argulp argulp
  1. Hello, it seems the problem was located in the converter usb -< sata used in one drive.. after unplug the drive on other machine it was ok and now it's ok. for my rockpi board so we can close this topic Thanks you
  2. Hello, after some troubleshooting, this boot issue occur only if I have my two ssd drive plugged. If I unplug this one, the kernel is booting, this issue is not occuring with older kernel 6.6.32 By the way, since the system is booted, if I plug the drives, the system panic so I will revert to 6.6.32 kernel. but I have loose my 6.6.32 headers, and I can't compil again the zfs module, anyone know how i can download the last 6.6.32 headers for rockpi ? Rgds
  3. Hello Each time I try to upgrade to kernel 6.6.39 on a rockpi-4a the system become unbootable: ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f01f6000, end f1f0Ad94 ... OK Loading Device Tree tn 00000000f0179000, end 0000 000f01f5fff ... OK Starting kernel ... efi_free_pool: illegal free 0x00000000f0f0d04 efi_free_pool: hllegal free 0x00000000f0f0a040 I have another rockpi-4a but with a rockpi4b image (installed by mistake) I was able to copy the file 6.6.32 from this system to my other one (creating the older symlink on /boot) , and I have be able to boot card successfully so I have try to upgrade this other rockpi-4a (running a rockpi-4b image) and upgrade has been a success. So I have trying again on the first rockpi... and error appear again, it's related only to kernel image of 4a or the related dtb file It's not urgent, because I can revert the install, if you need something let me know Thanks for your jobs !!!
  4. Hello, so we agree... latest kernel is affecting USB port Someone from Armbian works on the issue, or maybe I need to contact Radxa or Linus Torvals ? I don't complain, and your work is fabulous but I need to fix this issue soon Thank you
  5. Hello I have two Rockpi A (without wireless) since I have upgraded to latest kernel: 6.1.50-current-rockchip64 One of the two USB3 port is not working, the top one (from usb-devices and lsusb I don't see any special difference) it seems USB2 port are ok same issue on two rockpi cards, I have try many usb devices (storage, network etc...) without success I am alone with this issue ? armbianmonitor send to http://ix.io/4IE9 Rgds
  6. Hello, same issue for me but for a Rockpi 4 A (without BT Wifi chip) it seems issue begin with kernel upgrade to 6.1.50-current-rockchip64 just one usb3 port is working (the above one) here an output of armbianmonitor -u https://paste.armbian.com/avisobelaq Thanks for your help
