335436] iommu: Adding device 6600800.vind:scaler@3 to group 0
3593 [ 0.335725] iommu: Adding device 6600800.vind:scaler@4 to group 0
3594 [ 0.336009] iommu: Adding device 6600800.vind:scaler@5 to group 0
3595 [ 0.337039] iommu: Adding device vinc0 to group 0
3596 [ 0.337542] iommu: Adding device vinc1 to group 0
3597 [ 0.338994] iommu: Adding device 1420000.deinterlace to group 0
3598 [ 0.377854] HugeTLB registered 2 MB page size, pre-allocated 0 pages
3599 [ 0.433963] raid6: int64x1 gen() 391 MB/s
3600 [ 0.490701] raid6: int64x1 xor() 365 MB/s
3601 [ 0.547455] raid6: int64x2 gen() 591 MB/s
3602 [ 0.604205] raid6: int64x2 xor() 512 MB/s
3603 [ 0.660963] raid6: int64x4 gen() 840 MB/s
3604 [ 0.717685] raid6: int64x4 xor() 629 MB/s
3605 [ 0.774389] raid6: int64x8 gen() 964 MB/s
3606 [ 0.831166] raid6: int64x8 xor() 655 MB/s
3607 [ 0.887951] raid6: neonx1 gen() 648 MB/s
3608 [ 0.944646] raid6: neonx1 xor() 641 MB/s
3609 [ 1.001423] raid6: neonx2 gen() 976 MB/s
3610 [ 1.058128] raid6: neonx2 xor() 819 MB/s
3611 [ 1.114888] raid6: neonx4 gen() 1287 MB/s
3612 [ 1.171618] raid6: neonx4 xor() 965 MB/s
3613 [ 1.228373] raid6: neonx8 gen() 1323 MB/s
3614 [ 1.285089] raid6: neonx8 xor() 991 MB/s
3615 [ 1.285094] raid6: using algorithm neonx8 gen() 1323 MB/s
3616 [ 1.285099] raid6: .... xor() 991 MB/s, rmw enabled
3617 [ 1.285104] raid6: using intx1 recovery algorithm
3618 [ 1.285271] pwm module init!
3619 [ 1.289618] sunxi-pm debug v3.10
3620 [ 1.290703] SCSI subsystem initialized
3621 [ 1.291325] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
3622 [ 1.291408] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
3623 [ 1.291528] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
3624 [ 1.292011] spi spi0: master is unqueued, this is deprecated
3625 [ 1.292319] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
3626 [ 1.292903] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
3627 [ 1.292982] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
3628 [ 1.293098] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
3629 [ 1.293547] spi spi1: master is unqueued, this is deprecated
3630 [ 1.293854] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
3631 [ 1.294585] usbcore: registered new interface driver usbfs
3632 [ 1.294684] usbcore: registered new interface driver hub
3633 [ 1.294763] usbcore: registered new device driver usb
3634 [ 1.295046] sunxi_i2c_adap_init()2522 - init
3635 [ 1.295603] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
3636 [ 1.295695] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
3637 [ 1.295702] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
3638 [ 1.295717] twi3 supply twi not found, using dummy regulator
3639 [ 1.295792] twi_request_gpio()451 - [i2c3] init name: twi3
3640 [ 1.296525] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
3641 [ 1.296604] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
3642 [ 1.296611] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
3643 [ 1.296625] twi5 supply twi not found, using dummy regulator
3644 [ 1.296702] twi_request_gpio()451 - [i2c5] init name: twi5
3645 [ 1.297164] axp20x-i2c 5-0036: AXP20x variant AXP806 found
3646 [ 1.310180] axp806-aldo2: Bringing 700000uV into 3300000-3300000uV
3647 [ 1.313858] axp806-aldo3: Bringing 700000uV into 3300000-3300000uV
3648 [ 1.315058] random: fast init done
3649 [ 1.330654] axp20x-i2c 5-0036: AXP20X driver loaded
3650 [ 1.331139] media: Linux media interface: v0.10
3651 [ 1.331217] Linux video capture interface: v2.00
3652 [ 1.332015] Advanced Linux Sound Architecture Driver Initialized.
3653 [ 1.332808] Bluetooth: Core ver 2.22
3654 [ 1.332882] NET: Registered protocol family 31
3655 [ 1.332888] Bluetooth: HCI device and connection manager initialized
3656 [ 1.332906] Bluetooth: HCI socket layer initialized
3657 [ 1.332919] Bluetooth: L2CAP socket layer initialized
3658 [ 1.332958] Bluetooth: SCO socket layer initialized
3659 [ 1.333781] [DISP]disp_module_init
3660 [ 1.335074] [DISP] parser_disp_init_para,line:1403:
3661 [ 1.335083] of_property_read fb0_width fail
3662 [ 1.335094] [DISP] disp_init,line:2215:
3663 [ 1.335100] smooth display screen:0 type:4 mode:10
3664 [ 1.352552] [DISP]disp_module_init finish
3665 [ 1.353418] clocksource: Switched to clocksource arch_sys_counter
3666 [ 1.353675] VFS: Disk quotas dquot_6.6.0
3667 [ 1.353767] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
3668 [ 1.354501] Console: switching to colour frame buffer device 240x67
3669 [ 1.397742] NET: Registered protocol family 2
3670 [ 1.397862] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
3671 [ 1.417007] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
3672 [ 1.417080] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
3673 [ 1.417203] TCP: Hash tables configured (established 8192 bind 8192)
3674 [ 1.417289] UDP hash table entries: 512 (order: 2, 16384 bytes)
3675 [ 1.417318] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
3676 [ 1.417641] NET: Registered protocol family 1
3677 [ 1.418269] RPC: Registered named UNIX socket transport module.
3678 [ 1.418274] RPC: Registered udp transport module.
3679 [ 1.418277] RPC: Registered tcp transport module.
3680 [ 1.418281] RPC: Registered tcp NFSv4.1 backchannel transport module.
3681 [ 1.418556] Trying to unpack rootfs image as initramfs...
3682 [ 2.173216] Freeing initrd memory: 17256K
3683 [ 2.174337] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
3684 [ 2.178251] audit: initializing netlink subsys (disabled)
3685 [ 2.178333] audit: type=2000 audit(2.173:1): initialized
3686 [ 2.179242] workingset: timestamp_bits=45 max_order=18 bucket_order=0
3687 [ 2.190594] DLM installed
3688 [ 2.192418] squashfs: version 4.0 (2009/01/31) Phillip Lougher
3689 [ 2.192757] Registering sdcardfs 0.1
3690 [ 2.193223] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
3691 [ 2.194880] ntfs: driver 2.1.32 [Flags: R/W].
3692 [ 2.201328] NET: Registered protocol family 38
3693 [ 2.201686] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
3694 [ 2.201804] io scheduler noop registered
3695 [ 2.201811] io scheduler deadline registered
3696 [ 2.201970] io scheduler cfq registered (default)
3697 [ 2.203899] failed to get easy_light_used assign
3698 [ 2.203911] failed to get normal led pin assign
3699 [ 2.203916] failed to get standby led pin assign
3700 [ 2.203921] failed to get standby led pin assign
3701 [ 2.203926] these is zero number for gpio
3702 [ 2.203930] gpio_init finish with uesd
3703 [ 2.207432] uart uart0: get regulator failed
3704 [ 2.207645] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
3705 [ 2.207668] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
3706 [ 2.207762] console [ttyS0] enabled
3707 [ 2.208572] uart uart1: get regulator failed
3708 [ 2.208760] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
3709 [ 2.209477] uart uart5: get regulator failed
3710 [ 2.209658] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
3711 [ 2.210972] misc dump reg init
3712 [ 2.212103] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
3713 [ 2.212441] Unable to detect cache hierarchy for CPU 0
3714 [ 2.226536] brd: module loaded
3715 [ 2.234698] loop: module loaded
3716 [ 2.234889] [NAND][NE] Not found valid nand node on dts
3717 [ 2.235466] Get boot type cmd line fail
3718 [ 2.236050] sunxi-bt soc@03000000:bt: Missing bt_power.
3719 [ 2.236060] sunxi-bt soc@03000000:bt: bt_power_name ((null))
3720 [ 2.236067] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
3721 [ 2.236074] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
3722 [ 2.236132] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
3723 [ 2.236205] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
3724 [ 2.237089] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
3725 [ 2.237100] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
3726 [ 2.237108] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
3727 [ 2.237116] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
3728 [ 2.237123] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
3729 [ 2.237151] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
3730 [ 2.237185] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
3731 [ 2.237194] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
3732 [ 2.237211] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
3733 [ 2.238161] [ADDR_MGT] addr_mgt_probe: success.
3734 [ 2.244758] tun: Universal TUN/TAP device driver, 1.6
3735 [ 2.244768] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
3736 [ 2.246839] gmac-power0: NULL
3737 [ 2.246850] gmac-power1: NULL
3738 [ 2.246856] gmac-power2: NULL
3739 [ 2.247778] PPP generic driver version 2.4.2
3740 [ 2.248063] PPP BSD Compression module registered
3741 [ 2.248073] PPP Deflate Compression module registered
3742 [ 2.248100] PPP MPPE Compression module registered
3743 [ 2.248109] NET: Registered protocol family 24
3744 [ 2.248143] PPTP driver version 0.8.5
3745 [ 2.248502] usbcore: registered new interface driver r8152
3746 [ 2.248585] usbcore: registered new interface driver asix
3747 [ 2.248683] usbcore: registered new interface driver ax88179_178a
3748 [ 2.248751] usbcore: registered new interface driver cdc_ether
3749 [ 2.248820] usbcore: registered new interface driver net1080
3750 [ 2.248880] usbcore: registered new interface driver cdc_subset
3751 [ 2.248942] usbcore: registered new interface driver zaurus
3752 [ 2.249035] usbcore: registered new interface driver cdc_ncm
3753 [ 2.249042] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
3754 [ 2.249397] get drv_vbus is fail, 84
3755 [ 2.249405] get ehci0-controller, regulator_io is no nocare
3756 [ 2.249677] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
3757 [ 2.249682] [sunxi-ehci0]: Not init ehci0
3758 [ 2.249797] get ehci1-controller, regulator_io is no nocare
3759 [ 2.249973] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
3760 [ 2.250030] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
3761 [ 2.250057] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
3762 [ 2.250724] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
3763 [ 2.263435] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
3764 [ 2.263740] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
3765 [ 2.263749] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
3766 [ 2.263756] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
3767 [ 2.263764] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
3768 [ 2.263770] usb usb1: SerialNumber: sunxi-ehci
3769 [ 2.264681] hub 1-0:1.0: USB hub found
3770 [ 2.264732] hub 1-0:1.0: 1 port detected
3771 [ 2.265411] get drv_vbus is fail, 84
3772 [ 2.265419] get ehci2-controller, regulator_io is no nocare
3773 [ 2.265664] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
3774 [ 2.265715] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
3775 [ 2.265740] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
3776 [ 2.266053] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
3777 [ 2.276778] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
3778 [ 2.276987] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
3779 [ 2.276996] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
3780 [ 2.277004] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
3781 [ 2.277011] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
3782 [ 2.277018] usb usb2: SerialNumber: sunxi-ehci
3783 [ 2.277863] hub 2-0:1.0: USB hub found
3784 [ 2.277909] hub 2-0:1.0: 1 port detected
3785 [ 2.278579] get drv_vbus is fail, 84
3786 [ 2.278587] get ehci3-controller, regulator_io is no nocare
3787 [ 2.278830] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
3788 [ 2.278881] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
3789 [ 2.278906] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
3790 [ 2.279195] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
3791 [ 2.290095] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
3792 [ 2.290315] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
3793 [ 2.290324] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
3794 [ 2.290332] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
3795 [ 2.290339] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
3796 [ 2.290346] usb usb3: SerialNumber: sunxi-ehci
3797 [ 2.291181] hub 3-0:1.0: USB hub found
3798 [ 2.291223] hub 3-0:1.0: 1 port detected
3799 [ 2.292140] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
3800 [ 2.292518] get drv_vbus is fail, 84
3801 [ 2.292526] get ohci0-controller, regulator_io is no nocare
3802 [ 2.292859] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
3803 [ 2.292865] [sunxi-ohci0]: Not init ohci0
3804 [ 2.292978] get ohci1-controller, regulator_io is no nocare
3805 [ 2.293134] hci: request ohci1-controller gpio:80
3806 [ 2.293209] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
3807 [ 2.293258] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
3808 [ 2.293284] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
3809 [ 2.293362] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
3810 [ 2.354289] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
3811 [ 2.354300] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
3812 [ 2.354308] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
3813 [ 2.354315] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
3814 [ 2.354322] usb usb4: SerialNumber: sunxi-ohci
3815 [ 2.355199] hub 4-0:1.0: USB hub found
3816 [ 2.355247] hub 4-0:1.0: 1 port detected
3817 [ 2.355924] get drv_vbus is fail, 84
3818 [ 2.355933] get ohci2-controller, regulator_io is no nocare
3819 [ 2.356264] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
3820 [ 2.356314] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
3821 [ 2.356346] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
3822 [ 2.356424] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
3823 [ 2.414263] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
3824 [ 2.414273] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
3825 [ 2.414281] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
3826 [ 2.414288] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
3827 [ 2.414295] usb usb5: SerialNumber: sunxi-ohci
3828 [ 2.415160] hub 5-0:1.0: USB hub found
3829 [ 2.415205] hub 5-0:1.0: 1 port detected
3830 [ 2.415902] get drv_vbus is fail, 84
3831 [ 2.415911] get ohci3-controller, regulator_io is no nocare
3832 [ 2.416242] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
3833 [ 2.416292] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
3834 [ 2.416319] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
3835 [ 2.416395] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
3836 [ 2.474264] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
3837 [ 2.474275] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
3838 [ 2.474283] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
3839 [ 2.474290] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
3840 [ 2.474297] usb usb6: SerialNumber: sunxi-ohci
3841 [ 2.475152] hub 6-0:1.0: USB hub found
3842 [ 2.475202] hub 6-0:1.0: 1 port detected
3843 [ 2.476122] ohci-platform: OHCI generic platform driver
3844 [ 2.476901] usbcore: registered new interface driver uas
3845 [ 2.477073] usbcore: registered new interface driver usb-storage
3846 [ 2.477158] usbcore: registered new interface driver ums-alauda
3847 [ 2.477252] usbcore: registered new interface driver ums-cypress
3848 [ 2.477331] usbcore: registered new interface driver ums-datafab
3849 [ 2.477404] usbcore: registered new interface driver ums_eneub6250
3850 [ 2.477476] usbcore: registered new interface driver ums-freecom
3851 [ 2.477550] usbcore: registered new interface driver ums-isd200
3852 [ 2.477619] usbcore: registered new interface driver ums-jumpshot
3853 [ 2.477690] usbcore: registered new interface driver ums-karma
3854 [ 2.477764] usbcore: registered new interface driver ums-onetouch
3855 [ 2.477863] usbcore: registered new interface driver ums-realtek
3856 [ 2.477942] usbcore: registered new interface driver ums-sddr09
3857 [ 2.478011] usbcore: registered new interface driver ums-sddr55
3858 [ 2.478083] usbcore: registered new interface driver ums-usbat
3859 [ 2.478230] usb_serial_number:20080411
3860 [ 2.479464] input: sunxi-keyboard as /devices/virtual/input/input0
3861 [ 2.480122] usbcore: registered new interface driver xpad
3862 [ 2.480243] usbcore: registered new interface driver usb_acecad
3863 [ 2.480331] usbcore: registered new interface driver aiptek
3864 [ 2.480421] usbcore: registered new interface driver gtco
3865 [ 2.480501] usbcore: registered new interface driver hanwang
3866 [ 2.480579] usbcore: registered new interface driver kbtab
3867 [ 2.481065] axp2101_pek: axp2101-pek can not register without irq
3868 [ 2.481088] axp2101-pek: probe of axp2101-pek.0 failed with error -22
3869 [ 2.482496] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
3870 [ 2.482563] sunxi-rtc rtc: RTC enabled
3871 [ 2.483043] i2c /dev entries driver
3872 [ 2.483871] lirc_dev: IR Remote Control driver registered, major 244
3873 [ 2.483882] IR NEC protocol handler initialized
3874 [ 2.483888] IR RC5(x/sz) protocol handler initialized
3875 [ 2.483894] IR RC6 protocol handler initialized
3876 [ 2.483900] IR JVC protocol handler initialized
3877 [ 2.483905] IR Sony protocol handler initialized
3878 [ 2.483911] IR SANYO protocol handler initialized
3879 [ 2.483917] IR Sharp protocol handler initialized
3880 [ 2.483923] IR MCE Keyboard/mouse protocol handler initialized
3881 [ 2.483928] IR LIRC bridge handler initialized
3882 [ 2.483934] IR XMP protocol handler initialized
3883 [ 2.484454] sunxi_ir_startup: get ir protocol failed
3884 [ 2.484497] 7040000.s_cir supply ir0 not found, using dummy regulator
3885 [ 2.484692] Registered IR keymap rc_map_sunxi
3886 [ 2.485095] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
3887 [ 2.485338] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
3888 [ 2.486311] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
3889 [ 2.486942] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
3890 [ 2.487670] sunxi cedar version 0.1
3891 [ 2.487858] VE: install start!!!
3892
3893 [ 2.488044] cedar_ve: cedar-ve the get irq is 278
3894 [ 2.488650] VE: get debugfs_mpp_root is NULL, please check mpp
3895
3896 [ 2.488660] VE: sunxi ve debug register driver failed!
3897
3898 [ 2.491889] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
3899 [ 2.493179] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
3900 [ 2.493547] Bluetooth: HCI UART driver ver 2.3
3901 [ 2.493558] Bluetooth: HCI UART protocol H4 registered
3902 [ 2.493563] Bluetooth: HCI UART protocol LL registered
3903 [ 2.493569] Bluetooth: HCI UART protocol Three-wire (H5) registered
3904 [ 2.497768] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
3905 [ 2.497783] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
3906 [ 2.497796] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
3907 [ 2.497808] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
3908 [ 2.497820] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
3909 [ 2.497832] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
3910 [ 2.498249] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
3911 [ 2.498364] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
3912 [ 2.498560] sunxi-mmc sdc0: No vmmc regulator found
3913 [ 2.498567] sunxi-mmc sdc0: No vqmmc regulator found
3914 [ 2.498573] sunxi-mmc sdc0: No vdmmc regulator found
3915 [ 2.498580] sunxi-mmc sdc0: No vd33sw regulator found
3916 [ 2.498586] sunxi-mmc sdc0: No vd18sw regulator found
3917 [ 2.498592] sunxi-mmc sdc0: No vq33sw regulator found
3918 [ 2.498598] sunxi-mmc sdc0: No vq18sw regulator found
3919 [ 2.499326] sunxi-mmc sdc0: set host busy
3920 [ 2.499426] sunxi-mmc sdc0: Got CD GPIO
3921 [ 2.499813] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
3922 [ 2.499850] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
3923 [ 2.516764] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3924 [ 2.533806] sunxi-mmc sdc0: detmode:gpio irq
3925 [ 2.533839] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3926 [ 2.536344] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3927 [ 2.537075] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
3928 [ 2.537176] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
3929 [ 2.537314] sunxi-mmc sdc1: No vmmc regulator found
3930 [ 2.537321] sunxi-mmc sdc1: No vqmmc regulator found
3931 [ 2.537327] sunxi-mmc sdc1: No vdmmc regulator found
3932 [ 2.537334] sunxi-mmc sdc1: No vd33sw regulator found
3933 [ 2.537340] sunxi-mmc sdc1: No vd18sw regulator found
3934 [ 2.537346] sunxi-mmc sdc1: No vq33sw regulator found
3935 [ 2.537352] sunxi-mmc sdc1: No vq18sw regulator found
3936 [ 2.537991] sunxi-mmc sdc1: set host busy
3937 [ 2.538076] mmc:failed to get gpios
3938 [ 2.538370] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
3939 [ 2.538666] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3940 [ 2.541218] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3941 [ 2.553490] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3942 [ 2.558774] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3943 [ 2.558814] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
3944 [ 2.570101] sunxi-mmc sdc1: detmode:manually by software
3945 [ 2.570939] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
3946 [ 2.571786] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
3947 [ 2.571829] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3948 [ 2.573470] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3949 [ 2.574340] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
3950 [ 2.575452] ledtrig-cpu: registered to indicate activity on CPUs
3951 [ 2.576225] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
3952 [ 2.577065] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
3953 [ 2.577910] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
3954 [ 2.578743] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
3955 [ 2.578780] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
3956 [ 2.581383] mmc0: host does not support reading read-only switch, assuming write-enable
3957 [ 2.581747] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
3958 [ 2.581754] sunxi_emce_probe()590emce hw init failed!
3959 [ 2.581781] emce: probe of emce failed with error -2
3960 [ 2.582055] hidraw: raw HID events driver (C) Jiri Kosina
3961 [ 2.582071] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
3962 [ 2.583133] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
3963 [ 2.583288] sunxi-mmc sdc0: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
3964 [ 2.583498] mmc0: new ultra high speed SDR104 SDXC card at address 0001
3965 [ 2.584650] mmcblk0: mmc0:0001 SD16G 59.5 GiB
3966 [ 2.586287] mmcblk0: p1
3967 [ 2.588546] usbcore: registered new interface driver usbhid
3968 [ 2.588555] usbhid: USB HID core driver
3969 [ 2.589976] optee: probing for conduit method from DT.
3970 [ 2.589990] optee: api uid mismatch
3971 [ 2.590582] usbcore: registered new interface driver snd-usb-audio
3972 [ 2.592188] [sunxi_hdmi_codec_init] driver and deivce register finished.
3973 [ 2.593979] [sunxi_internal_codec_probe]:get audio avcc failed
3974 [ 2.594019] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
3975 [ 2.594256] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
3976 [ 2.596798] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
3977 [ 2.598699] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
3978 [ 2.598712] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
3979 [ 2.600998] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
3980 [ 2.601022] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
3981 [ 2.605039] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
3982 [ 2.606425] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
3983 [ 2.608467] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
3984 [ 2.611539] pktgen: Packet Generator for packet performance testing. Version: 2.75
3985 [ 2.611969] u32 classifier
3986 [ 2.611976] Actions configured
3987 [ 2.611988] Netfilter messages via NETLINK v0.30.
3988 [ 2.612017] nfnl_acct: registering with nfnetlink.
3989 [ 2.612355] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
3990 [ 2.612612] ctnetlink v0.93: registering with nfnetlink.
3991 [ 2.613365] xt_time: kernel timezone is -0000
3992 [ 2.613388] IPVS: Registered protocols (TCP, UDP)
3993 [ 2.613601] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
3994 [ 2.613739] IPVS: Creating netns size=1928 id=0
3995 [ 2.613881] IPVS: ipvs loaded.
3996 [ 2.613890] IPVS: [rr] scheduler registered.
3997 [ 2.613990] ipip: IPv4 and MPLS over IPv4 tunneling driver
3998 [ 2.614729] gre: GRE over IPv4 demultiplexor driver
3999 [ 2.614738] ip_gre: GRE over IPv4 tunneling driver
4000 [ 2.616062] IPv4 over IPsec tunneling driver
4001 [ 2.616986] ip_tables: (C) 2000-2006 Netfilter Core Team
4002 [ 2.617288] arp_tables: arp_tables: (C) 2002 David S. Miller
4003 [ 2.617354] Initializing XFRM netlink socket
4004 [ 2.617387] IPsec XFRM device driver
4005 [ 2.618249] NET: Registered protocol family 10
4006 [ 2.620158] mip6: Mobile IPv6
4007 [ 2.620199] ip6_tables: (C) 2000-2006 Netfilter Core Team
4008 [ 2.621525] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
4009 [ 2.623174] NET: Registered protocol family 17
4010 [ 2.623215] NET: Registered protocol family 15
4011 [ 2.623379] Bridge firewalling registered
4012 [ 2.623597] Bluetooth: RFCOMM TTY layer initialized
4013 [ 2.623616] Bluetooth: RFCOMM socket layer initialized
4014 [ 2.623649] Bluetooth: RFCOMM ver 1.11
4015 [ 2.623663] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
4016 [ 2.623669] Bluetooth: BNEP filters: protocol multicast
4017 [ 2.623682] Bluetooth: BNEP socket layer initialized
4018 [ 2.623688] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
4019 [ 2.623700] Bluetooth: HIDP socket layer initialized
4020 [ 2.623787] l2tp_core: L2TP core driver, V2.0
4021 [ 2.623803] l2tp_ppp: PPPoL2TP kernel driver, V2.0
4022 [ 2.623809] 8021q: 802.1Q VLAN Support v1.8
4023 [ 2.624029] sctp: Hash tables configured (bind 256/256)
4024 [ 2.624619] Key type dns_resolver registered
4025 [ 2.624759] Registered cp15_barrier emulation handler
4026 [ 2.624775] Registered setend emulation handler
4027 [ 2.625732] registered taskstats version 1
4028 [ 2.637412] zswap: default zpool zbud not available
4029 [ 2.637420] zswap: pool creation failed
4030 [ 2.640238] Btrfs loaded, crc32c=crc32c-arm64-hw
4031 [ 2.640984] HDMI 2.0 driver init start!
4032 [ 2.640999] boot_hdmi=true
4033 [ 2.641888] Can not find the node of esm
4034 [ 2.641910] ERROR: pinctrl_get for HDMI2.0 DDC fail
4035 [ 2.642000] Get hdmi_power0:vcc-hdmi
4036 [ 2.642039] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
4037 [ 2.642213] Get hdmi_power1:vdd-hdmi
4038 [ 2.642235] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
4039 [ 2.643781] hdmi_cec_init
4040 [ 2.644253] [DISP] disp_device_attached,line:146:
4041 [ 2.644263] attached ok, mgr0<-->device0, type=4
4042 [ 2.644273] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
4043 [ 2.644286] [DISP] disp_hdmi_set_mode,line:648:
4044 [ 2.644291] hdmi_set_mode is null!
4045 [ 2.646282] HDMI2.0 module init end
4046 [ 2.657625] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
4047 [ 2.661018] cpu cpu1: opp_list_debug_create_link: Failed to create link
4048 [ 2.661029] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
4049 [ 2.661062] cpu cpu2: opp_list_debug_create_link: Failed to create link
4050 [ 2.661069] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
4051 [ 2.661099] cpu cpu3: opp_list_debug_create_link: Failed to create link
4052 [ 2.661106] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
4053 [ 2.663372] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
4054 [ 2.664357] get det_vbus is fail, 84
4055 [ 2.664364] get id is fail, 84
4056 [ 2.664853] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:08 UTC (8)
4057 [ 2.666258] axp806-dcdcb: disabling
4058 [ 2.668244] axp806-cldo1: disabling
4059 [ 2.669878] ALSA device list:
4060 [ 2.669883] #0: audiocodec
4061 [ 2.669887] #1: sndahub
4062 [ 2.669890] #2: sndhdmi
4063 [ 2.671549] Freeing unused kernel memory: 3008K
4064 [ 2.716878] random: systemd-udevd: uninitialized urandom read (16 bytes read)
4065 [ 2.718849] random: systemd-udevd: uninitialized urandom read (16 bytes read)
4066 [ 2.721751] random: systemd-udevd: uninitialized urandom read (16 bytes read)
4067 [ 2.787155] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
4068 [ 2.950231] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
4069 [ 3.050169] HDMI cable is connected
4070 [ 3.300112] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
4071 [ 3.520629] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
4072 [ 3.520637] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
4073 [ 3.520642] usb 4-1: Product: Rapoo 2.4G Wireless Device
4074 [ 3.520647] usb 4-1: Manufacturer: RAPOO
4075 [ 3.528552] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
4076 [ 3.529137] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
4077 [ 3.535296] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
4078 [ 3.590987] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
4079 [ 3.594916] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
4080 [ 3.652089] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
4081 [ 4.648774] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
4082 [ 5.149026] systemd[1]: System time before build time, advancing clock.
4083 [ 5.153888] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
4084 [ 5.154532] cgroup: cgroup2: unknown option "nsdelegate"
4085 [ 5.167122] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
4086 [ 5.167146] systemd[1]: Detected architecture arm64.
4087 [ 5.168243] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
4088 [ 5.174347] systemd[1]: Hostname set to <opi>.
4089 [ 5.189012] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
4090 [ 6.048114] (sd-execut[1463]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
4091 [ 6.404139] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
4092 [ 6.630871] systemd[1]: Queued start job for default target graphical.target.
4093 [ 6.638188] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
4094 [ 6.640492] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
4095 [ 6.642717] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
4096 [ 6.644107] systemd[1]: Created slice user.slice - User and Session Slice.
4097 [ 6.644745] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
4098 [ 6.645300] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
4099 [ 6.645621] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
4100 [ 6.646126] systemd[1]: Reached target slices.target - Slice Units.
4101 [ 6.646424] systemd[1]: Reached target swap.target - Swaps.
4102 [ 6.646693] systemd[1]: Reached target time-set.target - System Time Set.
4103 [ 6.647210] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
4104 [ 6.664481] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
4105 [ 6.665565] systemd[1]: Listening on syslog.socket - Syslog Socket.
4106 [ 6.666493] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
4107 [ 6.667249] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
4108 [ 6.668873] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
4109 [ 6.669806] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
4110 [ 6.670921] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
4111 [ 6.672981] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
4112 [ 6.673962] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
4113 [ 6.677940] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
4114 [ 6.682530] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
4115 [ 6.687914] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
4116 [ 6.689005] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
4117 [ 6.690001] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
4118 [ 6.697394] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
4119 [ 6.702802] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
4120 [ 6.708936] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
4121 [ 6.717640] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
4122 [ 6.727773] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
4123 [ 6.734831] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
4124 [ 6.742802] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
4125 [ 6.750866] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
4126 [ 6.758016] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
4127 [ 6.760255] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
4128 [ 6.770670] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
4129 [ 6.777606] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
4130 [ 6.784370] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
4131 [ 6.793365] fuse init (API version 7.26)
4132 [ 6.800338] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
4133 [ 6.804451] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
4134 [ 6.807719] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
4135 [ 6.811750] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
4136 [ 6.815623] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
4137 [ 6.819314] systemd[1]: modprobe@configfs.service: Deactivated successfully.
4138 [ 6.821122] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
4139 [ 6.825927] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
4140 [ 6.826881]
4141 insmod_device_driver
4142
4143 [ 6.827201] device_chose finished 124!
4144 [ 6.827936] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
4145 [ 6.834941] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
4146 [ 6.844869] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
4147 [ 6.852000] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
4148 [ 6.852967] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
4149 [ 6.852977] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
4150 [ 6.853169] spidev spi1.1: Deleting spi1.1
4151 [ 6.854092] fbtft_device: GPIOS used by 'fb_st7735r':
4152 [ 6.854099] fbtft_device: 'reset' = GPIO73
4153 [ 6.854103] fbtft_device: 'dc' = GPIO70
4154 [ 6.854114] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
4155 [ 6.854120] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
4156 [ 6.879009] WCN: marlin_init entry!
4157 [ 6.880228] WCN: marlin_parse_dt reset gpio=211
4158 [ 6.880239] WCN_ERR: gpio reset request err: 211
4159 [ 6.880245] WCN: wcn config bt wake host
4160 [ 6.880795] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
4161 [ 6.881011] WCN: wcn config wifi wake host
4162 [ 6.881033] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
4163 [ 6.884501] sdiohal:sdiohal_init ok
4164 [ 6.885358] WCN: marlin_probe ok!
4165 [ 6.892654] mtty_probe init device addr: 0xffffffc0097acc00
4166 [ 6.892873] -->rfkill_bluetooth_init
4167 [ 6.893072] <--rfkill_bluetooth_init
4168 [ 6.901683] systemd[1]: modprobe@drm.service: Deactivated successfully.
4169 [ 6.902493] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
4170 [ 6.909481] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
4171 [ 6.910525] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
4172 [ 6.913492] systemd[1]: modprobe@fuse.service: Deactivated successfully.
4173 [ 6.914447] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
4174 [ 6.918362] systemd[1]: modprobe@loop.service: Deactivated successfully.
4175 [ 6.921887] WCN: start_marlin [MARLIN_WIFI]
4176 [ 6.921901] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
4177 [ 6.921904] WCN: the first power on start
4178 [ 6.964092] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
4179 [ 6.990704] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
4180 [ 6.998780] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
4181 [ 7.004536] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
4182 [ 7.005551] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
4183 [ 7.036842] WCN: marlin chip en pull up
4184 [ 7.041179] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
4185 [ 7.042418] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
4186 [ 7.049265] systemd[1]: Starting systemd-sysusers.service - Create System Users...
4187 [ 7.063498] sdiohal:sdiohal_scan_card
4188 [ 7.063518] sunxi-wlan soc@03000000:wlan: bus_index: 1
4189 [ 7.063715] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
4190 [ 7.065203] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
4191 [ 7.067908] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
4192 [ 7.070056] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
4193 [ 7.080184] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4194 [ 7.097638] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
4195 [ 7.098517] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
4196 [ 7.098557] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4197 [ 7.101071] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4198 [ 7.104191] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4199 [ 7.111988] systemd[1]: Finished systemd-sysusers.service - Create System Users.
4200 [ 7.118800] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
4201 [ 7.120218] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4202 [ 7.131520] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
4203 [ 7.132273] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
4204 [ 7.132328] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
4205 [ 7.132926] mmc1: new ultra high speed SDR104 SDIO card at address 8800
4206 [ 7.133371] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
4207 [ 7.133770] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
4208 [ 7.133804] sdiohal:scan end!
4209 [ 7.133815] WCN: marlin_scan_finish!
4210 [ 7.133827] WCN: then marlin start to download
4211 [ 7.133837] sdiohal:probe ok
4212 [ 7.133871] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
4213 [ 7.201228] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
4214 [ 7.203486] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
4215 [ 7.209184] systemd[1]: Mounting tmp.mount - /tmp...
4216 [ 7.214720] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
4217 [ 7.217170] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
4218 [ 7.222287] systemd[1]: Mounted tmp.mount - /tmp.
4219 [ 7.224625] systemd[1]: Reached target local-fs.target - Local File Systems.
4220 [ 7.253090] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
4221 [ 7.258291] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
4222 [ 7.263770] systemd[1]: Starting console-setup.service - Set console font and keymap...
4223 [ 7.273395] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
4224 [ 7.280051] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
4225 [ 7.297697] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
4226 [ 7.305671] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
4227 [ 7.312960] systemd[1]: Starting ufw.service - Uncomplicated firewall...
4228 [ 7.316886] systemd[1]: Finished console-setup.service - Set console font and keymap.
4229 [ 7.321392] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
4230 [ 7.324235] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
4231 [ 7.364894] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
4232 [ 7.367838] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
4233 [ 7.368732] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
4234 [ 7.369688] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
4235 [ 7.372600] systemd[1]: Finished ufw.service - Uncomplicated firewall.
4236 [ 7.385284] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
4237 [ 7.388680] systemd[1]: Reached target network-pre.target - Preparation for Network.
4238 [ 7.563709] zram: Added device: zram0
4239 [ 7.564594] zram: Added device: zram1
4240 [ 7.565372] zram: Added device: zram2
4241 [ 7.596641] zswap: can't enable, initialization failed
4242 [ 7.631630] zram0: detected capacity change from 0 to 506396672
4243 [ 7.717088] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
4244 [ 7.730819] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
4245 [ 7.788683] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
4246 [ 7.791220] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
4247 [ 7.792262] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
4248 [ 7.792933] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
4249 [ 7.808929] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
4250 [ 8.160208] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
4251 [ 9.153318] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
4252 [ 9.173543] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
4253 [ 9.242911] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
4254 [ 9.380524] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
4255 [ 9.671062] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
4256 [ 9.686402] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
4257 [ 9.729479] sunxi-bt soc@03000000:bt: set block: 0
4258 [ 9.749704] bluetooth_set_power: start_block=0
4259 [ 9.749717] WCN: start_marlin [MARLIN_BLUETOOTH]
4260 [ 9.873282] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
4261 [ 9.873595] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
4262 [ 9.874250] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
4263 [ 9.880617] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
4264 [ 9.891122] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
4265 [ 9.902156] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
4266 [ 9.910280] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
4267 [ 9.914021] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
4268 [ 9.914867] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
4269 [ 9.917807] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
4270 [ 9.921733] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
4271 [ 9.926699] systemd[1]: modprobe@loop.service: Deactivated successfully.
4272 [ 9.970866] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
4273 [ 9.973118] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
4274 [ 9.974600] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
4275 [ 9.975497] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
4276 [ 9.977899] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
4277 [ 9.978199] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
4278 [ 10.041010] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
4279 [ 10.046987] systemd[1]: Starting brltty.service - Braille Device Support...
4280 [ 10.186775] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
4281 [ 10.660377] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
4282 [ 10.715393] systemd[1]: Started brltty.service - Braille Device Support.
4283 [ 10.724860] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
4284 [ 10.825855] zram1: detected capacity change from 0 to 52428800
4285 [ 11.200171] WCN_ERR: btwifi_download_firmware request firmware error
4286 [ 14.879269] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
4287 [ 14.885303] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
4288 [ 14.941500] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
4289 [ 18.419212] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
4290 [ 18.425601] systemd[1]: Starting systemd-journald.service - Journal Service...
4291 [ 18.697120] systemd-journald[1844]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.1 (1655 of 2204 items, 1269760 file size, 767 bytes per hash table item), suggesting rotation.
4292 [ 18.697143] systemd-journald[1844]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
4293 [ 18.701111] systemd[1]: Started systemd-journald.service - Journal Service.
4294 [ 18.742686] systemd-journald[1844]: Received client request to flush runtime journal.
