beiqidai
4 -
Efforts to develop firmware for H96 MAX V56 RK3566 4G/32G
beiqidai replied to Hqnicolas's topic in Rockchip CPU Boxes
Do you have the correct dtb here? -
I use rk's sdk(http://en.t-firefly.com/doc/download/93.html#other_378) to directly compile all attachments ./build.sh Then I will overwrite the dtb in the compiled boot.img with your dtb(https://drive.google.com/file/d/1KPYJhKg6u4Q57ee4jhUlviu7zA0F_j2Y/view?usp=sharing). losetup -P /dev/loop1 boot.img mount /dev/loop1 /mnt cp ./rk3566-firefly-roc-pc.dtb /mnt/rk3566-firefly-roc-pc.dtb umount /mnt Then package it into rk firmware sudo ./build.sh updateimg But when I write to the development board, the system cannot be started normally. ttl: LP4/4x derate en, other dram:1x trefi ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB tdqss: cs0 dqs0: -48ps, dqs1: -168ps, dqs2: -120ps, dqs3: -217ps, tdqss: cs1 dqs0: -72ps, dqs1: -168ps, dqs2: -96ps, dqs3: -217ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x65 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 1056MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x46 cs 0: the read training result: DQS0:0x3f, DQS1:0x3b, DQS2:0x41, DQS3:0x39, min :0x10 0xf 0x11 0xf 0x1 0x5 0x8 0x3 , 0x8 0x8 0x3 0x1 0x8 0x6 0x9 0x4 , 0x12 0x11 0xe 0xd 0x5 0x0 0x1 0x4 , 0xc 0x8 0x6 0x2 0xc 0xb 0x8 0xb , mid :0x2d 0x2e 0x2f 0x2c 0x20 0x22 0x27 0x22 ,0x26 0x27 0x22 0x1f 0x26 0x26 0x27 0x23 , 0x30 0x2f 0x2b 0x2a 0x23 0x1e 0x20 0x22 ,0x2a 0x27 0x25 0x21 0x2a 0x2a 0x28 0x2a , max :0x4b 0x4e 0x4e 0x4a 0x40 0x40 0x46 0x41 ,0x45 0x47 0x41 0x3d 0x44 0x46 0x46 0x43 , 0x4e 0x4e 0x48 0x47 0x42 0x3d 0x40 0x40 ,0x49 0x47 0x44 0x41 0x48 0x49 0x48 0x49 , range:0x3b 0x3f 0x3d 0x3b 0x3f 0x3b 0x3e 0x3e ,0x3d 0x3f 0x3e 0x3c 0x3c 0x40 0x3d 0x3f , 0x3c 0x3d 0x3a 0x3a 0x3d 0x3d 0x3f 0x3c ,0x3d 0x3f 0x3e 0x3f 0x3c 0x3e 0x40 0x3e , the write training result: DQS0:0x40, DQS1:0x30, DQS2:0x36, DQS3:0x29, min :0x61 0x64 0x64 0x64 0x55 0x57 0x5c 0x5c 0x5a ,0x50 0x51 0x4b 0x49 0x51 0x51 0x51 0x52 0x4e , 0x58 0x58 0x54 0x54 0x4c 0x4a 0x49 0x4f 0x4e ,0x4c 0x4a 0x47 0x45 0x4d 0x4d 0x49 0x50 0x49 , mid :0x7c 0x80 0x80 0x7e 0x70 0x72 0x76 0x75 0x74 ,0x6a 0x6a 0x64 0x63 0x6c 0x6a 0x6a 0x6b 0x67 , 0x74 0x73 0x6e 0x70 0x66 0x61 0x61 0x68 0x68 ,0x67 0x66 0x61 0x60 0x68 0x68 0x64 0x6a 0x61 , max :0x98 0x9c 0x9c 0x99 0x8c 0x8e 0x91 0x8f 0x8e ,0x85 0x84 0x7d 0x7e 0x87 0x83 0x84 0x84 0x80 , 0x90 0x8f 0x88 0x8c 0x81 0x79 0x7a 0x82 0x83 ,0x82 0x82 0x7c 0x7b 0x84 0x83 0x80 0x84 0x79 , range:0x37 0x38 0x38 0x35 0x37 0x37 0x35 0x33 0x34 ,0x35 0x33 0x32 0x35 0x36 0x32 0x33 0x32 0x32 , 0x38 0x37 0x34 0x38 0x35 0x2f 0x31 0x33 0x35 ,0x36 0x38 0x35 0x36 0x37 0x36 0x37 0x34 0x30 , cs 1: the read training result: DQS0:0x3e, DQS1:0x3b, DQS2:0x41, DQS3:0x39, min :0x10 0x10 0x11 0xf 0x1 0x5 0x8 0x3 , 0x9 0x8 0x2 0x2 0x8 0x7 0xb 0x5 , 0x12 0x12 0xe 0xd 0x5 0x0 0x2 0x3 , 0xd 0x8 0x6 0x2 0xc 0xb 0x8 0xa , mid :0x2c 0x2e 0x2f 0x2b 0x20 0x22 0x26 0x20 ,0x27 0x27 0x21 0x1f 0x26 0x26 0x29 0x24 , 0x30 0x30 0x2b 0x2a 0x23 0x1e 0x21 0x21 ,0x2b 0x27 0x24 0x21 0x2a 0x2a 0x27 0x28 , max :0x49 0x4c 0x4d 0x48 0x3f 0x40 0x44 0x3e ,0x45 0x47 0x41 0x3d 0x44 0x46 0x47 0x43 , 0x4e 0x4e 0x48 0x47 0x42 0x3d 0x40 0x40 ,0x49 0x46 0x43 0x40 0x48 0x49 0x47 0x47 , range:0x39 0x3c 0x3c 0x39 0x3e 0x3b 0x3c 0x3b ,0x3c 0x3f 0x3f 0x3b 0x3c 0x3f 0x3c 0x3e , 0x3c 0x3c 0x3a 0x3a 0x3d 0x3d 0x3e 0x3d ,0x3c 0x3e 0x3d 0x3e 0x3c 0x3e 0x3f 0x3d , the write training result: DQS0:0x40, DQS1:0x30, DQS2:0x36, DQS3:0x29, min :0x5e 0x62 0x62 0x61 0x55 0x56 0x58 0x58 0x59 ,0x51 0x51 0x4c 0x4b 0x52 0x52 0x53 0x53 0x4e , 0x5c 0x5c 0x57 0x58 0x51 0x4e 0x4d 0x54 0x52 ,0x4d 0x4a 0x48 0x45 0x4d 0x4d 0x4a 0x4d 0x48 , mid :0x7a 0x7e 0x7e 0x7c 0x70 0x71 0x74 0x73 0x73 ,0x6b 0x6b 0x66 0x65 0x6c 0x6b 0x6b 0x6b 0x68 , 0x78 0x78 0x72 0x74 0x6c 0x67 0x68 0x6e 0x6e ,0x68 0x66 0x61 0x60 0x69 0x69 0x65 0x68 0x61 , max :0x97 0x9a 0x9a 0x97 0x8b 0x8c 0x91 0x8f 0x8e ,0x86 0x85 0x80 0x80 0x87 0x84 0x84 0x83 0x82 , 0x94 0x94 0x8d 0x90 0x87 0x80 0x83 0x88 0x8a ,0x84 0x82 0x7b 0x7c 0x86 0x86 0x80 0x83 0x7b , range:0x39 0x38 0x38 0x36 0x36 0x36 0x39 0x37 0x35 ,0x35 0x34 0x34 0x35 0x35 0x32 0x31 0x30 0x34 , 0x38 0x38 0x36 0x38 0x36 0x32 0x36 0x34 0x38 ,0x37 0x38 0x33 0x37 0x39 0x39 0x36 0x36 0x33 , CA Training result: cs:0 min :0x55 0x49 0x4a 0x3e 0x4a 0x3e 0x4d ,0x51 0x40 0x48 0x38 0x48 0x36 0x4d , cs:0 mid :0x8e 0x8e 0x84 0x83 0x84 0x82 0x77 ,0x88 0x86 0x80 0x7e 0x80 0x7d 0x75 , cs:0 max :0xc8 0xd3 0xbe 0xc9 0xbe 0xc7 0xa2 ,0xc0 0xcc 0xb8 0xc5 0xb9 0xc4 0x9d , cs:0 range:0x73 0x8a 0x74 0x8b 0x74 0x89 0x55 ,0x6f 0x8c 0x70 0x8d 0x71 0x8e 0x50 , cs:1 min :0x4e 0x49 0x46 0x3f 0x46 0x3e 0x47 ,0x4e 0x45 0x46 0x3d 0x46 0x3e 0x47 , cs:1 mid :0x8a 0x8b 0x81 0x81 