lalaki
  1. I have a h618 board(orangepizero3) with the same problem. Use the following solution, the device tree nodes may be a little different. Edit boot.cmd: nano /boot/boot.cmd Disabling dts nodes with fdt: # After adding to fdt resize …… fdt set "/thermal-zones/gpu-thermal" "status" "disabled" fdt set "/thermal-zones/cpu-thermal" "status" "disabled" fdt set "/thermal-zones/ddr-thermal" "status" "disabled" fdt set "/thermal-zones/ve-thermal" "status" "disabled" Re-generate boot.scr: mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr Try boot.
  2. Source: https://github.com/lalakii/lalaki-u-boot-tool
  3. Is this the right place to post this type of content? I have a board for Orange Pi. Since I'm usually using windows, it's very inconvenient to burn u-boot. I'll post it to github later if you guys are interested! (Machine translated, English not so good, don't know if the description is apt or not.)
  4. @going Since I didn't find an actively maintained kernel branch (for orangepizero3), I would have done this otherwise.
  5. dtbs fixed! kernel: https://drive.google.com/drive/folders/1EwbvUz_T67aveOomDhaL-y-YQ856dkYZ?usp=drive_link dtbs.tgz
  6. After a few days of trying to get rid of these annoyances by modifying the kernel source code as well as the device tree, I've finally gotten rid of them, and now there are only a few inconsequential warnings
  7. [root@lalaki ~]# journalctl -p4 Sep 16 14:27:11 lalaki kernel: watchdog: watchdog0: watchdog did not stop! Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0 Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 1 Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 2 Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 3 Sep 16 14:26:51 lalaki kernel: KASLR disabled due to lack of seed Sep 16 14:26:51 lalaki kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0 Sep 16 14:26:51 lalaki kernel: axp20x-regulator axp20x-regulator: DCDC frequency on AXP313a is fixed to 3 MHz. Sep 16 14:26:51 lalaki kernel: axp20x-regulator axp20x-regulator: Error setting dcdc frequency: -22 Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: debugfs: Directory '1100000.mixer' with parent 'regmap' already present! Sep 16 14:26:51 lalaki kernel: debugfs: Directory '1100000.mixer' with parent 'regmap' already present! Sep 16 14:26:51 lalaki kernel: sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: sun50i-cpufreq-nvmem: will use speed0 CPU OPPs Sep 16 14:26:51 lalaki kernel: OF: /thermal-zones/gpu-thermal/cooling-maps/map0: could not get #cooling-cells for /soc/gpu@1800000 Sep 16 14:26:51 lalaki kernel: thermal_sys: Add a cooling_device property with at least one device Sep 16 14:26:51 lalaki kernel: thermal thermal_zone0: binding zone gpu-thermal with cdev cpufreq-cpu0 failed:-2 Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pg not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: usb_phy_generic usb_phy_generic.4.auto: supply vcc not found, using dummy regulator Sep 16 14:26:51 lalaki kernel: usb_phy_generic usb_phy_generic.4.auto: dummy supplies not allowed for exclusive requests Sep 16 14:26:51 lalaki kernel: mmc0: host does not support reading read-only switch, assuming write-enable Sep 16 14:26:51 lalaki kernel: device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log. Sep 16 14:26:51 lalaki kernel: WCN_ERR: dts node for bt_wake not found Sep 16 14:26:53 lalaki kernel: sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. Sep 16 14:26:53 lalaki kernel: sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pi not found, using dummy regulator Sep 16 14:26:53 lalaki kernel: dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 0) Sep 16 14:26:53 lalaki kernel: wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini Sep 16 14:26:53 lalaki kernel: sprdwl:sprdwl_get_fw_info length mismatch: len_count=83, r_len=89 Sep 16 14:26:53 lalaki kernel: sprdwl:sprdwl_get_fw_info, drv_version=1, fw_version=2, compat_ver=0 Sep 16 14:26:53 lalaki kernel: sprdwl:chip_model:0x2355, chip_ver:0x0 Sep 16 14:26:53 lalaki kernel: sprdwl:fw_ver:0, fw_std:0x7f, fw_capa:0x120f7f Sep 16 14:26:53 lalaki kernel: sprdwl:mac_addr:a0:67:20:f1:db:fb Sep 16 14:26:53 lalaki kernel: sprdwl:credit_capa:TX_WITH_CREDIT Sep 16 14:26:53 lalaki kernel: sprdwl:ott support:0 Sep 16 14:26:53 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings. Sep 16 17:10:16 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: sprdwl_start_xmit drop msg due to TX Err Sep 16 17:10:17 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: sprdwl_start_xmit drop msg due to TX Err Sep 16 17:10:17 lalaki kernel: unisoc_wifi unisoc_wifi wlan0: sprdwl_start_xmit drop msg due to TX Err ... Is part of the content merely informative? Should some of the parameters be corrected? for example: default_syscon_value = 58000, should it be changed to 0?