4295 [ 19.006495] IPVS: Creating netns size=1928 id=1
4296 [ 19.976211] random: crng init done
4297 [ 19.976222] random: 7 urandom warning(s) missed due to ratelimiting
4298 [ 37.173491] WCN_ERR: marlin download timeout
4299 [ 37.173503] sdiohal:sdiohal_runtime_put entry
4300 [ 37.173609] sdiohal:sdiohal_runtime_put wait xmit_cnt end
4301 [ 37.173653] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 1
4302 [ 37.173658] WCN: no module to power on, start to power on
4303 [ 37.184625] sdiohal err:sdiohal_adma_pt_write xmit_cnt:0 xmit_start:0,not have card
4304 [ 37.184647] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
4305 [ 37.184652] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
4306 [ 37.200146] sdiohal:sdiohal_scan_card
4307 [ 37.200158] sdiohal:Already exist card!, xmit_cnt=0x0
4308 [ 37.200172] sunxi-wlan soc@03000000:wlan: bus_index: 1
4309 [ 37.200294] sdiohal:[sdiohal_remove]enter
4310 [ 37.200310] sdiohal:remove card end
4311 [ 37.200462] mmc1: card 8800 removed
4312 [ 37.200559] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
4313 [ 37.201660] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
4314 [ 37.216764] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4315 [ 37.234165] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4316 [ 37.236691] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4317 [ 37.239806] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4318 [ 37.253438] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
4319 [ 37.264006] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
4320 [ 37.264734] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
4321 [ 37.264783] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
4322 [ 37.265328] mmc1: new ultra high speed SDR104 SDIO card at address 8800
4323 [ 37.306765] sunxi-wlan soc@03000000:wlan: bus_index: 1
4324 [ 37.307017] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
4325 [ 37.307095] WCN: marlin_scan_finish!
4326 [ 37.307100] sdiohal:probe ok
4327 [ 37.307190] sdiohal:scan end!
4328 [ 37.307197] WCN: only marlin start to download
4329 [ 37.307218] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
4330 [ 38.320161] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
4331 [ 39.333502] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
4332 [ 40.346784] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
4333 [ 40.379920] unisoc_wifi: probe of unisoc_wifi failed with error -1
4334
4335 ### armbian-release:
4336
4337 # PLEASE DO NOT EDIT THIS FILE
4338 BOARD=orangepizero2
4339 BOARD_NAME="Orange Pi Zero2"
4340 BOARDFAMILY=sun50iw9
4341 BUILD_REPOSITORY_URL=https://github.com/armbian/build
4342 BUILD_REPOSITORY_COMMIT=ac829eb6
4343 LINUXFAMILY=sun50iw9
4344 ARCH=arm64
4345 IMAGE_TYPE=stable
4346 BOARD_TYPE=conf
4347 INITRD_ARCH=arm
4348 KERNEL_IMAGE_TYPE=Image
4349 FORCE_BOOTSCRIPT_UPDATE=yes
4350 VENDOR=Armbian
4351 BOOTSCRIPT_FORCE_UPDATE="yes"
4352 BOOTSCRIPT_DST="boot.cmd"
4353 VERSION=23.8.1
4354 REVISION=23.8.1
4355 BRANCH=legacy
4356
4357 ### boot environment:
4358
4359 verbosity=1
4360 console=serial
4361 #disp_mode=1080p60
4362 #fb0_width=1280
4363 #fb0_height=720
4364 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
4365 rootfstype=ext4
4366 overlays=spi-spidev
4367 param_spidev_spi_bus=1
4368 param_spidev_spi_cs=1
4369 extraargs=fbcon=map:1
4370 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
4371
4372 ### lsusb:
4373
4374 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
4375 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
4376 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
4377 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
4378 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
4379 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
4380 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
4381
4382 ### lscpu:
4383
4384 Architecture: aarch64
4385 CPU op-mode(s): 32-bit, 64-bit
4386 Byte Order: Little Endian
4387 CPU(s): 4
4388 On-line CPU(s) list: 0-3
4389 Vendor ID: ARM
4390 Model name: Cortex-A53
4391 Model: 4
4392 Thread(s) per core: 1
4393 Core(s) per cluster: 4
4394 Socket(s): -
4395 Cluster(s): 1
4396 Stepping: r0p4
4397 CPU(s) scaling MHz: 100%
4398 CPU max MHz: 1512.0000
4399 CPU min MHz: 480.0000
4400 BogoMIPS: 48.00
4401 Flags: fp asimd aes pmull sha1 sha2 crc32
4402
4403 ### cpuinfo:
4404
4405 processor : 0
4406 BogoMIPS : 48.00
4407 Features : fp asimd aes pmull sha1 sha2 crc32
4408 CPU implementer : 0x41
4409 CPU architecture: 8
4410 CPU variant : 0x0
4411 CPU part : 0xd03
4412 CPU revision : 4
4413
4414 processor : 1
4415 BogoMIPS : 48.00
4416 Features : fp asimd aes pmull sha1 sha2 crc32
4417 CPU implementer : 0x41
4418 CPU architecture: 8
4419 CPU variant : 0x0
4420 CPU part : 0xd03
4421 CPU revision : 4
4422
4423 processor : 2
4424 BogoMIPS : 48.00
4425 Features : fp asimd aes pmull sha1 sha2 crc32
4426 CPU implementer : 0x41
4427 CPU architecture: 8
4428 CPU variant : 0x0
4429 CPU part : 0xd03
4430 CPU revision : 4
4431
4432 processor : 3
4433 BogoMIPS : 48.00
4434 Features : fp asimd aes pmull sha1 sha2 crc32
4435 CPU implementer : 0x41
4436 CPU architecture: 8
4437 CPU variant : 0x0
4438 CPU part : 0xd03
4439 CPU revision : 4
4440
4441
4442 ### meminfo:
4443
4444 MemTotal: 989056 kB
4445 MemFree: 798200 kB
4446 MemAvailable: 886428 kB
4447 Buffers: 15720 kB
4448 Cached: 79444 kB
4449 SwapCached: 0 kB
4450 Active: 68448 kB
4451 Inactive: 50800 kB
4452 Active(anon): 24192 kB
4453 Inactive(anon): 644 kB
4454 Active(file): 44256 kB
4455 Inactive(file): 50156 kB
4456 Unevictable: 0 kB
4457 Mlocked: 0 kB
4458 SwapTotal: 494524 kB
4459 SwapFree: 494524 kB
4460 Dirty: 712 kB
4461 Writeback: 0 kB
4462 AnonPages: 23968 kB
4463 Mapped: 24876 kB
4464 Shmem: 812 kB
4465 Slab: 28268 kB
4466 SReclaimable: 9280 kB
4467 SUnreclaim: 18988 kB
4468 KernelStack: 2560 kB
4469 PageTables: 1036 kB
4470 NFS_Unstable: 0 kB
4471 Bounce: 0 kB
4472 WritebackTmp: 0 kB
4473 CommitLimit: 989052 kB
4474 Committed_AS: 83364 kB
4475 VmallocTotal: 263061440 kB
4476 VmallocUsed: 0 kB
4477 VmallocChunk: 0 kB
4478 CmaTotal: 16384 kB
4479 CmaFree: 7468 kB
4480 HugePages_Total: 0
4481 HugePages_Free: 0
4482 HugePages_Rsvd: 0
4483 HugePages_Surp: 0
4484 Hugepagesize: 2048 kB
4485
4486 ### virtual memory:
4487
4488 vm.admin_reserve_kbytes = 8192
4489 vm.block_dump = 0
4490 vm.compact_unevictable_allowed = 1
4491 vm.dirty_background_bytes = 0
4492 vm.dirty_background_ratio = 10
4493 vm.dirty_bytes = 0
4494 vm.dirty_expire_centisecs = 3000
4495 vm.dirty_ratio = 20
4496 vm.dirtytime_expire_seconds = 43200
4497 vm.dirty_writeback_centisecs = 500
4498 vm.extfrag_threshold = 500
4499 vm.extra_free_kbytes = 0
4500 vm.hugepages_treat_as_movable = 0
4501 vm.hugetlb_shm_group = 0
4502 vm.laptop_mode = 0
4503 vm.legacy_va_layout = 0
4504 vm.lowmem_reserve_ratio = 256 32
4505 vm.max_map_count = 65530
4506 vm.min_free_kbytes = 3937
4507 vm.mmap_min_addr = 4096
4508 vm.mmap_rnd_bits = 18
4509 vm.mmap_rnd_compat_bits = 11
4510 vm.nr_hugepages = 0
4511 vm.nr_overcommit_hugepages = 0
4512 vm.nr_pdflush_threads = 0
4513 vm.oom_dump_tasks = 1
4514 vm.oom_kill_allocating_task = 0
4515 vm.overcommit_kbytes = 0
4516 vm.overcommit_memory = 0
4517 vm.overcommit_ratio = 50
4518 vm.page-cluster = 0
4519 vm.panic_on_oom = 0
4520 vm.percpu_pagelist_fraction = 0
4521 vm.stat_interval = 1
4522 vm.swappiness = 100
4523 vm.user_reserve_kbytes = 30007
4524 vm.vfs_cache_pressure = 100
4525 vm.watermark_scale_factor = 10
4526
4527 ### ip addr:
4528
4529 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
4530 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
4531 inet XXX.XXX.0.1/8 scope host lo
4532 valid_lft forever preferred_lft forever
4533 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
4534 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
4535 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
4536 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
4537 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
4538 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
4539 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
4540 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
4541 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
4542 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
4543 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
4544 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
4545 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
4546 link/tunnel6 :: brd ::
4547 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
4548 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
4549 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
4550 link/tunnel6 :: brd ::
4551
4552 ### partitions:
4553
4554 major minor #blocks name
4555
4556 179 0 62410752 mmcblk0
4557 179 1 61763584 mmcblk0p1
4558 253 0 494528 zram0
4559 253 1 51200 zram1
4560
4561 ### df:
4562
4563 udev 466M 0 466M 0% /dev
4564 tmpfs 97M 2.1M 95M 3% /run
4565 /dev/mmcblk0p1 58G 6.3G 52G 11% /
4566 tmpfs 483M 0 483M 0% /dev/shm
4567 tmpfs 5.0M 0 5.0M 0% /run/lock
4568 tmpfs 483M 4.0K 483M 1% /tmp
4569 /dev/zram1 47M 6.9M 37M 16% /var/log
4570
4571 ### lsblk:
4572
4573 NAME FSTYPE SIZE MOUNTPOINT UUID
4574 mmcblk0 59.5G
4575 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
4576 zram1 50M /var/log
4577 zram2 0B
4578
4579 ### zramctl:
4580
4581 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
4582 /dev/zram1 lz4 50M 7M 2M 2.4M 4 /var/log
4583 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
4584
4585 ### mtab:
4586
4587 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
4588 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
4589 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
4590
4591 ### mmc0:0001 info:
4592
4593 manfid: 0x0000fe
4594 cid: fe3432534431364720000000690091f5
4595 fwrev: 0x0
4596 csd: 400e00325b590001dc277f800a40008b
4597 ocr: 0x00200000
4598 type: SD
4599 date: 01/2009
4600 hwrev: 0x2
4601 dsr: 0x404
4602 serial: 0x00000069
4603 erase_size: 512
4604 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
4605 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
4606 scr: 0285808300000000
4607 oemid: 0x3432
4608 preferred_erase_size: 4194304
4609 name: SD16G
4610
4611 ### Boot system health:
4612
4613 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
4614 14:17:38 1512 MHz 1.54 23% 11% 10% 0% 1% 0% 51.3 °C 0/5
4615 14:17:39 1512 MHz 1.54 96% 11% 59% 0% 24% 0% 51.3 °C 0/5
4616 14:17:39 1512 MHz 2.29 93% 13% 54% 1% 24% 0% 51.3 °C 0/5
4617 14:17:40 1512 MHz 2.29 86% 10% 54% 2% 19% 0% 49.6 °C 0/5
4618 14:17:40 1512 MHz 2.29 58% 6% 29% 2% 19% 0% 49.6 °C 0/5
4619
4620 ### Activated 1 lzo zram swap devices with 482MB each.
4621 ### Activated Armbian ramlog partition with lz4 compression
4622
4623 Mon Sep 25 02:27:47 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
4624
4625 ### dmesg:
4626
4627 [ 0.000000] Booting Linux on physical CPU 0x0
4628 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
4629 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
4630 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
4631 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
4632 [ 0.000000] On node 0 totalpages: 262144
4633 [ 0.000000] DMA zone: 4096 pages used for memmap
4634 [ 0.000000] DMA zone: 0 pages reserved
4635 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
4636 [ 0.000000] psci: probing for conduit method from DT.
4637 [ 0.000000] psci: PSCIv1.0 detected in firmware.
4638 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
4639 [ 0.000000] psci: Trusted OS migration not required
4640 [ 0.000000] psci: SMC Calling Convention v1.0
4641 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
4642 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
4643 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
4644 [ 0.000000] Detected VIPT I-cache on CPU0
4645 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
4646 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
4647 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
4648 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
4649 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
4650 [ 0.000000] log_buf_len min size: 131072 bytes
4651 [ 0.000000] log_buf_len: 524288 bytes
4652 [ 0.000000] early log buf free: 129352(98%)
4653 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
4654 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
4655 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
4656 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
4657 [ 0.000000] Virtual kernel memory layout:
4658 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
4659 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
4660 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
4661 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
4662 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
4663 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
4664 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
4665 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
4666 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
4667 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
4668 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
4669 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
4670 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
4671 [ 0.000000] Preemptible hierarchical RCU implementation.
4672 [ 0.000000] Build-time adjustment of leaf fanout to 64.
4673 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
4674 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
4675 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
4676 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
4677 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
4678 [ 0.000232] Console: colour dummy device 80x25
4679 [ 0.000248] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
4680 [ 0.000256] pid_max: default: 32768 minimum: 301
4681 [ 0.000453] Security Framework initialized
4682 [ 0.000463] AppArmor: AppArmor disabled by boot time parameter
4683 [ 0.000575] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
4684 [ 0.000581] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
4685 [ 0.001858] sched-energy: CPU device node has no sched-energy-costs
4686 [ 0.001872] Invalid sched_group_energy for CPU0
4687 [ 0.001880] CPU0: update cpu_capacity 1024
4688 [ 0.008940] ASID allocator initialised with 32768 entries
4689 [ 0.027902] BOOTEVENT: 27.887873: ON
4690 [ 0.055885] Detected VIPT I-cache on CPU1
4691 [ 0.055939] Invalid sched_group_energy for CPU1
4692 [ 0.055943] CPU1: update cpu_capacity 1024
4693 [ 0.055946] CPU1: Booted secondary processor [410fd034]
4694 [ 0.079271] Detected VIPT I-cache on CPU2
4695 [ 0.079310] Invalid sched_group_energy for CPU2
4696 [ 0.079313] CPU2: update cpu_capacity 1024
4697 [ 0.079316] CPU2: Booted secondary processor [410fd034]
4698 [ 0.102675] Detected VIPT I-cache on CPU3
4699 [ 0.102709] Invalid sched_group_energy for CPU3
4700 [ 0.102712] CPU3: update cpu_capacity 1024
4701 [ 0.102715] CPU3: Booted secondary processor [410fd034]
4702 [ 0.102795] Brought up 4 CPUs
4703 [ 0.102802] SMP: Total of 4 processors activated.
4704 [ 0.102810] CPU features: detected feature: 32-bit EL0 Support
4705 [ 0.102816] CPU features: detected feature: Kernel page table isolation (KPTI)
4706 [ 0.106582] CPU: All CPU(s) started at EL1
4707 [ 0.106603] alternatives: patching kernel code
4708 [ 0.106779] Invalid sched_group_energy for CPU3
4709 [ 0.106788] CPU3: update max cpu_capacity 1024
4710 [ 0.106794] Invalid sched_group_energy for Cluster3
4711 [ 0.106799] Invalid sched_group_energy for CPU2
4712 [ 0.106805] Invalid sched_group_energy for Cluster2
4713 [ 0.106810] Invalid sched_group_energy for CPU1
4714 [ 0.106816] Invalid sched_group_energy for Cluster1
4715 [ 0.106820] Invalid sched_group_energy for CPU0
4716 [ 0.106826] Invalid sched_group_energy for Cluster0
4717 [ 0.108252] devtmpfs: initialized
4718 [ 0.112691] CPU1: update max cpu_capacity 1024
4719 [ 0.143391] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
4720 [ 0.143418] futex hash table entries: 1024 (order: 5, 131072 bytes)
4721 [ 0.144081] xor: measuring software checksum speed
4722 [ 0.176232] 8regs : 1933.200 MB/sec
4723 [ 0.209611] 8regs_prefetch: 1720.800 MB/sec
4724 [ 0.242998] 32regs : 2287.200 MB/sec
4725 [ 0.276385] 32regs_prefetch: 1935.600 MB/sec
4726 [ 0.276391] xor: using function: 32regs (2287.200 MB/sec)
4727 [ 0.276450] atomic64_test: passed
4728 [ 0.276456] pinctrl core: initialized pinctrl subsystem
4729 [ 0.277619] NET: Registered protocol family 16
4730 [ 0.278704] dump_class_init,861, success
4731 [ 0.293114] cpuidle: using governor menu
4732 [ 0.294550] sunxi iommu: irq = 8
4733 [ 0.294876] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
4734 [ 0.294894] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
4735 [ 0.296301] DMA: preallocated 256 KiB pool for atomic allocations
4736 [ 0.297673] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
4737 [ 0.312051] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
4738 [ 0.316005] iommu: Adding device 1c0e000.ve to group 0
4739 [ 0.316524] iommu: Adding device 1c00000.vp9 to group 0
4740 [ 0.327918] iommu: Adding device 1000000.disp to group 0
4741 [ 0.329325] iommu: Adding device 1480000.g2d to group 0
4742 [ 0.332536] iommu: Adding device csi0 to group 0
4743 [ 0.332989] iommu: Adding device csi1 to group 0
4744 [ 0.334193] iommu: Adding device 6600800.vind:scaler@0 to group 0
4745 [ 0.334491] iommu: Adding device 6600800.vind:scaler@1 to group 0
4746 [ 0.334795] iommu: Adding device 6600800.vind:scaler@2 to group 0
4747 [ 0.335085] iommu: Adding device 6600800.vind:scaler@3 to group 0
4748 [ 0.335375] iommu: Adding device 6600800.vind:scaler@4 to group 0
4749 [ 0.335667] iommu: Adding device 6600800.vind:scaler@5 to group 0
4750 [ 0.336601] iommu: Adding device vinc0 to group 0
4751 [ 0.337176] iommu: Adding device vinc1 to group 0
4752 [ 0.338627] iommu: Adding device 1420000.deinterlace to group 0
4753 [ 0.381265] HugeTLB registered 2 MB page size, pre-allocated 0 pages
4754 [ 0.437401] raid6: int64x1 gen() 391 MB/s
4755 [ 0.494198] raid6: int64x1 xor() 362 MB/s
4756 [ 0.551001] raid6: int64x2 gen() 591 MB/s
4757 [ 0.607743] raid6: int64x2 xor() 512 MB/s
4758 [ 0.664516] raid6: int64x4 gen() 840 MB/s
4759 [ 0.721310] raid6: int64x4 xor() 629 MB/s
4760 [ 0.778092] raid6: int64x8 gen() 965 MB/s
4761 [ 0.834848] raid6: int64x8 xor() 655 MB/s
4762 [ 0.891626] raid6: neonx1 gen() 648 MB/s
4763 [ 0.948406] raid6: neonx1 xor() 641 MB/s
4764 [ 1.005173] raid6: neonx2 gen() 976 MB/s
4765 [ 1.061984] raid6: neonx2 xor() 820 MB/s
4766 [ 1.118763] raid6: neonx4 gen() 1287 MB/s
4767 [ 1.175509] raid6: neonx4 xor() 965 MB/s
4768 [ 1.232299] raid6: neonx8 gen() 1324 MB/s
4769 [ 1.289082] raid6: neonx8 xor() 991 MB/s
4770 [ 1.289088] raid6: using algorithm neonx8 gen() 1324 MB/s
4771 [ 1.289093] raid6: .... xor() 991 MB/s, rmw enabled
4772 [ 1.289099] raid6: using intx1 recovery algorithm
4773 [ 1.289234] pwm module init!
4774 [ 1.293531] sunxi-pm debug v3.10
4775 [ 1.294638] SCSI subsystem initialized
4776 [ 1.295261] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
4777 [ 1.295345] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
4778 [ 1.295466] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
4779 [ 1.295982] spi spi0: master is unqueued, this is deprecated
4780 [ 1.296291] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
4781 [ 1.296861] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
4782 [ 1.296943] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
4783 [ 1.297058] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
4784 [ 1.297525] spi spi1: master is unqueued, this is deprecated
4785 [ 1.297869] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
4786 [ 1.298680] usbcore: registered new interface driver usbfs
4787 [ 1.298773] usbcore: registered new interface driver hub
4788 [ 1.298845] usbcore: registered new device driver usb
4789 [ 1.299003] sunxi_i2c_adap_init()2522 - init
4790 [ 1.299574] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
4791 [ 1.299662] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
4792 [ 1.299670] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
4793 [ 1.299685] twi3 supply twi not found, using dummy regulator
4794 [ 1.299761] twi_request_gpio()451 - [i2c3] init name: twi3
4795 [ 1.300506] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
4796 [ 1.300585] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
4797 [ 1.300592] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
4798 [ 1.300606] twi5 supply twi not found, using dummy regulator
4799 [ 1.300685] twi_request_gpio()451 - [i2c5] init name: twi5
4800 [ 1.301170] axp20x-i2c 5-0036: AXP20x variant AXP806 found
4801 [ 1.319867] random: fast init done
4802 [ 1.331019] axp20x-i2c 5-0036: AXP20X driver loaded
4803 [ 1.331548] media: Linux media interface: v0.10
4804 [ 1.331628] Linux video capture interface: v2.00
4805 [ 1.332254] Advanced Linux Sound Architecture Driver Initialized.
4806 [ 1.332978] Bluetooth: Core ver 2.22
4807 [ 1.333045] NET: Registered protocol family 31
4808 [ 1.333051] Bluetooth: HCI device and connection manager initialized
4809 [ 1.333066] Bluetooth: HCI socket layer initialized
4810 [ 1.333078] Bluetooth: L2CAP socket layer initialized
4811 [ 1.333117] Bluetooth: SCO socket layer initialized
4812 [ 1.333961] [DISP]disp_module_init
4813 [ 1.335211] [DISP] parser_disp_init_para,line:1403:
4814 [ 1.335219] of_property_read fb0_width fail
4815 [ 1.335231] [DISP] disp_init,line:2215:
4816 [ 1.335237] smooth display screen:0 type:4 mode:10
4817 [ 1.352707] [DISP]disp_module_init finish
4818 [ 1.353576] clocksource: Switched to clocksource arch_sys_counter
4819 [ 1.353836] VFS: Disk quotas dquot_6.6.0
4820 [ 1.353924] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
4821 [ 1.354663] Console: switching to colour frame buffer device 240x67
4822 [ 1.398069] NET: Registered protocol family 2
4823 [ 1.398194] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
4824 [ 1.420504] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
4825 [ 1.420578] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
4826 [ 1.420700] TCP: Hash tables configured (established 8192 bind 8192)
4827 [ 1.420788] UDP hash table entries: 512 (order: 2, 16384 bytes)
4828 [ 1.420816] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
4829 [ 1.421140] NET: Registered protocol family 1
4830 [ 1.421730] RPC: Registered named UNIX socket transport module.
4831 [ 1.421735] RPC: Registered udp transport module.
4832 [ 1.421738] RPC: Registered tcp transport module.
4833 [ 1.421741] RPC: Registered tcp NFSv4.1 backchannel transport module.
4834 [ 1.421982] Trying to unpack rootfs image as initramfs...
4835 [ 2.176299] Freeing initrd memory: 17256K
4836 [ 2.177391] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
4837 [ 2.181283] audit: initializing netlink subsys (disabled)
4838 [ 2.181341] audit: type=2000 audit(2.176:1): initialized
4839 [ 2.182247] workingset: timestamp_bits=45 max_order=18 bucket_order=0
4840 [ 2.193379] DLM installed
4841 [ 2.195253] squashfs: version 4.0 (2009/01/31) Phillip Lougher
4842 [ 2.195608] Registering sdcardfs 0.1
4843 [ 2.196095] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
4844 [ 2.197649] ntfs: driver 2.1.32 [Flags: R/W].
4845 [ 2.204503] NET: Registered protocol family 38
4846 [ 2.204869] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
4847 [ 2.205012] io scheduler noop registered
4848 [ 2.205021] io scheduler deadline registered
4849 [ 2.205187] io scheduler cfq registered (default)
4850 [ 2.207065] failed to get easy_light_used assign
4851 [ 2.207077] failed to get normal led pin assign
4852 [ 2.207082] failed to get standby led pin assign
4853 [ 2.207087] failed to get standby led pin assign
4854 [ 2.207093] these is zero number for gpio
4855 [ 2.207097] gpio_init finish with uesd
4856 [ 2.210188] uart uart0: get regulator failed
4857 [ 2.210559] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
4858 [ 2.210585] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
4859 [ 2.210703] console [ttyS0] enabled
4860 [ 2.211592] uart uart1: get regulator failed
4861 [ 2.211786] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
4862 [ 2.212494] uart uart5: get regulator failed
4863 [ 2.212677] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
4864 [ 2.213975] misc dump reg init
4865 [ 2.215108] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
4866 [ 2.215446] Unable to detect cache hierarchy for CPU 0
4867 [ 2.229903] brd: module loaded
4868 [ 2.238374] loop: module loaded
4869 [ 2.238564] [NAND][NE] Not found valid nand node on dts
4870 [ 2.239152] Get boot type cmd line fail
4871 [ 2.239735] sunxi-bt soc@03000000:bt: Missing bt_power.
4872 [ 2.239746] sunxi-bt soc@03000000:bt: bt_power_name ((null))
4873 [ 2.239753] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
4874 [ 2.239760] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
4875 [ 2.239815] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
4876 [ 2.239885] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
4877 [ 2.240792] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
4878 [ 2.240804] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
4879 [ 2.240812] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
4880 [ 2.240819] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
4881 [ 2.240826] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
4882 [ 2.240858] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
4883 [ 2.240891] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
4884 [ 2.240899] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
4885 [ 2.240916] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
4886 [ 2.241850] [ADDR_MGT] addr_mgt_probe: success.
4887 [ 2.248669] tun: Universal TUN/TAP device driver, 1.6
4888 [ 2.248681] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
4889 [ 2.250720] gmac-power0: NULL
4890 [ 2.250730] gmac-power1: NULL
4891 [ 2.250736] gmac-power2: NULL
4892 [ 2.251659] PPP generic driver version 2.4.2
4893 [ 2.251945] PPP BSD Compression module registered
4894 [ 2.251954] PPP Deflate Compression module registered
4895 [ 2.251980] PPP MPPE Compression module registered
4896 [ 2.251989] NET: Registered protocol family 24
4897 [ 2.252024] PPTP driver version 0.8.5
4898 [ 2.252376] usbcore: registered new interface driver r8152
4899 [ 2.252452] usbcore: registered new interface driver asix
4900 [ 2.252547] usbcore: registered new interface driver ax88179_178a
4901 [ 2.252621] usbcore: registered new interface driver cdc_ether
4902 [ 2.252683] usbcore: registered new interface driver net1080
4903 [ 2.252751] usbcore: registered new interface driver cdc_subset
4904 [ 2.252812] usbcore: registered new interface driver zaurus
4905 [ 2.252897] usbcore: registered new interface driver cdc_ncm
4906 [ 2.252904] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
4907 [ 2.253270] get drv_vbus is fail, 84
4908 [ 2.253279] get ehci0-controller, regulator_io is no nocare
4909 [ 2.253543] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
4910 [ 2.253549] [sunxi-ehci0]: Not init ehci0
4911 [ 2.253781] get ehci1-controller, regulator_io is no nocare
4912 [ 2.253992] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
4913 [ 2.254050] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
4914 [ 2.254077] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
4915 [ 2.254622] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
4916 [ 2.266929] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
4917 [ 2.267218] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
4918 [ 2.267227] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
4919 [ 2.267235] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
4920 [ 2.267242] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
4921 [ 2.267249] usb usb1: SerialNumber: sunxi-ehci
4922 [ 2.268117] hub 1-0:1.0: USB hub found
4923 [ 2.268163] hub 1-0:1.0: 1 port detected
4924 [ 2.268836] get drv_vbus is fail, 84
4925 [ 2.268844] get ehci2-controller, regulator_io is no nocare
4926 [ 2.269091] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
4927 [ 2.269143] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
4928 [ 2.269169] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
4929 [ 2.269444] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
4930 [ 2.280267] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
4931 [ 2.280504] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
4932 [ 2.280513] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
4933 [ 2.280520] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
4934 [ 2.280527] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
4935 [ 2.280534] usb usb2: SerialNumber: sunxi-ehci
4936 [ 2.281378] hub 2-0:1.0: USB hub found
4937 [ 2.281421] hub 2-0:1.0: 1 port detected
4938 [ 2.282089] get drv_vbus is fail, 84
4939 [ 2.282097] get ehci3-controller, regulator_io is no nocare
4940 [ 2.282342] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
4941 [ 2.282405] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
4942 [ 2.282431] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
4943 [ 2.282717] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
4944 [ 2.293595] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
4945 [ 2.293782] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
4946 [ 2.293791] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
4947 [ 2.293799] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
4948 [ 2.293806] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
4949 [ 2.293813] usb usb3: SerialNumber: sunxi-ehci
4950 [ 2.294681] hub 3-0:1.0: USB hub found
4951 [ 2.294727] hub 3-0:1.0: 1 port detected
4952 [ 2.295653] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
4953 [ 2.296022] get drv_vbus is fail, 84
4954 [ 2.296030] get ohci0-controller, regulator_io is no nocare
4955 [ 2.296362] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
4956 [ 2.296367] [sunxi-ohci0]: Not init ohci0
4957 [ 2.296487] get ohci1-controller, regulator_io is no nocare
4958 [ 2.296652] hci: request ohci1-controller gpio:80
4959 [ 2.296729] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
4960 [ 2.296780] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
4961 [ 2.296806] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
4962 [ 2.296885] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
4963 [ 2.357785] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
4964 [ 2.357797] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
4965 [ 2.357804] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
4966 [ 2.357811] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
4967 [ 2.357818] usb usb4: SerialNumber: sunxi-ohci
4968 [ 2.358708] hub 4-0:1.0: USB hub found
4969 [ 2.358756] hub 4-0:1.0: 1 port detected
4970 [ 2.359439] get drv_vbus is fail, 84
4971 [ 2.359447] get ohci2-controller, regulator_io is no nocare
4972 [ 2.359782] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
4973 [ 2.359832] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
4974 [ 2.359858] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
4975 [ 2.359935] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
4976 [ 2.417759] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
4977 [ 2.417769] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
4978 [ 2.417777] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
4979 [ 2.417784] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
4980 [ 2.417791] usb usb5: SerialNumber: sunxi-ohci
4981 [ 2.418665] hub 5-0:1.0: USB hub found
4982 [ 2.418712] hub 5-0:1.0: 1 port detected
4983 [ 2.419383] get drv_vbus is fail, 84
4984 [ 2.419391] get ohci3-controller, regulator_io is no nocare
4985 [ 2.419729] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
4986 [ 2.419779] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
4987 [ 2.419808] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
4988 [ 2.419885] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
4989 [ 2.477754] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
4990 [ 2.477764] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
4991 [ 2.477771] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
4992 [ 2.477779] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
4993 [ 2.477785] usb usb6: SerialNumber: sunxi-ohci
4994 [ 2.478632] hub 6-0:1.0: USB hub found
4995 [ 2.478678] hub 6-0:1.0: 1 port detected
4996 [ 2.479616] ohci-platform: OHCI generic platform driver
4997 [ 2.480358] usbcore: registered new interface driver uas
4998 [ 2.480526] usbcore: registered new interface driver usb-storage
4999 [ 2.480618] usbcore: registered new interface driver ums-alauda
5000 [ 2.480699] usbcore: registered new interface driver ums-cypress
5001 [ 2.480772] usbcore: registered new interface driver ums-datafab
5002 [ 2.480840] usbcore: registered new interface driver ums_eneub6250
5003 [ 2.480914] usbcore: registered new interface driver ums-freecom
5004 [ 2.480988] usbcore: registered new interface driver ums-isd200
5005 [ 2.481057] usbcore: registered new interface driver ums-jumpshot
5006 [ 2.481127] usbcore: registered new interface driver ums-karma
5007 [ 2.481196] usbcore: registered new interface driver ums-onetouch
5008 [ 2.481293] usbcore: registered new interface driver ums-realtek
5009 [ 2.481375] usbcore: registered new interface driver ums-sddr09
5010 [ 2.481456] usbcore: registered new interface driver ums-sddr55
5011 [ 2.481530] usbcore: registered new interface driver ums-usbat
5012 [ 2.481679] usb_serial_number:20080411
5013 [ 2.482917] input: sunxi-keyboard as /devices/virtual/input/input0
5014 [ 2.483538] usbcore: registered new interface driver xpad
5015 [ 2.483708] usbcore: registered new interface driver usb_acecad
5016 [ 2.483807] usbcore: registered new interface driver aiptek
5017 [ 2.483894] usbcore: registered new interface driver gtco
5018 [ 2.483974] usbcore: registered new interface driver hanwang
5019 [ 2.484055] usbcore: registered new interface driver kbtab
5020 [ 2.484523] axp2101_pek: axp2101-pek can not register without irq
5021 [ 2.484545] axp2101-pek: probe of axp2101-pek.0 failed with error -22
5022 [ 2.485934] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
5023 [ 2.486005] sunxi-rtc rtc: RTC enabled
5024 [ 2.486472] i2c /dev entries driver
5025 [ 2.487521] lirc_dev: IR Remote Control driver registered, major 244
5026 [ 2.487532] IR NEC protocol handler initialized
5027 [ 2.487538] IR RC5(x/sz) protocol handler initialized
5028 [ 2.487544] IR RC6 protocol handler initialized
5029 [ 2.487550] IR JVC protocol handler initialized
5030 [ 2.487555] IR Sony protocol handler initialized
5031 [ 2.487561] IR SANYO protocol handler initialized
5032 [ 2.487567] IR Sharp protocol handler initialized
5033 [ 2.487573] IR MCE Keyboard/mouse protocol handler initialized
5034 [ 2.487578] IR LIRC bridge handler initialized
5035 [ 2.487584] IR XMP protocol handler initialized
5036 [ 2.488107] sunxi_ir_startup: get ir protocol failed
5037 [ 2.488149] 7040000.s_cir supply ir0 not found, using dummy regulator
5038 [ 2.488335] Registered IR keymap rc_map_sunxi
5039 [ 2.488734] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
5040 [ 2.488964] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
5041 [ 2.489991] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
5042 [ 2.490615] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
5043 [ 2.491320] sunxi cedar version 0.1
5044 [ 2.491509] VE: install start!!!
5045
5046 [ 2.491695] cedar_ve: cedar-ve the get irq is 278
5047 [ 2.492315] VE: get debugfs_mpp_root is NULL, please check mpp
5048
5049 [ 2.492328] VE: sunxi ve debug register driver failed!
5050
5051 [ 2.495523] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
5052 [ 2.496822] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
5053 [ 2.497216] Bluetooth: HCI UART driver ver 2.3
5054 [ 2.497227] Bluetooth: HCI UART protocol H4 registered
5055 [ 2.497233] Bluetooth: HCI UART protocol LL registered
5056 [ 2.497238] Bluetooth: HCI UART protocol Three-wire (H5) registered
5057 [ 2.501443] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
5058 [ 2.501460] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
5059 [ 2.501473] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
5060 [ 2.501485] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
5061 [ 2.501497] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
5062 [ 2.501509] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
5063 [ 2.501919] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
5064 [ 2.502028] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
5065 [ 2.502231] sunxi-mmc sdc0: No vmmc regulator found
5066 [ 2.502238] sunxi-mmc sdc0: No vqmmc regulator found
5067 [ 2.502244] sunxi-mmc sdc0: No vdmmc regulator found
5068 [ 2.502250] sunxi-mmc sdc0: No vd33sw regulator found
5069 [ 2.502257] sunxi-mmc sdc0: No vd18sw regulator found
5070 [ 2.502263] sunxi-mmc sdc0: No vq33sw regulator found
5071 [ 2.502269] sunxi-mmc sdc0: No vq18sw regulator found
5072 [ 2.502988] sunxi-mmc sdc0: set host busy
5073 [ 2.503089] sunxi-mmc sdc0: Got CD GPIO
5074 [ 2.503446] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
5075 [ 2.503481] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
5076 [ 2.516936] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5077 [ 2.537167] sunxi-mmc sdc0: detmode:gpio irq
5078 [ 2.537198] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5079 [ 2.539695] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5080 [ 2.541065] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
5081 [ 2.541206] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
5082 [ 2.541347] sunxi-mmc sdc1: No vmmc regulator found
5083 [ 2.541353] sunxi-mmc sdc1: No vqmmc regulator found
5084 [ 2.541360] sunxi-mmc sdc1: No vdmmc regulator found
5085 [ 2.541366] sunxi-mmc sdc1: No vd33sw regulator found
5086 [ 2.541372] sunxi-mmc sdc1: No vd18sw regulator found
5087 [ 2.541378] sunxi-mmc sdc1: No vq33sw regulator found
5088 [ 2.541384] sunxi-mmc sdc1: No vq18sw regulator found
5089 [ 2.541756] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5090 [ 2.542140] sunxi-mmc sdc1: set host busy
5091 [ 2.542223] mmc:failed to get gpios
5092 [ 2.542515] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
5093 [ 2.544240] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5094 [ 2.556988] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5095 [ 2.567590] mmc0: host does not support reading read-only switch, assuming write-enable
5096 [ 2.569443] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
5097 [ 2.569513] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
5098 [ 2.569656] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
5099 [ 2.569747] mmc0: new high speed SDXC card at address 0001
5100 [ 2.570802] mmcblk0: mmc0:0001 SD16G 59.5 GiB
5101 [ 2.572337] mmcblk0: p1
5102 [ 2.573637] sunxi-mmc sdc1: detmode:manually by software
5103 [ 2.576045] ledtrig-cpu: registered to indicate activity on CPUs
5104 [ 2.576546] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
5105 [ 2.577391] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
5106 [ 2.577425] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5107 [ 2.579918] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5108 [ 2.581843] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
5109 [ 2.582681] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
5110 [ 2.583518] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
5111 [ 2.584356] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
5112 [ 2.584394] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
5113 [ 2.584398] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
5114 [ 2.584402] sunxi_emce_probe()590emce hw init failed!