0x81 0x7f 0x73 ,0x89 0x86 0x81 0x7f 0x81 0x7f 0x73 , cs:1 max :0xc7 0xcd 0xbd 0xc4 0xbd 0xc1 0x9f ,0xc4 0xc7 0xbc 0xc2 0xbd 0xc0 0xa0 , cs:1 range:0x79 0x84 0x77 0x85 0x77 0x83 0x58 ,0x76 0x82 0x76 0x85 0x77 0x82 0x59 , out U-Boot SPL board init U-Boot SPL 2017.09(u-boot commit id: 8cf7a403b1cfcd50512c4a7b6669fbd0d57ba876)(sdk version: rk356x_linux_release_20230710_v1.3.2f.xml)-) unrecognized JEDEC id bytes: ff, ff, ff Trying to boot from MMC2 Card did not respond to voltage select! mmc_init: -95, time 9 spl: mmc init failed with error: -95 Trying to boot from MMC1 SPL: A/B-slot: _a, successful: 0, tries-remain: 7 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(0d5225a4ab...) + OK ## Checking uboot 0x00a00000 ... sha256(4e042d4e83...) + OK ## Checking fdt 0x00b2fa48 ... sha256(607e77a63b...) + OK ## Checking atf-2 0xfdcc1000 ... sha256(3e94d16e6a...) + OK ## Checking atf-3 0x0006b000 ... sha256(fde0ef262b...) + OK ## Checking atf-4 0xfdcd0000 ... sha256(befba422b8...) + OK ## Checking atf-5 0xfdcce000 ... sha256(c9eb312bf2...) + OK ## Checking atf-6 0x00069000 ... sha256(6ede7a3b44...) + OK ## Checking optee 0x08400000 ... sha256(af414b9c9f...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 159.546 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-607-gbf602aff1:cl NOTICE: BL31: Built : 10:16:03, Jun 5 2023 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid 220114 INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 I/TC: I/TC: OP-TEE version: 3.13.0-651-gd84087907 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.4 I/TC: Primary CPU initializing I/TC: Primary CPU switching to normal world boot INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09(u-boot commit id: 8cf7a403b1cfcd50512c4a7b6669fbd0d57ba876)(sdk version: rk356x_linux_release_20230710_v1.3.2f.xml)-g8cf) Model: Firefly RK3566 Board PreSerial: 2, raw, 0xfe660000 DRAM: 4 GiB Sysmem: init Relocation Offset: ed249000 Relocation fdt: eb9f8720 - eb9fecd8 CR: M/C/I Using default environment Hotkey: ctrl+` dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 0 MMC0: HS200, 200Mhz PartType: EFI DM: v1 boot mode: recovery (misc) FIT: no signed, no conf required =================begin=================== 112204 bytes read in 7 ms (15.3 MiB/s) DTB(Distro): rk-kernel.dtb I2c0 speed: 100000Hz PMIC: RK8090 (on=0x40, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV io-domain: OK Model: Firefly rk3566-roc-pc rockchip_set_serialno: could not find efuse/otp device No FDT memory address configured. Default at 0x08300000 CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 528000 KHz gpll 1200000 KHz cpll 1000000 KHz npll 24000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 50000 KHz aclk_top_high 300000 KHz aclk_top_low 200000 KHz hclk_top 150000 KHz pclk_top 50000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz Net: eth0: ethernet@fe010000 Hit key to stop autoboot('CTRL+C'): 0 ANDROID: reboot reason: "recovery" optee api revision: 2.0 TEEC: Waring: Could not find security partition Not AVB images, AVB skip No valid android hdr Android image load failed Android boot failed, error -1. ## Booting FIT Image at 0xe96b0f00 with size 0x02146800 Fdt Ramdisk skip relocation ## Loading kernel from FIT Image at e96b0f00 ... Using 'conf' configuration ## Verified-boot: 0 Trying 'kernel' kernel subimage Description: unavailable Type: Kernel Image Compression: uncompressed Data Start: 0xe96d1500 Data Size: 24940552 Bytes = 23.8 MiB Architecture: AArch64 OS: Linux Load Address: 0x00280000 Entry Point: 0x00280000 Hash algo: sha256 Hash value: 31cca7854008e66d8acf6071ca552cef81a7302e2487979662c87e4f05eaaa65 Verifying Hash Integrity ... sha256+ OK ## Loading ramdisk from FIT Image at e96b0f00 ... Using 'conf' configuration Trying 'ramdisk' ramdisk subimage Description: unavailable Type: RAMDisk Image Compression: uncompressed Data Start: 0xeae9a700 Data Size: 9818024 Bytes = 9.4 MiB Architecture: AArch64 OS: Linux Load Address: 0x0a200000 Entry Point: unavailable Hash algo: sha256 Hash value: 2f5de603deedb025c2cefcb6b6d3d708b30211729cbadc652632eb3e781a80dc Verifying Hash Integrity ... sha256+ OK Loading ramdisk from 0xeae9a700 to 0x0a200000 ## Loading fdt from FIT Image at e96b0f00 ... Using 'conf' configuration Trying 'fdt' fdt subimage Description: unavailable Type: Flat Device Tree Compression: uncompressed Data Start: 0xe96b1700 Data Size: 130218 Bytes = 127.2 KiB Architecture: AArch64 Load Address: 0x08300000 Hash algo: sha256 Hash value: 1a50a36a025a43f85741ff5f9f0912c89deb1eaa4bc2bb1981c1999fa81b4f41 Verifying Hash Integrity ... sha256+ OK Loading fdt from 0x08300000 to 0x08300000 Booting using the fdt blob at 0x08300000 Loading Kernel Image