8 -
I have a h618 board(orangepizero3) with the same problem. Use the following solution, the device tree nodes may be a little different. Edit boot.cmd: nano /boot/boot.cmd Disabling dts nodes with fdt: # After adding to fdt resize …… fdt set "/thermal-zones/gpu-thermal" "status" "disabled" fdt set "/thermal-zones/cpu-thermal" "status" "disabled" fdt set "/thermal-zones/ddr-thermal" "status" "disabled" fdt set "/thermal-zones/ve-thermal" "status" "disabled" Re-generate boot.scr: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr Try boot.
Is this the right place to post this type of content? I have a board for Orange Pi. Since I'm usually using windows, it's very inconvenient to burn u-boot. I'll post it to github later if you guys are interested! (Machine translated, English not so good, don't know if the description is apt or not.)
[root@lalaki ~]# journalctl -p4 Sep 16 14:27:11 lalaki kernel: watchdog: watchdog0: watchdog did not stop! Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0 Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 1 Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 2 Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 3 Sep 16 14:26:51 lalaki kernel: KASLR disabled due to lack of seed Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0 Sep 16 14:26:51 lalaki kernel: axp20x-regulator axp20x-regulator: DCDC frequency on AXP313a is fixed to 3 MHz. Sep 16 14:26:51 lalaki kernel: axp20x-regulator axp20x-regulator: Error setting dcdc frequency: -22 Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: debugfs: Directory '1100000.mixer' with parent 'regmap' already present! Sep 16 14:26:51 lalaki kernel: debugfs: Directory '1100000.mixer' with parent 'regmap' already present! Sep 16 14:26:51 lalaki kernel: sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: sun50i-cpufreq-nvmem: will use speed0 CPU OPPs Sep 16 14:26:51 lalaki kernel: OF: /thermal-zones/gpu-thermal/cooling-maps/map0: could not get #cooling-cells for /soc/gpu@1800000 Sep 16 14:26:51 lalaki kernel: thermal_sys: Add a cooling_device property with at least one device Sep 16 14:26:51 lalaki kernel: thermal thermal_zone0: binding zone gpu-thermal with cdev cpufreq-cpu0 failed:-2 Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pg not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests Sep 16 14:26:51 lalaki kernel: mmc0: host does not support reading read-only switch, assuming write-enable Sep 16 14:26:51 lalaki kernel: device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log. Sep 16 14:26:51 lalaki kernel: WCN_ERR: dts node for bt_wake not found Sep 16 14:26:53 lalaki kernel: sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. Sep 16 14:26:53 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pi not found, using dummy regulator Sep 16 14:26:53 lalaki kernel: dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0) Sep 16 14:26:53 lalaki kernel: wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini Sep 16 14:26:53 lalaki kernel: sprdwl:sprdwl_get_fw_info length mismatch: len_count=83, r_len=89 Sep 16 14:26:53 lalaki kernel: sprdwl:sprdwl_get_fw_info, drv_version=1, fw_version=2, compat_ver=0 Sep 16 14:26:53 lalaki kernel: sprdwl:chip_model:0x2355, chip_ver:0x0 Sep 16 14:26:53 lalaki kernel: sprdwl:fw_ver:0, fw_std:0x7f, fw_capa:0x120f7f Sep 16 14:26:53 lalaki kernel: sprdwl:mac_addr:a0:67:20:f1:db:fb Sep 16 14:26:53 lalaki kernel: sprdwl:credit_capa:TX_WITH_CREDIT Sep 16 14:26:53 lalaki kernel: sprdwl:ott support:0 Sep 16 14:26:53 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. Sep 16 17:10:16 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: sprdwl_start_xmit drop msg due to TX Err Sep 16 17:10:17 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: sprdwl_start_xmit drop msg due to TX Err Sep 16 17:10:17 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: sprdwl_start_xmit drop msg due to TX Err ... Is part of the content merely informative? Should some of the parameters be corrected? for example: default_syscon_value = 58000, should it be changed to 0?