5115 [ 2.584429] emce: probe of emce failed with error -2
5116 [ 2.584698] hidraw: raw HID events driver (C) Jiri Kosina
5117 [ 2.589321] usbcore: registered new interface driver usbhid
5118 [ 2.589329] usbhid: USB HID core driver
5119 [ 2.590831] optee: probing for conduit method from DT.
5120 [ 2.590844] optee: api uid mismatch
5121 [ 2.591387] usbcore: registered new interface driver snd-usb-audio
5122 [ 2.592969] [sunxi_hdmi_codec_init] driver and deivce register finished.
5123 [ 2.594731] [sunxi_internal_codec_probe]:get audio avcc failed
5124 [ 2.594772] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
5125 [ 2.595003] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
5126 [ 2.597532] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
5127 [ 2.599510] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
5128 [ 2.599523] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
5129 [ 2.601936] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
5130 [ 2.601959] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
5131 [ 2.606020] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
5132 [ 2.607650] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
5133 [ 2.609571] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
5134 [ 2.612620] pktgen: Packet Generator for packet performance testing. Version: 2.75
5135 [ 2.613063] u32 classifier
5136 [ 2.613070] Actions configured
5137 [ 2.613084] Netfilter messages via NETLINK v0.30.
5138 [ 2.613112] nfnl_acct: registering with nfnetlink.
5139 [ 2.613436] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
5140 [ 2.613748] ctnetlink v0.93: registering with nfnetlink.
5141 [ 2.614517] xt_time: kernel timezone is -0000
5142 [ 2.614541] IPVS: Registered protocols (TCP, UDP)
5143 [ 2.614649] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
5144 [ 2.614777] IPVS: Creating netns size=1928 id=0
5145 [ 2.614915] IPVS: ipvs loaded.
5146 [ 2.614923] IPVS: [rr] scheduler registered.
5147 [ 2.615020] ipip: IPv4 and MPLS over IPv4 tunneling driver
5148 [ 2.615732] gre: GRE over IPv4 demultiplexor driver
5149 [ 2.615741] ip_gre: GRE over IPv4 tunneling driver
5150 [ 2.617217] IPv4 over IPsec tunneling driver
5151 [ 2.618081] ip_tables: (C) 2000-2006 Netfilter Core Team
5152 [ 2.618374] arp_tables: arp_tables: (C) 2002 David S. Miller
5153 [ 2.618439] Initializing XFRM netlink socket
5154 [ 2.618473] IPsec XFRM device driver
5155 [ 2.619316] NET: Registered protocol family 10
5156 [ 2.621244] mip6: Mobile IPv6
5157 [ 2.621282] ip6_tables: (C) 2000-2006 Netfilter Core Team
5158 [ 2.622597] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
5159 [ 2.624303] NET: Registered protocol family 17
5160 [ 2.624344] NET: Registered protocol family 15
5161 [ 2.624512] Bridge firewalling registered
5162 [ 2.624645] Bluetooth: RFCOMM TTY layer initialized
5163 [ 2.624662] Bluetooth: RFCOMM socket layer initialized
5164 [ 2.624692] Bluetooth: RFCOMM ver 1.11
5165 [ 2.624706] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
5166 [ 2.624711] Bluetooth: BNEP filters: protocol multicast
5167 [ 2.624725] Bluetooth: BNEP socket layer initialized
5168 [ 2.624730] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
5169 [ 2.624742] Bluetooth: HIDP socket layer initialized
5170 [ 2.624829] l2tp_core: L2TP core driver, V2.0
5171 [ 2.624843] l2tp_ppp: PPPoL2TP kernel driver, V2.0
5172 [ 2.624849] 8021q: 802.1Q VLAN Support v1.8
5173 [ 2.625048] sctp: Hash tables configured (bind 256/256)
5174 [ 2.625633] Key type dns_resolver registered
5175 [ 2.625774] Registered cp15_barrier emulation handler
5176 [ 2.625790] Registered setend emulation handler
5177 [ 2.626760] registered taskstats version 1
5178 [ 2.638328] zswap: default zpool zbud not available
5179 [ 2.638336] zswap: pool creation failed
5180 [ 2.641182] Btrfs loaded, crc32c=crc32c-arm64-hw
5181 [ 2.641924] HDMI 2.0 driver init start!
5182 [ 2.641939] boot_hdmi=true
5183 [ 2.642724] Can not find the node of esm
5184 [ 2.642744] ERROR: pinctrl_get for HDMI2.0 DDC fail
5185 [ 2.642832] Get hdmi_power0:vcc-hdmi
5186 [ 2.642873] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
5187 [ 2.643061] Get hdmi_power1:vdd-hdmi
5188 [ 2.643085] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
5189 [ 2.644764] hdmi_cec_init
5190 [ 2.645234] [DISP] disp_device_attached,line:146:
5191 [ 2.645243] attached ok, mgr0<-->device0, type=4
5192 [ 2.645254] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
5193 [ 2.645265] [DISP] disp_hdmi_set_mode,line:648:
5194 [ 2.645270] hdmi_set_mode is null!
5195 [ 2.647260] HDMI2.0 module init end
5196 [ 2.658460] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
5197 [ 2.661895] cpu cpu1: opp_list_debug_create_link: Failed to create link
5198 [ 2.661907] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
5199 [ 2.661938] cpu cpu2: opp_list_debug_create_link: Failed to create link
5200 [ 2.661946] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
5201 [ 2.661976] cpu cpu3: opp_list_debug_create_link: Failed to create link
5202 [ 2.661983] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
5203 [ 2.664324] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
5204 [ 2.665265] get det_vbus is fail, 84
5205 [ 2.665272] get id is fail, 84
5206 [ 2.665750] sunxi-rtc rtc: setting system clock to 1970-01-01 00:10:40 UTC (640)
5207 [ 2.669552] ALSA device list:
5208 [ 2.669560] #0: audiocodec
5209 [ 2.669564] #1: sndahub
5210 [ 2.669568] #2: sndhdmi
5211 [ 2.671225] Freeing unused kernel memory: 3008K
5212 [ 2.716495] random: systemd-udevd: uninitialized urandom read (16 bytes read)
5213 [ 2.718640] random: systemd-udevd: uninitialized urandom read (16 bytes read)
5214 [ 2.721557] random: systemd-udevd: uninitialized urandom read (16 bytes read)
5215 [ 2.790590] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
5216 [ 2.957015] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
5217 [ 3.050291] HDMI cable is connected
5218 [ 3.310321] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
5219 [ 3.530364] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
5220 [ 3.530373] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
5221 [ 3.530378] usb 4-1: Product: Rapoo 2.4G Wireless Device
5222 [ 3.530383] usb 4-1: Manufacturer: RAPOO
5223 [ 3.538164] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
5224 [ 3.538556] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
5225 [ 3.544172] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
5226 [ 3.601540] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
5227 [ 3.605612] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
5228 [ 3.662259] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
5229 [ 4.184305] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
5230 [ 5.107278] systemd[1]: System time before build time, advancing clock.
5231 [ 5.111989] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
5232 [ 5.112548] cgroup: cgroup2: unknown option "nsdelegate"
5233 [ 5.132864] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
5234 [ 5.132888] systemd[1]: Detected architecture arm64.
5235 [ 5.134059] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
5236 [ 5.144226] systemd[1]: Hostname set to <opi>.
5237 [ 5.171708] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
5238 [ 6.785192] (sd-execut[1457]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
5239 [ 6.827008]
5240 insmod_device_driver
5241
5242 [ 6.827282] device_chose finished 124!
5243 [ 7.151137] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
5244 [ 7.389532] systemd[1]: Queued start job for default target graphical.target.
5245 [ 7.396979] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
5246 [ 7.399185] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
5247 [ 7.401496] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
5248 [ 7.402807] systemd[1]: Created slice user.slice - User and Session Slice.
5249 [ 7.403444] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
5250 [ 7.404067] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
5251 [ 7.404407] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
5252 [ 7.404970] systemd[1]: Reached target slices.target - Slice Units.
5253 [ 7.405321] systemd[1]: Reached target swap.target - Swaps.
5254 [ 7.405576] systemd[1]: Reached target time-set.target - System Time Set.
5255 [ 7.406053] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
5256 [ 7.423447] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
5257 [ 7.424620] systemd[1]: Listening on syslog.socket - Syslog Socket.
5258 [ 7.425513] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
5259 [ 7.426148] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
5260 [ 7.427828] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
5261 [ 7.428788] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
5262 [ 7.429848] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
5263 [ 7.432086] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
5264 [ 7.432982] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
5265 [ 7.437017] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
5266 [ 7.441506] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
5267 [ 7.446652] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
5268 [ 7.447895] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
5269 [ 7.448829] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
5270 [ 7.456252] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
5271 [ 7.461856] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
5272 [ 7.467672] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
5273 [ 7.475944] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
5274 [ 7.482378] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
5275 [ 7.497854] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
5276 [ 7.505020] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
5277 [ 7.513050] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
5278 [ 7.520455] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
5279 [ 7.521688] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
5280 [ 7.530978] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
5281 [ 7.537310] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
5282 [ 7.542303] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
5283 [ 7.552627] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
5284 [ 7.554939] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
5285 [ 7.557337] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
5286 [ 7.559936] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
5287 [ 7.563508] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
5288 [ 7.567852] systemd[1]: modprobe@configfs.service: Deactivated successfully.
5289 [ 7.568459] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
5290 [ 7.571252] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
5291 [ 7.572800] fuse init (API version 7.26)
5292 [ 7.613687] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
5293 [ 7.617515] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
5294 [ 7.622990] systemd[1]: modprobe@drm.service: Deactivated successfully.
5295 [ 7.623514] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
5296 [ 7.625599] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
5297 [ 7.626142] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
5298 [ 7.628359] systemd[1]: modprobe@fuse.service: Deactivated successfully.
5299 [ 7.628905] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
5300 [ 7.631043] systemd[1]: modprobe@loop.service: Deactivated successfully.
5301 [ 7.631176] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
5302 [ 7.631706] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
5303 [ 7.634441] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
5304 [ 7.642017] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
5305 [ 7.647591] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
5306 [ 7.648414] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
5307 [ 7.648423] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
5308 [ 7.648613] spidev spi1.1: Deleting spi1.1
5309 [ 7.649260] fbtft_device: GPIOS used by 'fb_st7735r':
5310 [ 7.649268] fbtft_device: 'reset' = GPIO73
5311 [ 7.649272] fbtft_device: 'dc' = GPIO70
5312 [ 7.649284] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
5313 [ 7.649290] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
5314 [ 7.687336] WCN: marlin_init entry!
5315 [ 7.688479] WCN: marlin_parse_dt reset gpio=211
5316 [ 7.688490] WCN_ERR: gpio reset request err: 211
5317 [ 7.688496] WCN: wcn config bt wake host
5318 [ 7.689006] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
5319 [ 7.689225] WCN: wcn config wifi wake host
5320 [ 7.689248] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
5321 [ 7.692552] sdiohal:sdiohal_init ok
5322 [ 7.693427] WCN: marlin_probe ok!
5323 [ 7.702198] mtty_probe init device addr: 0xffffffc03b74c000
5324 [ 7.702415] -->rfkill_bluetooth_init
5325 [ 7.702606] <--rfkill_bluetooth_init
5326 [ 7.745836] WCN: start_marlin [MARLIN_WIFI]
5327 [ 7.745849] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
5328 [ 7.745853] WCN: the first power on start
5329 [ 7.766598] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
5330 [ 7.767360] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
5331 [ 7.773105] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
5332 [ 7.773959] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
5333 [ 7.780312] systemd[1]: Starting systemd-sysusers.service - Create System Users...
5334 [ 7.788980] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
5335 [ 7.801249] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
5336 [ 7.803813] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
5337 [ 7.859166] systemd[1]: Finished systemd-sysusers.service - Create System Users.
5338 [ 7.860302] WCN: marlin chip en pull up
5339 [ 7.865715] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
5340 [ 7.886985] sdiohal:sdiohal_scan_card
5341 [ 7.887008] sunxi-wlan soc@03000000:wlan: bus_index: 1
5342 [ 7.887335] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
5343 [ 7.903713] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5344 [ 7.921174] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
5345 [ 7.922022] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
5346 [ 7.922042] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5347 [ 7.924568] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5348 [ 7.927805] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5349 [ 7.943663] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
5350 [ 7.954915] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
5351 [ 7.955678] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
5352 [ 7.955761] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
5353 [ 7.956446] mmc1: new ultra high speed SDR104 SDIO card at address 8800
5354 [ 7.957308] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
5355 [ 7.957495] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
5356 [ 7.957518] WCN: marlin_scan_finish!
5357 [ 7.957522] sdiohal:probe ok
5358 [ 7.957533] sdiohal:scan end!
5359 [ 7.957539] WCN: then marlin start to download
5360 [ 7.957569] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
5361 [ 7.970097] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
5362 [ 7.972015] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
5363 [ 7.977767] systemd[1]: Mounting tmp.mount - /tmp...
5364 [ 7.984217] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
5365 [ 8.000771] systemd[1]: Mounted tmp.mount - /tmp.
5366 [ 8.003318] systemd[1]: Reached target local-fs.target - Local File Systems.
5367 [ 8.008578] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
5368 [ 8.013818] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
5369 [ 8.019504] systemd[1]: Starting console-setup.service - Set console font and keymap...
5370 [ 8.024942] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
5371 [ 8.040209] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
5372 [ 8.047139] systemd[1]: Starting ufw.service - Uncomplicated firewall...
5373 [ 8.051022] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
5374 [ 8.084374] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
5375 [ 8.092187] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
5376 [ 8.100670] systemd[1]: Finished console-setup.service - Set console font and keymap.
5377 [ 8.103043] systemd[1]: Received SIGRTMIN+20 from PID 1420 (plymouthd).
5378 [ 8.147246] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
5379 [ 8.153190] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
5380 [ 8.154607] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
5381 [ 8.155638] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
5382 [ 8.160081] systemd[1]: Finished ufw.service - Uncomplicated firewall.
5383 [ 8.177515] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
5384 [ 8.180109] systemd[1]: Reached target network-pre.target - Preparation for Network.
5385 [ 8.210840] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
5386 [ 8.451940] zram: Added device: zram0
5387 [ 8.452691] zram: Added device: zram1
5388 [ 8.453473] zram: Added device: zram2
5389 [ 8.485148] zswap: can't enable, initialization failed
5390 [ 8.531886] zram0: detected capacity change from 0 to 506396672
5391 [ 8.533302] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
5392 [ 8.547536] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
5393 [ 8.609483] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
5394 [ 8.615789] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
5395 [ 8.618153] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
5396 [ 8.618996] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
5397 [ 8.619587] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
5398 [ 8.987033] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
5399 [ 9.661041] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
5400 [ 9.697069] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
5401 [ 9.909975] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
5402 [ 10.000388] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
5403 [ 10.482601] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
5404 [ 10.482810] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
5405 [ 10.483353] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
5406 [ 10.496267] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
5407 [ 10.507236] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
5408 [ 10.515133] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
5409 [ 10.523273] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
5410 [ 10.532717] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
5411 [ 10.533541] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
5412 [ 10.540494] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
5413 [ 10.541319] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
5414 [ 10.544077] systemd[1]: modprobe@loop.service: Deactivated successfully.
5415 [ 10.547054] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
5416 [ 10.549615] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
5417 [ 10.549951] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
5418 [ 10.610953] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
5419 [ 10.612020] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
5420 [ 10.619382] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
5421 [ 10.631739] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
5422 [ 10.676370] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
5423 [ 10.723858] sunxi-bt soc@03000000:bt: block state already is 1
5424 [ 10.729174] bluetooth_set_power: start_block=1
5425 [ 10.866278] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
5426 [ 10.872162] systemd[1]: Starting brltty.service - Braille Device Support...
5427 [ 11.013680] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
5428 [ 11.574902] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
5429 [ 11.595538] systemd[1]: Started brltty.service - Braille Device Support.
5430 [ 11.611377] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
5431 [ 11.742636] zram1: detected capacity change from 0 to 52428800
5432 [ 12.026952] WCN_ERR: btwifi_download_firmware request firmware error
5433 [ 15.819983] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
5434 [ 15.826001] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
5435 [ 15.888604] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
5436 [ 19.668573] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
5437 [ 19.674901] systemd[1]: Starting systemd-journald.service - Journal Service...
5438 [ 19.948113] systemd-journald[1838]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.1 (1656 of 2204 items, 1269760 file size, 766 bytes per hash table item), suggesting rotation.
5439 [ 19.948134] systemd-journald[1838]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
5440 [ 19.951727] systemd[1]: Started systemd-journald.service - Journal Service.
5441 [ 19.998127] systemd-journald[1838]: Received client request to flush runtime journal.
5442 [ 20.253092] IPVS: Creating netns size=1928 id=1
5443 [ 21.264355] random: crng init done
5444 [ 21.264368] random: 7 urandom warning(s) missed due to ratelimiting
5445 [ 38.880315] WCN_ERR: marlin download timeout
5446 [ 38.880327] sdiohal:sdiohal_runtime_put entry
5447 [ 38.880443] sdiohal:sdiohal_runtime_put wait xmit_cnt end
5448 [ 38.880492] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0
5449 [ 38.880500] bluetooth_set_power: end_block=1
5450 [ 38.891587] sdiohal err:sdiohal_adma_pt_write xmit_cnt:0 xmit_start:0,not have card
5451 [ 38.891609] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
5452 [ 38.891613] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
5453 [ 42.086720] unisoc_wifi: probe of unisoc_wifi failed with error -1
5454
5455 ### armbian-release:
5456
5457 # PLEASE DO NOT EDIT THIS FILE
5458 BOARD=orangepizero2
5459 BOARD_NAME="Orange Pi Zero2"
5460 BOARDFAMILY=sun50iw9
5461 BUILD_REPOSITORY_URL=https://github.com/armbian/build
5462 BUILD_REPOSITORY_COMMIT=ac829eb6
5463 LINUXFAMILY=sun50iw9
5464 ARCH=arm64
5465 IMAGE_TYPE=stable
5466 BOARD_TYPE=conf
5467 INITRD_ARCH=arm
5468 KERNEL_IMAGE_TYPE=Image
5469 FORCE_BOOTSCRIPT_UPDATE=yes
5470 VENDOR=Armbian
5471 BOOTSCRIPT_FORCE_UPDATE="yes"
5472 BOOTSCRIPT_DST="boot.cmd"
5473 VERSION=23.8.1
5474 REVISION=23.8.1
5475 BRANCH=legacy
5476
5477 ### boot environment:
5478
5479 verbosity=1
5480 console=serial
5481 #disp_mode=1080p60
5482 #fb0_width=1280
5483 #fb0_height=720
5484 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
5485 rootfstype=ext4
5486 overlays=spi-spidev
5487 param_spidev_spi_bus=1
5488 param_spidev_spi_cs=1
5489 extraargs=fbcon=map:1
5490 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
5491
5492 ### lsusb:
5493
5494 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
5495 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
5496 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
5497 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
5498 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
5499 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
5500 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
5501
5502 ### lscpu:
5503
5504 Architecture: aarch64
5505 CPU op-mode(s): 32-bit, 64-bit
5506 Byte Order: Little Endian
5507 CPU(s): 4
5508 On-line CPU(s) list: 0-3
5509 Vendor ID: ARM
5510 Model name: Cortex-A53
5511 Model: 4
5512 Thread(s) per core: 1
5513 Core(s) per cluster: 4
5514 Socket(s): -
5515 Cluster(s): 1
5516 Stepping: r0p4
5517 CPU(s) scaling MHz: 100%
5518 CPU max MHz: 1512.0000
5519 CPU min MHz: 480.0000
5520 BogoMIPS: 48.00
5521 Flags: fp asimd aes pmull sha1 sha2 crc32
5522
5523 ### cpuinfo:
5524
5525 processor : 0
5526 BogoMIPS : 48.00
5527 Features : fp asimd aes pmull sha1 sha2 crc32
5528 CPU implementer : 0x41
5529 CPU architecture: 8
5530 CPU variant : 0x0
5531 CPU part : 0xd03
5532 CPU revision : 4
5533
5534 processor : 1
5535 BogoMIPS : 48.00
5536 Features : fp asimd aes pmull sha1 sha2 crc32
5537 CPU implementer : 0x41
5538 CPU architecture: 8
5539 CPU variant : 0x0
5540 CPU part : 0xd03
5541 CPU revision : 4
5542
5543 processor : 2
5544 BogoMIPS : 48.00
5545 Features : fp asimd aes pmull sha1 sha2 crc32
5546 CPU implementer : 0x41
5547 CPU architecture: 8
5548 CPU variant : 0x0
5549 CPU part : 0xd03
5550 CPU revision : 4
5551
5552 processor : 3
5553 BogoMIPS : 48.00
5554 Features : fp asimd aes pmull sha1 sha2 crc32
5555 CPU implementer : 0x41
5556 CPU architecture: 8
5557 CPU variant : 0x0
5558 CPU part : 0xd03
5559 CPU revision : 4
5560
5561
5562 ### meminfo:
5563
5564 MemTotal: 989056 kB
5565 MemFree: 798740 kB
5566 MemAvailable: 887012 kB
5567 Buffers: 15096 kB
5568 Cached: 80252 kB
5569 SwapCached: 0 kB
5570 Active: 67012 kB
5571 Inactive: 51664 kB
5572 Active(anon): 23516 kB
5573 Inactive(anon): 652 kB
5574 Active(file): 43496 kB
5575 Inactive(file): 51012 kB
5576 Unevictable: 0 kB
5577 Mlocked: 0 kB
5578 SwapTotal: 494524 kB
5579 SwapFree: 494524 kB
5580 Dirty: 692 kB
5581 Writeback: 0 kB
5582 AnonPages: 23400 kB
5583 Mapped: 23472 kB
5584 Shmem: 828 kB
5585 Slab: 27944 kB
5586 SReclaimable: 9176 kB
5587 SUnreclaim: 18768 kB
5588 KernelStack: 2480 kB
5589 PageTables: 1148 kB
5590 NFS_Unstable: 0 kB
5591 Bounce: 0 kB
5592 WritebackTmp: 0 kB
5593 CommitLimit: 989052 kB
5594 Committed_AS: 83468 kB
5595 VmallocTotal: 263061440 kB
5596 VmallocUsed: 0 kB
5597 VmallocChunk: 0 kB
5598 CmaTotal: 16384 kB
5599 CmaFree: 7468 kB
5600 HugePages_Total: 0
5601 HugePages_Free: 0
5602 HugePages_Rsvd: 0
5603 HugePages_Surp: 0
5604 Hugepagesize: 2048 kB
5605
5606 ### virtual memory:
5607
5608 vm.admin_reserve_kbytes = 8192
5609 vm.block_dump = 0
5610 vm.compact_unevictable_allowed = 1
5611 vm.dirty_background_bytes = 0
5612 vm.dirty_background_ratio = 10
5613 vm.dirty_bytes = 0
5614 vm.dirty_expire_centisecs = 3000
5615 vm.dirty_ratio = 20
5616 vm.dirtytime_expire_seconds = 43200
5617 vm.dirty_writeback_centisecs = 500
5618 vm.extfrag_threshold = 500
5619 vm.extra_free_kbytes = 0
5620 vm.hugepages_treat_as_movable = 0
5621 vm.hugetlb_shm_group = 0
5622 vm.laptop_mode = 0
5623 vm.legacy_va_layout = 0
5624 vm.lowmem_reserve_ratio = 256 32
5625 vm.max_map_count = 65530
5626 vm.min_free_kbytes = 3937
5627 vm.mmap_min_addr = 4096
5628 vm.mmap_rnd_bits = 18
5629 vm.mmap_rnd_compat_bits = 11
5630 vm.nr_hugepages = 0
5631 vm.nr_overcommit_hugepages = 0
5632 vm.nr_pdflush_threads = 0
5633 vm.oom_dump_tasks = 1
5634 vm.oom_kill_allocating_task = 0
5635 vm.overcommit_kbytes = 0
5636 vm.overcommit_memory = 0
5637 vm.overcommit_ratio = 50
5638 vm.page-cluster = 0
5639 vm.panic_on_oom = 0
5640 vm.percpu_pagelist_fraction = 0
5641 vm.stat_interval = 1
5642 vm.swappiness = 100
5643 vm.user_reserve_kbytes = 30000
5644 vm.vfs_cache_pressure = 100
5645 vm.watermark_scale_factor = 10
5646
5647 ### ip addr:
5648
5649 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
5650 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
5651 inet XXX.XXX.0.1/8 scope host lo
5652 valid_lft forever preferred_lft forever
5653 inet6 ::1/128 scope host noprefixroute
5654 valid_lft forever preferred_lft forever
5655 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
5656 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
5657 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
5658 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
5659 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
5660 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
5661 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
5662 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
5663 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
5664 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
5665 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
5666 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
5667 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
5668 link/tunnel6 :: brd ::
5669 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
5670 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
5671 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
5672 link/tunnel6 :: brd ::
5673
5674 ### partitions:
5675
5676 major minor #blocks name
5677
5678 179 0 62410752 mmcblk0
5679 179 1 61763584 mmcblk0p1
5680 253 0 494528 zram0
5681 253 1 51200 zram1
5682
5683 ### df:
5684
5685 udev 466M 0 466M 0% /dev
5686 tmpfs 97M 868K 96M 1% /run
5687 /dev/mmcblk0p1 58G 6.4G 51G 12% /
5688 tmpfs 483M 0 483M 0% /dev/shm
5689 tmpfs 5.0M 0 5.0M 0% /run/lock
5690 tmpfs 483M 4.0K 483M 1% /tmp
5691 /dev/zram1 47M 7.9M 36M 19% /var/log
5692
5693 ### lsblk:
5694
5695 NAME FSTYPE SIZE MOUNTPOINT UUID
5696 mmcblk0 59.5G
5697 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
5698 zram1 50M /var/log
5699 zram2 0B
5700
5701 ### zramctl:
5702
5703 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
5704 /dev/zram1 lz4 50M 7.7M 2.1M 2.5M 4 /var/log
5705 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
5706
5707 ### mtab:
5708
5709 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
5710 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
5711 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
5712
5713 ### mmc0:0001 info:
5714
5715 manfid: 0x0000fe
5716 cid: fe3432534431364720000000690091f5
5717 fwrev: 0x0
5718 csd: 400e00325b590001dc277f800a40008b
5719 ocr: 0x00200000
5720 type: SD
5721 date: 01/2009
5722 hwrev: 0x2
5723 dsr: 0x404
5724 serial: 0x00000069
5725 erase_size: 512
5726 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
5727 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
5728 scr: 0285808300000000
5729 oemid: 0x3432
5730 preferred_erase_size: 4194304
5731 name: SD16G
5732
5733 ### Boot system health:
5734
5735 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
5736 14:27:49 1512 MHz 1.56 19% 9% 6% 0% 3% 0% 47.8 °C 0/5
5737 14:27:50 1512 MHz 1.56 89% 17% 17% 1% 53% 0% 47.2 °C 0/5
5738 14:27:50 1512 MHz 2.56 98% 34% 50% 1% 12% 0% 47.2 °C 0/5
5739 14:27:51 1512 MHz 2.56 100% 34% 61% 0% 3% 0% 49.4 °C 0/5
5740 14:27:51 1512 MHz 2.56 100% 39% 51% 1% 7% 0% 49.4 °C 0/5
5741
5742 ### Activated 1 lzo zram swap devices with 482MB each.
5743 ### Activated Armbian ramlog partition with lz4 compression
5744
5745 Mon Sep 25 02:38:27 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
5746
5747 ### dmesg:
5748
5749 [ 0.000000] Booting Linux on physical CPU 0x0
5750 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
5751 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
5752 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
5753 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
5754 [ 0.000000] On node 0 totalpages: 262144
5755 [ 0.000000] DMA zone: 4096 pages used for memmap
5756 [ 0.000000] DMA zone: 0 pages reserved
5757 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
5758 [ 0.000000] psci: probing for conduit method from DT.
5759 [ 0.000000] psci: PSCIv1.0 detected in firmware.
5760 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
5761 [ 0.000000] psci: Trusted OS migration not required
5762 [ 0.000000] psci: SMC Calling Convention v1.0
5763 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
5764 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
5765 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
5766 [ 0.000000] Detected VIPT I-cache on CPU0
5767 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
5768 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
5769 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
5770 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
5771 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
5772 [ 0.000000] log_buf_len min size: 131072 bytes
5773 [ 0.000000] log_buf_len: 524288 bytes
5774 [ 0.000000] early log buf free: 129352(98%)
5775 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
5776 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
5777 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
5778 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
5779 [ 0.000000] Virtual kernel memory layout:
5780 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
5781 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
5782 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
5783 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
5784 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
5785 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
5786 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
5787 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
5788 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
5789 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
5790 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
5791 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
5792 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
5793 [ 0.000000] Preemptible hierarchical RCU implementation.
5794 [ 0.000000] Build-time adjustment of leaf fanout to 64.
5795 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
5796 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
5797 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
5798 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
5799 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
5800 [ 0.000238] Console: colour dummy device 80x25
5801 [ 0.000253] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
5802 [ 0.000262] pid_max: default: 32768 minimum: 301
5803 [ 0.000458] Security Framework initialized
5804 [ 0.000467] AppArmor: AppArmor disabled by boot time parameter
5805 [ 0.000582] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
5806 [ 0.000588] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
5807 [ 0.001861] sched-energy: CPU device node has no sched-energy-costs
5808 [ 0.001876] Invalid sched_group_energy for CPU0
5809 [ 0.001883] CPU0: update cpu_capacity 1024
5810 [ 0.008972] ASID allocator initialised with 32768 entries
5811 [ 0.027956] BOOTEVENT: 27.942499: ON
5812 [ 0.055924] Detected VIPT I-cache on CPU1
5813 [ 0.055978] Invalid sched_group_energy for CPU1
5814 [ 0.055982] CPU1: update cpu_capacity 1024
5815 [ 0.055985] CPU1: Booted secondary processor [410fd034]
5816 [ 0.079315] Detected VIPT I-cache on CPU2
5817 [ 0.079353] Invalid sched_group_energy for CPU2
5818 [ 0.079357] CPU2: update cpu_capacity 1024
5819 [ 0.079360] CPU2: Booted secondary processor [410fd034]
5820 [ 0.102713] Detected VIPT I-cache on CPU3
5821 [ 0.102747] Invalid sched_group_energy for CPU3
5822 [ 0.102750] CPU3: update cpu_capacity 1024
5823 [ 0.102753] CPU3: Booted secondary processor [410fd034]
5824 [ 0.102832] Brought up 4 CPUs
5825 [ 0.102840] SMP: Total of 4 processors activated.
5826 [ 0.102848] CPU features: detected feature: 32-bit EL0 Support
5827 [ 0.102854] CPU features: detected feature: Kernel page table isolation (KPTI)
5828 [ 0.106614] CPU: All CPU(s) started at EL1
5829 [ 0.106637] alternatives: patching kernel code
5830 [ 0.106815] Invalid sched_group_energy for CPU3
5831 [ 0.106824] CPU3: update max cpu_capacity 1024
5832 [ 0.106830] Invalid sched_group_energy for Cluster3
5833 [ 0.106835] Invalid sched_group_energy for CPU2
5834 [ 0.106840] Invalid sched_group_energy for Cluster2
5835 [ 0.106845] Invalid sched_group_energy for CPU1
5836 [ 0.106851] Invalid sched_group_energy for Cluster1
5837 [ 0.106855] Invalid sched_group_energy for CPU0
5838 [ 0.106861] Invalid sched_group_energy for Cluster0
5839 [ 0.108293] devtmpfs: initialized
5840 [ 0.112726] CPU1: update max cpu_capacity 1024
5841 [ 0.143431] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
5842 [ 0.143451] futex hash table entries: 1024 (order: 5, 131072 bytes)
5843 [ 0.144111] xor: measuring software checksum speed
5844 [ 0.176260] 8regs : 1933.200 MB/sec
5845 [ 0.209639] 8regs_prefetch: 1720.800 MB/sec
5846 [ 0.243027] 32regs : 2287.200 MB/sec
5847 [ 0.276414] 32regs_prefetch: 1935.600 MB/sec
5848 [ 0.276419] xor: using function: 32regs (2287.200 MB/sec)
5849 [ 0.276479] atomic64_test: passed
5850 [ 0.276485] pinctrl core: initialized pinctrl subsystem
5851 [ 0.277657] NET: Registered protocol family 16
5852 [ 0.278906] dump_class_init,861, success
5853 [ 0.296479] cpuidle: using governor menu
5854 [ 0.297894] sunxi iommu: irq = 8
5855 [ 0.298211] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
5856 [ 0.298229] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
5857 [ 0.299634] DMA: preallocated 256 KiB pool for atomic allocations
5858 [ 0.301012] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
5859 [ 0.315393] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
5860 [ 0.319314] iommu: Adding device 1c0e000.ve to group 0
5861 [ 0.319820] iommu: Adding device 1c00000.vp9 to group 0
5862 [ 0.331245] iommu: Adding device 1000000.disp to group 0
5863 [ 0.332650] iommu: Adding device 1480000.g2d to group 0
5864 [ 0.335865] iommu: Adding device csi0 to group 0
5865 [ 0.336319] iommu: Adding device csi1 to group 0
5866 [ 0.337515] iommu: Adding device 6600800.vind:scaler@0 to group 0
5867 [ 0.337814] iommu: Adding device 6600800.vind:scaler@1 to group 0
5868 [ 0.338113] iommu: Adding device 6600800.vind:scaler@2 to group 0
5869 [ 0.338403] iommu: Adding device 6600800.vind:scaler@3 to group 0
5870 [ 0.338693] iommu: Adding device 6600800.vind:scaler@4 to group 0
5871 [ 0.338987] iommu: Adding device 6600800.vind:scaler@5 to group 0
5872 [ 0.339927] iommu: Adding device vinc0 to group 0
5873 [ 0.340536] iommu: Adding device vinc1 to group 0
5874 [ 0.341999] iommu: Adding device 1420000.deinterlace to group 0
5875 [ 0.387969] HugeTLB registered 2 MB page size, pre-allocated 0 pages
5876 [ 0.444207] raid6: int64x1 gen() 393 MB/s
5877 [ 0.500872] raid6: int64x1 xor() 365 MB/s
5878 [ 0.557597] raid6: int64x2 gen() 590 MB/s
5879 [ 0.614378] raid6: int64x2 xor() 512 MB/s
5880 [ 0.671168] raid6: int64x4 gen() 840 MB/s
5881 [ 0.727954] raid6: int64x4 xor() 629 MB/s
5882 [ 0.784771] raid6: int64x8 gen() 965 MB/s
5883 [ 0.841502] raid6: int64x8 xor() 655 MB/s
5884 [ 0.898290] raid6: neonx1 gen() 648 MB/s
5885 [ 0.955061] raid6: neonx1 xor() 641 MB/s
5886 [ 1.011844] raid6: neonx2 gen() 976 MB/s
5887 [ 1.068646] raid6: neonx2 xor() 820 MB/s
5888 [ 1.125400] raid6: neonx4 gen() 1287 MB/s
5889 [ 1.182198] raid6: neonx4 xor() 966 MB/s
5890 [ 1.238981] raid6: neonx8 gen() 1324 MB/s
5891 [ 1.295733] raid6: neonx8 xor() 991 MB/s
5892 [ 1.295738] raid6: using algorithm neonx8 gen() 1324 MB/s
5893 [ 1.295743] raid6: .... xor() 991 MB/s, rmw enabled
5894 [ 1.295749] raid6: using intx1 recovery algorithm
5895 [ 1.295881] pwm module init!
5896 [ 1.300143] sunxi-pm debug v3.10
5897 [ 1.301215] SCSI subsystem initialized
5898 [ 1.301842] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
5899 [ 1.301924] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
5900 [ 1.302044] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
5901 [ 1.302561] spi spi0: master is unqueued, this is deprecated
5902 [ 1.302868] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
5903 [ 1.303441] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
5904 [ 1.303519] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
5905 [ 1.303635] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
5906 [ 1.304098] spi spi1: master is unqueued, this is deprecated
5907 [ 1.304403] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
5908 [ 1.305208] usbcore: registered new interface driver usbfs
5909 [ 1.305292] usbcore: registered new interface driver hub
5910 [ 1.305365] usbcore: registered new device driver usb
5911 [ 1.305526] sunxi_i2c_adap_init()2522 - init
5912 [ 1.306099] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
5913 [ 1.306194] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
5914 [ 1.306202] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
5915 [ 1.306217] twi3 supply twi not found, using dummy regulator
5916 [ 1.306291] twi_request_gpio()451 - [i2c3] init name: twi3
5917 [ 1.307063] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
5918 [ 1.307144] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
5919 [ 1.307151] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
5920 [ 1.307165] twi5 supply twi not found, using dummy regulator
5921 [ 1.307238] twi_request_gpio()451 - [i2c5] init name: twi5
5922 [ 1.307723] axp20x-i2c 5-0036: AXP20x variant AXP806 found
5923 [ 1.326445] random: fast init done
5924 [ 1.337599] axp20x-i2c 5-0036: AXP20X driver loaded
5925 [ 1.338134] media: Linux media interface: v0.10
5926 [ 1.338214] Linux video capture interface: v2.00
5927 [ 1.338950] Advanced Linux Sound Architecture Driver Initialized.