from 0xe96d1500 to 0x00280000 ... OK kernel loaded at 0x00280000, end = 0x01a49008 Using Device Tree in place at 0000000008300000, end 000000000831e64b can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000) Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000) Total: 813.141 ms Starting kernel ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 4.19.232 (root@firefly) (firefly: f7165816db073abb32bfe4f754a317d687c7bbcf) (sdk version: rk356x_linux_rel3 [ 0.000000] Machine model: Firefly rk3566-roc-pc [ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 24 pages/cpu s60136 r8192 d29976 u98304 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656 [ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/sdhci@fe31000e [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0xeafff000-0xeefff000] (64MB) [ 0.000000] Memory: 3969132K/4175872K available (15422K kernel code, 1956K rwdata, 5340K rodata, 1600K init, 596K bss, 190356K reser) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 54754 entries in 214 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: MBI range [296:319] [ 0.000000] GICv3: Using MBI frame 0x00000000fd410000 [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] random: random: get_random_bytes called from start_kernel+0x358/0x4e4 with crng_init=0 [ 0.000000] rockchip_clk_register_muxgrf: regmap not available [ 0.000000] rockchip_clk_register_branches: failed to register clock clk_32k_ioe: -524 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001295] Console: colour dummy device 80x25 [ 0.001976] console [tty0] enabled [ 0.002033] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 0.002071] pid_max: default: 32768 minimum: 301 [ 0.002251] Security Framework initialized [ 0.002284] AppArmor: AppArmor disabled by boot time parameter [ 0.002385] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.002430] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.004623] ASID allocator initialised with 32768 entries [ 0.004825] rcu: Hierarchical SRCU implementation. [ 0.009156] smp: Bringing up secondary CPUs ... [ 0.010792] Detected VIPT I-cache on CPU1 [ 0.010835] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.010883] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.012531] Detected VIPT I-cache on CPU2 [ 0.012562] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.012598] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.014249] Detected VIPT I-cache on CPU3 [ 0.014280] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.014313] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.014455] smp: Brought up 1 node, 4 CPUs [ 0.014620] SMP: Total of 4 processors activated. [ 0.014641] CPU features: detected: GIC system register CPU interface [ 0.014661] CPU features: detected: Privileged Access Never [ 0.014680] CPU features: detected: LSE atomic instructions [ 0.014699] CPU features: detected: User Access Override [ 0.014717] CPU features: detected: 32-bit EL0 Support [ 0.014736] CPU features: detected: RAS Extension Support [ 0.014923] CPU: All CPU(s) started at EL2 [ 0.014973] alternatives: patching kernel code [ 0.022199] devtmpfs: initialized [ 0.047755] Registered cp15_barrier emulation handler [ 0.047803] Registered setend emulation handler [ 0.048256] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 0.048308] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.049247] pinctrl core: initialized pinctrl subsystem [ 0.050446] NET: Registered protocol family 16 [ 0.051207] audit: initializing netlink subsys (disabled) [ 0.051513] audit: type=2000 audit(0.046:1): state=initialized audit_enabled=0 res=1 [ 0.055130] cpuidle: using governor menu [ 0.055194] Registered FIQ tty driver [ 0.055685] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.057092] DMA: preallocated 256 KiB pool for atomic allocations [ 0.091817] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio) [ 0.092596] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio) [ 0.093327] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio) [ 0.094043] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio) [ 0.094771] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio) [ 0.094979] rockchip-pinctrl pinctrl: probed pinctrl [ 0.112016] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.112298] cryptd: max_cpu_qlen set to 1000 [ 0.112982] fbcon: Taking over console [ 0.114105] reg-fixed-voltage vcc3v3-sys: Failed to register regulator: -517 [ 0.114266] vcc5v0_sys: supplied by vcc5v0_in [ 0.115075] vcc5v0_host: supplied by vcc5v0_sys [ 0.115761] vcc5v0_otg: supplied by vcc5v0_sys [ 0.117342] SCSI subsystem initialized [ 0.117688] usbcore: registered new interface driver usbfs [ 0.117778] usbcore: registered new interface driver hub [ 0.117863] usbcore: registered new device driver usb [ 0.118000] media: Linux media interface: v0.10 [ 0.118068] videodev: Linux video capture interface: v2.00 [ 0.118233] pps_core: LinuxPPS API ver. 1 registered [ 0.118257] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.118305] PTP clock support registered [ 0.118750] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 0.120704] Advanced Linux Sound Architecture Driver Initialized. [ 0.121420] Bluetooth: Core ver 2.22 [ 0.121550] NET: Registered protocol family 31 [ 0.121574] Bluetooth: HCI device and connection manager initialized [ 0.121607] Bluetooth: HCI socket layer initialized [ 0.121632] Bluetooth: L2CAP socket layer initialized [ 0.121689] Bluetooth: SCO socket layer initialized [ 0.126365] clocksource: Switched to clocksource arch_sys_counter [ 0.223492] thermal thermal_zone0: power_allocator: sustainable_power will be estimated [ 0.223729] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.224157] NET: Registered protocol family 2 [ 0.224462] IP idents hash table entries: 65536 (order: 7, 524288 bytes) [ 0.226875] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes) [ 0.227004] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 0.227294] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 0.228312] TCP: Hash tables configured (established 32768 bind 32768) [ 0.228569] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 0.228827] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 0.229284] NET: Registered protocol family 1 [ 0.230981] Trying to unpack rootfs image as initramfs... [ 0.801814] Freeing initrd memory: 9584K [ 0.803174] kvm [1]: 16-bit VMID [ 0.803216] kvm [1]: GICv3: no GICV resource entry [ 0.803237] kvm [1]: disabling GICv2 emulation [ 0.803255] kvm [1]: GIC system register CPU interface enabled [ 0.803471] kvm [1]: vgic interrupt IRQ1 [ 0.803687] kvm [1]: VHE mode initialized successfully [ 0.805901] Initialise system trusted keyrings [ 0.806175] workingset: timestamp_bits=45 max_order=20 bucket_order=0 [ 0.816143] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.816602] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 0.816913] fuse init (API version 7.27) [ 0.817537] SGI XFS with security attributes, no debug enabled [ 0.821502] NET: Registered protocol family 38 [ 0.821558] Key type asymmetric registered [ 0.821580] Asymmetric key parser 'x509' registered [ 0.821646] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.821868] io scheduler noop registered [ 0.821893] io scheduler deadline registered [ 0.822092] io scheduler cfq registered (default) [ 0.822118] io scheduler mq-deadline registered [ 0.822138] io scheduler kyber registered [ 0.824824] phy phy-fe8a0000.usb2phy.0: Linked as a consumer to regulator.4 [ 0.825212] phy phy-fe8a0000.usb2phy.1: Linked as a consumer to regulator.5 [ 0.827527] extcon extcon1: failed to create extcon usb2phy link [ 0.827733] phy phy-fe8b0000.usb2phy.2: Linked as a consumer to regulator.4 [ 0.827985] phy phy-fe8b0000.usb2phy.3: Linked as a consumer to regulator.4 [ 0.828162] phy phy-fe8b0000.usb2phy.3: No vbus specified for otg port [ 0.832207] naneng-combphy fe830000.phy: Failed to get clk 'refclk': -2 [ 0.834739] rockchip-pwm fdd70030.pwm: No active pinctrl state [ 0.840524] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.840567] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.843880] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.843920] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.845798] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.847030] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 33, base_baud = 1500000) is a 16550A [ 0.847986] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 34, base_baud = 1500000) is a 16550A [ 0.935159] console [ttyS2] enabled [ 0.942139] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop [ 0.943821] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi [ 0.949534] mali fde60000.gpu: Kernel DDK version g7p1-01bet0 [ 0.949561] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 0.950692] mali fde60000.gpu: Device initialization Deferred [ 0.951743] brd: module loaded [ 0.962151] loop: module loaded [ 0.963187] zram: Added device: zram0 [ 0.963689] lkdtm: No crash points registered, enable through debugfs [ 0.967137] register firefly_spi_init spi return v = :0 [ 0.967991] CAN device driver interface [ 0.970231] rk_gmac-dwmac fe010000.ethernet: phy regulator is not available yet, deferred probing [ 0.972239] usbcore: registered new interface driver rndis_wlan [ 0.972849] usbcore: registered new interface driver rtl8150 [ 0.973462] usbcore: registered new interface driver r8152 [ 0.974027] usbcore: registered new interface driver asix [ 0.974574] usbcore: registered new interface driver ax88179_178a [ 0.975179] usbcore: registered new interface driver cdc_ether [ 0.975759] usbcore: registered new interface driver rndis_host [ 0.976424] usbcore: registered new interface driver cdc_ncm [ 0.977000] usbcore: registered new interface driver qmi_wwan_q [ 0.977592] usbcore: registered new interface driver qmi_wwan [ 0.978169] usbcore: registered new interface driver cdc_mbim [ 0.979053] dwc3 fd000000.usb: Failed to get clk 'ref': -2 [ 0.979800] naneng-combphy fe830000.phy: No refclk found [ 0.980290] naneng-combphy fe830000.phy: failed to init phy for usb3 [ 0.981881] naneng-combphy fe830000.phy: wait phy status ready timeout [ 0.986892] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.987506] ehci-pci: EHCI PCI platform driver [ 0.987989] ehci-platform: EHCI generic platform driver [ 0.988759] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.989337] ohci-platform: OHCI generic platform driver [ 0.990796] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 0.991570] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 0.992873] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [ 0.993830] xhci-hcd xhci-hcd.0.auto: irq 10, io mem 0xfd000000 [ 0.994847] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 0.995602] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.996258] usb usb1: Product: xHCI Host Controller [ 0.996732] usb usb1: Manufacturer: Linux 4.19.232 xhci-hcd [ 0.997241] usb usb1: SerialNumber: xhci-hcd.0.auto [ 0.998379] hub 1-0:1.0: USB hub found [ 0.998785] hub 1-0:1.0: 1 port detected [ 0.999669] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.000442] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 1.001153] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 1.001863] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.002784] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 1.003567] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.004224] usb usb2: Product: xHCI Host Controller [ 1.004669] usb usb2: Manufacturer: Linux 4.19.232 xhci-hcd [ 1.005175] usb usb2: SerialNumber: xhci-hcd.0.auto [ 1.006261] hub 2-0:1.0: USB hub found [ 1.006686] hub 2-0:1.0: 1 port detected [ 1.007716] usbcore: registered new interface driver cdc_acm [ 1.008235] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.009017] usbcore: registered new interface driver cdc_wdm [ 1.009910] usbcore: registered new interface driver uas [ 1.010519] usbcore: registered new interface driver usb-storage [ 1.011189] usbcore: registered new interface driver usbserial_generic [ 1.011816] usbserial: USB Serial support registered for generic [ 1.012423] usbcore: registered new interface driver cp210x [ 1.012962] usbserial: USB Serial support registered for cp210x [ 1.013610] usbcore: registered new interface driver ftdi_sio [ 1.014164] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.014973] usbcore: registered new interface driver keyspan [ 1.015518] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 1.016252] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 1.016970] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 1.017662] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 1.018394] usbcore: registered new interface driver option [ 1.018938] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.019817] usbcore: registered new interface driver oti6858 [ 1.020366] usbserial: USB Serial support registered for oti6858 [ 1.020968] usbcore: registered new interface driver pl2303 [ 1.021506] usbserial: USB Serial support registered for pl2303 [ 1.022108] usbcore: registered new interface driver qcserial [ 1.022660] usbserial: USB Serial support registered for Qualcomm USB modem [ 1.023392] usbcore: registered new interface driver sierra [ 1.023943] usbserial: USB Serial support registered for Sierra USB modem [ 1.025632] usbcore: registered new interface driver usbtouchscreen [ 1.026244] ============ himax_hx83102_init 1742 jjlook ========== [ 1.026834] ============ himax_hx83102_probe 1725 jjlook ========== [ 1.027474] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0 [ 1.028239] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0 [ 1.029877] i2c /dev entries driver [ 1.034087] rk808 0-0020: chip id: 0x8090 [ 1.034537] rk808 0-0020: No cache defaults, reading back from HW [ 1.058928] rk808 0-0020: source: on=0x40, off=0x00 [ 1.059388] rk808 0-0020: support dcdc3 fb mode:-22, 63 [ 1.059912] rk808 0-0020: support pmic reset mode:0,0 [ 1.062222] rk808 0-0020: had get a pinctrl! [ 1.067391] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 1.067991] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 