5928 [ 1.339676] Bluetooth: Core ver 2.22
5929 [ 1.339753] NET: Registered protocol family 31
5930 [ 1.339759] Bluetooth: HCI device and connection manager initialized
5931 [ 1.339775] Bluetooth: HCI socket layer initialized
5932 [ 1.339788] Bluetooth: L2CAP socket layer initialized
5933 [ 1.339825] Bluetooth: SCO socket layer initialized
5934 [ 1.340637] [DISP]disp_module_init
5935 [ 1.341879] [DISP] parser_disp_init_para,line:1403:
5936 [ 1.341888] of_property_read fb0_width fail
5937 [ 1.341898] [DISP] disp_init,line:2215:
5938 [ 1.341904] smooth display screen:0 type:4 mode:10
5939 [ 1.359383] [DISP]disp_module_init finish
5940 [ 1.360268] clocksource: Switched to clocksource arch_sys_counter
5941 [ 1.360527] VFS: Disk quotas dquot_6.6.0
5942 [ 1.360615] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
5943 [ 1.361355] Console: switching to colour frame buffer device 240x67
5944 [ 1.404965] NET: Registered protocol family 2
5945 [ 1.405091] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
5946 [ 1.420527] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
5947 [ 1.420600] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
5948 [ 1.420724] TCP: Hash tables configured (established 8192 bind 8192)
5949 [ 1.420812] UDP hash table entries: 512 (order: 2, 16384 bytes)
5950 [ 1.420841] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
5951 [ 1.421169] NET: Registered protocol family 1
5952 [ 1.421788] RPC: Registered named UNIX socket transport module.
5953 [ 1.421793] RPC: Registered udp transport module.
5954 [ 1.421796] RPC: Registered tcp transport module.
5955 [ 1.421799] RPC: Registered tcp NFSv4.1 backchannel transport module.
5956 [ 1.422067] Trying to unpack rootfs image as initramfs...
5957 [ 2.176429] Freeing initrd memory: 17256K
5958 [ 2.177558] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
5959 [ 2.181455] audit: initializing netlink subsys (disabled)
5960 [ 2.181510] audit: type=2000 audit(2.176:1): initialized
5961 [ 2.182415] workingset: timestamp_bits=45 max_order=18 bucket_order=0
5962 [ 2.193668] DLM installed
5963 [ 2.195511] squashfs: version 4.0 (2009/01/31) Phillip Lougher
5964 [ 2.195852] Registering sdcardfs 0.1
5965 [ 2.196316] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
5966 [ 2.197871] ntfs: driver 2.1.32 [Flags: R/W].
5967 [ 2.204515] NET: Registered protocol family 38
5968 [ 2.204881] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
5969 [ 2.205015] io scheduler noop registered
5970 [ 2.205022] io scheduler deadline registered
5971 [ 2.205184] io scheduler cfq registered (default)
5972 [ 2.207233] failed to get easy_light_used assign
5973 [ 2.207243] failed to get normal led pin assign
5974 [ 2.207249] failed to get standby led pin assign
5975 [ 2.207254] failed to get standby led pin assign
5976 [ 2.207259] these is zero number for gpio
5977 [ 2.207264] gpio_init finish with uesd
5978 [ 2.210400] uart uart0: get regulator failed
5979 [ 2.210603] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
5980 [ 2.210625] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
5981 [ 2.210711] console [ttyS0] enabled
5982 [ 2.211510] uart uart1: get regulator failed
5983 [ 2.211708] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
5984 [ 2.212410] uart uart5: get regulator failed
5985 [ 2.212594] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
5986 [ 2.213915] misc dump reg init
5987 [ 2.215056] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
5988 [ 2.215392] Unable to detect cache hierarchy for CPU 0
5989 [ 2.229485] brd: module loaded
5990 [ 2.237791] loop: module loaded
5991 [ 2.237983] [NAND][NE] Not found valid nand node on dts
5992 [ 2.238568] Get boot type cmd line fail
5993 [ 2.239150] sunxi-bt soc@03000000:bt: Missing bt_power.
5994 [ 2.239160] sunxi-bt soc@03000000:bt: bt_power_name ((null))
5995 [ 2.239167] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
5996 [ 2.239174] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
5997 [ 2.239230] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
5998 [ 2.239301] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
5999 [ 2.240148] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
6000 [ 2.240159] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
6001 [ 2.240166] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
6002 [ 2.240174] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
6003 [ 2.240181] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
6004 [ 2.240211] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
6005 [ 2.240245] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
6006 [ 2.240311] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
6007 [ 2.240332] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
6008 [ 2.241315] [ADDR_MGT] addr_mgt_probe: success.
6009 [ 2.247933] tun: Universal TUN/TAP device driver, 1.6
6010 [ 2.247945] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
6011 [ 2.249924] gmac-power0: NULL
6012 [ 2.249934] gmac-power1: NULL
6013 [ 2.249940] gmac-power2: NULL
6014 [ 2.250894] PPP generic driver version 2.4.2
6015 [ 2.251187] PPP BSD Compression module registered
6016 [ 2.251197] PPP Deflate Compression module registered
6017 [ 2.251225] PPP MPPE Compression module registered
6018 [ 2.251234] NET: Registered protocol family 24
6019 [ 2.251267] PPTP driver version 0.8.5
6020 [ 2.251630] usbcore: registered new interface driver r8152
6021 [ 2.251705] usbcore: registered new interface driver asix
6022 [ 2.251803] usbcore: registered new interface driver ax88179_178a
6023 [ 2.251872] usbcore: registered new interface driver cdc_ether
6024 [ 2.251932] usbcore: registered new interface driver net1080
6025 [ 2.252001] usbcore: registered new interface driver cdc_subset
6026 [ 2.252068] usbcore: registered new interface driver zaurus
6027 [ 2.252156] usbcore: registered new interface driver cdc_ncm
6028 [ 2.252163] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
6029 [ 2.252552] get drv_vbus is fail, 84
6030 [ 2.252561] get ehci0-controller, regulator_io is no nocare
6031 [ 2.252825] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
6032 [ 2.252831] [sunxi-ehci0]: Not init ehci0
6033 [ 2.252946] get ehci1-controller, regulator_io is no nocare
6034 [ 2.253136] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
6035 [ 2.253195] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
6036 [ 2.253222] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
6037 [ 2.253891] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
6038 [ 2.270279] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
6039 [ 2.270552] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
6040 [ 2.270560] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
6041 [ 2.270568] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
6042 [ 2.270575] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
6043 [ 2.270582] usb usb1: SerialNumber: sunxi-ehci
6044 [ 2.271442] hub 1-0:1.0: USB hub found
6045 [ 2.271486] hub 1-0:1.0: 1 port detected
6046 [ 2.272176] get drv_vbus is fail, 84
6047 [ 2.272184] get ehci2-controller, regulator_io is no nocare
6048 [ 2.272428] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
6049 [ 2.272479] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
6050 [ 2.272503] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
6051 [ 2.272783] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
6052 [ 2.283632] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
6053 [ 2.283861] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
6054 [ 2.283870] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
6055 [ 2.283878] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
6056 [ 2.283885] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
6057 [ 2.283892] usb usb2: SerialNumber: sunxi-ehci
6058 [ 2.284749] hub 2-0:1.0: USB hub found
6059 [ 2.284793] hub 2-0:1.0: 1 port detected
6060 [ 2.285459] get drv_vbus is fail, 84
6061 [ 2.285466] get ehci3-controller, regulator_io is no nocare
6062 [ 2.285708] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
6063 [ 2.285758] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
6064 [ 2.285783] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
6065 [ 2.286072] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
6066 [ 2.296944] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
6067 [ 2.297151] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
6068 [ 2.297159] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
6069 [ 2.297167] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
6070 [ 2.297174] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
6071 [ 2.297181] usb usb3: SerialNumber: sunxi-ehci
6072 [ 2.298000] hub 3-0:1.0: USB hub found
6073 [ 2.298055] hub 3-0:1.0: 1 port detected
6074 [ 2.298981] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
6075 [ 2.299346] get drv_vbus is fail, 84
6076 [ 2.299354] get ohci0-controller, regulator_io is no nocare
6077 [ 2.299693] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
6078 [ 2.299700] [sunxi-ohci0]: Not init ohci0
6079 [ 2.299812] get ohci1-controller, regulator_io is no nocare
6080 [ 2.299981] hci: request ohci1-controller gpio:80
6081 [ 2.300057] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
6082 [ 2.300109] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
6083 [ 2.300135] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
6084 [ 2.300223] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
6085 [ 2.361139] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
6086 [ 2.361150] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
6087 [ 2.361158] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
6088 [ 2.361165] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
6089 [ 2.361172] usb usb4: SerialNumber: sunxi-ohci
6090 [ 2.362029] hub 4-0:1.0: USB hub found
6091 [ 2.362074] hub 4-0:1.0: 1 port detected
6092 [ 2.362745] get drv_vbus is fail, 84
6093 [ 2.362754] get ohci2-controller, regulator_io is no nocare
6094 [ 2.363081] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
6095 [ 2.363130] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
6096 [ 2.363160] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
6097 [ 2.363237] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
6098 [ 2.421123] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
6099 [ 2.421134] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
6100 [ 2.421142] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
6101 [ 2.421149] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
6102 [ 2.421156] usb usb5: SerialNumber: sunxi-ohci
6103 [ 2.422016] hub 5-0:1.0: USB hub found
6104 [ 2.422065] hub 5-0:1.0: 1 port detected
6105 [ 2.422745] get drv_vbus is fail, 84
6106 [ 2.422753] get ohci3-controller, regulator_io is no nocare
6107 [ 2.423090] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
6108 [ 2.423138] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
6109 [ 2.423165] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
6110 [ 2.423241] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
6111 [ 2.481119] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
6112 [ 2.481129] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
6113 [ 2.481137] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
6114 [ 2.481144] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
6115 [ 2.481151] usb usb6: SerialNumber: sunxi-ohci
6116 [ 2.481999] hub 6-0:1.0: USB hub found
6117 [ 2.482044] hub 6-0:1.0: 1 port detected
6118 [ 2.482968] ohci-platform: OHCI generic platform driver
6119 [ 2.483728] usbcore: registered new interface driver uas
6120 [ 2.483903] usbcore: registered new interface driver usb-storage
6121 [ 2.483998] usbcore: registered new interface driver ums-alauda
6122 [ 2.484075] usbcore: registered new interface driver ums-cypress
6123 [ 2.484150] usbcore: registered new interface driver ums-datafab
6124 [ 2.484223] usbcore: registered new interface driver ums_eneub6250
6125 [ 2.484316] usbcore: registered new interface driver ums-freecom
6126 [ 2.484395] usbcore: registered new interface driver ums-isd200
6127 [ 2.484468] usbcore: registered new interface driver ums-jumpshot
6128 [ 2.484540] usbcore: registered new interface driver ums-karma
6129 [ 2.484613] usbcore: registered new interface driver ums-onetouch
6130 [ 2.484704] usbcore: registered new interface driver ums-realtek
6131 [ 2.484780] usbcore: registered new interface driver ums-sddr09
6132 [ 2.484857] usbcore: registered new interface driver ums-sddr55
6133 [ 2.484941] usbcore: registered new interface driver ums-usbat
6134 [ 2.485089] usb_serial_number:20080411
6135 [ 2.486316] input: sunxi-keyboard as /devices/virtual/input/input0
6136 [ 2.486971] usbcore: registered new interface driver xpad
6137 [ 2.487100] usbcore: registered new interface driver usb_acecad
6138 [ 2.487191] usbcore: registered new interface driver aiptek
6139 [ 2.487279] usbcore: registered new interface driver gtco
6140 [ 2.487364] usbcore: registered new interface driver hanwang
6141 [ 2.487447] usbcore: registered new interface driver kbtab
6142 [ 2.487928] axp2101_pek: axp2101-pek can not register without irq
6143 [ 2.487951] axp2101-pek: probe of axp2101-pek.0 failed with error -22
6144 [ 2.489416] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
6145 [ 2.489483] sunxi-rtc rtc: RTC enabled
6146 [ 2.489972] i2c /dev entries driver
6147 [ 2.490942] lirc_dev: IR Remote Control driver registered, major 244
6148 [ 2.490955] IR NEC protocol handler initialized
6149 [ 2.490961] IR RC5(x/sz) protocol handler initialized
6150 [ 2.490967] IR RC6 protocol handler initialized
6151 [ 2.490973] IR JVC protocol handler initialized
6152 [ 2.490978] IR Sony protocol handler initialized
6153 [ 2.490984] IR SANYO protocol handler initialized
6154 [ 2.490990] IR Sharp protocol handler initialized
6155 [ 2.490996] IR MCE Keyboard/mouse protocol handler initialized
6156 [ 2.491002] IR LIRC bridge handler initialized
6157 [ 2.491007] IR XMP protocol handler initialized
6158 [ 2.491532] sunxi_ir_startup: get ir protocol failed
6159 [ 2.491574] 7040000.s_cir supply ir0 not found, using dummy regulator
6160 [ 2.491767] Registered IR keymap rc_map_sunxi
6161 [ 2.492173] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
6162 [ 2.492424] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
6163 [ 2.493405] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
6164 [ 2.494022] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
6165 [ 2.494730] sunxi cedar version 0.1
6166 [ 2.494906] VE: install start!!!
6167
6168 [ 2.495095] cedar_ve: cedar-ve the get irq is 278
6169 [ 2.495719] VE: get debugfs_mpp_root is NULL, please check mpp
6170
6171 [ 2.495733] VE: sunxi ve debug register driver failed!
6172
6173 [ 2.498983] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
6174 [ 2.500304] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
6175 [ 2.504005] Bluetooth: HCI UART driver ver 2.3
6176 [ 2.504017] Bluetooth: HCI UART protocol H4 registered
6177 [ 2.504023] Bluetooth: HCI UART protocol LL registered
6178 [ 2.504029] Bluetooth: HCI UART protocol Three-wire (H5) registered
6179 [ 2.508037] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
6180 [ 2.508053] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
6181 [ 2.508065] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
6182 [ 2.508077] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
6183 [ 2.508090] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
6184 [ 2.508101] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
6185 [ 2.508459] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
6186 [ 2.508558] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
6187 [ 2.508751] sunxi-mmc sdc0: No vmmc regulator found
6188 [ 2.508758] sunxi-mmc sdc0: No vqmmc regulator found
6189 [ 2.508764] sunxi-mmc sdc0: No vdmmc regulator found
6190 [ 2.508771] sunxi-mmc sdc0: No vd33sw regulator found
6191 [ 2.508777] sunxi-mmc sdc0: No vd18sw regulator found
6192 [ 2.508783] sunxi-mmc sdc0: No vq33sw regulator found
6193 [ 2.508789] sunxi-mmc sdc0: No vq18sw regulator found
6194 [ 2.509499] sunxi-mmc sdc0: set host busy
6195 [ 2.509585] sunxi-mmc sdc0: Got CD GPIO
6196 [ 2.509947] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
6197 [ 2.509981] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
6198 [ 2.523690] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6199 [ 2.540522] sunxi-mmc sdc0: detmode:gpio irq
6200 [ 2.540557] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6201 [ 2.543067] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6202 [ 2.544448] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
6203 [ 2.544584] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
6204 [ 2.544724] sunxi-mmc sdc1: No vmmc regulator found
6205 [ 2.544731] sunxi-mmc sdc1: No vqmmc regulator found
6206 [ 2.544737] sunxi-mmc sdc1: No vdmmc regulator found
6207 [ 2.544744] sunxi-mmc sdc1: No vd33sw regulator found
6208 [ 2.544750] sunxi-mmc sdc1: No vd18sw regulator found
6209 [ 2.544756] sunxi-mmc sdc1: No vq33sw regulator found
6210 [ 2.544762] sunxi-mmc sdc1: No vq18sw regulator found
6211 [ 2.545126] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6212 [ 2.545596] sunxi-mmc sdc1: set host busy
6213 [ 2.545679] mmc:failed to get gpios
6214 [ 2.545966] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
6215 [ 2.547614] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6216 [ 2.560348] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6217 [ 2.571412] mmc0: host does not support reading read-only switch, assuming write-enable
6218 [ 2.573275] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
6219 [ 2.573349] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
6220 [ 2.573493] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
6221 [ 2.573584] mmc0: new high speed SDXC card at address 0001
6222 [ 2.577048] sunxi-mmc sdc1: detmode:manually by software
6223 [ 2.578128] mmcblk0: mmc0:0001 SD16G 59.5 GiB
6224 [ 2.579024] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
6225 [ 2.579653] ledtrig-cpu: registered to indicate activity on CPUs
6226 [ 2.579944] mmcblk0: p1
6227 [ 2.580248] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
6228 [ 2.580338] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6229 [ 2.582890] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6230 [ 2.584840] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
6231 [ 2.585679] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
6232 [ 2.586138] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
6233 [ 2.586147] sunxi_emce_probe()590emce hw init failed!
6234 [ 2.586174] emce: probe of emce failed with error -2
6235 [ 2.586465] hidraw: raw HID events driver (C) Jiri Kosina
6236 [ 2.586518] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
6237 [ 2.587372] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
6238 [ 2.587423] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
6239 [ 2.591403] usbcore: registered new interface driver usbhid
6240 [ 2.591411] usbhid: USB HID core driver
6241 [ 2.592834] optee: probing for conduit method from DT.
6242 [ 2.592847] optee: api uid mismatch
6243 [ 2.593428] usbcore: registered new interface driver snd-usb-audio
6244 [ 2.595169] [sunxi_hdmi_codec_init] driver and deivce register finished.
6245 [ 2.596779] [sunxi_internal_codec_probe]:get audio avcc failed
6246 [ 2.596820] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
6247 [ 2.597237] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
6248 [ 2.599761] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
6249 [ 2.601723] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
6250 [ 2.601737] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
6251 [ 2.604011] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
6252 [ 2.604036] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
6253 [ 2.608032] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
6254 [ 2.609428] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
6255 [ 2.611366] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
6256 [ 2.614415] pktgen: Packet Generator for packet performance testing. Version: 2.75
6257 [ 2.614849] u32 classifier
6258 [ 2.614856] Actions configured
6259 [ 2.614868] Netfilter messages via NETLINK v0.30.
6260 [ 2.614895] nfnl_acct: registering with nfnetlink.
6261 [ 2.615228] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
6262 [ 2.615480] ctnetlink v0.93: registering with nfnetlink.
6263 [ 2.616249] xt_time: kernel timezone is -0000
6264 [ 2.616273] IPVS: Registered protocols (TCP, UDP)
6265 [ 2.616381] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
6266 [ 2.616505] IPVS: Creating netns size=1928 id=0
6267 [ 2.616637] IPVS: ipvs loaded.
6268 [ 2.616645] IPVS: [rr] scheduler registered.
6269 [ 2.616742] ipip: IPv4 and MPLS over IPv4 tunneling driver
6270 [ 2.617538] gre: GRE over IPv4 demultiplexor driver
6271 [ 2.617547] ip_gre: GRE over IPv4 tunneling driver
6272 [ 2.618849] IPv4 over IPsec tunneling driver
6273 [ 2.619693] ip_tables: (C) 2000-2006 Netfilter Core Team
6274 [ 2.619971] arp_tables: arp_tables: (C) 2002 David S. Miller
6275 [ 2.620039] Initializing XFRM netlink socket
6276 [ 2.620073] IPsec XFRM device driver
6277 [ 2.620976] NET: Registered protocol family 10
6278 [ 2.622825] mip6: Mobile IPv6
6279 [ 2.622863] ip6_tables: (C) 2000-2006 Netfilter Core Team
6280 [ 2.624413] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
6281 [ 2.626030] NET: Registered protocol family 17
6282 [ 2.626072] NET: Registered protocol family 15
6283 [ 2.626229] Bridge firewalling registered
6284 [ 2.626375] Bluetooth: RFCOMM TTY layer initialized
6285 [ 2.626393] Bluetooth: RFCOMM socket layer initialized
6286 [ 2.626423] Bluetooth: RFCOMM ver 1.11
6287 [ 2.626438] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
6288 [ 2.626444] Bluetooth: BNEP filters: protocol multicast
6289 [ 2.626458] Bluetooth: BNEP socket layer initialized
6290 [ 2.626463] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
6291 [ 2.626475] Bluetooth: HIDP socket layer initialized
6292 [ 2.626579] l2tp_core: L2TP core driver, V2.0
6293 [ 2.626595] l2tp_ppp: PPPoL2TP kernel driver, V2.0
6294 [ 2.626601] 8021q: 802.1Q VLAN Support v1.8
6295 [ 2.626806] sctp: Hash tables configured (bind 256/256)
6296 [ 2.627451] Key type dns_resolver registered
6297 [ 2.627591] Registered cp15_barrier emulation handler
6298 [ 2.627604] Registered setend emulation handler
6299 [ 2.628525] registered taskstats version 1
6300 [ 2.640055] zswap: default zpool zbud not available
6301 [ 2.640063] zswap: pool creation failed
6302 [ 2.642876] Btrfs loaded, crc32c=crc32c-arm64-hw
6303 [ 2.643649] HDMI 2.0 driver init start!
6304 [ 2.643665] boot_hdmi=true
6305 [ 2.644470] Can not find the node of esm
6306 [ 2.644492] ERROR: pinctrl_get for HDMI2.0 DDC fail
6307 [ 2.644582] Get hdmi_power0:vcc-hdmi
6308 [ 2.644623] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
6309 [ 2.644796] Get hdmi_power1:vdd-hdmi
6310 [ 2.644817] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
6311 [ 2.646384] hdmi_cec_init
6312 [ 2.646837] [DISP] disp_device_attached,line:146:
6313 [ 2.646845] attached ok, mgr0<-->device0, type=4
6314 [ 2.646856] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
6315 [ 2.646868] [DISP] disp_hdmi_set_mode,line:648:
6316 [ 2.646873] hdmi_set_mode is null!
6317 [ 2.647942] HDMI2.0 module init end
6318 [ 2.659175] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
6319 [ 2.662696] cpu cpu1: opp_list_debug_create_link: Failed to create link
6320 [ 2.662709] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
6321 [ 2.662740] cpu cpu2: opp_list_debug_create_link: Failed to create link
6322 [ 2.662748] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
6323 [ 2.662778] cpu cpu3: opp_list_debug_create_link: Failed to create link
6324 [ 2.662785] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
6325 [ 2.665054] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
6326 [ 2.665950] get det_vbus is fail, 84
6327 [ 2.665958] get id is fail, 84
6328 [ 2.666440] sunxi-rtc rtc: setting system clock to 1970-01-01 00:22:04 UTC (1324)
6329 [ 2.670300] ALSA device list:
6330 [ 2.670309] #0: audiocodec
6331 [ 2.670312] #1: sndahub
6332 [ 2.670315] #2: sndhdmi
6333 [ 2.671925] Freeing unused kernel memory: 3008K
6334 [ 2.717256] random: systemd-udevd: uninitialized urandom read (16 bytes read)
6335 [ 2.719187] random: systemd-udevd: uninitialized urandom read (16 bytes read)
6336 [ 2.722174] random: systemd-udevd: uninitialized urandom read (16 bytes read)
6337 [ 2.790881] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
6338 [ 2.953709] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
6339 [ 3.050362] HDMI cable is connected
6340 [ 3.306956] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
6341 [ 3.527153] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
6342 [ 3.527162] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
6343 [ 3.527168] usb 4-1: Product: Rapoo 2.4G Wireless Device
6344 [ 3.527172] usb 4-1: Manufacturer: RAPOO
6345 [ 3.535130] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
6346 [ 3.535857] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
6347 [ 3.542018] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
6348 [ 3.598482] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
6349 [ 3.602405] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
6350 [ 3.659004] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
6351 [ 4.254527] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
6352 [ 5.147597] systemd[1]: System time before build time, advancing clock.
6353 [ 5.152434] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
6354 [ 5.152993] cgroup: cgroup2: unknown option "nsdelegate"
6355 [ 5.173411] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
6356 [ 5.173436] systemd[1]: Detected architecture arm64.
6357 [ 5.174620] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
6358 [ 5.184716] systemd[1]: Hostname set to <opi>.
6359 [ 5.211711] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
6360 [ 6.679990] (sd-execut[1459]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
6361 [ 6.827012]
6362 insmod_device_driver
6363
6364 [ 6.827268] device_chose finished 124!
6365 [ 7.178621] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
6366 [ 7.418011] systemd[1]: Queued start job for default target graphical.target.
6367 [ 7.425278] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
6368 [ 7.427470] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
6369 [ 7.429662] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
6370 [ 7.431043] systemd[1]: Created slice user.slice - User and Session Slice.
6371 [ 7.431679] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
6372 [ 7.432218] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
6373 [ 7.432550] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
6374 [ 7.433083] systemd[1]: Reached target slices.target - Slice Units.
6375 [ 7.433377] systemd[1]: Reached target swap.target - Swaps.
6376 [ 7.433743] systemd[1]: Reached target time-set.target - System Time Set.
6377 [ 7.434281] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
6378 [ 7.451639] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
6379 [ 7.452724] systemd[1]: Listening on syslog.socket - Syslog Socket.
6380 [ 7.453747] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
6381 [ 7.454427] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
6382 [ 7.456042] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
6383 [ 7.457073] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
6384 [ 7.458147] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
6385 [ 7.460405] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
6386 [ 7.461331] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
6387 [ 7.465149] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
6388 [ 7.469688] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
6389 [ 7.474704] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
6390 [ 7.475827] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
6391 [ 7.476789] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
6392 [ 7.484676] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
6393 [ 7.490408] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
6394 [ 7.496305] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
6395 [ 7.504391] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
6396 [ 7.513221] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
6397 [ 7.521256] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
6398 [ 7.534210] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
6399 [ 7.541610] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
6400 [ 7.548969] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
6401 [ 7.552011] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
6402 [ 7.560987] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
6403 [ 7.566893] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
6404 [ 7.572008] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
6405 [ 7.582594] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
6406 [ 7.585445] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
6407 [ 7.587692] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
6408 [ 7.590770] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
6409 [ 7.594680] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
6410 [ 7.598538] systemd[1]: modprobe@configfs.service: Deactivated successfully.
6411 [ 7.599539] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
6412 [ 7.600206] fuse init (API version 7.26)
6413 [ 7.602681] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
6414 [ 7.604458] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
6415 [ 7.608567] systemd[1]: modprobe@drm.service: Deactivated successfully.
6416 [ 7.624464] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
6417 [ 7.647729] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
6418 [ 7.671022] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
6419 [ 7.678825] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
6420 [ 7.679738] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
6421 [ 7.679751] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
6422 [ 7.679938] spidev spi1.1: Deleting spi1.1
6423 [ 7.681122] fbtft_device: GPIOS used by 'fb_st7735r':
6424 [ 7.681130] fbtft_device: 'reset' = GPIO73
6425 [ 7.681134] fbtft_device: 'dc' = GPIO70
6426 [ 7.681147] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
6427 [ 7.681152] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
6428 [ 7.682299] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
6429 [ 7.694285] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
6430 [ 7.700918] systemd[1]: modprobe@fuse.service: Deactivated successfully.
6431 [ 7.701801] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
6432 [ 7.704713] systemd[1]: modprobe@loop.service: Deactivated successfully.
6433 [ 7.705487] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
6434 [ 7.718320] WCN: marlin_init entry!
6435 [ 7.719543] WCN: marlin_parse_dt reset gpio=211
6436 [ 7.719554] WCN_ERR: gpio reset request err: 211
6437 [ 7.719560] WCN: wcn config bt wake host
6438 [ 7.720070] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
6439 [ 7.720400] WCN: wcn config wifi wake host
6440 [ 7.720428] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
6441 [ 7.723976] sdiohal:sdiohal_init ok
6442 [ 7.724860] WCN: marlin_probe ok!
6443 [ 7.733508] mtty_probe init device addr: 0xffffffc009756300
6444 [ 7.733750] -->rfkill_bluetooth_init
6445 [ 7.733974] <--rfkill_bluetooth_init
6446 [ 7.751476] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
6447 [ 7.760549] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
6448 [ 7.777992] WCN: start_marlin [MARLIN_WIFI]
6449 [ 7.778004] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
6450 [ 7.778007] WCN: the first power on start
6451 [ 7.784001] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
6452 [ 7.785242] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
6453 [ 7.791742] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
6454 [ 7.792850] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
6455 [ 7.799736] systemd[1]: Starting systemd-sysusers.service - Create System Users...
6456 [ 7.816104] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
6457 [ 7.818743] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
6458 [ 7.824547] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
6459 [ 7.880072] systemd[1]: Finished systemd-sysusers.service - Create System Users.
6460 [ 7.893738] WCN: marlin chip en pull up
6461 [ 7.913856] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
6462 [ 7.923686] sdiohal:sdiohal_scan_card
6463 [ 7.923702] sunxi-wlan soc@03000000:wlan: bus_index: 1
6464 [ 7.923749] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
6465 [ 7.940352] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6466 [ 7.957817] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
6467 [ 7.958681] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
6468 [ 7.958732] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6469 [ 7.961342] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6470 [ 7.964519] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6471 [ 7.980323] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
6472 [ 7.991478] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
6473 [ 7.992265] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
6474 [ 7.992481] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
6475 [ 7.993275] mmc1: new ultra high speed SDR104 SDIO card at address 8800
6476 [ 7.994154] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
6477 [ 7.994414] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
6478 [ 7.994440] WCN: marlin_scan_finish!
6479 [ 7.994444] sdiohal:probe ok
6480 [ 7.994497] sdiohal:scan end!
6481 [ 7.994504] WCN: then marlin start to download
6482 [ 7.994525] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
6483 [ 8.028352] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
6484 [ 8.064490] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
6485 [ 8.070144] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
6486 [ 8.072860] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
6487 [ 8.075576] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
6488 [ 8.083857] systemd[1]: Mounting tmp.mount - /tmp...
6489 [ 8.104791] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
6490 [ 8.108173] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
6491 [ 8.114375] systemd[1]: Mounted tmp.mount - /tmp.
6492 [ 8.125610] systemd[1]: Reached target local-fs.target - Local File Systems.
6493 [ 8.131996] WCN: combin_img 0 marlin_firmware_write finish and successful
6494 [ 8.132017] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
6495 [ 8.132412] WCN: marlin_start_run read reset reg val:0x1
6496 [ 8.132420] WCN: after do marlin_start_run reset reg val:0x0
6497 [ 8.132740] WCN: s_marlin_bootup_time=8132731884
6498 [ 8.139412] WCN: clock mode: TSX
6499 [ 8.139605] WCN: marlin_write_cali_data sync init_state:0x1a0f50
6500 [ 8.158138] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
6501 [ 8.165206] systemd[1]: Starting console-setup.service - Set console font and keymap...
6502 [ 8.166614] WCN: marlin_write_cali_data sync init_state:0x1a0f50
6503 [ 8.172428] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
6504 [ 8.186760] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
6505 [ 8.190913] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
6506 [ 8.190922] WCN: sdio_config bt_wake_host trigger:[high]
6507 [ 8.190926] WCN: sdio_config irq:[inband]
6508 [ 8.190929] WCN: sdio_config wl_wake_host trigger:[high]
6509 [ 8.190934] WCN: sdio_config wake_host_level_duration_time:[20ms]
6510 [ 8.190937] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
6511 [ 8.190941] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
6512 [ 8.191424] WCN: marlin_write_cali_data finish
6513 [ 8.191680] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
6514 [ 8.195894] systemd[1]: Starting ufw.service - Uncomplicated firewall...
6515 [ 8.206647] systemd[1]: Finished console-setup.service - Set console font and keymap.
6516 [ 8.217359] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
6517 [ 8.243964] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
6518 [ 8.248385] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
6519 [ 8.250720] systemd[1]: Finished ufw.service - Uncomplicated firewall.
6520 [ 8.255168] systemd[1]: Reached target network-pre.target - Preparation for Network.
6521 [ 8.261346] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
6522 [ 8.270807] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
6523 [ 8.290946] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
6524 [ 8.291585] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
6525 [ 8.297313] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
6526 [ 8.307628] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
6527 [ 8.318753] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
6528 [ 8.324025] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
6529 [ 8.324035] WCN: marlin_bind_verify confuse data: 0x8badefa1b12bbe26aeffa8d1a5c07
6530 [ 8.324052] WCN: marlin_bind_verify verify data: 0xccd7f963c19581907680f88f2044f687
6531 [ 8.324656] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
6532 [ 8.350520] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
6533 [ 8.350528] sdiohal:sdiohal_runtime_get entry
6534 [ 8.350678] WCN: get_cp2_version entry!
6535 [ 8.352067] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
6536 [ 8.352082] WCN: switch_cp2_log - close entry!
6537 [ 8.353466] WCN: WCND at cmd read:OK
6538 [ 8.353509] WCN: then marlin download finished and run ok
6539 [ 8.353515] WCN: start_loopcheck
6540 [ 8.366973] WCN: get_board_ant_num [one_ant]
6541 [ 8.366985] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
6542 [ 8.459917] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
6543 [ 8.464808] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
6544 [ 8.471521] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
6545 [ 8.538395] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
6546 [ 8.548382] systemd[1]: Starting networking.service - Raise network interfaces...
6547 [ 8.612143] zram: Added device: zram0
6548 [ 8.614514] zram: Added device: zram1
6549 [ 8.615542] zram: Added device: zram2
6550 [ 8.651867] zswap: can't enable, initialization failed
6551 [ 8.699500] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
6552 [ 8.703442] zram0: detected capacity change from 0 to 506396672
6553 [ 8.720976] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
6554 [ 8.786344] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
6555 [ 8.792421] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
6556 [ 8.794501] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
6557 [ 8.795219] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
6558 [ 8.805873] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
6559 [ 9.145127] systemd[1]: Finished networking.service - Raise network interfaces.
6560 [ 10.030601] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
6561 [ 10.148026] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
6562 [ 10.292618] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
6563 [ 10.937818] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
6564 [ 10.938089] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
6565 [ 10.938840] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
6566 [ 10.939951] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
6567 [ 10.953804] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
6568 [ 10.966397] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
6569 [ 10.976169] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
6570 [ 10.983026] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
6571 [ 10.988631] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
6572 [ 10.989717] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
6573 [ 10.994754] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
6574 [ 10.995641] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
6575 [ 11.002768] systemd[1]: modprobe@loop.service: Deactivated successfully.
6576 [ 11.003539] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
6577 [ 11.006299] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
6578 [ 11.006531] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
6579 [ 11.061551] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
6580 [ 11.063576] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
6581 [ 11.064633] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
6582 [ 11.065824] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
6583 [ 11.105893] sunxi-bt soc@03000000:bt: block state already is 1
6584 [ 11.108477] bluetooth_set_power: start_block=1
6585 [ 11.108493] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 0
6586 [ 11.108497] WCN: can not power off, other module is on
6587 [ 11.108505] bluetooth_set_power: end_block=1
6588 [ 11.119009] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
6589 [ 11.163270] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
6590 [ 11.169077] systemd[1]: Starting brltty.service - Braille Device Support...
6591 [ 11.738965] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
6592 [ 11.887401] zram1: detected capacity change from 0 to 52428800
6593 [ 11.901934] systemd[1]: Started brltty.service - Braille Device Support.
6594 [ 11.929997] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
6595 [ 15.993123] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
6596 [ 15.999188] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
6597 [ 16.060586] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
6598 [ 16.128164] systemd[1]: systemd-rfkill.service: Deactivated successfully.
6599 [ 19.887335] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
6600 [ 19.894062] systemd[1]: Starting systemd-journald.service - Journal Service...
6601 [ 20.169716] systemd-journald[1922]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.0 (1654 of 2204 items, 1269760 file size, 767 bytes per hash table item), suggesting rotation.
6602 [ 20.169738] systemd-journald[1922]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
6603 [ 20.176762] systemd[1]: Started systemd-journald.service - Journal Service.
6604 [ 20.223448] systemd-journald[1922]: Received client request to flush runtime journal.
6605 [ 20.493386] IPVS: Creating netns size=1928 id=1
6606
6607 ### armbian-release:
6608
6609 # PLEASE DO NOT EDIT THIS FILE
6610 BOARD=orangepizero2
6611 BOARD_NAME="Orange Pi Zero2"
6612 BOARDFAMILY=sun50iw9
6613 BUILD_REPOSITORY_URL=https://github.com/armbian/build
6614 BUILD_REPOSITORY_COMMIT=ac829eb6
6615 LINUXFAMILY=sun50iw9
6616 ARCH=arm64
6617 IMAGE_TYPE=stable
6618 BOARD_TYPE=conf
6619 INITRD_ARCH=arm
6620 KERNEL_IMAGE_TYPE=Image
6621 FORCE_BOOTSCRIPT_UPDATE=yes
6622 VENDOR=Armbian
6623 BOOTSCRIPT_FORCE_UPDATE="yes"
6624 BOOTSCRIPT_DST="boot.cmd"
6625 VERSION=23.8.1
6626 REVISION=23.8.1
6627 BRANCH=legacy
6628
6629 ### boot environment:
6630
6631 verbosity=1
6632 console=serial
6633 #disp_mode=1080p60
6634 #fb0_width=1280
6635 #fb0_height=720
6636 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
6637 rootfstype=ext4
6638 overlays=spi-spidev
6639 param_spidev_spi_bus=1
6640 param_spidev_spi_cs=1
6641 extraargs=fbcon=map:1
6642 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
6643
6644 ### lsusb:
6645
6646 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
6647 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
6648 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
6649 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
6650 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
6651 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
6652 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
6653
6654 ### lscpu:
6655
6656 Architecture: aarch64
6657 CPU op-mode(s): 32-bit, 64-bit
6658 Byte Order: Little Endian
6659 CPU(s): 4
6660 On-line CPU(s) list: 0-3
6661 Vendor ID: ARM
6662 Model name: Cortex-A53
6663 Model: 4
6664 Thread(s) per core: 1
6665 Core(s) per cluster: 4
6666 Socket(s): -
6667 Cluster(s): 1
6668 Stepping: r0p4
6669 CPU(s) scaling MHz: 100%
6670 CPU max MHz: 1512.0000
6671 CPU min MHz: 480.0000
6672 BogoMIPS: 48.00
6673 Flags: fp asimd aes pmull sha1 sha2 crc32
6674
6675 ### cpuinfo:
6676
6677 processor : 0
6678 BogoMIPS : 48.00
6679 Features : fp asimd aes pmull sha1 sha2 crc32
6680 CPU implementer : 0x41
6681 CPU architecture: 8
6682 CPU variant : 0x0
6683 CPU part : 0xd03
6684 CPU revision : 4
6685
6686 processor : 1
6687 BogoMIPS : 48.00
6688 Features : fp asimd aes pmull sha1 sha2 crc32
6689 CPU implementer : 0x41
6690 CPU architecture: 8
6691 CPU variant : 0x0
6692 CPU part : 0xd03
6693 CPU revision : 4
6694
6695 processor : 2
6696 BogoMIPS : 48.00
6697 Features : fp asimd aes pmull sha1 sha2 crc32
6698 CPU implementer : 0x41
6699 CPU architecture: 8
6700 CPU variant : 0x0
6701 CPU part : 0xd03
6702 CPU revision : 4
6703
6704 processor : 3
6705 BogoMIPS : 48.00
6706 Features : fp asimd aes pmull sha1 sha2 crc32
6707 CPU implementer : 0x41
6708 CPU architecture: 8
6709 CPU variant : 0x0
6710 CPU part : 0xd03
6711 CPU revision : 4
6712
6713
6714 ### meminfo:
6715
6716 MemTotal: 989056 kB
6717 MemFree: 792776 kB
6718 MemAvailable: 886300 kB
6719 Buffers: 15368 kB
6720 Cached: 85348 kB
6721 SwapCached: 0 kB
6722 Active: 64416 kB
6723 Inactive: 56496 kB
6724 Active(anon): 20552 kB
6725 Inactive(anon): 644 kB
6726 Active(file): 43864 kB
6727 Inactive(file): 55852 kB
6728 Unevictable: 0 kB
6729 Mlocked: 0 kB
6730 SwapTotal: 494524 kB
6731 SwapFree: 494524 kB
6732 Dirty: 9360 kB
6733 Writeback: 0 kB
6734 AnonPages: 20404 kB
6735 Mapped: 24492 kB
6736 Shmem: 828 kB
6737 Slab: 33092 kB
6738 SReclaimable: 9260 kB
6739 SUnreclaim: 23832 kB
6740 KernelStack: 2544 kB
6741 PageTables: 1056 kB
6742 NFS_Unstable: 0 kB
6743 Bounce: 0 kB
6744 WritebackTmp: 0 kB
6745 CommitLimit: 989052 kB
6746 Committed_AS: 75080 kB
6747 VmallocTotal: 263061440 kB
6748 VmallocUsed: 0 kB
6749 VmallocChunk: 0 kB
6750 CmaTotal: 16384 kB
6751 CmaFree: 7468 kB
6752 HugePages_Total: 0
6753 HugePages_Free: 0
6754 HugePages_Rsvd: 0
6755 HugePages_Surp: 0
6756 Hugepagesize: 2048 kB
6757
6758 ### virtual memory:
6759
6760 vm.admin_reserve_kbytes = 8192
6761 vm.block_dump = 0
6762 vm.compact_unevictable_allowed = 1
6763 vm.dirty_background_bytes = 0
6764 vm.dirty_background_ratio = 10
6765 vm.dirty_bytes = 0
6766 vm.dirty_expire_centisecs = 3000
6767 vm.dirty_ratio = 20
6768 vm.dirtytime_expire_seconds = 43200
6769 vm.dirty_writeback_centisecs = 500
6770 vm.extfrag_threshold = 500
6771 vm.extra_free_kbytes = 0
6772 vm.hugepages_treat_as_movable = 0
6773 vm.hugetlb_shm_group = 0
6774 vm.laptop_mode = 0
6775 vm.legacy_va_layout = 0
6776 vm.lowmem_reserve_ratio = 256 32
6777 vm.max_map_count = 65530
6778 vm.min_free_kbytes = 3937
6779 vm.mmap_min_addr = 4096
6780 vm.mmap_rnd_bits = 18
6781 vm.mmap_rnd_compat_bits = 11
6782 vm.nr_hugepages = 0
6783 vm.nr_overcommit_hugepages = 0
6784 vm.nr_pdflush_threads = 0
6785 vm.oom_dump_tasks = 1
6786 vm.oom_kill_allocating_task = 0
6787 vm.overcommit_kbytes = 0
6788 vm.overcommit_memory = 0
6789 vm.overcommit_ratio = 50
6790 vm.page-cluster = 0
6791 vm.panic_on_oom = 0
6792 vm.percpu_pagelist_fraction = 0
6793 vm.stat_interval = 1
6794 vm.swappiness = 100
6795 vm.user_reserve_kbytes = 30000
6796 vm.vfs_cache_pressure = 100
6797 vm.watermark_scale_factor = 10
6798
6799 ### ip addr:
6800
6801 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
6802 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
6803 inet XXX.XXX.0.1/8 scope host lo
6804 valid_lft forever preferred_lft forever
6805 inet6 ::1/128 scope host noprefixroute
6806 valid_lft forever preferred_lft forever
6807 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
6808 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
6809 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
6810 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
6811 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
6812 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
6813 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
6814 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
6815 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
6816 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
6817 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
6818 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
6819 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
6820 link/tunnel6 :: brd ::
6821 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
6822 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
6823 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
6824 link/tunnel6 :: brd ::
6825 11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
6826 link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
6827
6828 ### partitions:
6829
6830 major minor #blocks name
6831
6832 179 0 62410752 mmcblk0
6833 179 1 61763584 mmcblk0p1
6834 253 0 494528 zram0
6835 253 1 51200 zram1
6836
6837 ### df:
6838
6839 udev 466M 0 466M 0% /dev
6840 tmpfs 97M 2.1M 95M 3% /run
6841 /dev/mmcblk0p1 58G 7.3G 51G 13% /
6842 tmpfs 483M 0 483M 0% /dev/shm
6843 tmpfs 5.0M 0 5.0M 0% /run/lock
6844 tmpfs 483M 4.0K 483M 1% /tmp
6845 /dev/zram1 47M 8.8M 35M 21% /var/log
6846
6847 ### lsblk:
6848
6849 NAME FSTYPE SIZE MOUNTPOINT UUID
6850 mmcblk0 59.5G
6851 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
6852 zram1 50M /var/log
6853 zram2 0B
6854
6855 ### zramctl:
6856
6857 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
6858 /dev/zram1 lz4 50M 8.9M 2.4M 2.9M 4 /var/log
6859 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
6860
6861 ### mtab:
6862
6863 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
6864 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
6865 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
6866
6867 ### mmc0:0001 info:
6868
6869 manfid: 0x0000fe
6870 cid: fe3432534431364720000000690091f5
6871 fwrev: 0x0
6872 csd: 400e00325b590001dc277f800a40008b
6873 ocr: 0x00200000
6874 type: SD
6875 date: 01/2009
6876 hwrev: 0x2
6877 dsr: 0x404
6878 serial: 0x00000069
6879 erase_size: 512
6880 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
6881 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
6882 scr: 0285808300000000
6883 oemid: 0x3432
6884 preferred_erase_size: 4194304
6885 name: SD16G
6886
6887 ### Boot system health:
6888
6889 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
6890 14:38:29 1512 MHz 1.17 39% 18% 13% 0% 6% 0% 50.8 °C 0/5
6891 14:38:29 1512 MHz 1.17 95% 32% 36% 0% 25% 0% 50.8 °C 0/5
6892 14:38:30 1512 MHz 1.17 100% 34% 57% 1% 7% 0% 49.7 °C 0/5
6893 14:38:30 1512 MHz 1.17 99% 27% 42% 0% 29% 0% 49.7 °C 0/5
6894 14:38:31 1512 MHz 1.17 94% 10% 12% 1% 71% 0% 50.2 °C 0/5
6895
6896 ### Activated 1 lzo zram swap devices with 482MB each.
6897 ### Activated Armbian ramlog partition with lz4 compression
6898
6899 Mon Sep 25 03:19:04 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
6900
6901 ### dmesg:
6902
6903 [ 0.000000] Booting Linux on physical CPU 0x0
6904 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
6905 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
6906 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
6907 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
6908 [ 0.000000] On node 0 totalpages: 262144
6909 [ 0.000000] DMA zone: 4096 pages used for memmap
6910 [ 0.000000] DMA zone: 0 pages reserved
6911 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
6912 [ 0.000000] psci: probing for conduit method from DT.
6913 [ 0.000000] psci: PSCIv1.0 detected in firmware.
6914 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
6915 [ 0.000000] psci: Trusted OS migration not required
6916 [ 0.000000] psci: SMC Calling Convention v1.0
6917 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
6918 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
6919 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
6920 [ 0.000000] Detected VIPT I-cache on CPU0
6921 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
6922 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
6923 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
6924 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
6925 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
6926 [ 0.000000] log_buf_len min size: 131072 bytes
6927 [ 0.000000] log_buf_len: 524288 bytes
6928 [ 0.000000] early log buf free: 129352(98%)
6929 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
6930 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
6931 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
6932 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
6933 [ 0.000000] Virtual kernel memory layout:
6934 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
6935 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
6936 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
6937 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
6938 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
6939 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
6940 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
6941 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
6942 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
6943 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
6944 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
6945 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
6946 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
6947 [ 0.000000] Preemptible hierarchical RCU implementation.
6948 [ 0.000000] Build-time adjustment of leaf fanout to 64.
6949 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
6950 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
6951 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
6952 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
6953 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
6954 [ 0.000233] Console: colour dummy device 80x25
6955 [ 0.000248] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
6956 [ 0.000257] pid_max: default: 32768 minimum: 301
6957 [ 0.000453] Security Framework initialized
6958 [ 0.000462] AppArmor: AppArmor disabled by boot time parameter
6959 [ 0.000578] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
6960 [ 0.000584] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
6961 [ 0.001853] sched-energy: CPU device node has no sched-energy-costs
6962 [ 0.001868] Invalid sched_group_energy for CPU0
6963 [ 0.001875] CPU0: update cpu_capacity 1024
6964 [ 0.008962] ASID allocator initialised with 32768 entries
6965 [ 0.027934] BOOTEVENT: 27.918666: ON
6966 [ 0.055912] Detected VIPT I-cache on CPU1
6967 [ 0.055965] Invalid sched_group_energy for CPU1
6968 [ 0.055970] CPU1: update cpu_capacity 1024
6969 [ 0.055973] CPU1: Booted secondary processor [410fd034]
6970 [ 0.079298] Detected VIPT I-cache on CPU2
6971 [ 0.079335] Invalid sched_group_energy for CPU2
6972 [ 0.079338] CPU2: update cpu_capacity 1024
6973 [ 0.079341] CPU2: Booted secondary processor [410fd034]
6974 [ 0.102698] Detected VIPT I-cache on CPU3
6975 [ 0.102733] Invalid sched_group_energy for CPU3
6976 [ 0.102736] CPU3: update cpu_capacity 1024
6977 [ 0.102739] CPU3: Booted secondary processor [410fd034]
6978 [ 0.102819] Brought up 4 CPUs
6979 [ 0.102827] SMP: Total of 4 processors activated.
6980 [ 0.102835] CPU features: detected feature: 32-bit EL0 Support
6981 [ 0.102841] CPU features: detected feature: Kernel page table isolation (KPTI)
6982 [ 0.106589] CPU: All CPU(s) started at EL1
6983 [ 0.106610] alternatives: patching kernel code
6984 [ 0.106786] Invalid sched_group_energy for CPU3
6985 [ 0.106795] CPU3: update max cpu_capacity 1024
6986 [ 0.106801] Invalid sched_group_energy for Cluster3
6987 [ 0.106806] Invalid sched_group_energy for CPU2
6988 [ 0.106811] Invalid sched_group_energy for Cluster2
6989 [ 0.106816] Invalid sched_group_energy for CPU1
6990 [ 0.106822] Invalid sched_group_energy for Cluster1
6991 [ 0.106826] Invalid sched_group_energy for CPU0
6992 [ 0.106832] Invalid sched_group_energy for Cluster0
6993 [ 0.108261] devtmpfs: initialized
6994 [ 0.112714] CPU1: update max cpu_capacity 1024
6995 [ 0.143376] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
6996 [ 0.143397] futex hash table entries: 1024 (order: 5, 131072 bytes)
6997 [ 0.144050] xor: measuring software checksum speed
6998 [ 0.176262] 8regs : 1933.200 MB/sec
6999 [ 0.209641] 8regs_prefetch: 1720.800 MB/sec
7000 [ 0.243028] 32regs : 2287.200 MB/sec
7001 [ 0.276414] 32regs_prefetch: 1995.600 MB/sec
7002 [ 0.276420] xor: using function: 32regs (2287.200 MB/sec)
7003 [ 0.276481] atomic64_test: passed
7004 [ 0.276487] pinctrl core: initialized pinctrl subsystem
7005 [ 0.277654] NET: Registered protocol family 16
7006 [ 0.278817] dump_class_init,861, success
7007 [ 0.296479] cpuidle: using governor menu
7008 [ 0.297921] sunxi iommu: irq = 8
7009 [ 0.298250] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
7010 [ 0.298267] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
7011 [ 0.299690] DMA: preallocated 256 KiB pool for atomic allocations
7012 [ 0.301073] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
7013 [ 0.315450] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
7014 [ 0.319373] iommu: Adding device 1c0e000.ve to group 0
7015 [ 0.319896] iommu: Adding device 1c00000.vp9 to group 0
7016 [ 0.331336] iommu: Adding device 1000000.disp to group 0
7017 [ 0.332744] iommu: Adding device 1480000.g2d to group 0
7018 [ 0.335938] iommu: Adding device csi0 to group 0
7019 [ 0.336392] iommu: Adding device csi1 to group 0
7020 [ 0.337594] iommu: Adding device 6600800.vind:scaler@0 to group 0
7021 [ 0.337887] iommu: Adding device 6600800.vind:scaler@1 to group 0
7022 [ 0.338197] iommu: Adding device 6600800.vind:scaler@2 to group 0
7023 [ 0.338484] iommu: Adding device 6600800.vind:scaler@3 to group 0
7024 [ 0.338767] iommu: Adding device 6600800.vind:scaler@4 to group 0
7025 [ 0.339049] iommu: Adding device 6600800.vind:scaler@5 to group 0
7026 [ 0.340020] iommu: Adding device vinc0 to group 0
7027 [ 0.340615] iommu: Adding device vinc1 to group 0
7028 [ 0.342081] iommu: Adding device 1420000.deinterlace to group 0
7029 [ 0.387873] HugeTLB registered 2 MB page size, pre-allocated 0 pages
7030 [ 0.444149] raid6: int64x1 gen() 393 MB/s
7031 [ 0.500762] raid6: int64x1 xor() 364 MB/s
7032 [ 0.557586] raid6: int64x2 gen() 591 MB/s
7033 [ 0.614335] raid6: int64x2 xor() 512 MB/s
7034 [ 0.671105] raid6: int64x4 gen() 840 MB/s
7035 [ 0.727900] raid6: int64x4 xor() 629 MB/s
7036 [ 0.784647] raid6: int64x8 gen() 964 MB/s
7037 [ 0.841457] raid6: int64x8 xor() 655 MB/s
7038 [ 0.898234] raid6: neonx1 gen() 648 MB/s
7039 [ 0.954993] raid6: neonx1 xor() 641 MB/s
7040 [ 1.011776] raid6: neonx2 gen() 976 MB/s
7041 [ 1.068564] raid6: neonx2 xor() 819 MB/s
7042 [ 1.125350] raid6: neonx4 gen() 1287 MB/s
7043 [ 1.182100] raid6: neonx4 xor() 965 MB/s
7044 [ 1.238914] raid6: neonx8 gen() 1324 MB/s
7045 [ 1.295675] raid6: neonx8 xor() 991 MB/s
7046 [ 1.295680] raid6: using algorithm neonx8 gen() 1324 MB/s
7047 [ 1.295685] raid6: .... xor() 991 MB/s, rmw enabled
7048 [ 1.295691] raid6: using intx1 recovery algorithm
7049 [ 1.295829] pwm module init!
7050 [ 1.300128] sunxi-pm debug v3.10
7051 [ 1.301208] SCSI subsystem initialized
7052 [ 1.301846] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
7053 [ 1.301929] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
7054 [ 1.302048] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
7055 [ 1.302569] spi spi0: master is unqueued, this is deprecated
7056 [ 1.302881] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
7057 [ 1.303458] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
7058 [ 1.303540] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
7059 [ 1.303657] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
7060 [ 1.304121] spi spi1: master is unqueued, this is deprecated
7061 [ 1.304430] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
7062 [ 1.305270] usbcore: registered new interface driver usbfs
7063 [ 1.305352] usbcore: registered new interface driver hub
7064 [ 1.305421] usbcore: registered new device driver usb
7065 [ 1.305590] sunxi_i2c_adap_init()2522 - init
7066 [ 1.306154] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
7067 [ 1.306248] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
7068 [ 1.306255] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
7069 [ 1.306271] twi3 supply twi not found, using dummy regulator
7070 [ 1.306354] twi_request_gpio()451 - [i2c3] init name: twi3
7071 [ 1.307109] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
7072 [ 1.307190] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
7073 [ 1.307197] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
7074 [ 1.307211] twi5 supply twi not found, using dummy regulator
7075 [ 1.307285] twi_request_gpio()451 - [i2c5] init name: twi5
7076 [ 1.307766] axp20x-i2c 5-0036: AXP20x variant AXP806 found
7077 [ 1.326358] random: fast init done
7078 [ 1.337543] axp20x-i2c 5-0036: AXP20X driver loaded
7079 [ 1.338038] media: Linux media interface: v0.10
7080 [ 1.338149] Linux video capture interface: v2.00
7081 [ 1.341644] Advanced Linux Sound Architecture Driver Initialized.
7082 [ 1.342376] Bluetooth: Core ver 2.22
7083 [ 1.342475] NET: Registered protocol family 31
7084 [ 1.342481] Bluetooth: HCI device and connection manager initialized
7085 [ 1.342497] Bluetooth: HCI socket layer initialized
7086 [ 1.342510] Bluetooth: L2CAP socket layer initialized
7087 [ 1.342549] Bluetooth: SCO socket layer initialized
7088 [ 1.343348] [DISP]disp_module_init
7089 [ 1.344556] [DISP] parser_disp_init_para,line:1403:
7090 [ 1.344565] of_property_read fb0_width fail
7091 [ 1.344577] [DISP] disp_init,line:2215:
7092 [ 1.344583] smooth display screen:0 type:4 mode:10
7093 [ 1.361858] [DISP]disp_module_init finish
7094 [ 1.362779] clocksource: Switched to clocksource arch_sys_counter
7095 [ 1.363033] VFS: Disk quotas dquot_6.6.0
7096 [ 1.363120] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
7097 [ 1.363882] Console: switching to colour frame buffer device 240x67
7098 [ 1.407227] NET: Registered protocol family 2
7099 [ 1.407354] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
7100 [ 1.426377] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
7101 [ 1.426450] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
7102 [ 1.426572] TCP: Hash tables configured (established 8192 bind 8192)
7103 [ 1.426659] UDP hash table entries: 512 (order: 2, 16384 bytes)
7104 [ 1.426686] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
7105 [ 1.427011] NET: Registered protocol family 1
7106 [ 1.427623] RPC: Registered named UNIX socket transport module.
7107 [ 1.427628] RPC: Registered udp transport module.
7108 [ 1.427631] RPC: Registered tcp transport module.
7109 [ 1.427634] RPC: Registered tcp NFSv4.1 backchannel transport module.
7110 [ 1.427904] Trying to unpack rootfs image as initramfs...
7111 [ 2.181948] Freeing initrd memory: 17256K
7112 [ 2.183090] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
7113 [ 2.186984] audit: initializing netlink subsys (disabled)
7114 [ 2.187040] audit: type=2000 audit(2.183:1): initialized
7115 [ 2.187965] workingset: timestamp_bits=45 max_order=18 bucket_order=0
7116 [ 2.199123] DLM installed
7117 [ 2.200975] squashfs: version 4.0 (2009/01/31) Phillip Lougher
7118 [ 2.201311] Registering sdcardfs 0.1
7119 [ 2.201792] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
7120 [ 2.203342] ntfs: driver 2.1.32 [Flags: R/W].
7121 [ 2.209765] NET: Registered protocol family 38
7122 [ 2.210131] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
7123 [ 2.210270] io scheduler noop registered
7124 [ 2.210278] io scheduler deadline registered
7125 [ 2.210443] io scheduler cfq registered (default)
7126 [ 2.212267] failed to get easy_light_used assign
7127 [ 2.212277] failed to get normal led pin assign
7128 [ 2.212283] failed to get standby led pin assign
7129 [ 2.212288] failed to get standby led pin assign
7130 [ 2.212293] these is zero number for gpio
7131 [ 2.212298] gpio_init finish with uesd
7132 [ 2.215523] uart uart0: get regulator failed
7133 [ 2.215723] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
7134 [ 2.215746] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
7135 [ 2.215842] console [ttyS0] enabled
7136 [ 2.216722] uart uart1: get regulator failed
7137 [ 2.216914] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
7138 [ 2.217636] uart uart5: get regulator failed
7139 [ 2.217824] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
7140 [ 2.219118] misc dump reg init
7141 [ 2.220682] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
7142 [ 2.221027] Unable to detect cache hierarchy for CPU 0
7143 [ 2.235199] brd: module loaded
7144 [ 2.243362] loop: module loaded
7145 [ 2.243551] [NAND][NE] Not found valid nand node on dts
7146 [ 2.244133] Get boot type cmd line fail
7147 [ 2.244717] sunxi-bt soc@03000000:bt: Missing bt_power.
7148 [ 2.244727] sunxi-bt soc@03000000:bt: bt_power_name ((null))
7149 [ 2.244735] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
7150 [ 2.244741] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
7151 [ 2.244798] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
7152 [ 2.244869] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
7153 [ 2.245712] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
7154 [ 2.245723] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
7155 [ 2.245730] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
7156 [ 2.245737] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
7157 [ 2.245744] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
7158 [ 2.245774] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
7159 [ 2.245806] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
7160 [ 2.245814] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
7161 [ 2.245831] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
7162 [ 2.246834] [ADDR_MGT] addr_mgt_probe: success.
7163 [ 2.253317] tun: Universal TUN/TAP device driver, 1.6
7164 [ 2.253327] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
7165 [ 2.255320] gmac-power0: NULL
7166 [ 2.255329] gmac-power1: NULL
7167 [ 2.255335] gmac-power2: NULL
7168 [ 2.256289] PPP generic driver version 2.4.2
7169 [ 2.256610] PPP BSD Compression module registered
7170 [ 2.256620] PPP Deflate Compression module registered
7171 [ 2.256652] PPP MPPE Compression module registered
7172 [ 2.256661] NET: Registered protocol family 24
7173 [ 2.256695] PPTP driver version 0.8.5
7174 [ 2.257063] usbcore: registered new interface driver r8152
7175 [ 2.257140] usbcore: registered new interface driver asix
7176 [ 2.257232] usbcore: registered new interface driver ax88179_178a
7177 [ 2.257297] usbcore: registered new interface driver cdc_ether
7178 [ 2.257357] usbcore: registered new interface driver net1080
7179 [ 2.257416] usbcore: registered new interface driver cdc_subset
7180 [ 2.257474] usbcore: registered new interface driver zaurus
7181 [ 2.257574] usbcore: registered new interface driver cdc_ncm
7182 [ 2.257581] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
7183 [ 2.257942] get drv_vbus is fail, 84
7184 [ 2.257950] get ehci0-controller, regulator_io is no nocare
7185 [ 2.258212] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
7186 [ 2.258218] [sunxi-ehci0]: Not init ehci0
7187 [ 2.258335] get ehci1-controller, regulator_io is no nocare
7188 [ 2.258519] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
7189 [ 2.258578] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
7190 [ 2.258604] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
7191 [ 2.259184] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
7192 [ 2.269475] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
7193 [ 2.269763] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
7194 [ 2.269772] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
7195 [ 2.269780] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
7196 [ 2.269787] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
7197 [ 2.269794] usb usb1: SerialNumber: sunxi-ehci
7198 [ 2.270655] hub 1-0:1.0: USB hub found
7199 [ 2.270701] hub 1-0:1.0: 1 port detected
7200 [ 2.271370] get drv_vbus is fail, 84
7201 [ 2.271379] get ehci2-controller, regulator_io is no nocare
7202 [ 2.271622] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
7203 [ 2.271682] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
7204 [ 2.271707] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
7205 [ 2.271982] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
7206 [ 2.282810] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
7207 [ 2.283024] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
7208 [ 2.283033] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
7209 [ 2.283040] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
7210 [ 2.283048] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
7211 [ 2.283054] usb usb2: SerialNumber: sunxi-ehci
7212 [ 2.283925] hub 2-0:1.0: USB hub found
7213 [ 2.283969] hub 2-0:1.0: 1 port detected
7214 [ 2.284638] get drv_vbus is fail, 84
7215 [ 2.284646] get ehci3-controller, regulator_io is no nocare
7216 [ 2.284893] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
7217 [ 2.284944] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
7218 [ 2.284969] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
7219 [ 2.285283] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
7220 [ 2.296127] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
7221 [ 2.296319] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
7222 [ 2.296328] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
7223 [ 2.296336] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
7224 [ 2.296343] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
7225 [ 2.296350] usb usb3: SerialNumber: sunxi-ehci
7226 [ 2.297209] hub 3-0:1.0: USB hub found
7227 [ 2.297254] hub 3-0:1.0: 1 port detected
7228 [ 2.298190] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
7229 [ 2.298560] get drv_vbus is fail, 84
7230 [ 2.298568] get ohci0-controller, regulator_io is no nocare
7231 [ 2.298901] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
7232 [ 2.298906] [sunxi-ohci0]: Not init ohci0
7233 [ 2.299023] get ohci1-controller, regulator_io is no nocare
7234 [ 2.299189] hci: request ohci1-controller gpio:80
7235 [ 2.299268] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
7236 [ 2.299319] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
7237 [ 2.299345] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
7238 [ 2.299423] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
7239 [ 2.360295] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
7240 [ 2.360306] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
7241 [ 2.360313] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
7242 [ 2.360321] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
7243 [ 2.360328] usb usb4: SerialNumber: sunxi-ohci
7244 [ 2.361205] hub 4-0:1.0: USB hub found
7245 [ 2.361252] hub 4-0:1.0: 1 port detected
7246 [ 2.361920] get drv_vbus is fail, 84
7247 [ 2.361928] get ohci2-controller, regulator_io is no nocare
7248 [ 2.362257] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
7249 [ 2.362308] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
7250 [ 2.362335] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
7251 [ 2.362419] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
7252 [ 2.420292] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
7253 [ 2.420302] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
7254 [ 2.420310] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
7255 [ 2.420317] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
7256 [ 2.420324] usb usb5: SerialNumber: sunxi-ohci
7257 [ 2.421182] hub 5-0:1.0: USB hub found
7258 [ 2.421226] hub 5-0:1.0: 1 port detected
7259 [ 2.421906] get drv_vbus is fail, 84
7260 [ 2.421914] get ohci3-controller, regulator_io is no nocare
7261 [ 2.422239] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
7262 [ 2.422288] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
7263 [ 2.422313] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
7264 [ 2.422392] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
7265 [ 2.480310] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
7266 [ 2.480320] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
7267 [ 2.480328] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
7268 [ 2.480335] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
7269 [ 2.480342] usb usb6: SerialNumber: sunxi-ohci
7270 [ 2.481176] hub 6-0:1.0: USB hub found
7271 [ 2.481227] hub 6-0:1.0: 1 port detected
7272 [ 2.482149] ohci-platform: OHCI generic platform driver
7273 [ 2.482889] usbcore: registered new interface driver uas
7274 [ 2.483057] usbcore: registered new interface driver usb-storage
7275 [ 2.483145] usbcore: registered new interface driver ums-alauda
7276 [ 2.483221] usbcore: registered new interface driver ums-cypress
7277 [ 2.483291] usbcore: registered new interface driver ums-datafab
7278 [ 2.483370] usbcore: registered new interface driver ums_eneub6250
7279 [ 2.483440] usbcore: registered new interface driver ums-freecom
7280 [ 2.483511] usbcore: registered new interface driver ums-isd200
7281 [ 2.483579] usbcore: registered new interface driver ums-jumpshot
7282 [ 2.483648] usbcore: registered new interface driver ums-karma
7283 [ 2.483717] usbcore: registered new interface driver ums-onetouch
7284 [ 2.483809] usbcore: registered new interface driver ums-realtek
7285 [ 2.483893] usbcore: registered new interface driver ums-sddr09
7286 [ 2.483964] usbcore: registered new interface driver ums-sddr55
7287 [ 2.484034] usbcore: registered new interface driver ums-usbat
7288 [ 2.484183] usb_serial_number:20080411
7289 [ 2.485425] input: sunxi-keyboard as /devices/virtual/input/input0
7290 [ 2.486025] usbcore: registered new interface driver xpad
7291 [ 2.486169] usbcore: registered new interface driver usb_acecad
7292 [ 2.486264] usbcore: registered new interface driver aiptek
7293 [ 2.486343] usbcore: registered new interface driver gtco
7294 [ 2.486422] usbcore: registered new interface driver hanwang
7295 [ 2.486501] usbcore: registered new interface driver kbtab
7296 [ 2.486984] axp2101_pek: axp2101-pek can not register without irq
7297 [ 2.487007] axp2101-pek: probe of axp2101-pek.0 failed with error -22
7298 [ 2.488438] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
7299 [ 2.488502] sunxi-rtc rtc: RTC enabled
7300 [ 2.489001] i2c /dev entries driver
7301 [ 2.489834] lirc_dev: IR Remote Control driver registered, major 244
7302 [ 2.489847] IR NEC protocol handler initialized
7303 [ 2.489853] IR RC5(x/sz) protocol handler initialized
7304 [ 2.489859] IR RC6 protocol handler initialized
7305 [ 2.489865] IR JVC protocol handler initialized
7306 [ 2.489870] IR Sony protocol handler initialized
7307 [ 2.489876] IR SANYO protocol handler initialized
7308 [ 2.489882] IR Sharp protocol handler initialized
7309 [ 2.489888] IR MCE Keyboard/mouse protocol handler initialized
7310 [ 2.489893] IR LIRC bridge handler initialized
7311 [ 2.489898] IR XMP protocol handler initialized
7312 [ 2.490427] sunxi_ir_startup: get ir protocol failed
7313 [ 2.490471] 7040000.s_cir supply ir0 not found, using dummy regulator
7314 [ 2.490653] Registered IR keymap rc_map_sunxi
7315 [ 2.491052] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
7316 [ 2.491306] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
7317 [ 2.492317] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
7318 [ 2.492953] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
7319 [ 2.493657] sunxi cedar version 0.1
7320 [ 2.493847] VE: install start!!!
7321
7322 [ 2.494037] cedar_ve: cedar-ve the get irq is 278
7323 [ 2.494672] VE: get debugfs_mpp_root is NULL, please check mpp
7324
7325 [ 2.494685] VE: sunxi ve debug register driver failed!
7326
7327 [ 2.497872] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
7328 [ 2.499171] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
7329 [ 2.499531] Bluetooth: HCI UART driver ver 2.3
7330 [ 2.499542] Bluetooth: HCI UART protocol H4 registered
7331 [ 2.499547] Bluetooth: HCI UART protocol LL registered
7332 [ 2.499554] Bluetooth: HCI UART protocol Three-wire (H5) registered
7333 [ 2.503735] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
7334 [ 2.503751] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
7335 [ 2.503764] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
7336 [ 2.503776] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
7337 [ 2.503788] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
7338 [ 2.503800] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
7339 [ 2.504220] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
7340 [ 2.504336] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
7341 [ 2.504533] sunxi-mmc sdc0: No vmmc regulator found
7342 [ 2.504540] sunxi-mmc sdc0: No vqmmc regulator found
7343 [ 2.504546] sunxi-mmc sdc0: No vdmmc regulator found
7344 [ 2.504552] sunxi-mmc sdc0: No vd33sw regulator found
7345 [ 2.504559] sunxi-mmc sdc0: No vd18sw regulator found
7346 [ 2.504565] sunxi-mmc sdc0: No vq33sw regulator found
7347 [ 2.504571] sunxi-mmc sdc0: No vq18sw regulator found
7348 [ 2.505287] sunxi-mmc sdc0: set host busy
7349 [ 2.505383] sunxi-mmc sdc0: Got CD GPIO
7350 [ 2.505768] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
7351 [ 2.505807] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
7352 [ 2.519473] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7353 [ 2.536426] sunxi-mmc sdc0: detmode:gpio irq
7354 [ 2.536459] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7355 [ 2.538963] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7356 [ 2.540325] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
7357 [ 2.540461] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
7358 [ 2.540604] sunxi-mmc sdc1: No vmmc regulator found
7359 [ 2.540611] sunxi-mmc sdc1: No vqmmc regulator found
7360 [ 2.540617] sunxi-mmc sdc1: No vdmmc regulator found
7361 [ 2.540624] sunxi-mmc sdc1: No vd33sw regulator found
7362 [ 2.540630] sunxi-mmc sdc1: No vd18sw regulator found
7363 [ 2.540636] sunxi-mmc sdc1: No vq33sw regulator found
7364 [ 2.540642] sunxi-mmc sdc1: No vq18sw regulator found
7365 [ 2.541246] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7366 [ 2.542509] sunxi-mmc sdc1: set host busy
7367 [ 2.542591] mmc:failed to get gpios
7368 [ 2.543734] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7369 [ 2.545000] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
7370 [ 2.559526] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7371 [ 2.567486] mmc0: host does not support reading read-only switch, assuming write-enable
7372 [ 2.569393] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
7373 [ 2.569483] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
7374 [ 2.569629] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
7375 [ 2.569719] mmc0: new high speed SDXC card at address 0001
7376 [ 2.574095] mmcblk0: mmc0:0001 SD16G 59.5 GiB
7377 [ 2.575723] mmcblk0: p1
7378 [ 2.576275] sunxi-mmc sdc1: detmode:manually by software
7379 [ 2.577158] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
7380 [ 2.578572] ledtrig-cpu: registered to indicate activity on CPUs
7381 [ 2.579300] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
7382 [ 2.579336] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7383 [ 2.581911] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7384 [ 2.583839] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
7385 [ 2.584675] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
7386 [ 2.585510] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
7387 [ 2.586345] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
7388 [ 2.586391] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
7389 [ 2.586772] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
7390 [ 2.586778] sunxi_emce_probe()590emce hw init failed!
7391 [ 2.586804] emce: probe of emce failed with error -2
7392 [ 2.587070] hidraw: raw HID events driver (C) Jiri Kosina
7393 [ 2.590537] usbcore: registered new interface driver usbhid
7394 [ 2.590545] usbhid: USB HID core driver
7395 [ 2.591815] optee: probing for conduit method from DT.
7396 [ 2.591827] optee: api uid mismatch
7397 [ 2.592469] usbcore: registered new interface driver snd-usb-audio
7398 [ 2.594847] [sunxi_hdmi_codec_init] driver and deivce register finished.
7399 [ 2.597097] [sunxi_internal_codec_probe]:get audio avcc failed
7400 [ 2.597135] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
7401 [ 2.597359] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
7402 [ 2.599957] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
7403 [ 2.601928] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
7404 [ 2.601941] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
7405 [ 2.604379] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
7406 [ 2.604404] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
7407 [ 2.608337] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
7408 [ 2.609749] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
7409 [ 2.611618] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
7410 [ 2.614757] pktgen: Packet Generator for packet performance testing. Version: 2.75
7411 [ 2.615204] u32 classifier
7412 [ 2.615211] Actions configured
7413 [ 2.615223] Netfilter messages via NETLINK v0.30.
7414 [ 2.615251] nfnl_acct: registering with nfnetlink.
7415 [ 2.615593] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
7416 [ 2.615842] ctnetlink v0.93: registering with nfnetlink.
7417 [ 2.616662] xt_time: kernel timezone is -0000
7418 [ 2.616686] IPVS: Registered protocols (TCP, UDP)
7419 [ 2.616790] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
7420 [ 2.616915] IPVS: Creating netns size=1928 id=0
7421 [ 2.617048] IPVS: ipvs loaded.