1.069061] rk808 0-0020: failed to register 0 regulator [ 1.069846] rk817-battery rk817-battery: Failed to find matching dt id [ 1.070663] rk817-charger rk817-charger: Failed to find matching dt id [ 1.074592] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0 [ 1.082087] rk808-rtc rk808-rtc: registered as rtc0 [ 1.084293] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:03 UTC (1501837203) [ 1.088408] usbcore: registered new interface driver uvcvideo [ 1.088938] USB Video Class driver (1.1.1) [ 1.093301] rockchip-thermal fe710000.tsadc: Missing tshut mode property, using default (gpio) [ 1.094096] rockchip-thermal fe710000.tsadc: Missing tshut-polarity property, using default (low) [ 1.094902] rockchip-thermal fe710000.tsadc: Missing trim_base property [ 1.095762] rockchip-thermal fe710000.tsadc: failed to find thermal gpio state [ 1.096473] rockchip-thermal fe710000.tsadc: failed to find thermal otpout state [ 1.097660] rockchip-thermal fe710000.tsadc: tsadc is probed successfully! [ 1.099574] Bluetooth: HCI UART driver ver 2.3 [ 1.100036] Bluetooth: HCI UART protocol H4 registered [ 1.100507] Bluetooth: HCI UART protocol ATH3K registered [ 1.101187] Bluetooth: HCI UART protocol Broadcom registered [ 1.101799] usbcore: registered new interface driver bfusb [ 1.102377] usbcore: registered new interface driver btusb [ 1.103125] cpu cpu0: Failed to get cpu_leakage [ 1.104835] sdhci: Secure Digital Host Controller Interface driver [ 1.105401] sdhci: Copyright(c) Pierre Ossman [ 1.105800] Synopsys Designware Multimedia Card Interface Driver [ 1.107564] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [ 1.108351] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [ 1.108962] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [ 1.109535] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 23,32 bit host data width,256 deep fifo [ 1.112011] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 1.112827] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 1.113489] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 1.114069] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo [ 1.115234] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.118061] hidraw: raw HID events driver (C) Jiri Kosina [ 1.119102] usbcore: registered new interface driver usbhid [ 1.119615] usbhid: USB HID core driver [ 1.122478] rockchip-saradc fe720000.saradc: failed to get regulator, -517 [ 1.123550] rksfc_base v1.1 2016-01-08 [ 1.124824] usbcore: registered new interface driver snd-usb-audio [ 1.127189] rk817_codec_parse_dt_property: rk809 have no io-channels defined [ 1.127848] invalid rk817->hp_det_gpio: -2 [ 1.128232] invalid gpio: -2 [ 1.128649] rk817-codec rk817-codec: Unable to get mclk [ 1.135321] NET: Registered protocol family 10 [ 1.137011] Segment Routing with IPv6 [ 1.137433] NET: Registered protocol family 17 [ 1.137854] can: controller area network core (rev 20170425 abi 9) [ 1.138606] NET: Registered protocol family 29 [ 1.139022] can: raw protocol (rev 20170425) [ 1.139418] can: broadcast manager protocol (rev 20170425 t) [ 1.139981] can: netlink gateway (rev 20170425) max_hops=1 [ 1.140820] Bluetooth: RFCOMM socket layer initialized [ 1.141326] Bluetooth: RFCOMM ver 1.11 [ 1.141684] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.142229] Bluetooth: HIDP socket layer initialized [ 1.142680] [BT_RFKILL]: Enter rfkill_rk_init [ 1.143116] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.144170] Key type dns_resolver registered [ 1.144890] flash vendor_init_thread! [ 1.145233] flash vendor storage:20170308 ret = -1 [ 1.147142] Loading compiled-in X.509 certificates [ 1.149012] rga2: Module initialized. [ 1.191019] pvtm list NULL [ 1.191648] vcc3v3_sys: supplied by vcc5v0_sys [ 1.194523] mali fde60000.gpu: Kernel DDK version g7p1-01bet0 [ 1.195200] mali fde60000.gpu: Device initialization Deferred [ 1.195742] rk_gmac-dwmac fe010000.ethernet: phy regulator is not available yet, deferred probing [ 1.197071] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 1.197662] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 1.198325] vdd_logic: supplied by vcc3v3_sys [ 1.199652] vdd_gpu: supplied by vcc3v3_sys [ 1.200549] vcc_ddr: supplied by vcc3v3_sys [ 1.201612] vdd_npu: supplied by vcc3v3_sys [ 1.202578] vcc_1v8: supplied by vcc3v3_sys [ 1.203427] vdda0v9_image: supplied by vcc3v3_sys [ 1.204654] vdda_0v9: supplied by vcc3v3_sys [ 1.205487] vdda0v9_pmu: supplied by vcc3v3_sys [ 1.206333] vccio_acodec: supplied by vcc3v3_sys [ 1.207610] vccio_sd: supplied by vcc3v3_sys [ 1.208451] vcc3v3_pmu: supplied by vcc3v3_sys [ 1.209658] vcca_1v8: supplied by vcc3v3_sys [ 1.210536] vcca1v8_pmu: supplied by vcc3v3_sys [ 