7422 [ 2.617056] IPVS: [rr] scheduler registered.
7423 [ 2.617156] ipip: IPv4 and MPLS over IPv4 tunneling driver
7424 [ 2.617859] gre: GRE over IPv4 demultiplexor driver
7425 [ 2.617869] ip_gre: GRE over IPv4 tunneling driver
7426 [ 2.619142] IPv4 over IPsec tunneling driver
7427 [ 2.620078] ip_tables: (C) 2000-2006 Netfilter Core Team
7428 [ 2.620360] arp_tables: arp_tables: (C) 2002 David S. Miller
7429 [ 2.620428] Initializing XFRM netlink socket
7430 [ 2.620461] IPsec XFRM device driver
7431 [ 2.621305] NET: Registered protocol family 10
7432 [ 2.623214] mip6: Mobile IPv6
7433 [ 2.623253] ip6_tables: (C) 2000-2006 Netfilter Core Team
7434 [ 2.624571] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
7435 [ 2.626483] NET: Registered protocol family 17
7436 [ 2.626533] NET: Registered protocol family 15
7437 [ 2.626696] Bridge firewalling registered
7438 [ 2.626857] Bluetooth: RFCOMM TTY layer initialized
7439 [ 2.626878] Bluetooth: RFCOMM socket layer initialized
7440 [ 2.626915] Bluetooth: RFCOMM ver 1.11
7441 [ 2.626930] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
7442 [ 2.626936] Bluetooth: BNEP filters: protocol multicast
7443 [ 2.626950] Bluetooth: BNEP socket layer initialized
7444 [ 2.626955] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
7445 [ 2.626967] Bluetooth: HIDP socket layer initialized
7446 [ 2.627052] l2tp_core: L2TP core driver, V2.0
7447 [ 2.627068] l2tp_ppp: PPPoL2TP kernel driver, V2.0
7448 [ 2.627074] 8021q: 802.1Q VLAN Support v1.8
7449 [ 2.627278] sctp: Hash tables configured (bind 256/256)
7450 [ 2.627866] Key type dns_resolver registered
7451 [ 2.628005] Registered cp15_barrier emulation handler
7452 [ 2.628017] Registered setend emulation handler
7453 [ 2.628922] registered taskstats version 1
7454 [ 2.640553] zswap: default zpool zbud not available
7455 [ 2.640561] zswap: pool creation failed
7456 [ 2.643425] Btrfs loaded, crc32c=crc32c-arm64-hw
7457 [ 2.644174] HDMI 2.0 driver init start!
7458 [ 2.644189] boot_hdmi=true
7459 [ 2.645058] Can not find the node of esm
7460 [ 2.645079] ERROR: pinctrl_get for HDMI2.0 DDC fail
7461 [ 2.645170] Get hdmi_power0:vcc-hdmi
7462 [ 2.645210] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
7463 [ 2.645401] Get hdmi_power1:vdd-hdmi
7464 [ 2.645425] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
7465 [ 2.647008] hdmi_cec_init
7466 [ 2.647509] [DISP] disp_device_attached,line:146:
7467 [ 2.647519] attached ok, mgr0<-->device0, type=4
7468 [ 2.647529] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
7469 [ 2.647541] [DISP] disp_hdmi_set_mode,line:648:
7470 [ 2.647546] hdmi_set_mode is null!
7471 [ 2.649787] HDMI2.0 module init end
7472 [ 2.660885] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
7473 [ 2.664523] cpu cpu1: opp_list_debug_create_link: Failed to create link
7474 [ 2.664535] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
7475 [ 2.664568] cpu cpu2: opp_list_debug_create_link: Failed to create link
7476 [ 2.664575] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
7477 [ 2.664605] cpu cpu3: opp_list_debug_create_link: Failed to create link
7478 [ 2.664613] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
7479 [ 2.666916] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
7480 [ 2.667820] get det_vbus is fail, 84
7481 [ 2.667827] get id is fail, 84
7482 [ 2.668300] sunxi-rtc rtc: setting system clock to 2023-09-25 18:18:46 UTC (1695665926)
7483 [ 2.672091] ALSA device list:
7484 [ 2.672099] #0: audiocodec
7485 [ 2.672103] #1: sndahub
7486 [ 2.672106] #2: sndhdmi
7487 [ 2.673747] Freeing unused kernel memory: 3008K
7488 [ 2.718922] random: systemd-udevd: uninitialized urandom read (16 bytes read)
7489 [ 2.721056] random: systemd-udevd: uninitialized urandom read (16 bytes read)
7490 [ 2.724330] random: systemd-udevd: uninitialized urandom read (16 bytes read)
7491 [ 2.796516] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
7492 [ 2.959558] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
7493 [ 3.052820] HDMI cable is connected
7494 [ 3.309468] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
7495 [ 3.529904] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
7496 [ 3.529914] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
7497 [ 3.529919] usb 4-1: Product: Rapoo 2.4G Wireless Device
7498 [ 3.529924] usb 4-1: Manufacturer: RAPOO
7499 [ 3.537841] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
7500 [ 3.538427] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
7501 [ 3.544586] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
7502 [ 3.600307] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
7503 [ 3.604165] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
7504 [ 3.661441] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
7505 [ 4.240626] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
7506 [ 5.145795] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
7507 [ 5.146414] cgroup: cgroup2: unknown option "nsdelegate"
7508 [ 5.166417] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
7509 [ 5.166442] systemd[1]: Detected architecture arm64.
7510 [ 5.167573] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
7511 [ 5.177663] systemd[1]: Hostname set to <opi>.
7512 [ 5.204773] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
7513 [ 6.811857] (sd-execut[1456]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
7514 [ 6.829498]
7515 insmod_device_driver
7516
7517 [ 6.829774] device_chose finished 124!
7518 [ 7.179240] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
7519 [ 7.418750] systemd[1]: Queued start job for default target graphical.target.
7520 [ 7.426080] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
7521 [ 7.428409] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
7522 [ 7.430737] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
7523 [ 7.432003] systemd[1]: Created slice user.slice - User and Session Slice.
7524 [ 7.432654] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
7525 [ 7.433310] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
7526 [ 7.433681] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
7527 [ 7.434215] systemd[1]: Reached target slices.target - Slice Units.
7528 [ 7.434632] systemd[1]: Reached target swap.target - Swaps.
7529 [ 7.434911] systemd[1]: Reached target time-set.target - System Time Set.
7530 [ 7.435401] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
7531 [ 7.452861] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
7532 [ 7.453967] systemd[1]: Listening on syslog.socket - Syslog Socket.
7533 [ 7.454906] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
7534 [ 7.455555] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
7535 [ 7.457208] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
7536 [ 7.458156] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
7537 [ 7.459235] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
7538 [ 7.461469] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
7539 [ 7.462357] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
7540 [ 7.466421] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
7541 [ 7.471032] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
7542 [ 7.475978] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
7543 [ 7.477424] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
7544 [ 7.478405] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
7545 [ 7.486045] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
7546 [ 7.491690] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
7547 [ 7.497469] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
7548 [ 7.506003] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
7549 [ 7.515590] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
7550 [ 7.527791] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
7551 [ 7.535173] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
7552 [ 7.543132] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
7553 [ 7.551053] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
7554 [ 7.552604] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
7555 [ 7.562751] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
7556 [ 7.569321] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
7557 [ 7.574418] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
7558 [ 7.584799] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
7559 [ 7.587299] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
7560 [ 7.589247] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
7561 [ 7.592005] fuse init (API version 7.26)
7562 [ 7.593312] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
7563 [ 7.599112] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
7564 [ 7.603263] systemd[1]: modprobe@configfs.service: Deactivated successfully.
7565 [ 7.603890] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
7566 [ 7.608223] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
7567 [ 7.644815] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
7568 [ 7.656743] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
7569 [ 7.662023] systemd[1]: modprobe@drm.service: Deactivated successfully.
7570 [ 7.662567] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
7571 [ 7.664769] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
7572 [ 7.665330] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
7573 [ 7.667531] systemd[1]: modprobe@fuse.service: Deactivated successfully.
7574 [ 7.668055] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
7575 [ 7.670976] systemd[1]: modprobe@loop.service: Deactivated successfully.
7576 [ 7.675122] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
7577 [ 7.683286] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
7578 [ 7.684222] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
7579 [ 7.684232] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
7580 [ 7.684421] spidev spi1.1: Deleting spi1.1
7581 [ 7.685390] fbtft_device: GPIOS used by 'fb_st7735r':
7582 [ 7.685397] fbtft_device: 'reset' = GPIO73
7583 [ 7.685401] fbtft_device: 'dc' = GPIO70
7584 [ 7.685412] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
7585 [ 7.685418] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
7586 [ 7.696780] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
7587 [ 7.722550] WCN: marlin_init entry!
7588 [ 7.723788] WCN: marlin_parse_dt reset gpio=211
7589 [ 7.723799] WCN_ERR: gpio reset request err: 211
7590 [ 7.723804] WCN: wcn config bt wake host
7591 [ 7.724317] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
7592 [ 7.724446] WCN: wcn config wifi wake host
7593 [ 7.724465] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
7594 [ 7.728152] sdiohal:sdiohal_init ok
7595 [ 7.729058] WCN: marlin_probe ok!
7596 [ 7.737855] mtty_probe init device addr: 0xffffffc0095b6e00
7597 [ 7.738035] -->rfkill_bluetooth_init
7598 [ 7.738242] <--rfkill_bluetooth_init
7599 [ 7.750168] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
7600 [ 7.758288] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
7601 [ 7.764967] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
7602 [ 7.765975] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
7603 [ 7.782030] WCN: start_marlin [MARLIN_WIFI]
7604 [ 7.782044] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
7605 [ 7.782048] WCN: the first power on start
7606 [ 7.791125] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
7607 [ 7.791851] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
7608 [ 7.798448] systemd[1]: Starting systemd-sysusers.service - Create System Users...
7609 [ 7.804260] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
7610 [ 7.807510] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
7611 [ 7.825607] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
7612 [ 7.884017] systemd[1]: Finished systemd-sysusers.service - Create System Users.
7613 [ 7.890545] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
7614 [ 7.896198] WCN: marlin chip en pull up
7615 [ 7.922933] sdiohal:sdiohal_scan_card
7616 [ 7.922967] sunxi-wlan soc@03000000:wlan: bus_index: 1
7617 [ 7.923018] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
7618 [ 7.939528] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7619 [ 7.960381] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
7620 [ 7.961290] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
7621 [ 7.961331] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7622 [ 7.963903] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7623 [ 7.967016] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7624 [ 7.982832] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
7625 [ 7.989419] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
7626 [ 7.991496] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
7627 [ 7.993907] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
7628 [ 7.994700] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
7629 [ 7.994798] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
7630 [ 7.995529] mmc1: new ultra high speed SDR104 SDIO card at address 8800
7631 [ 7.996246] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
7632 [ 7.996461] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
7633 [ 7.996490] WCN: marlin_scan_finish!
7634 [ 7.996494] sdiohal:probe ok
7635 [ 7.996505] sdiohal:scan end!
7636 [ 7.996511] WCN: then marlin start to download
7637 [ 7.996551] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
7638 [ 7.997527] systemd[1]: Mounting tmp.mount - /tmp...
7639 [ 8.033608] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
7640 [ 8.038411] systemd[1]: Mounted tmp.mount - /tmp.
7641 [ 8.041135] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
7642 [ 8.043567] systemd[1]: Reached target local-fs.target - Local File Systems.
7643 [ 8.048513] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
7644 [ 8.053562] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
7645 [ 8.087280] systemd[1]: Starting console-setup.service - Set console font and keymap...
7646 [ 8.102521] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
7647 [ 8.112421] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
7648 [ 8.130433] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
7649 [ 8.133574] WCN: combin_img 0 marlin_firmware_write finish and successful
7650 [ 8.133756] WCN: marlin_start_run read reset reg val:0x1
7651 [ 8.133760] WCN: after do marlin_start_run reset reg val:0x0
7652 [ 8.133966] WCN: s_marlin_bootup_time=8133959468
7653 [ 8.138879] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
7654 [ 8.139807] WCN: clock mode: TSX
7655 [ 8.140084] WCN: marlin_write_cali_data sync init_state:0x1a0f50
7656 [ 8.147303] systemd[1]: Starting ufw.service - Uncomplicated firewall...
7657 [ 8.151926] systemd[1]: Finished console-setup.service - Set console font and keymap.
7658 [ 8.164753] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
7659 [ 8.167222] WCN: marlin_write_cali_data sync init_state:0x1a0f50
7660 [ 8.182202] systemd[1]: Received SIGRTMIN+20 from PID 1419 (plymouthd).
7661 [ 8.193224] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
7662 [ 8.193235] WCN: sdio_config bt_wake_host trigger:[high]
7663 [ 8.193239] WCN: sdio_config irq:[inband]
7664 [ 8.193244] WCN: sdio_config wl_wake_host trigger:[high]
7665 [ 8.193249] WCN: sdio_config wake_host_level_duration_time:[20ms]
7666 [ 8.193252] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
7667 [ 8.193256] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
7668 [ 8.193618] WCN: marlin_write_cali_data finish
7669 [ 8.193804] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
7670 [ 8.210627] systemd[1]: Finished ufw.service - Uncomplicated firewall.
7671 [ 8.217819] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
7672 [ 8.219776] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
7673 [ 8.222579] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
7674 [ 8.223377] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
7675 [ 8.224142] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
7676 [ 8.227534] systemd[1]: Reached target network-pre.target - Preparation for Network.
7677 [ 8.246350] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
7678 [ 8.270355] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
7679 [ 8.273053] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
7680 [ 8.299706] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
7681 [ 8.327502] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
7682 [ 8.327514] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a117df30c640a9405a3d69
7683 [ 8.327533] WCN: marlin_bind_verify verify data: 0x16d6ab91e1d71b3ae4604f224021aa
7684 [ 8.328066] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
7685 [ 8.353173] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
7686 [ 8.353181] sdiohal:sdiohal_runtime_get entry
7687 [ 8.353343] WCN: get_cp2_version entry!
7688 [ 8.354857] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
7689 [ 8.354887] WCN: switch_cp2_log - close entry!
7690 [ 8.356169] WCN: WCND at cmd read:OK
7691 [ 8.356226] WCN: then marlin download finished and run ok
7692 [ 8.356231] WCN: start_loopcheck
7693 [ 8.374295] WCN: get_board_ant_num [one_ant]
7694 [ 8.374308] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
7695 [ 8.436980] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
7696 [ 8.441339] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
7697 [ 8.449680] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
7698 [ 8.520727] zram: Added device: zram0
7699 [ 8.521818] zram: Added device: zram1
7700 [ 8.522652] zram: Added device: zram2
7701 [ 8.547016] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
7702 [ 8.556837] systemd[1]: Starting networking.service - Raise network interfaces...
7703 [ 8.560976] zswap: can't enable, initialization failed
7704 [ 8.593041] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
7705 [ 8.612058] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
7706 [ 8.622557] zram0: detected capacity change from 0 to 506396672
7707 [ 8.689130] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
7708 [ 8.695579] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
7709 [ 8.697665] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
7710 [ 8.698424] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
7711 [ 8.698850] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
7712 [ 9.164249] systemd[1]: Finished networking.service - Raise network interfaces.
7713 [ 9.885868] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
7714 [ 9.949826] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
7715 [ 10.196492] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
7716 [ 10.835602] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
7717 [ 10.835936] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
7718 [ 10.837595] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
7719 [ 10.838464] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
7720 [ 10.858823] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
7721 [ 10.892384] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
7722 [ 10.902749] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
7723 [ 10.912628] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
7724 [ 10.919820] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
7725 [ 10.927187] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
7726 [ 10.936512] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
7727 [ 10.938331] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
7728 [ 10.941050] systemd[1]: modprobe@loop.service: Deactivated successfully.
7729 [ 10.941884] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
7730 [ 10.954859] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
7731 [ 10.955133] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
7732 [ 11.014423] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
7733 [ 11.017667] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
7734 [ 11.018461] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
7735 [ 11.020090] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
7736 [ 11.054368] sunxi-bt soc@03000000:bt: set block: 0
7737 [ 11.068226] bluetooth_set_power: start_block=0
7738 [ 11.068238] WCN: start_marlin [MARLIN_BLUETOOTH]
7739 [ 11.068249] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
7740 [ 11.068253] WCN: marlin have open, GNSS is closed
7741 [ 11.068258] bluetooth_set_power: end_block=0
7742 [ 11.082041] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
7743 [ 11.101996] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
7744 [ 11.107741] systemd[1]: Starting brltty.service - Braille Device Support...
7745 [ 11.665490] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
7746 [ 11.811684] zram1: detected capacity change from 0 to 52428800
7747 [ 11.867311] systemd[1]: Started brltty.service - Braille Device Support.
7748 [ 11.887015] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
7749 [ 15.912948] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
7750 [ 15.918761] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
7751 [ 15.980222] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
7752 [ 16.099167] systemd[1]: systemd-rfkill.service: Deactivated successfully.
7753 [ 19.866397] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
7754 [ 19.872691] systemd[1]: Starting systemd-journald.service - Journal Service...
7755 [ 20.143398] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
7756 [ 20.143420] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
7757 [ 20.150867] systemd[1]: Started systemd-journald.service - Journal Service.
7758 [ 20.197915] systemd-journald[1921]: Received client request to flush runtime journal.
7759 [ 20.271279] systemd-journald[1921]: Data hash table of /var/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 77.0 (3505 of 4551 items, 2621440 file size, 747 bytes per hash table item), suggesting rotation.
7760 [ 20.271303] systemd-journald[1921]: /var/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
7761 [ 20.676205] IPVS: Creating netns size=1928 id=1
7762
7763 ### armbian-release:
7764
7765 # PLEASE DO NOT EDIT THIS FILE
7766 BOARD=orangepizero2
7767 BOARD_NAME="Orange Pi Zero2"
7768 BOARDFAMILY=sun50iw9
7769 BUILD_REPOSITORY_URL=https://github.com/armbian/build
7770 BUILD_REPOSITORY_COMMIT=ac829eb6
7771 LINUXFAMILY=sun50iw9
7772 ARCH=arm64
7773 IMAGE_TYPE=stable
7774 BOARD_TYPE=conf
7775 INITRD_ARCH=arm
7776 KERNEL_IMAGE_TYPE=Image
7777 FORCE_BOOTSCRIPT_UPDATE=yes
7778 VENDOR=Armbian
7779 BOOTSCRIPT_FORCE_UPDATE="yes"
7780 BOOTSCRIPT_DST="boot.cmd"
7781 VERSION=23.8.1
7782 REVISION=23.8.1
7783 BRANCH=legacy
7784
7785 ### boot environment:
7786
7787 verbosity=1
7788 console=serial
7789 #disp_mode=1080p60
7790 #fb0_width=1280
7791 #fb0_height=720
7792 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
7793 rootfstype=ext4
7794 overlays=spi-spidev
7795 param_spidev_spi_bus=1
7796 param_spidev_spi_cs=1
7797 extraargs=fbcon=map:1
7798 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
7799
7800 ### lsusb:
7801
7802 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
7803 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
7804 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
7805 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
7806 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
7807 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
7808 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
7809
7810 ### lscpu:
7811
7812 Architecture: aarch64
7813 CPU op-mode(s): 32-bit, 64-bit
7814 Byte Order: Little Endian
7815 CPU(s): 4
7816 On-line CPU(s) list: 0-3
7817 Vendor ID: ARM
7818 Model name: Cortex-A53
7819 Model: 4
7820 Thread(s) per core: 1
7821 Core(s) per cluster: 4
7822 Socket(s): -
7823 Cluster(s): 1
7824 Stepping: r0p4
7825 CPU(s) scaling MHz: 100%
7826 CPU max MHz: 1512.0000
7827 CPU min MHz: 480.0000
7828 BogoMIPS: 48.00
7829 Flags: fp asimd aes pmull sha1 sha2 crc32
7830
7831 ### cpuinfo:
7832
7833 processor : 0
7834 BogoMIPS : 48.00
7835 Features : fp asimd aes pmull sha1 sha2 crc32
7836 CPU implementer : 0x41
7837 CPU architecture: 8
7838 CPU variant : 0x0
7839 CPU part : 0xd03
7840 CPU revision : 4
7841
7842 processor : 1
7843 BogoMIPS : 48.00
7844 Features : fp asimd aes pmull sha1 sha2 crc32
7845 CPU implementer : 0x41
7846 CPU architecture: 8
7847 CPU variant : 0x0
7848 CPU part : 0xd03
7849 CPU revision : 4
7850
7851 processor : 2
7852 BogoMIPS : 48.00
7853 Features : fp asimd aes pmull sha1 sha2 crc32
7854 CPU implementer : 0x41
7855 CPU architecture: 8
7856 CPU variant : 0x0
7857 CPU part : 0xd03
7858 CPU revision : 4
7859
7860 processor : 3
7861 BogoMIPS : 48.00
7862 Features : fp asimd aes pmull sha1 sha2 crc32
7863 CPU implementer : 0x41
7864 CPU architecture: 8
7865 CPU variant : 0x0
7866 CPU part : 0xd03
7867 CPU revision : 4
7868
7869
7870 ### meminfo:
7871
7872 MemTotal: 989056 kB
7873 MemFree: 791132 kB
7874 MemAvailable: 886204 kB
7875 Buffers: 15672 kB
7876 Cached: 86408 kB
7877 SwapCached: 0 kB
7878 Active: 66432 kB
7879 Inactive: 56804 kB
7880 Active(anon): 21348 kB
7881 Inactive(anon): 632 kB
7882 Active(file): 45084 kB
7883 Inactive(file): 56172 kB
7884 Unevictable: 0 kB
7885 Mlocked: 0 kB
7886 SwapTotal: 494524 kB
7887 SwapFree: 494524 kB
7888 Dirty: 10092 kB
7889 Writeback: 0 kB
7890 AnonPages: 21068 kB
7891 Mapped: 24172 kB
7892 Shmem: 808 kB
7893 Slab: 33212 kB
7894 SReclaimable: 9276 kB
7895 SUnreclaim: 23936 kB
7896 KernelStack: 2544 kB
7897 PageTables: 1056 kB
7898 NFS_Unstable: 0 kB
7899 Bounce: 0 kB
7900 WritebackTmp: 0 kB
7901 CommitLimit: 989052 kB
7902 Committed_AS: 79860 kB
7903 VmallocTotal: 263061440 kB
7904 VmallocUsed: 0 kB
7905 VmallocChunk: 0 kB
7906 CmaTotal: 16384 kB
7907 CmaFree: 7468 kB
7908 HugePages_Total: 0
7909 HugePages_Free: 0
7910 HugePages_Rsvd: 0
7911 HugePages_Surp: 0
7912 Hugepagesize: 2048 kB
7913
7914 ### virtual memory:
7915
7916 vm.admin_reserve_kbytes = 8192
7917 vm.block_dump = 0
7918 vm.compact_unevictable_allowed = 1
7919 vm.dirty_background_bytes = 0
7920 vm.dirty_background_ratio = 10
7921 vm.dirty_bytes = 0
7922 vm.dirty_expire_centisecs = 3000
7923 vm.dirty_ratio = 20
7924 vm.dirtytime_expire_seconds = 43200
7925 vm.dirty_writeback_centisecs = 500
7926 vm.extfrag_threshold = 500
7927 vm.extra_free_kbytes = 0
7928 vm.hugepages_treat_as_movable = 0
7929 vm.hugetlb_shm_group = 0
7930 vm.laptop_mode = 0
7931 vm.legacy_va_layout = 0
7932 vm.lowmem_reserve_ratio = 256 32
7933 vm.max_map_count = 65530
7934 vm.min_free_kbytes = 3937
7935 vm.mmap_min_addr = 4096
7936 vm.mmap_rnd_bits = 18
7937 vm.mmap_rnd_compat_bits = 11
7938 vm.nr_hugepages = 0
7939 vm.nr_overcommit_hugepages = 0
7940 vm.nr_pdflush_threads = 0
7941 vm.oom_dump_tasks = 1
7942 vm.oom_kill_allocating_task = 0
7943 vm.overcommit_kbytes = 0
7944 vm.overcommit_memory = 0
7945 vm.overcommit_ratio = 50
7946 vm.page-cluster = 0
7947 vm.panic_on_oom = 0
7948 vm.percpu_pagelist_fraction = 0
7949 vm.stat_interval = 1
7950 vm.swappiness = 100
7951 vm.user_reserve_kbytes = 29994
7952 vm.vfs_cache_pressure = 100
7953 vm.watermark_scale_factor = 10
7954
7955 ### ip addr:
7956
7957 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
7958 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
7959 inet XXX.XXX.0.1/8 scope host lo
7960 valid_lft forever preferred_lft forever
7961 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
7962 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
7963 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
7964 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
7965 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
7966 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
7967 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
7968 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
7969 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
7970 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
7971 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
7972 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
7973 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
7974 link/tunnel6 :: brd ::
7975 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
7976 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
7977 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
7978 link/tunnel6 :: brd ::
7979 11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
7980 link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
7981
7982 ### partitions:
7983
7984 major minor #blocks name
7985
7986 179 0 62410752 mmcblk0
7987 179 1 61763584 mmcblk0p1
7988 253 0 494528 zram0
7989 253 1 51200 zram1
7990
7991 ### df:
7992
7993 udev 466M 0 466M 0% /dev
7994 tmpfs 97M 2.1M 95M 3% /run
7995 /dev/mmcblk0p1 58G 7.3G 51G 13% /
7996 tmpfs 483M 0 483M 0% /dev/shm
7997 tmpfs 5.0M 0 5.0M 0% /run/lock
7998 tmpfs 483M 4.0K 483M 1% /tmp
7999 /dev/zram1 47M 9.8M 34M 23% /var/log
8000
8001 ### lsblk:
8002
8003 NAME FSTYPE SIZE MOUNTPOINT UUID
8004 mmcblk0 59.5G
8005 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
8006 zram1 50M /var/log
8007 zram2 0B
8008
8009 ### zramctl:
8010
8011 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
8012 /dev/zram1 lz4 50M 9.8M 2.6M 3.1M 4 /var/log
8013 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
8014
8015 ### mtab:
8016
8017 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
8018 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
8019 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
8020
8021 ### mmc0:0001 info:
8022
8023 manfid: 0x0000fe
8024 cid: fe3432534431364720000000690091f5
8025 fwrev: 0x0
8026 csd: 400e00325b590001dc277f800a40008b
8027 ocr: 0x00200000
8028 type: SD
8029 date: 01/2009
8030 hwrev: 0x2
8031 dsr: 0x404
8032 serial: 0x00000069
8033 erase_size: 512
8034 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
8035 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
8036 scr: 0285808300000000
8037 oemid: 0x3432
8038 preferred_erase_size: 4194304
8039 name: SD16G
8040
8041 ### Boot system health:
8042
8043 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
8044 15:19:07 1512 MHz 1.10 39% 19% 13% 0% 6% 0% 52.2 °C 0/5
8045 15:19:07 1512 MHz 1.10 95% 31% 45% 1% 17% 0% 49.6 °C 0/5
8046 15:19:07 1512 MHz 1.10 99% 29% 48% 0% 20% 0% 49.6 °C 0/5
8047 15:19:08 1512 MHz 1.10 99% 38% 52% 0% 7% 0% 51.7 °C 0/5
8048 15:19:08 1512 MHz 1.10 98% 28% 63% 0% 5% 0% 51.7 °C 0/5
8049
8050 ### Activated 1 lzo zram swap devices with 482MB each.
8051 ### Activated Armbian ramlog partition with lz4 compression
8052
8053 Mon Sep 25 03:30:19 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
8054
8055 ### dmesg:
8056
8057 [ 0.000000] Booting Linux on physical CPU 0x0
8058 [ 0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
8059 [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
8060 [ 0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
8061 [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
8062 [ 0.000000] On node 0 totalpages: 262144
8063 [ 0.000000] DMA zone: 4096 pages used for memmap
8064 [ 0.000000] DMA zone: 0 pages reserved
8065 [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
8066 [ 0.000000] psci: probing for conduit method from DT.
8067 [ 0.000000] psci: PSCIv1.0 detected in firmware.
8068 [ 0.000000] psci: Using standard PSCI v0.2 function IDs
8069 [ 0.000000] psci: Trusted OS migration not required
8070 [ 0.000000] psci: SMC Calling Convention v1.0
8071 [ 0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
8072 [ 0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
8073 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
8074 [ 0.000000] Detected VIPT I-cache on CPU0
8075 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
8076 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 258048
8077 [ 0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
8078 [ 0.000000] log_buf_len individual max cpu contribution: 131072 bytes
8079 [ 0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
8080 [ 0.000000] log_buf_len min size: 131072 bytes
8081 [ 0.000000] log_buf_len: 524288 bytes
8082 [ 0.000000] early log buf free: 129352(98%)
8083 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
8084 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
8085 [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
8086 [ 0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
8087 [ 0.000000] Virtual kernel memory layout:
8088 [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
8089 [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
8090 [ 0.000000] .text : 0xffffff8008208000 - 0xffffff8008da8000 ( 11904 KB)
8091 [ 0.000000] .rodata : 0xffffff8008da8000 - 0xffffff8009438000 ( 6720 KB)
8092 [ 0.000000] .init : 0xffffff8009438000 - 0xffffff8009728000 ( 3008 KB)
8093 [ 0.000000] .data : 0xffffff8009728000 - 0xffffff8009899008 ( 1477 KB)
8094 [ 0.000000] .bss : 0xffffff8009899008 - 0xffffff8009941b94 ( 675 KB)
8095 [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
8096 [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
8097 [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
8098 [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
8099 [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
8100 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
8101 [ 0.000000] Preemptible hierarchical RCU implementation.
8102 [ 0.000000] Build-time adjustment of leaf fanout to 64.
8103 [ 0.000000] NR_IRQS:64 nr_irqs:64 0
8104 [ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
8105 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
8106 [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
8107 [ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
8108 [ 0.000226] Console: colour dummy device 80x25
8109 [ 0.000240] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
8110 [ 0.000250] pid_max: default: 32768 minimum: 301
8111 [ 0.000445] Security Framework initialized
8112 [ 0.000453] AppArmor: AppArmor disabled by boot time parameter
8113 [ 0.000570] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
8114 [ 0.000576] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
8115 [ 0.001838] sched-energy: CPU device node has no sched-energy-costs
8116 [ 0.001854] Invalid sched_group_energy for CPU0
8117 [ 0.001861] CPU0: update cpu_capacity 1024
8118 [ 0.008972] ASID allocator initialised with 32768 entries
8119 [ 0.027949] BOOTEVENT: 27.933623: ON
8120 [ 0.055922] Detected VIPT I-cache on CPU1
8121 [ 0.055976] Invalid sched_group_energy for CPU1
8122 [ 0.055979] CPU1: update cpu_capacity 1024
8123 [ 0.055982] CPU1: Booted secondary processor [410fd034]
8124 [ 0.079312] Detected VIPT I-cache on CPU2
8125 [ 0.079350] Invalid sched_group_energy for CPU2
8126 [ 0.079353] CPU2: update cpu_capacity 1024
8127 [ 0.079356] CPU2: Booted secondary processor [410fd034]
8128 [ 0.102713] Detected VIPT I-cache on CPU3
8129 [ 0.102748] Invalid sched_group_energy for CPU3
8130 [ 0.102752] CPU3: update cpu_capacity 1024
8131 [ 0.102754] CPU3: Booted secondary processor [410fd034]
8132 [ 0.102833] Brought up 4 CPUs
8133 [ 0.102841] SMP: Total of 4 processors activated.
8134 [ 0.102849] CPU features: detected feature: 32-bit EL0 Support
8135 [ 0.102855] CPU features: detected feature: Kernel page table isolation (KPTI)
8136 [ 0.106620] CPU: All CPU(s) started at EL1
8137 [ 0.106643] alternatives: patching kernel code
8138 [ 0.106819] Invalid sched_group_energy for CPU3
8139 [ 0.106829] CPU3: update max cpu_capacity 1024
8140 [ 0.106834] Invalid sched_group_energy for Cluster3
8141 [ 0.106839] Invalid sched_group_energy for CPU2
8142 [ 0.106845] Invalid sched_group_energy for Cluster2
8143 [ 0.106849] Invalid sched_group_energy for CPU1
8144 [ 0.106855] Invalid sched_group_energy for Cluster1
8145 [ 0.106860] Invalid sched_group_energy for CPU0
8146 [ 0.106865] Invalid sched_group_energy for Cluster0
8147 [ 0.108291] devtmpfs: initialized
8148 [ 0.112724] CPU1: update max cpu_capacity 1024
8149 [ 0.143412] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
8150 [ 0.143433] futex hash table entries: 1024 (order: 5, 131072 bytes)
8151 [ 0.144092] xor: measuring software checksum speed
8152 [ 0.176256] 8regs : 1933.200 MB/sec
8153 [ 0.209635] 8regs_prefetch: 1720.800 MB/sec
8154 [ 0.243021] 32regs : 2287.200 MB/sec
8155 [ 0.276408] 32regs_prefetch: 1935.600 MB/sec
8156 [ 0.276414] xor: using function: 32regs (2287.200 MB/sec)
8157 [ 0.276474] atomic64_test: passed
8158 [ 0.276480] pinctrl core: initialized pinctrl subsystem
8159 [ 0.277654] NET: Registered protocol family 16
8160 [ 0.278809] dump_class_init,861, success
8161 [ 0.296468] cpuidle: using governor menu
8162 [ 0.297898] sunxi iommu: irq = 8
8163 [ 0.298211] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
8164 [ 0.298228] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
8165 [ 0.299630] DMA: preallocated 256 KiB pool for atomic allocations
8166 [ 0.301010] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
8167 [ 0.315366] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
8168 [ 0.319287] iommu: Adding device 1c0e000.ve to group 0
8169 [ 0.319799] iommu: Adding device 1c00000.vp9 to group 0
8170 [ 0.331254] iommu: Adding device 1000000.disp to group 0
8171 [ 0.332671] iommu: Adding device 1480000.g2d to group 0
8172 [ 0.335875] iommu: Adding device csi0 to group 0
8173 [ 0.336335] iommu: Adding device csi1 to group 0
8174 [ 0.337567] iommu: Adding device 6600800.vind:scaler@0 to group 0
8175 [ 0.337861] iommu: Adding device 6600800.vind:scaler@1 to group 0
8176 [ 0.338173] iommu: Adding device 6600800.vind:scaler@2 to group 0
8177 [ 0.338459] iommu: Adding device 6600800.vind:scaler@3 to group 0
8178 [ 0.338742] iommu: Adding device 6600800.vind:scaler@4 to group 0
8179 [ 0.339026] iommu: Adding device 6600800.vind:scaler@5 to group 0
8180 [ 0.339983] iommu: Adding device vinc0 to group 0
8181 [ 0.340544] iommu: Adding device vinc1 to group 0
8182 [ 0.341998] iommu: Adding device 1420000.deinterlace to group 0
8183 [ 0.391224] HugeTLB registered 2 MB page size, pre-allocated 0 pages
8184 [ 0.447338] raid6: int64x1 gen() 391 MB/s
8185 [ 0.504125] raid6: int64x1 xor() 363 MB/s
8186 [ 0.560790] raid6: int64x2 gen() 590 MB/s
8187 [ 0.617590] raid6: int64x2 xor() 512 MB/s
8188 [ 0.674310] raid6: int64x4 gen() 840 MB/s
8189 [ 0.731025] raid6: int64x4 xor() 628 MB/s
8190 [ 0.787767] raid6: int64x8 gen() 964 MB/s
8191 [ 0.844540] raid6: int64x8 xor() 655 MB/s
8192 [ 0.901328] raid6: neonx1 gen() 648 MB/s
8193 [ 0.958023] raid6: neonx1 xor() 641 MB/s
8194 [ 1.014746] raid6: neonx2 gen() 975 MB/s
8195 [ 1.071510] raid6: neonx2 xor() 819 MB/s
8196 [ 1.128240] raid6: neonx4 gen() 1286 MB/s
8197 [ 1.184979] raid6: neonx4 xor() 965 MB/s
8198 [ 1.241748] raid6: neonx8 gen() 1323 MB/s
8199 [ 1.298459] raid6: neonx8 xor() 991 MB/s
8200 [ 1.298465] raid6: using algorithm neonx8 gen() 1323 MB/s
8201 [ 1.298470] raid6: .... xor() 991 MB/s, rmw enabled
8202 [ 1.298475] raid6: using intx1 recovery algorithm
8203 [ 1.298647] pwm module init!
8204 [ 1.302976] sunxi-pm debug v3.10
8205 [ 1.304067] SCSI subsystem initialized
8206 [ 1.304687] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
8207 [ 1.304772] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
8208 [ 1.304889] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
8209 [ 1.305384] spi spi0: master is unqueued, this is deprecated
8210 [ 1.305695] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
8211 [ 1.306284] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
8212 [ 1.306365] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
8213 [ 1.306483] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
8214 [ 1.306950] spi spi1: master is unqueued, this is deprecated
8215 [ 1.307263] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
8216 [ 1.308058] usbcore: registered new interface driver usbfs
8217 [ 1.308143] usbcore: registered new interface driver hub
8218 [ 1.308221] usbcore: registered new device driver usb
8219 [ 1.308375] sunxi_i2c_adap_init()2522 - init
8220 [ 1.308951] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
8221 [ 1.309047] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
8222 [ 1.309054] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
8223 [ 1.309070] twi3 supply twi not found, using dummy regulator
8224 [ 1.309146] twi_request_gpio()451 - [i2c3] init name: twi3
8225 [ 1.309915] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
8226 [ 1.309994] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
8227 [ 1.310001] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
8228 [ 1.310015] twi5 supply twi not found, using dummy regulator
8229 [ 1.310090] twi_request_gpio()451 - [i2c5] init name: twi5
8230 [ 1.310571] axp20x-i2c 5-0036: AXP20x variant AXP806 found
8231 [ 1.329304] random: fast init done
8232 [ 1.340490] axp20x-i2c 5-0036: AXP20X driver loaded
8233 [ 1.340973] media: Linux media interface: v0.10
8234 [ 1.341049] Linux video capture interface: v2.00
8235 [ 1.341908] Advanced Linux Sound Architecture Driver Initialized.
8236 [ 1.342633] Bluetooth: Core ver 2.22
8237 [ 1.342705] NET: Registered protocol family 31
8238 [ 1.342711] Bluetooth: HCI device and connection manager initialized
8239 [ 1.342727] Bluetooth: HCI socket layer initialized
8240 [ 1.342739] Bluetooth: L2CAP socket layer initialized
8241 [ 1.342777] Bluetooth: SCO socket layer initialized
8242 [ 1.343552] [DISP]disp_module_init
8243 [ 1.344766] [DISP] parser_disp_init_para,line:1403:
8244 [ 1.344776] of_property_read fb0_width fail
8245 [ 1.344788] [DISP] disp_init,line:2215:
8246 [ 1.344794] smooth display screen:0 type:4 mode:10
8247 [ 1.362118] [DISP]disp_module_init finish
8248 [ 1.362980] clocksource: Switched to clocksource arch_sys_counter
8249 [ 1.363241] VFS: Disk quotas dquot_6.6.0
8250 [ 1.363330] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
8251 [ 1.364068] Console: switching to colour frame buffer device 240x67
8252 [ 1.407307] NET: Registered protocol family 2
8253 [ 1.407432] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
8254 [ 1.419902] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
8255 [ 1.419977] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
8256 [ 1.420100] TCP: Hash tables configured (established 8192 bind 8192)
8257 [ 1.420192] UDP hash table entries: 512 (order: 2, 16384 bytes)
8258 [ 1.420220] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
8259 [ 1.420538] NET: Registered protocol family 1
8260 [ 1.421159] RPC: Registered named UNIX socket transport module.
8261 [ 1.421164] RPC: Registered udp transport module.
8262 [ 1.421167] RPC: Registered tcp transport module.
8263 [ 1.421170] RPC: Registered tcp NFSv4.1 backchannel transport module.
8264 [ 1.421447] Trying to unpack rootfs image as initramfs...
8265 [ 2.175632] Freeing initrd memory: 17256K
8266 [ 2.176730] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
8267 [ 2.180610] audit: initializing netlink subsys (disabled)
8268 [ 2.180669] audit: type=2000 audit(2.176:1): initialized
8269 [ 2.181586] workingset: timestamp_bits=45 max_order=18 bucket_order=0
8270 [ 2.192665] DLM installed
8271 [ 2.194509] squashfs: version 4.0 (2009/01/31) Phillip Lougher
8272 [ 2.194846] Registering sdcardfs 0.1
8273 [ 2.195314] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
8274 [ 2.196852] ntfs: driver 2.1.32 [Flags: R/W].
8275 [ 2.203364] NET: Registered protocol family 38
8276 [ 2.203725] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
8277 [ 2.203867] io scheduler noop registered
8278 [ 2.203874] io scheduler deadline registered
8279 [ 2.204034] io scheduler cfq registered (default)
8280 [ 2.205837] failed to get easy_light_used assign
8281 [ 2.205848] failed to get normal led pin assign
8282 [ 2.205854] failed to get standby led pin assign
8283 [ 2.205858] failed to get standby led pin assign
8284 [ 2.205864] these is zero number for gpio
8285 [ 2.205868] gpio_init finish with uesd
8286 [ 2.209224] uart uart0: get regulator failed
8287 [ 2.209419] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
8288 [ 2.209441] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
8289 [ 2.209530] console [ttyS0] enabled
8290 [ 2.210376] uart uart1: get regulator failed
8291 [ 2.210568] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
8292 [ 2.211256] uart uart5: get regulator failed
8293 [ 2.211441] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
8294 [ 2.212650] misc dump reg init
8295 [ 2.214153] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
8296 [ 2.214492] Unable to detect cache hierarchy for CPU 0
8297 [ 2.228621] brd: module loaded
8298 [ 2.236971] loop: module loaded
8299 [ 2.237161] [NAND][NE] Not found valid nand node on dts
8300 [ 2.237751] Get boot type cmd line fail
8301 [ 2.238358] sunxi-bt soc@03000000:bt: Missing bt_power.
8302 [ 2.238368] sunxi-bt soc@03000000:bt: bt_power_name ((null))
8303 [ 2.238376] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
8304 [ 2.238383] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
8305 [ 2.238438] sunxi-bt soc@03000000:bt: bt_rst gpio=211 mul-sel=1 pull=-1 drv_level=-1 data=0
8306 [ 2.238509] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
8307 [ 2.239340] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
8308 [ 2.239351] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
8309 [ 2.239358] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
8310 [ 2.239365] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
8311 [ 2.239372] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
8312 [ 2.239400] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210 mul-sel=1 pull=-1 drv_level=-1 data=0
8313 [ 2.239433] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
8314 [ 2.239441] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
8315 [ 2.239459] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207 mul-sel=6 pull=-1 drv_level=-1 data=0
8316 [ 2.240488] [ADDR_MGT] addr_mgt_probe: success.
8317 [ 2.247040] tun: Universal TUN/TAP device driver, 1.6
8318 [ 2.247049] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
8319 [ 2.249068] gmac-power0: NULL
8320 [ 2.249077] gmac-power1: NULL
8321 [ 2.249083] gmac-power2: NULL
8322 [ 2.250067] PPP generic driver version 2.4.2
8323 [ 2.250358] PPP BSD Compression module registered
8324 [ 2.250367] PPP Deflate Compression module registered
8325 [ 2.250393] PPP MPPE Compression module registered
8326 [ 2.250401] NET: Registered protocol family 24
8327 [ 2.250436] PPTP driver version 0.8.5
8328 [ 2.250796] usbcore: registered new interface driver r8152
8329 [ 2.250879] usbcore: registered new interface driver asix
8330 [ 2.250978] usbcore: registered new interface driver ax88179_178a
8331 [ 2.251047] usbcore: registered new interface driver cdc_ether
8332 [ 2.251115] usbcore: registered new interface driver net1080
8333 [ 2.251177] usbcore: registered new interface driver cdc_subset
8334 [ 2.251244] usbcore: registered new interface driver zaurus
8335 [ 2.251332] usbcore: registered new interface driver cdc_ncm
8336 [ 2.251338] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
8337 [ 2.251694] get drv_vbus is fail, 84
8338 [ 2.251702] get ehci0-controller, regulator_io is no nocare
8339 [ 2.251972] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
8340 [ 2.251978] [sunxi-ehci0]: Not init ehci0
8341 [ 2.252100] get ehci1-controller, regulator_io is no nocare
8342 [ 2.252283] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
8343 [ 2.252343] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
8344 [ 2.252369] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
8345 [ 2.252940] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
8346 [ 2.266333] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
8347 [ 2.266621] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
8348 [ 2.266630] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
8349 [ 2.266638] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
8350 [ 2.266645] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
8351 [ 2.266652] usb usb1: SerialNumber: sunxi-ehci
8352 [ 2.267517] hub 1-0:1.0: USB hub found
8353 [ 2.267564] hub 1-0:1.0: 1 port detected
8354 [ 2.268248] get drv_vbus is fail, 84
8355 [ 2.268255] get ehci2-controller, regulator_io is no nocare
8356 [ 2.268498] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
8357 [ 2.268550] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
8358 [ 2.268575] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
8359 [ 2.268856] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
8360 [ 2.279667] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
8361 [ 2.279900] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
8362 [ 2.279908] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
8363 [ 2.279916] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
8364 [ 2.279923] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
8365 [ 2.279930] usb usb2: SerialNumber: sunxi-ehci
8366 [ 2.280780] hub 2-0:1.0: USB hub found
8367 [ 2.280827] hub 2-0:1.0: 1 port detected
8368 [ 2.281492] get drv_vbus is fail, 84
8369 [ 2.281501] get ehci3-controller, regulator_io is no nocare
8370 [ 2.281752] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
8371 [ 2.281804] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
8372 [ 2.281829] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
8373 [ 2.282118] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
8374 [ 2.292996] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
8375 [ 2.293184] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
8376 [ 2.293193] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
8377 [ 2.293201] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
8378 [ 2.293208] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
8379 [ 2.293214] usb usb3: SerialNumber: sunxi-ehci
8380 [ 2.294072] hub 3-0:1.0: USB hub found
8381 [ 2.294127] hub 3-0:1.0: 1 port detected
8382 [ 2.295056] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
8383 [ 2.295424] get drv_vbus is fail, 84
8384 [ 2.295433] get ohci0-controller, regulator_io is no nocare
8385 [ 2.295766] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
8386 [ 2.295771] [sunxi-ohci0]: Not init ohci0
8387 [ 2.295894] get ohci1-controller, regulator_io is no nocare
8388 [ 2.296065] hci: request ohci1-controller gpio:80
8389 [ 2.296142] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
8390 [ 2.296193] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
8391 [ 2.296221] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
8392 [ 2.296349] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
8393 [ 2.357161] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
8394 [ 2.357171] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
8395 [ 2.357179] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
8396 [ 2.357186] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
8397 [ 2.357193] usb usb4: SerialNumber: sunxi-ohci
8398 [ 2.358062] hub 4-0:1.0: USB hub found
8399 [ 2.358111] hub 4-0:1.0: 1 port detected
8400 [ 2.358785] get drv_vbus is fail, 84
8401 [ 2.358793] get ohci2-controller, regulator_io is no nocare
8402 [ 2.359127] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
8403 [ 2.359176] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
8404 [ 2.359200] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
8405 [ 2.359276] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
8406 [ 2.417156] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
8407 [ 2.417165] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
8408 [ 2.417173] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
8409 [ 2.417180] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
8410 [ 2.417187] usb usb5: SerialNumber: sunxi-ohci
8411 [ 2.418050] hub 5-0:1.0: USB hub found
8412 [ 2.418098] hub 5-0:1.0: 1 port detected
8413 [ 2.418769] get drv_vbus is fail, 84
8414 [ 2.418778] get ohci3-controller, regulator_io is no nocare
8415 [ 2.419116] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
8416 [ 2.419164] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
8417 [ 2.419189] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
8418 [ 2.419272] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
8419 [ 2.477167] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
8420 [ 2.477177] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
8421 [ 2.477185] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
8422 [ 2.477192] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
8423 [ 2.477199] usb usb6: SerialNumber: sunxi-ohci
8424 [ 2.478053] hub 6-0:1.0: USB hub found
8425 [ 2.478102] hub 6-0:1.0: 1 port detected
8426 [ 2.479025] ohci-platform: OHCI generic platform driver
8427 [ 2.479761] usbcore: registered new interface driver uas
8428 [ 2.479930] usbcore: registered new interface driver usb-storage
8429 [ 2.480022] usbcore: registered new interface driver ums-alauda
8430 [ 2.480105] usbcore: registered new interface driver ums-cypress
8431 [ 2.480180] usbcore: registered new interface driver ums-datafab
8432 [ 2.480252] usbcore: registered new interface driver ums_eneub6250
8433 [ 2.480324] usbcore: registered new interface driver ums-freecom
8434 [ 2.480398] usbcore: registered new interface driver ums-isd200
8435 [ 2.480467] usbcore: registered new interface driver ums-jumpshot
8436 [ 2.480538] usbcore: registered new interface driver ums-karma
8437 [ 2.480610] usbcore: registered new interface driver ums-onetouch
8438 [ 2.480705] usbcore: registered new interface driver ums-realtek
8439 [ 2.480786] usbcore: registered new interface driver ums-sddr09
8440 [ 2.480860] usbcore: registered new interface driver ums-sddr55
8441 [ 2.480930] usbcore: registered new interface driver ums-usbat
8442 [ 2.481078] usb_serial_number:20080411
8443 [ 2.482313] input: sunxi-keyboard as /devices/virtual/input/input0
8444 [ 2.482918] usbcore: registered new interface driver xpad
8445 [ 2.483079] usbcore: registered new interface driver usb_acecad
8446 [ 2.483182] usbcore: registered new interface driver aiptek
8447 [ 2.483274] usbcore: registered new interface driver gtco
8448 [ 2.483354] usbcore: registered new interface driver hanwang
8449 [ 2.483428] usbcore: registered new interface driver kbtab
8450 [ 2.483907] axp2101_pek: axp2101-pek can not register without irq
8451 [ 2.483929] axp2101-pek: probe of axp2101-pek.0 failed with error -22
8452 [ 2.485346] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
8453 [ 2.485413] sunxi-rtc rtc: RTC enabled
8454 [ 2.485898] i2c /dev entries driver
8455 [ 2.486907] lirc_dev: IR Remote Control driver registered, major 244
8456 [ 2.486921] IR NEC protocol handler initialized
8457 [ 2.486927] IR RC5(x/sz) protocol handler initialized
8458 [ 2.486933] IR RC6 protocol handler initialized
8459 [ 2.486938] IR JVC protocol handler initialized
8460 [ 2.486944] IR Sony protocol handler initialized
8461 [ 2.486950] IR SANYO protocol handler initialized
8462 [ 2.486955] IR Sharp protocol handler initialized
8463 [ 2.486961] IR MCE Keyboard/mouse protocol handler initialized
8464 [ 2.486967] IR LIRC bridge handler initialized
8465 [ 2.486973] IR XMP protocol handler initialized
8466 [ 2.487486] sunxi_ir_startup: get ir protocol failed
8467 [ 2.487529] 7040000.s_cir supply ir0 not found, using dummy regulator
8468 [ 2.487721] Registered IR keymap rc_map_sunxi
8469 [ 2.488116] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
8470 [ 2.488357] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
8471 [ 2.489366] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
8472 [ 2.490022] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
8473 [ 2.490724] sunxi cedar version 0.1
8474 [ 2.490913] VE: install start!!!
8475
8476 [ 2.491111] cedar_ve: cedar-ve the get irq is 278
8477 [ 2.491723] VE: get debugfs_mpp_root is NULL, please check mpp
8478
8479 [ 2.491736] VE: sunxi ve debug register driver failed!
8480
8481 [ 2.494939] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
8482 [ 2.496210] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
8483 [ 2.496595] Bluetooth: HCI UART driver ver 2.3
8484 [ 2.496606] Bluetooth: HCI UART protocol H4 registered
8485 [ 2.496611] Bluetooth: HCI UART protocol LL registered
8486 [ 2.496617] Bluetooth: HCI UART protocol Three-wire (H5) registered
8487 [ 2.500827] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
8488 [ 2.500842] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
8489 [ 2.500856] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
8490 [ 2.500867] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
8491 [ 2.500880] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
8492 [ 2.500892] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
8493 [ 2.501309] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
8494 [ 2.501428] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
8495 [ 2.501623] sunxi-mmc sdc0: No vmmc regulator found
8496 [ 2.501630] sunxi-mmc sdc0: No vqmmc regulator found
8497 [ 2.501636] sunxi-mmc sdc0: No vdmmc regulator found
8498 [ 2.501643] sunxi-mmc sdc0: No vd33sw regulator found
8499 [ 2.501649] sunxi-mmc sdc0: No vd18sw regulator found
8500 [ 2.501655] sunxi-mmc sdc0: No vq33sw regulator found
8501 [ 2.501661] sunxi-mmc sdc0: No vq18sw regulator found
8502 [ 2.502371] sunxi-mmc sdc0: set host busy
8503 [ 2.502473] sunxi-mmc sdc0: Got CD GPIO
8504 [ 2.502857] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
8505 [ 2.502895] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
8506 [ 2.516376] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8507 [ 2.533298] sunxi-mmc sdc0: detmode:gpio irq
8508 [ 2.533332] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8509 [ 2.535844] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8510 [ 2.536714] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
8511 [ 2.536825] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
8512 [ 2.536966] sunxi-mmc sdc1: No vmmc regulator found
8513 [ 2.536973] sunxi-mmc sdc1: No vqmmc regulator found
8514 [ 2.536980] sunxi-mmc sdc1: No vdmmc regulator found
8515 [ 2.536986] sunxi-mmc sdc1: No vd33sw regulator found
8516 [ 2.536992] sunxi-mmc sdc1: No vd18sw regulator found
8517 [ 2.536998] sunxi-mmc sdc1: No vq33sw regulator found
8518 [ 2.537004] sunxi-mmc sdc1: No vq18sw regulator found
8519 [ 2.537718] sunxi-mmc sdc1: set host busy
8520 [ 2.537803] mmc:failed to get gpios
8521 [ 2.538013] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8522 [ 2.538075] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
8523 [ 2.540529] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8524 [ 2.553046] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8525 [ 2.564072] mmc0: host does not support reading read-only switch, assuming write-enable
8526 [ 2.565936] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
8527 [ 2.566012] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
8528 [ 2.566157] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
8529 [ 2.566246] mmc0: new high speed SDXC card at address 0001
8530 [ 2.567310] mmcblk0: mmc0:0001 SD16G 59.5 GiB
8531 [ 2.568929] mmcblk0: p1
8532 [ 2.569701] sunxi-mmc sdc1: detmode:manually by software
8533 [ 2.572007] ledtrig-cpu: registered to indicate activity on CPUs
8534 [ 2.572640] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
8535 [ 2.573501] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
8536 [ 2.573535] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8537 [ 2.576038] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8538 [ 2.577979] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
8539 [ 2.578814] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
8540 [ 2.579346] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
8541 [ 2.579356] sunxi_emce_probe()590emce hw init failed!
8542 [ 2.579383] emce: probe of emce failed with error -2
8543 [ 2.579661] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
8544 [ 2.579706] hidraw: raw HID events driver (C) Jiri Kosina
8545 [ 2.580515] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
8546 [ 2.580558] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
8547 [ 2.584734] usbcore: registered new interface driver usbhid
8548 [ 2.584742] usbhid: USB HID core driver
8549 [ 2.586156] optee: probing for conduit method from DT.
8550 [ 2.586170] optee: api uid mismatch
8551 [ 2.586791] usbcore: registered new interface driver snd-usb-audio
8552 [ 2.588405] [sunxi_hdmi_codec_init] driver and deivce register finished.
8553 [ 2.590251] [sunxi_internal_codec_probe]:get audio avcc failed
8554 [ 2.590288] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
8555 [ 2.590522] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
8556 [ 2.593057] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
8557 [ 2.595028] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
8558 [ 2.595041] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
8559 [ 2.597331] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
8560 [ 2.597354] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
8561 [ 2.601497] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
8562 [ 2.602879] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
8563 [ 2.604821] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
8564 [ 2.607941] pktgen: Packet Generator for packet performance testing. Version: 2.75
8565 [ 2.608358] u32 classifier
8566 [ 2.608365] Actions configured
8567 [ 2.608377] Netfilter messages via NETLINK v0.30.
8568 [ 2.608412] nfnl_acct: registering with nfnetlink.
8569 [ 2.608756] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
8570 [ 2.609006] ctnetlink v0.93: registering with nfnetlink.
8571 [ 2.609825] xt_time: kernel timezone is -0000
8572 [ 2.609850] IPVS: Registered protocols (TCP, UDP)
8573 [ 2.609966] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
8574 [ 2.610093] IPVS: Creating netns size=1928 id=0
8575 [ 2.610224] IPVS: ipvs loaded.
8576 [ 2.610232] IPVS: [rr] scheduler registered.
8577 [ 2.610330] ipip: IPv4 and MPLS over IPv4 tunneling driver
8578 [ 2.611032] gre: GRE over IPv4 demultiplexor driver
8579 [ 2.611040] ip_gre: GRE over IPv4 tunneling driver
8580 [ 2.612335] IPv4 over IPsec tunneling driver
8581 [ 2.613220] ip_tables: (C) 2000-2006 Netfilter Core Team
8582 [ 2.613513] arp_tables: arp_tables: (C) 2002 David S. Miller
8583 [ 2.613577] Initializing XFRM netlink socket
8584 [ 2.613610] IPsec XFRM device driver
8585 [ 2.614458] NET: Registered protocol family 10
8586 [ 2.616399] mip6: Mobile IPv6
8587 [ 2.616442] ip6_tables: (C) 2000-2006 Netfilter Core Team
8588 [ 2.617778] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
8589 [ 2.619393] NET: Registered protocol family 17
8590 [ 2.619435] NET: Registered protocol family 15
8591 [ 2.619593] Bridge firewalling registered
8592 [ 2.619825] Bluetooth: RFCOMM TTY layer initialized
8593 [ 2.619857] Bluetooth: RFCOMM socket layer initialized
8594 [ 2.619890] Bluetooth: RFCOMM ver 1.11
8595 [ 2.619904] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
8596 [ 2.619910] Bluetooth: BNEP filters: protocol multicast
8597 [ 2.619923] Bluetooth: BNEP socket layer initialized
8598 [ 2.619929] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
8599 [ 2.619940] Bluetooth: HIDP socket layer initialized
8600 [ 2.620040] l2tp_core: L2TP core driver, V2.0
8601 [ 2.620055] l2tp_ppp: PPPoL2TP kernel driver, V2.0
8602 [ 2.620061] 8021q: 802.1Q VLAN Support v1.8
8603 [ 2.620273] sctp: Hash tables configured (bind 256/256)
8604 [ 2.620854] Key type dns_resolver registered
8605 [ 2.620994] Registered cp15_barrier emulation handler
8606 [ 2.621007] Registered setend emulation handler
8607 [ 2.621924] registered taskstats version 1
8608 [ 2.633581] zswap: default zpool zbud not available
8609 [ 2.633589] zswap: pool creation failed
8610 [ 2.636385] Btrfs loaded, crc32c=crc32c-arm64-hw
8611 [ 2.637159] HDMI 2.0 driver init start!
8612 [ 2.637174] boot_hdmi=true
8613 [ 2.637967] Can not find the node of esm
8614 [ 2.637985] ERROR: pinctrl_get for HDMI2.0 DDC fail
8615 [ 2.638077] Get hdmi_power0:vcc-hdmi
8616 [ 2.638116] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
8617 [ 2.638286] Get hdmi_power1:vdd-hdmi
8618 [ 2.638308] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
8619 [ 2.639871] hdmi_cec_init
8620 [ 2.640362] [DISP] disp_device_attached,line:146:
8621 [ 2.640372] attached ok, mgr0<-->device0, type=4
8622 [ 2.640382] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
8623 [ 2.640395] [DISP] disp_hdmi_set_mode,line:648:
8624 [ 2.640399] hdmi_set_mode is null!
8625 [ 2.643344] HDMI2.0 module init end
8626 [ 2.654464] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
8627 [ 2.657947] cpu cpu1: opp_list_debug_create_link: Failed to create link
8628 [ 2.657959] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
8629 [ 2.657991] cpu cpu2: opp_list_debug_create_link: Failed to create link
8630 [ 2.657998] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
8631 [ 2.658028] cpu cpu3: opp_list_debug_create_link: Failed to create link
8632 [ 2.658035] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
8633 [ 2.660318] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
8634 [ 2.661220] get det_vbus is fail, 84
8635 [ 2.661227] get id is fail, 84
8636 [ 2.661721] sunxi-rtc rtc: setting system clock to 2023-09-25 18:30:00 UTC (1695666600)
8637 [ 2.665499] ALSA device list:
8638 [ 2.665507] #0: audiocodec
8639 [ 2.665510] #1: sndahub
8640 [ 2.665514] #2: sndhdmi
8641 [ 2.667177] Freeing unused kernel memory: 3008K
8642 [ 2.712490] random: systemd-udevd: uninitialized urandom read (16 bytes read)
8643 [ 2.714526] random: systemd-udevd: uninitialized urandom read (16 bytes read)
8644 [ 2.717507] random: systemd-udevd: uninitialized urandom read (16 bytes read)
8645 [ 2.790131] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
8646 [ 2.953094] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
8647 [ 3.046476] HDMI cable is connected
8648 [ 3.303019] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
8649 [ 3.523445] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
8650 [ 3.523453] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
8651 [ 3.523458] usb 4-1: Product: Rapoo 2.4G Wireless Device
8652 [ 3.523463] usb 4-1: Manufacturer: RAPOO
8653 [ 3.531450] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
8654 [ 3.531851] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
8655 [ 3.538116] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
8656 [ 3.593821] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
8657 [ 3.597732] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
8658 [ 3.655013] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
8659 [ 4.172009] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
8660 [ 5.088174] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
8661 [ 5.088729] cgroup: cgroup2: unknown option "nsdelegate"
8662 [ 5.108905] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
8663 [ 5.108928] systemd[1]: Detected architecture arm64.
8664 [ 5.110063] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
8665 [ 5.120132] systemd[1]: Hostname set to <opi>.
8666 [ 5.147190] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
8667 [ 6.751702] (sd-execut[1458]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
8668 [ 6.826412]
8669 insmod_device_driver
8670
8671 [ 6.826664] device_chose finished 124!
8672 [ 7.115440] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
8673 [ 7.353360] systemd[1]: Queued start job for default target graphical.target.
8674 [ 7.360912] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
8675 [ 7.363078] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
8676 [ 7.365312] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
8677 [ 7.366692] systemd[1]: Created slice user.slice - User and Session Slice.
8678 [ 7.367364] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
8679 [ 7.367910] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
8680 [ 7.368238] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
8681 [ 7.368754] systemd[1]: Reached target slices.target - Slice Units.
8682 [ 7.369075] systemd[1]: Reached target swap.target - Swaps.
8683 [ 7.369356] systemd[1]: Reached target time-set.target - System Time Set.
8684 [ 7.369884] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
8685 [ 7.387168] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
8686 [ 7.388284] systemd[1]: Listening on syslog.socket - Syslog Socket.
8687 [ 7.389250] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
8688 [ 7.389957] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
8689 [ 7.391577] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
8690 [ 7.392533] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
8691 [ 7.393634] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
8692 [ 7.395836] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
8693 [ 7.396804] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
8694 [ 7.400774] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
8695 [ 7.405320] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
8696 [ 7.410389] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
8697 [ 7.411621] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
8698 [ 7.412593] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
8699 [ 7.420265] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
8700 [ 7.425722] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
8701 [ 7.431650] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
8702 [ 7.440500] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
8703 [ 7.447331] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
8704 [ 7.454548] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
8705 [ 7.462303] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
8706 [ 7.473740] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
8707 [ 7.481344] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
8708 [ 7.482443] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
8709 [ 7.493092] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
8710 [ 7.499560] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
8711 [ 7.506195] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
8712 [ 7.516841] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
8713 [ 7.519005] fuse init (API version 7.26)
8714 [ 7.519490] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
8715 [ 7.522235] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
8716 [ 7.526118] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
8717 [ 7.529936] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
8718 [ 7.533852] systemd[1]: modprobe@configfs.service: Deactivated successfully.
8719 [ 7.534744] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
8720 [ 7.538055] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
8721 [ 7.538688] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
8722 [ 7.541365] systemd[1]: modprobe@drm.service: Deactivated successfully.
8723 [ 7.542298] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
8724 [ 7.574567] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
8725 [ 7.591901] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
8726 [ 7.607877] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
8727 [ 7.608629] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
8728 [ 7.608639] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
8729 [ 7.608821] spidev spi1.1: Deleting spi1.1
8730 [ 7.609454] fbtft_device: GPIOS used by 'fb_st7735r':
8731 [ 7.609461] fbtft_device: 'reset' = GPIO73
8732 [ 7.609465] fbtft_device: 'dc' = GPIO70
8733 [ 7.609475] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
8734 [ 7.609481] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
8735 [ 7.638015] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
8736 [ 7.638919] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
8737 [ 7.645879] systemd[1]: modprobe@fuse.service: Deactivated successfully.
8738 [ 7.646962] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
8739 [ 7.648404] WCN: marlin_init entry!
8740 [ 7.649755] WCN: marlin_parse_dt reset gpio=211
8741 [ 7.649767] WCN_ERR: gpio reset request err: 211
8742 [ 7.649773] WCN: wcn config bt wake host
8743 [ 7.650362] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
8744 [ 7.650505] WCN: wcn config wifi wake host
8745 [ 7.650528] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
8746 [ 7.650657] systemd[1]: modprobe@loop.service: Deactivated successfully.
8747 [ 7.651761] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
8748 [ 7.654271] sdiohal:sdiohal_init ok
8749 [ 7.655500] WCN: marlin_probe ok!
8750 [ 7.664425] mtty_probe init device addr: 0xffffffc009691300
8751 [ 7.664618] -->rfkill_bluetooth_init
8752 [ 7.664783] <--rfkill_bluetooth_init
8753 [ 7.707577] WCN: start_marlin [MARLIN_WIFI]
8754 [ 7.707591] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
8755 [ 7.707594] WCN: the first power on start
8756 [ 7.734127] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
8757 [ 7.741893] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
8758 [ 7.747724] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
8759 [ 7.748381] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
8760 [ 7.754364] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
8761 [ 7.755073] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
8762 [ 7.762283] systemd[1]: Starting systemd-sysusers.service - Create System Users...
8763 [ 7.777941] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
8764 [ 7.789071] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
8765 [ 7.791343] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
8766 [ 7.823067] WCN: marlin chip en pull up
8767 [ 7.846466] systemd[1]: Finished systemd-sysusers.service - Create System Users.
8768 [ 7.849776] sdiohal:sdiohal_scan_card
8769 [ 7.849796] sunxi-wlan soc@03000000:wlan: bus_index: 1
8770 [ 7.849843] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
8771 [ 7.853128] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
8772 [ 7.869767] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8773 [ 7.887224] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
8774 [ 7.888126] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
8775 [ 7.888152] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8776 [ 7.890713] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8777 [ 7.893813] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8778 [ 7.909833] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
8779 [ 7.921526] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
8780 [ 7.922310] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
8781 [ 7.922399] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
8782 [ 7.923148] mmc1: new ultra high speed SDR104 SDIO card at address 8800
8783 [ 7.923572] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
8784 [ 7.923777] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
8785 [ 7.923802] WCN: marlin_scan_finish!
8786 [ 7.923806] sdiohal:probe ok
8787 [ 7.923815] sdiohal:scan end!
8788 [ 7.923822] WCN: then marlin start to download
8789 [ 7.923852] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
8790 [ 7.975932] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
8791 [ 8.003941] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
8792 [ 8.009254] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
8793 [ 8.028187] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
8794 [ 8.031986] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
8795 [ 8.034815] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
8796 [ 8.054097] WCN: combin_img 0 marlin_firmware_write finish and successful
8797 [ 8.054258] WCN: marlin_start_run read reset reg val:0x1
8798 [ 8.054262] WCN: after do marlin_start_run reset reg val:0x0
8799 [ 8.054446] WCN: s_marlin_bootup_time=8054442843
8800 [ 8.059830] WCN: clock mode: TSX
8801 [ 8.060008] WCN: marlin_write_cali_data sync init_state:0x1a0f50
8802 [ 8.086581] WCN: marlin_write_cali_data sync init_state:0x1a0f50
8803 [ 8.103931] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
8804 [ 8.113313] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
8805 [ 8.113320] WCN: sdio_config bt_wake_host trigger:[high]
8806 [ 8.113324] WCN: sdio_config irq:[inband]
8807 [ 8.113328] WCN: sdio_config wl_wake_host trigger:[high]
8808 [ 8.113333] WCN: sdio_config wake_host_level_duration_time:[20ms]
8809 [ 8.113336] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
8810 [ 8.113341] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
8811 [ 8.113836] WCN: marlin_write_cali_data finish
8812 [ 8.114047] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
8813 [ 8.140045] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
8814 [ 8.166816] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
8815 [ 8.194046] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
8816 [ 8.220108] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
8817 [ 8.246820] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
8818 [ 8.246830] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a117df30c640a9405a3d69
8819 [ 8.246846] WCN: marlin_bind_verify verify data: 0x16d6ab91e1d71b3ae4604f224021aa
8820 [ 8.247587] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
8821 [ 8.273306] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
8822 [ 8.273314] sdiohal:sdiohal_runtime_get entry
8823 [ 8.273538] WCN: get_cp2_version entry!
8824 [ 8.275022] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
8825 [ 8.276174] WCN: switch_cp2_log - close entry!
8826 [ 8.277357] WCN: WCND at cmd read:OK
8827 [ 8.277407] WCN: then marlin download finished and run ok
8828 [ 8.277413] WCN: start_loopcheck
8829 [ 8.291310] WCN: get_board_ant_num [one_ant]
8830 [ 8.291321] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
8831 [ 8.351243] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
8832 [ 8.355693] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
8833 [ 8.363121] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
8834 [ 8.426057] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
8835 [ 8.473186] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
8836 [ 8.482704] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
8837 [ 8.556898] systemd[1]: Mounting tmp.mount - /tmp...
8838 [ 8.563210] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
8839 [ 8.577168] systemd[1]: Mounted tmp.mount - /tmp.
8840 [ 8.583105] systemd[1]: Reached target local-fs.target - Local File Systems.
8841 [ 8.595141] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
8842 [ 8.603193] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
8843 [ 8.614005] systemd[1]: Starting console-setup.service - Set console font and keymap...
8844 [ 8.630626] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
8845 [ 8.657014] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
8846 [ 8.667052] systemd[1]: Starting ufw.service - Uncomplicated firewall...
8847 [ 8.672909] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
8848 [ 8.711853] systemd[1]: Finished console-setup.service - Set console font and keymap.
8849 [ 8.715338] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
8850 [ 8.718391] systemd[1]: Received SIGRTMIN+20 from PID 1420 (plymouthd).
8851 [ 8.719486] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
8852 [ 8.720812] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
8853 [ 8.721402] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
8854 [ 8.722909] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
8855 [ 8.729296] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
8856 [ 8.730244] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
8857 [ 8.733715] systemd[1]: Finished ufw.service - Uncomplicated firewall.
8858 [ 8.735896] systemd[1]: Reached target network-pre.target - Preparation for Network.
8859 [ 8.820062] systemd[1]: Starting networking.service - Raise network interfaces...
8860 [ 8.823212] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
8861 [ 9.134198] zram: Added device: zram0
8862 [ 9.137482] zram: Added device: zram1
8863 [ 9.140693] zram: Added device: zram2
8864 [ 9.213815] zswap: can't enable, initialization failed
8865 [ 9.283892] zram0: detected capacity change from 0 to 506396672
8866 [ 9.468604] systemd[1]: Finished networking.service - Raise network interfaces.
8867 [ 10.026558] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
8868 [ 10.087472] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
8869 [ 10.255438] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
8870 [ 10.838127] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
8871 [ 10.838386] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
8872 [ 10.842784] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
8873 [ 10.844808] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
8874 [ 10.862392] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
8875 [ 10.872755] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
8876 [ 10.902803] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
8877 [ 10.923927] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
8878 [ 10.931494] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
8879 [ 10.932769] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
8880 [ 10.936796] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
8881 [ 10.937756] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
8882 [ 10.945788] systemd[1]: modprobe@loop.service: Deactivated successfully.
8883 [ 10.946873] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
8884 [ 10.963034] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
8885 [ 10.963434] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
8886 [ 11.010957] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
8887 [ 11.013289] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
8888 [ 11.014319] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
8889 [ 11.015398] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
8890 [ 11.052518] sunxi-bt soc@03000000:bt: set block: 0
8891 [ 11.064965] bluetooth_set_power: start_block=0
8892 [ 11.064975] WCN: start_marlin [MARLIN_BLUETOOTH]
8893 [ 11.064987] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
8894 [ 11.064992] WCN: marlin have open, GNSS is closed
8895 [ 11.064998] bluetooth_set_power: end_block=0
8896 [ 11.078425] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
8897 [ 11.125453] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
8898 [ 11.131316] systemd[1]: Starting brltty.service - Braille Device Support...
8899 [ 11.848745] systemd[1]: Started brltty.service - Braille Device Support.
8900 [ 11.863372] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
8901 [ 12.318625] Adding 494524k swap on /dev/zram0. Priority:5 extents:1 across:494524k SSFS
8902 [ 12.459276] zram1: detected capacity change from 0 to 52428800
8903 [ 16.088924] systemd[1]: systemd-rfkill.service: Deactivated successfully.
8904 [ 16.536118] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
8905 [ 16.542493] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
8906 [ 16.604114] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
8907 [ 20.536223] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
8908 [ 20.542685] systemd[1]: Starting systemd-journald.service - Journal Service...
8909 [ 20.811168] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
8910 [ 20.811191] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
8911 [ 20.818287] systemd[1]: Started systemd-journald.service - Journal Service.
8912 [ 20.865608] systemd-journald[1921]: Received client request to flush runtime journal.