1.211593] vcca1v8_image: supplied by vcc3v3_sys [ 1.212587] vcc_3v3: supplied by vcc3v3_sys [ 1.213789] vcc3v3_sd: supplied by vcc3v3_sys [ 1.215169] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.18 [ 1.215981] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu [ 1.216994] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu [ 1.217928] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.16 [ 1.218737] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec [ 1.219700] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.12 [ 1.220506] rockchip-iodomain fdc20000.syscon:io-domains: vccio2(1800000 uV) supplied by vcc_1v8 [ 1.221429] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.17 [ 1.222239] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd [ 1.223191] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8 [ 1.224099] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.22 [ 1.224908] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3 [ 1.225837] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8 [ 1.226794] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3 [ 1.229285] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [ 1.230188] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [ 1.230799] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [ 1.231357] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 23,32 bit host data width,256 deep fifo [ 1.232364] dwmmc_rockchip fe2b0000.mmc: Linked as a consumer to regulator.22 [ 1.233189] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO [ 1.246958] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 1.262216] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 1.262983] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 1.263659] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 1.264237] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo [ 1.265247] dwmmc_rockchip fe2c0000.mmc: Linked as a consumer to regulator.22 [ 1.266018] dwmmc_rockchip fe2c0000.mmc: Linked as a consumer to regulator.19 [ 1.266790] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq [ 1.267320] mmc_host mmc2: card is non-removable. [ 1.281046] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 1.295512] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.19 [ 1.300232] mali fde60000.gpu: Kernel DDK version g7p1-01bet0 [ 1.300987] mali fde60000.gpu: Linked as a consumer to regulator.9 [ 1.302101] rk_gmac-dwmac fe010000.ethernet: Linked as a consumer to regulator.22 [ 1.302792] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 1.303491] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4e). [ 1.303507] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19 [ 1.304013] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2c). [ 1.304855] mali fde60000.gpu: Failed to get gpu_leakage [ 1.305311] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 1.306541] mali fde60000.gpu: avs=0 [ 1.306871] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 1.307121] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 1.307436] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(). [ 1.308277] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 1.309656] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0 [ 1.309956] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 1.310720] mali fde60000.gpu: No priority control manager is configured [ 1.311059] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 1.311666] mali fde60000.gpu: No memory group manager is configured [ 1.312335] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 1.313611] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 1.314254] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 1.314690] mali fde60000.gpu: Couldn't find power_model DT node matching 'arm,mali-simple-power-model' [ 1.314895] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 1.315698] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0] [ 1.316190] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 1.317359] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0] [ 1.317810] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 1.318941] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0] [ 1.319287] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) [ 1.320237] mali fde60000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = '' [ 1.324637] mali fde60000.gpu: Using configured power model mali-g52_r1-power-model, and fallback mali-simple-power-model [ 1.326910] mali fde60000.gpu: Probed as mali0 [ 1.462854] rockchip-vop2 fe040000.vop: ignoring dependency for device, assuming no driver [ 1.464022] devfreq fde60000.gpu: Couldn't update frequency transition information. [ 1.464120] rockchip-drm display-subsystem: devfreq is not