8913 [ 21.145803] IPVS: Creating netns size=1928 id=1
8914
8915 ### armbian-release:
8916
8917 # PLEASE DO NOT EDIT THIS FILE
8918 BOARD=orangepizero2
8919 BOARD_NAME="Orange Pi Zero2"
8920 BOARDFAMILY=sun50iw9
8921 BUILD_REPOSITORY_URL=https://github.com/armbian/build
8922 BUILD_REPOSITORY_COMMIT=ac829eb6
8923 LINUXFAMILY=sun50iw9
8924 ARCH=arm64
8925 IMAGE_TYPE=stable
8926 BOARD_TYPE=conf
8927 INITRD_ARCH=arm
8928 KERNEL_IMAGE_TYPE=Image
8929 FORCE_BOOTSCRIPT_UPDATE=yes
8930 VENDOR=Armbian
8931 BOOTSCRIPT_FORCE_UPDATE="yes"
8932 BOOTSCRIPT_DST="boot.cmd"
8933 VERSION=23.8.1
8934 REVISION=23.8.1
8935 BRANCH=legacy
8936
8937 ### boot environment:
8938
8939 verbosity=1
8940 console=serial
8941 #disp_mode=1080p60
8942 #fb0_width=1280
8943 #fb0_height=720
8944 rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
8945 rootfstype=ext4
8946 overlays=spi-spidev
8947 param_spidev_spi_bus=1
8948 param_spidev_spi_cs=1
8949 extraargs=fbcon=map:1
8950 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
8951
8952 ### lsusb:
8953
8954 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
8955 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
8956 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
8957 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
8958 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
8959 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
8960 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
8961
8962 ### lscpu:
8963
8964 Architecture: aarch64
8965 CPU op-mode(s): 32-bit, 64-bit
8966 Byte Order: Little Endian
8967 CPU(s): 4
8968 On-line CPU(s) list: 0-3
8969 Vendor ID: ARM
8970 Model name: Cortex-A53
8971 Model: 4
8972 Thread(s) per core: 1
8973 Core(s) per cluster: 4
8974 Socket(s): -
8975 Cluster(s): 1
8976 Stepping: r0p4
8977 CPU(s) scaling MHz: 100%
8978 CPU max MHz: 1512.0000
8979 CPU min MHz: 480.0000
8980 BogoMIPS: 48.00
8981 Flags: fp asimd aes pmull sha1 sha2 crc32
8982
8983 ### cpuinfo:
8984
8985 processor : 0
8986 BogoMIPS : 48.00
8987 Features : fp asimd aes pmull sha1 sha2 crc32
8988 CPU implementer : 0x41
8989 CPU architecture: 8
8990 CPU variant : 0x0
8991 CPU part : 0xd03
8992 CPU revision : 4
8993
8994 processor : 1
8995 BogoMIPS : 48.00
8996 Features : fp asimd aes pmull sha1 sha2 crc32
8997 CPU implementer : 0x41
8998 CPU architecture: 8
8999 CPU variant : 0x0
9000 CPU part : 0xd03
9001 CPU revision : 4
9002
9003 processor : 2
9004 BogoMIPS : 48.00
9005 Features : fp asimd aes pmull sha1 sha2 crc32
9006 CPU implementer : 0x41
9007 CPU architecture: 8
9008 CPU variant : 0x0
9009 CPU part : 0xd03
9010 CPU revision : 4
9011
9012 processor : 3
9013 BogoMIPS : 48.00
9014 Features : fp asimd aes pmull sha1 sha2 crc32
9015 CPU implementer : 0x41
9016 CPU architecture: 8
9017 CPU variant : 0x0
9018 CPU part : 0xd03
9019 CPU revision : 4
9020
9021
9022 ### meminfo:
9023
9024 MemTotal: 989056 kB
9025 MemFree: 790420 kB
9026 MemAvailable: 885996 kB
9027 Buffers: 15620 kB
9028 Cached: 86968 kB
9029 SwapCached: 0 kB
9030 Active: 65592 kB
9031 Inactive: 58252 kB
9032 Active(anon): 21428 kB
9033 Inactive(anon): 652 kB
9034 Active(file): 44164 kB
9035 Inactive(file): 57600 kB
9036 Unevictable: 0 kB
9037 Mlocked: 0 kB
9038 SwapTotal: 494524 kB
9039 SwapFree: 494524 kB
9040 Dirty: 11316 kB
9041 Writeback: 0 kB
9042 AnonPages: 21292 kB
9043 Mapped: 24272 kB
9044 Shmem: 828 kB
9045 Slab: 33084 kB
9046 SReclaimable: 9272 kB
9047 SUnreclaim: 23812 kB
9048 KernelStack: 2512 kB
9049 PageTables: 1116 kB
9050 NFS_Unstable: 0 kB
9051 Bounce: 0 kB
9052 WritebackTmp: 0 kB
9053 CommitLimit: 989052 kB
9054 Committed_AS: 79636 kB
9055 VmallocTotal: 263061440 kB
9056 VmallocUsed: 0 kB
9057 VmallocChunk: 0 kB
9058 CmaTotal: 16384 kB
9059 CmaFree: 7468 kB
9060 HugePages_Total: 0
9061 HugePages_Free: 0
9062 HugePages_Rsvd: 0
9063 HugePages_Surp: 0
9064 Hugepagesize: 2048 kB
9065
9066 ### virtual memory:
9067
9068 vm.admin_reserve_kbytes = 8192
9069 vm.block_dump = 0
9070 vm.compact_unevictable_allowed = 1
9071 vm.dirty_background_bytes = 0
9072 vm.dirty_background_ratio = 10
9073 vm.dirty_bytes = 0
9074 vm.dirty_expire_centisecs = 3000
9075 vm.dirty_ratio = 20
9076 vm.dirtytime_expire_seconds = 43200
9077 vm.dirty_writeback_centisecs = 500
9078 vm.extfrag_threshold = 500
9079 vm.extra_free_kbytes = 0
9080 vm.hugepages_treat_as_movable = 0
9081 vm.hugetlb_shm_group = 0
9082 vm.laptop_mode = 0
9083 vm.legacy_va_layout = 0
9084 vm.lowmem_reserve_ratio = 256 32
9085 vm.max_map_count = 65530
9086 vm.min_free_kbytes = 3937
9087 vm.mmap_min_addr = 4096
9088 vm.mmap_rnd_bits = 18
9089 vm.mmap_rnd_compat_bits = 11
9090 vm.nr_hugepages = 0
9091 vm.nr_overcommit_hugepages = 0
9092 vm.nr_pdflush_threads = 0
9093 vm.oom_dump_tasks = 1
9094 vm.oom_kill_allocating_task = 0
9095 vm.overcommit_kbytes = 0
9096 vm.overcommit_memory = 0
9097 vm.overcommit_ratio = 50
9098 vm.page-cluster = 0
9099 vm.panic_on_oom = 0
9100 vm.percpu_pagelist_fraction = 0
9101 vm.stat_interval = 1
9102 vm.swappiness = 100
9103 vm.user_reserve_kbytes = 29998
9104 vm.vfs_cache_pressure = 100
9105 vm.watermark_scale_factor = 10
9106
9107 ### ip addr:
9108
9109 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
9110 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
9111 inet XXX.XXX.0.1/8 scope host lo
9112 valid_lft forever preferred_lft forever
9113 inet6 ::1/128 scope host noprefixroute
9114 valid_lft forever preferred_lft forever
9115 2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
9116 link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
9117 3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
9118 link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
9119 4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
9120 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
9121 5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
9122 link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
9123 6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
9124 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
9125 7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
9126 link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
9127 8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
9128 link/tunnel6 :: brd ::
9129 9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
9130 link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
9131 10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
9132 link/tunnel6 :: brd ::
9133 11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
9134 link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
9135
9136 ### partitions:
9137
9138 major minor #blocks name
9139
9140 179 0 62410752 mmcblk0
9141 179 1 61763584 mmcblk0p1
9142 253 0 494528 zram0
9143 253 1 51200 zram1
9144
9145 ### df:
9146
9147 udev 466M 0 466M 0% /dev
9148 tmpfs 97M 2.1M 95M 3% /run
9149 /dev/mmcblk0p1 58G 7.3G 51G 13% /
9150 tmpfs 483M 0 483M 0% /dev/shm
9151 tmpfs 5.0M 0 5.0M 0% /run/lock
9152 tmpfs 483M 4.0K 483M 1% /tmp
9153 /dev/zram1 47M 11M 33M 25% /var/log
9154
9155 ### lsblk:
9156
9157 NAME FSTYPE SIZE MOUNTPOINT UUID
9158 mmcblk0 59.5G
9159 └─mmcblk0p1 ext4 58.9G / 0c85f38a-a16e-49a0-a53c-99d9856e983e
9160 zram1 50M /var/log
9161 zram2 0B
9162
9163 ### zramctl:
9164
9165 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
9166 /dev/zram1 lz4 50M 10.8M 2.9M 3.3M 4 /var/log
9167 /dev/zram0 lzo 482.9M 4K 76B 12K 4 [SWAP]
9168
9169 ### mtab:
9170
9171 /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
9172 /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
9173 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
9174
9175 ### mmc0:0001 info:
9176
9177 manfid: 0x0000fe
9178 cid: fe3432534431364720000000690091f5
9179 fwrev: 0x0
9180 csd: 400e00325b590001dc277f800a40008b
9181 ocr: 0x00200000
9182 type: SD
9183 date: 01/2009
9184 hwrev: 0x2
9185 dsr: 0x404
9186 serial: 0x00000069
9187 erase_size: 512
9188 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
9189 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
9190 scr: 0285808300000000
9191 oemid: 0x3432
9192 preferred_erase_size: 4194304
9193 name: SD16G
9194
9195 ### Boot system health:
9196
9197 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
9198 15:30:21 1512 MHz 1.31 38% 18% 13% 0% 6% 0% 50.1 °C 0/5
9199 15:30:22 1512 MHz 1.31 99% 38% 49% 0% 11% 0% 50.1 °C 0/5
9200 15:30:22 1512 MHz 1.31 100% 33% 60% 1% 4% 0% 51.3 °C 0/5
9201 15:30:22 1512 MHz 1.31 100% 42% 51% 1% 4% 0% 51.3 °C 0/5
9202 15:30:23 1512 MHz 4.81 98% 29% 56% 1% 10% 0% 51.3 °C 0/5
9203
9204 ### lsusb:
9205
9206 Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
9207 Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
9208 Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
9209 Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
9210 Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
9211 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
9212 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
9213
9214 /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
9215 /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
9216 /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
9217 |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
9218 |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
9219 |__ Port 1: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
9220 /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
9221 /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
9222 /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
9223
9224 ### Userland:
9225
9226 PRETTY_NAME="Armbian 23.8.3 bookworm"
9227 ARMBIAN_PRETTY_NAME="Armbian 23.8.3 bookworm"
9228
9229 ### Installed packages:
9230
9231 ii armbian-bookworm-desktop-xfce 23.8.3 all Armbian desktop for Debian bookworm xfce
9232 ii armbian-bsp-cli-orangepizero2-legacy 23.8.1 arm64 Armbian CLI BSP for board 'orangepizero2' branch 'legacy'
9233 ii armbian-config 23.8.3 all Armbian configuration utility
9234 ii armbian-firmware-full 23.02.2 all Linux firmware-full
9235 ii armbian-zsh 23.8.3 all Armbian improved ZShell (oh-my-zsh...)
9236 ii linux-base 4.9 all Linux image base package
9237 ii linux-dtb-legacy-sun50iw9 23.8.1 arm64 Armbian Linux legacy DTBs in /boot/dtb-4.9.318-legacy-sun50iw9
9238 ii linux-image-legacy-sun50iw9 23.8.1 arm64 Armbian Linux legacy kernel image 4.9.318-legacy-sun50iw9
9239 ii linux-libc-dev:arm64 23.02.2 arm64 Armbian Linux support headers for userspace development
9240 ii linux-u-boot-orangepizero2-legacy 23.8.1 arm64 Das U-Boot for orangepizero2
9241
9242 ### Loaded modules:
9243
9244 Module Size Used by
9245 zram 36864 2
9246 fb_st7735r 16384 1
9247 sprdwl_ng 442368 0
9248 sprdbt_tty 40960 2
9249 uwe5622_bsp_sdio 307200 2 sprdbt_tty,sprdwl_ng
9250 fbtft_device 61440 0
9251 fbtft 57344 2 fbtft_device,fb_st7735r
9252 fb_sys_fops 16384 1 fbtft
9253 syscopyarea 16384 1 fbtft
9254 sysfillrect 16384 1 fbtft
9255 sysimgblt 16384 1 fbtft
9256 fuse 139264 3
9257
9258 ### Current system health:
9259
9260 Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St.
9261 17:08:45 1512 MHz 2.63 25% 5% 14% 0% 4% 0% 44.2 °C 0/5
9262 17:08:45 1512 MHz 2.63 5% 2% 0% 1% 0% 0% 44.2 °C 0/5
9263 17:08:45 1512 MHz 2.63 8% 5% 2% 0% 0% 0% 45.7 °C 0/5
9264 17:08:46 1512 MHz 2.63 5% 2% 0% 2% 0% 0% 45.7 °C 0/5
9265 17:08:46 1512 MHz 2.63 10% 5% 5% 0% 0% 0% 45.7 °C 0/5
9266 17:08:48 1512 MHz 2.63 25% 5% 14% 0% 4% 0% 51.2 °C 0/5
9267 17:08:49 1512 MHz 2.63 100% 1% 97% 0% 0% 0% 55.9 °C 0/5
9268 17:08:50 1512 MHz 2.98 74% 1% 72% 0% 0% 0% 56.4 °C 0/5
9269 17:08:50 1512 MHz 2.98 7% 5% 1% 0% 0% 0% 56.4 °C 0/5
9270 17:08:51 1512 MHz 2.98 5% 2% 0% 1% 0% 0% 50.3 °C 0/5
9271
9272 ### resolv.conf
9273
9274 -rw-r--r-- 1 root root 30 Sep 25 17:02 /etc/resolv.conf
9275 # Generated by NetworkManager
9276
9277 ### Current sysinfo:
9278
9279 Linux 4.9.318-legacy-sun50iw9 (opi) 09/25/2023 _aarch64_ (4 CPU)
9280
9281 avg-cpu: %user %nice %system %iowait %steal %idle
9282 14.58 0.01 5.88 4.60 0.00 74.94
9283
9284 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd
9285 ram0 0.00 0.00 0.00 0.00 0 0 0
9286 ram1 0.00 0.00 0.00 0.00 0 0 0
9287 ram2 0.00 0.00 0.00 0.00 0 0 0
9288 ram3 0.00 0.00 0.00 0.00 0 0 0
9289 ram4 0.00 0.00 0.00 0.00 0 0 0
9290 ram5 0.00 0.00 0.00 0.00 0 0 0
9291 ram6 0.00 0.00 0.00 0.00 0 0 0
9292 ram7 0.00 0.00 0.00 0.00 0 0 0
9293 ram8 0.00 0.00 0.00 0.00 0 0 0
9294 ram9 0.00 0.00 0.00 0.00 0 0 0
9295 ram10 0.00 0.00 0.00 0.00 0 0 0
9296 ram11 0.00 0.00 0.00 0.00 0 0 0
9297 ram12 0.00 0.00 0.00 0.00 0 0 0
9298 ram13 0.00 0.00 0.00 0.00 0 0 0
9299 ram14 0.00 0.00 0.00 0.00 0 0 0
9300 ram15 0.00 0.00 0.00 0.00 0 0 0
9301 mmcblk0 37.13 1581.19 2.58 0.00 9385503 15340 0
9302 mmcblk0p1 37.12 1580.84 2.58 0.00 9383399 15340 0
9303 zram0 47.34 35.42 153.93 0.00 210216 913700 0
9304 zram1 0.73 0.50 2.40 0.00 2976 14260 0
9305 zram2 0.00 0.00 0.00 0.00 0 0 0
9306
9307 --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- ----------cpu----------
9308 r b swpd free buff cache si so bi bo in cs us sy id wa st gu
9309 3 0 484508 14440 14888 297328 9 39 402 1 312 458 15 6 75 5 0 0
9310
9311 total used free shared buff/cache available
9312 Mem: 965Mi 702Mi 14Mi 40Mi 304Mi 263Mi
9313 Swap: 482Mi 473Mi 9.8Mi
9314
9315 NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
9316 /dev/zram1 lz4 50M 11.9M 3.2M 3.7M 4 /var/log
9317 /dev/zram0 lzo 482.9M 471.2M 134.8M 139.7M 4 [SWAP]
9318
9319 17:08:51 up 1:38, 2 users, load average: 2.98, 2.40, 2.27
9320
9321 [ 5528.824915] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
9322 [ 5528.824920] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
9323 [ 5528.824949] sunxi-mmc sdc1: *****retry:re-send cmd*****
9324 [ 5528.935756] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9325 [ 5528.935852] sunxi-mmc sdc1: *****retry:start*****
9326 [ 5528.935890] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9327 [ 5528.935895] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9328 [ 5528.935922] sunxi-mmc sdc1: *****retry:re-send cmd*****
9329 [ 5529.046729] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9330 [ 5529.046811] sunxi-mmc sdc1: *****retry:start*****
9331 [ 5529.046847] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9332 [ 5529.046852] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9333 [ 5529.046877] sunxi-mmc sdc1: *****retry:re-send cmd*****
9334 [ 5529.157645] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9335 [ 5529.157681] sunxi-mmc sdc1: *****retry:start*****
9336 [ 5529.157716] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9337 [ 5529.157721] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9338 [ 5529.157745] sunxi-mmc sdc1: *****retry:re-send cmd*****
9339 [ 5529.268510] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9340 [ 5529.268603] sunxi-mmc sdc1: *****retry:start*****
9341 [ 5529.268638] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
9342 [ 5529.268643] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9343 [ 5529.268669] sunxi-mmc sdc1: *****retry:re-send cmd*****
9344 [ 5529.379488] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9345 [ 5529.379579] sunxi-mmc sdc1: *****retry:start*****
9346 [ 5529.379614] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
9347 [ 5529.379619] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9348 [ 5529.379643] sunxi-mmc sdc1: *****retry:re-send cmd*****
9349 [ 5529.490458] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9350 [ 5529.490493] sunxi-mmc sdc1: *****retry:start*****
9351 [ 5529.490528] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
9352 [ 5529.490534] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9353 [ 5529.490566] sunxi-mmc sdc1: *****retry:re-send cmd*****
9354 [ 5529.601328] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9355 [ 5529.601364] sunxi-mmc sdc1: *****retry:start*****
9356 [ 5529.601396] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9357 [ 5529.601406] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
9358 [ 5529.601432] sunxi-mmc sdc1: *****retry:re-send cmd*****
9359 [ 5529.712241] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9360 [ 5529.712332] sunxi-mmc sdc1: *****retry:start*****
9361 [ 5529.712368] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9362 [ 5529.712373] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
9363 [ 5529.712398] sunxi-mmc sdc1: *****retry:re-send cmd*****
9364 [ 5529.823213] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9365 [ 5529.823250] sunxi-mmc sdc1: *****retry:start*****
9366 [ 5529.823285] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9367 [ 5529.823290] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
9368 [ 5529.823314] sunxi-mmc sdc1: *****retry:re-send cmd*****
9369 [ 5529.934127] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9370 [ 5529.934218] sunxi-mmc sdc1: *****retry:start*****
9371 [ 5529.934254] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
9372 [ 5529.934259] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
9373 [ 5529.934286] sunxi-mmc sdc1: *****retry:re-send cmd*****
9374 [ 5530.045094] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9375 [ 5530.045184] sunxi-mmc sdc1: *****retry:start*****
9376 [ 5530.045219] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
9377 [ 5530.045224] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
9378 [ 5530.045251] sunxi-mmc sdc1: *****retry:re-send cmd*****
9379 [ 5530.156092] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9380 [ 5530.156224] sunxi-mmc sdc1: *****retry:start*****
9381 [ 5530.156288] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
9382 [ 5530.156301] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
9383 [ 5530.156339] sunxi-mmc sdc1: *****retry:re-send cmd*****
9384 [ 5530.267115] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9385 [ 5530.267170] sunxi-mmc sdc1: *****retry:start*****
9386 [ 5530.267227] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9387 [ 5530.267239] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
9388 [ 5530.267277] sunxi-mmc sdc1: *****retry:re-send cmd*****
9389 [ 5530.378085] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9390 [ 5530.378170] sunxi-mmc sdc1: *****retry:start*****
9391 [ 5530.378204] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9392 [ 5530.378209] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
9393 [ 5530.378235] sunxi-mmc sdc1: *****retry:re-send cmd*****
9394 [ 5530.488998] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9395 [ 5530.489081] sunxi-mmc sdc1: *****retry:start*****
9396 [ 5530.489116] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9397 [ 5530.489121] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
9398 [ 5530.489146] sunxi-mmc sdc1: *****retry:re-send cmd*****
9399 [ 5530.599954] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9400 [ 5530.599992] sunxi-mmc sdc1: *****retry:start*****
9401 [ 5530.600031] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9402 [ 5530.600038] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9403 [ 5530.600069] sunxi-mmc sdc1: *****retry:re-send cmd*****
9404 [ 5530.710876] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9405 [ 5530.710960] sunxi-mmc sdc1: *****retry:start*****
9406 [ 5530.710995] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9407 [ 5530.711000] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9408 [ 5530.711026] sunxi-mmc sdc1: *****retry:re-send cmd*****
9409 [ 5530.821834] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9410 [ 5530.821916] sunxi-mmc sdc1: *****retry:start*****
9411 [ 5530.821950] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9412 [ 5530.821955] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9413 [ 5530.821979] sunxi-mmc sdc1: *****retry:re-send cmd*****
9414 [ 5530.932792] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9415 [ 5530.932884] sunxi-mmc sdc1: *****retry:start*****
9416 [ 5530.932919] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9417 [ 5530.932924] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9418 [ 5530.932952] sunxi-mmc sdc1: *****retry:re-send cmd*****
9419 [ 5531.043761] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9420 [ 5531.043853] sunxi-mmc sdc1: *****retry:start*****
9421 [ 5531.043887] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9422 [ 5531.043892] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9423 [ 5531.043918] sunxi-mmc sdc1: *****retry:re-send cmd*****
9424 [ 5531.154729] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9425 [ 5531.154820] sunxi-mmc sdc1: *****retry:start*****
9426 [ 5531.154854] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9427 [ 5531.154859] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9428 [ 5531.154883] sunxi-mmc sdc1: *****retry:re-send cmd*****
9429 [ 5531.265646] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9430 [ 5531.265695] sunxi-mmc sdc1: *****retry:start*****
9431 [ 5531.265729] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9432 [ 5531.265734] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9433 [ 5531.265755] sunxi-mmc sdc1: *****retry:re-send cmd*****
9434 [ 5531.376573] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9435 [ 5531.376667] sunxi-mmc sdc1: *****retry:start*****
9436 [ 5531.376703] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9437 [ 5531.376708] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9438 [ 5531.376734] sunxi-mmc sdc1: *****retry:re-send cmd*****
9439 [ 5531.487542] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9440 [ 5531.487631] sunxi-mmc sdc1: *****retry:start*****
9441 [ 5531.487666] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9442 [ 5531.487671] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9443 [ 5531.487697] sunxi-mmc sdc1: *****retry:re-send cmd*****
9444 [ 5531.598507] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
9445 [ 5531.598547] sunxi-mmc sdc1: *****retry:start*****
9446 [ 5531.598582] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
9447 [ 5531.598593] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
9448 [ 5531.598601] sunxi-mmc sdc1: sunxi v4p1x retry give up
9449 [ 5531.598607] sunxi-mmc sdc1: retry:set phase failed or over retry times
9450 [ 5531.598624] sunxi-mmc sdc1: retry:give up
9451 [ 5531.598667] sdiohal err:dt read fail ret:-110, system_addr=0x4024f000
9452 [ 5531.598672] sdiohal:sdio dump_aon_reg entry
9453 [ 5531.598707] sdiohal:pmu sdio status:[0x140]:0x6b
9454 [ 5531.598735] sdiohal:pmu sdio status:[0x141]:0x3c
9455 [ 5531.598755] sdiohal:pmu sdio status:[0x142]:0xe1
9456 [ 5531.598775] sdiohal:pmu sdio status:[0x143]:0x0
9457 [ 5531.598794] sdiohal:pmu sdio status:[0x144]:0x0
9458 [ 5531.598812] sdiohal:pmu sdio status:[0x145]:0x0
9459 [ 5531.598831] sdiohal:pmu sdio status:[0x146]:0x0
9460 [ 5531.598849] sdiohal:pmu sdio status:[0x147]:0x0
9461 [ 5531.598868] sdiohal:pmu sdio status:[0x148]:0x60
9462 [ 5531.598887] sdiohal:pmu sdio status:[0x149]:0x0
9463 [ 5531.598906] sdiohal:pmu sdio status:[0x14a]:0x0
9464 [ 5531.598925] sdiohal:pmu sdio status:[0x14b]:0x0
9465 [ 5531.598945] sdiohal:pmu sdio status:[0x14c]:0x0
9466 [ 5531.598963] sdiohal:pmu sdio status:[0x14d]:0x0
9467 [ 5531.598982] sdiohal:pmu sdio status:[0x14e]:0x0
9468 [ 5531.599000] sdiohal:pmu sdio status:[0x14f]:0x0
9469 [ 5531.599077] sdiohal:cm4d haddr 0:[0x144]:0x0
9470 [ 5531.599096] sdiohal:cm4d haddr 0:[0x145]:0x20
9471 [ 5531.599115] sdiohal:cm4d haddr 0:[0x146]:0x12
9472 [ 5531.599134] sdiohal:cm4d haddr 0:[0x147]:0x0
9473 [ 5531.599209] sdiohal:cm4i haddr 1:[0x144]:0xe0
9474 [ 5531.599228] sdiohal:cm4i haddr 1:[0x145]:0x40
9475 [ 5531.599247] sdiohal:cm4i haddr 1:[0x146]:0x10
9476 [ 5531.599266] sdiohal:cm4i haddr 1:[0x147]:0x0
9477 [ 5531.599341] sdiohal:cm4s haddr 2:[0x144]:0x7c
9478 [ 5531.599360] sdiohal:cm4s haddr 2:[0x145]:0x6
9479 [ 5531.599379] sdiohal:cm4s haddr 2:[0x146]:0x14
9480 [ 5531.599398] sdiohal:cm4s haddr 2:[0x147]:0x40
9481 [ 5531.599474] sdiohal:dmaw haddr 3:[0x144]:0x0
9482 [ 5531.599493] sdiohal:dmaw haddr 3:[0x145]:0x0
9483 [ 5531.599512] sdiohal:dmaw haddr 3:[0x146]:0x0
9484 [ 5531.599531] sdiohal:dmaw haddr 3:[0x147]:0x0
9485 [ 5531.599645] sdiohal:dmar haddr 4:[0x144]:0x0
9486 [ 5531.599665] sdiohal:dmar haddr 4:[0x145]:0x0
9487 [ 5531.599684] sdiohal:dmar haddr 4:[0x146]:0x0
9488 [ 5531.599703] sdiohal:dmar haddr 4:[0x147]:0x0
9489 [ 5531.599828] sdiohal:aon_to_ahb haddr 5:[0x144]:0x0
9490 [ 5531.599859] sdiohal:aon_to_ahb haddr 5:[0x145]:0x0
9491 [ 5531.599881] sdiohal:aon_to_ahb haddr 5:[0x146]:0x0
9492 [ 5531.599900] sdiohal:aon_to_ahb haddr 5:[0x147]:0x0
9493 [ 5531.599977] sdiohal:axi_to_ahb haddr 6:[0x144]:0x4
9494 [ 5531.599996] sdiohal:axi_to_ahb haddr 6:[0x145]:0xf0
9495 [ 5531.600015] sdiohal:axi_to_ahb haddr 6:[0x146]:0x24
9496 [ 5531.600035] sdiohal:axi_to_ahb haddr 6:[0x147]:0x40
9497 [ 5531.600111] sdiohal:hready_status haddr 7:[0x144]:0xcf
9498 [ 5531.600130] sdiohal:hready_status haddr 7:[0x145]:0xff
9499 [ 5531.600149] sdiohal:hready_status haddr 7:[0x146]:0xf9
9500 [ 5531.600168] sdiohal:hready_status haddr 7:[0x147]:0x70
9501 [ 5531.600171] sdiohal:val:0xc
9502 [ 5531.600220] sdiohal:after reset hready status:[0x144]:0xcf
9503 [ 5531.600238] sdiohal:after reset hready status:[0x145]:0xff
9504 [ 5531.600256] sdiohal:after reset hready status:[0x146]:0xf9
9505 [ 5531.600275] sdiohal:after reset hready status:[0x147]:0x70
9506 [ 5531.600278] sdiohal:sdio dump_aon_reg end
9507
9508 [ 5531.600281] sdiohal:sdiohal_abort
9509 [ 5531.600286] sdiohal:carddump flag set[1]
9510 [ 5531.600315] sdiohal:disable rx int for dump
9511 [ 5531.600321] sdiohal:chn8 tx push old, cmdid=25, mstime=5527952, record_time=5527952
9512 [ 5531.600330] chn8 tx push old: 00 00 00 00 10 19 a5 00 90 59 54 00 00 00 00 00 .........YT.....
9513 [ 5531.600335] sdiohal:chn8 tx denq old, cmdid=25, mstime=5527952, record_time=5527955
9514 [ 5531.600339] chn8 tx denq old: 80 52 00 08 10 19 a5 00 90 59 54 00 00 00 00 00 .R.......YT.....
9515 [ 5531.600344] sdiohal:chn22 rx dispatch old, cmdid=27, mstime=5527848, record_time=5527853
9516 [ 5531.600348] chn22 rx dispatch old: 3f 06 00 0a 00 1b 0c 00 28 59 54 00 00 38 00 00 ?.......(YT..8..
9517 [ 5531.600353] sdiohal:chn8 tx push new, cmdid=11, mstime=5527958, record_time=5527958
9518 [ 5531.600357] chn8 tx push new: 00 00 00 00 10 0b 57 00 96 59 54 00 00 00 00 00 ......W..YT.....
9519 [ 5531.600361] sdiohal:chn8 tx denq new, cmdid=11, mstime=5527958, record_time=5527958
9520 [ 5531.600366] chn8 tx denq new: 80 2b 00 08 10 0b 57 00 96 59 54 00 00 00 00 00 .+....W..YT.....
9521 [ 5531.600370] sdiohal:chn22 rx dispatch new, cmdid=25, mstime=5527952, record_time=5527958
9522 [ 5531.600375] chn22 rx dispatch new: 3f 06 00 0a 00 19 0c 00 90 59 54 00 00 39 00 00 ?........YT..9..
9523 [ 5531.600381] WCN_ERR: mdbg_dump_data dump memory error:-110
9524 [ 5531.600394] WCN: mdbg dump bt modem 0 ok!
9525 [ 5531.600399] WCN_ERR: read HCI_ARM_WR_RD_MODE reg error:-1
9526 [ 5531.600413] WCN_ERR: mdbg_dump_data dump memory error:-1
9527 [ 5531.600418] WCN: mdbg dump bt_cmd buf 0 ok!
9528 [ 5531.600422] WCN_ERR: mdbg_dump_data dump memory error:-1
9529 [ 5531.600427] WCN: mdbg dump btevent buf 0 ok!
9530 [ 5531.600431] WCN_ERR: mdbg_dump_data dump memory error:-1
9531 [ 5531.600435] WCN: mdbg dump bt_lmp_tx_buf 0 ok!
9532 [ 5531.600440] WCN_ERR: mdbg_dump_data dump memory error:-1
9533 [ 5531.600444] WCN: mdbg dump bt_lmp_rx_buf 0 ok!
9534 [ 5531.600449] WCN_ERR: mdbg_dump_data dump memory error:-1
9535 [ 5531.600453] WCN: mdbg dump bt_acl_tx_buf0 ok!
9536 [ 5531.600457] WCN_ERR: mdbg_dump_data dump memory error:-1
9537 [ 5531.600462] WCN: mdbg dump bt_acl_rx_buf 0 ok!
9538 [ 5531.600466] WCN_ERR: mdbg_dump_data dump memory error:-1
9539 [ 5531.600470] WCN: mdbg dump bt_sco_tx_buf 0 ok!
9540 [ 5531.600475] WCN_ERR: mdbg_dump_data dump memory error:-1
9541 [ 5531.600479] WCN: mdbg dump bt_sco_rx_buf 0 ok!
9542 [ 5531.600483] WCN_ERR: mdbg_dump_data dump memory error:-1
9543 [ 5531.600488] WCN: mdbg dump bt_bb_tx_buf 0 ok!
9544 [ 5531.600492] WCN_ERR: mdbg_dump_data dump memory error:-1
9545 [ 5531.600496] WCN: mdbg dump bt_bb_rx_buf 0 ok!
9546 [ 5531.646525] WCN: dumpmem_rx_callback
9547 [ 5531.646535] WCN: dump str finish!
9548 [ 5531.646538] WCN: mdbg dump memory finish
9549 [ 5531.646564] sdiohal err:sdiohal_adma_pt_read line 510 dump happened
9550 [ 5531.646568] sdiohal err:adma read fail ret:-19
9551 [ 5531.876603] WCN: stop_loopcheck
9552 [ 5537.210058] WCN: mdbg_assert_interface:[CMD] WIFI_CMD_SCAN, [REASON] CMD_RSP_TIMEOUT_ERROR
9553 [ 5537.210077] sdiohal:carddump flag set[1]
9554 [ 5537.210150] sdiohal:disable rx int for dump
9555 [ 5537.210162] sdiohal:chn8 tx push old, cmdid=25, mstime=5527952, record_time=5527952
9556 [ 5537.210174] chn8 tx push old: 00 00 00 00 10 19 a5 00 90 59 54 00 00 00 00 00 .........YT.....
9557 [ 5537.210180] sdiohal:chn8 tx denq old, cmdid=25, mstime=5527952, record_time=5527955
9558 [ 5537.210184] chn8 tx denq old: 80 52 00 08 10 19 a5 00 90 59 54 00 00 00 00 00 .R.......YT.....
9559 [ 5537.210189] sdiohal:chn22 rx dispatch old, cmdid=27, mstime=5527848, record_time=5527853
9560 [ 5537.210194] chn22 rx dispatch old: 3f 06 00 0a 00 1b 0c 00 28 59 54 00 00 38 00 00 ?.......(YT..8..
9561 [ 5537.210198] sdiohal:chn8 tx push new, cmdid=11, mstime=5527958, record_time=5527958
9562 [ 5537.210203] chn8 tx push new: 00 00 00 00 10 0b 57 00 96 59 54 00 00 00 00 00 ......W..YT.....
9563 [ 5537.210208] sdiohal:chn8 tx denq new, cmdid=11, mstime=5527958, record_time=5527958
9564 [ 5537.210213] chn8 tx denq new: 80 2b 00 08 10 0b 57 00 96 59 54 00 00 00 00 00 .+....W..YT.....
9565 [ 5537.210218] sdiohal:chn22 rx dispatch new, cmdid=25, mstime=5527952, record_time=5527958
9566 [ 5537.210223] chn22 rx dispatch new: 3f 06 00 0a 00 19 0c 00 90 59 54 00 00 39 00 00 ?........YT..9..
9567 [ 5537.210227] WCN_ERR: Not dump again!
9568 [ 5543.137795] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
9569 [ 5549.247975] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.0 (1654 of 2204 items, 1269760 file size, 767 bytes per hash table item), suggesting rotation.
9570 [ 5549.248004] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
9571
9572
9573
9574 ### interrupts:
9575 CPU0 CPU1 CPU2 CPU3
9576 3: 199127 209462 208307 179917 wakeupgen 48 Level sun4i_timer0
9577 6: 848063 721119 701849 726177 GIC-0 27 Level arch_timer
9578 8: 0 0 0 0 wakeupgen 61 Level 30f0000.iommu
9579 151: 0 0 0 0 sunxi_pio_edge 134 Edge sdc0 cd
9580 193: 0 0 0 0 sunxi_pio_edge 176 Edge bt_wake_isr
9581 273: 483 0 0 0 wakeupgen 42 Level 3002000.dma-controller
9582 275: 0 0 0 0 wakeupgen 106 Level RemoteIR_RX
9583 276: 0 0 0 0 wakeupgen 104 Level rtc
9584 278: 0 0 0 0 wakeupgen 93 Level cedar_dev
9585 280: 298 0 0 0 wakeupgen 0 Level uart0
9586 283: 0 0 0 0 wakeupgen 9 Level twi3
9587 284: 138080 0 0 0 wakeupgen 105 Level twi5
9588 285: 0 0 0 0 wakeupgen 25 Level sunxi_usb_udc
9589 288: 2 0 0 0 wakeupgen 28 Level ehci_hcd:usb1
9590 289: 94396 0 0 0 wakeupgen 29 Level ohci_hcd:usb4
9591 290: 0 0 0 0 wakeupgen 30 Level ehci_hcd:usb2
9592 291: 0 0 0 0 wakeupgen 31 Level ohci_hcd:usb5
9593 292: 0 0 0 0 wakeupgen 32 Level ehci_hcd:usb3
9594 293: 0 0 0 0 wakeupgen 33 Level ohci_hcd:usb6
9595 294: 0 0 0 0 wakeupgen 12 Level spi0
9596 295: 504 0 0 0 wakeupgen 13 Level spi1
9597 298: 3567 0 0 239620 wakeupgen 35 Level sunxi-mmc0
9598 299: 104922 0 0 0 wakeupgen 36 Level sunxi-mmc1
9599 300: 9 0 0 0 wakeupgen 88 Level dispaly
9600 303: 355994 0 0 0 wakeupgen 66 Level dispaly
9601 314: 0 0 0 0 wakeupgen 91 Edge ss
9602 316: 0 0 0 0 wakeupgen 89 Level 1420000.deinterlace
9603 319: 0 0 0 0 wakeupgen 20 Edge sunxikbd
9604 320: 0 0 0 0 wakeupgen 14 Level gmac0
9605 IPI0: 624833 665809 618948 567108 Rescheduling interrupts
9606 IPI1: 1658 2105 2104 2033 Function call interrupts
9607 IPI2: 0 0 0 0 CPU stop interrupts
9608 IPI3: 5958 12785 18303 20397 Timer broadcast interrupts
9609 IPI4: 2433 2158 1928 2034 IRQ work interrupts
9610 IPI5: 0 0 0 0 CPU wake-up interrupts
9611 Err: 0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