set [ 1.465365] rockchip-drm display-subsystem: master bind failed: -12 [ 1.465981] rockchip-vop2: probe of fe040000.vop failed with error -12 [ 1.467652] register spi return v = :0 [ 1.468005] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8) [ 1.468775] ======== dhd_wlan_init_plat_data ======== [ 1.469235] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.469770] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized [ 1.469775] dhd_wlan_init_gpio: unknown oob irqflags ! [ 1.469780] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=-1, oob_irq_flags=0x410 [ 1.469783] dhd_wlan_init_gpio: WL_REG_ON=-1 [ 1.469792] dhd_wifi_platform_load: Enter [ 1.471104] Power-up adapter 'DHD generic adapter' [ 1.472992] wifi_platform_set_power = 1, delay: 200 msec [ 1.473508] ======== PULL WL_REG_ON(-1) HIGH! ======== [ 1.473977] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.474405] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized [ 1.779741] wifi_platform_bus_enumerate device present 1 [ 1.780231] ======== Card detection to detect SDIO card! ======== [ 1.780783] sdio: host isn't initialization successfully. [ 3.896394] failed to power up DHD generic adapter, 0 retry left [ 3.913046] wifi_platform_set_power = 0, delay: 0 msec [ 3.913520] ======== PULL WL_REG_ON(-1) LOW! ======== [ 3.913979] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 3.914407] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized [ 3.915203] wifi_platform_bus_enumerate device present 0 [ 3.915684] ======== Card detection to remove SDIO card! ======== [ 3.916232] sdio: host isn't initialization successfully. [ 3.916749] failed to power up DHD generic adapter, max retry reached** [ 3.917352] unregister wifi platform drivers [ 3.917743] wifi_platform_bus_enumerate device present 0 [ 3.918223] ======== Card detection to remove SDIO card! ======== [ 3.918770] sdio: host isn't initialization successfully. [ 3.919267] ======== dhd_wlan_deinit_plat_data ======== [ 3.919766] dhd_module_init: Failed to load the driver, try cnt 0 [ 3.920374] dhd_module_init: Failed to load driver max retry reached** [ 3.920966] dhd_module_init: Exit err=-19 [ 3.921696] ==gsl_ts_init== [ 3.922029] ret=0 [ 3.924009] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 3.932714] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 3.933517] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 3.934302] cfg80211: failed to load regulatory.db [ 3.936806] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 413; [Func] : mali_module_init(); svn_rev_. [ 3.938952] Mali: [ 3.938954] Mali device driver loaded [ 4.236400] vendor storage:20190527 ret = -1 Looks like something is wrong with dtb -
I own the 8GB and 4GB boxes But when I finished the first step of flashing update.img, I was unable to enter the loader. I tried flashing back linaro and re-doing the first step, but I got the same result -
After I finished writing to root, the ttl prompt was as follows. I don’t know what the problem is boot mode: recovery (misc) No resource partition No resource partition Failed to load DTB, ret=-19 No find valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 io-domain: OK Failed to get scmi clk dev dmc_fsp failed, ret=-19 Model: Rockchip RK3568 Evaluation Board rockchip_set_serialno: could not find efuse/otp device CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 528000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 24000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 50000 KHz aclk_top_high 300000 KHz aclk_top_low 200000 KHz hclk_top 150000 KHz pclk_top 50000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 ANDROID: reboot reason: "recovery" optee api revision: 2.0 TEEC: Waring: Could not find security partition Not AVB images, AVB skip No valid android hdr Android image load failed Android boot failed, error -1. ## Booting FIT Image FIT: No fit blob FIT: No FIT image ## Booting Rockchip Format Image Could not find kernel partition, ret=-1 Card did not respond to voltage select! mmc_init: -95, time 9 switch to partitions #0, OK mmc0(part 0) is current device Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** ## Error: "mtd_boot" not defined ## Error: "mtd_boot" not defined ## Error: "mtd_boot" not defined starting USB... Bus dwc3@fcc00000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3@fd000000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device No ethernet found. missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rockchip No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm No ethernet found. missing environment variable: bootfile Retrieving file: pxelinux.cfg/default No ethernet found. Config file not found No ethernet found.
