chuckles67
4 -
I've seen this 'initramfs' thing before and, whilst I don't know, I usually blame the microSD card being corrupted somehow. You are using m2 SATA - so may be different problem
... when I run `dmesg -w` and then plug USB hub or USB BT/WiFI dongle into the blue colored USB3.0 ports the dmesg does not update.
My USB3.0 ports (blue colored) on OrangePi 5 are not supplying any power - tested with Anker USB hub and with Realtek BT/Wifi dongle (both work on the USB2.0 port (white colored). Everything looks fine in the dmesg log, so I'm thinking this hardware issue between the controller and the physical sockets.: [ 3.612366] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree [ 3.612369] vcc5v0_usbdcin: supplied by vcc12v_dcin [ 3.612386] vcc5v0_usbdcin: 5000 mV, enabled [ 3.612442] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV [ 3.612483] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree [ 3.612486] vcc5v0_usb: supplied by vcc5v0_usbdcin [ 3.612490] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT [ 3.612508] vcc5v0_usb: 5000 mV, enabled [ 3.612561] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV [ 3.612711] vbus5v0_typec: supplied by vcc5v0_usb [ 3.674938] usbcore: registered new interface driver usbfs [ 3.674955] usbcore: registered new interface driver hub [ 3.674968] usbcore: registered new device driver usb [ 4.482624] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree [ 4.482632] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.482675] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree [ 4.482681] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed [ 4.483974] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree [ 4.483982] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed [ 4.485089] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree [ 4.485096] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed [ 5.159667] usbcore: registered new interface driver rndis_wlan [ 5.159843] usbcore: registered new interface driver asix [ 5.159880] usbcore: registered new interface driver cdc_ether [ 5.159917] usbcore: registered new interface driver rndis_host [ 5.159972] usbcore: registered new interface driver cdc_ncm [ 5.167053] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree [ 5.167108] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed [ 5.173919] ehci-platform fc800000.usb: EHCI Host Controller [ 5.173946] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1 [ 5.174099] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000 [ 5.185349] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 5.185634] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.185645] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.185652] usb usb1: Product: EHCI Host Controller [ 5.185660] usb usb1: Manufacturer: Linux 5.10.160-rockchip ehci_hcd [ 5.185667] usb usb1: SerialNumber: fc800000.usb [ 5.189217] ehci-platform fc880000.usb: EHCI Host Controller [ 5.189242] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2 [ 5.189361] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000 [ 5.202019] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 5.202264] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.202274] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.202282] usb usb2: Product: EHCI Host Controller [ 5.202289] usb usb2: Manufacturer: Linux 5.10.160-rockchip ehci_hcd [ 5.202296] usb usb2: SerialNumber: fc880000.usb [ 5.204233] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 5.204257] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3 [ 5.204361] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000 [ 5.262893] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.262903] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.262911] usb usb3: Product: Generic Platform OHCI controller [ 5.262918] usb usb3: Manufacturer: Linux 5.10.160-rockchip ohci_hcd [ 5.262925] usb usb3: SerialNumber: fc840000.usb [ 5.264157] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 5.264177] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 5.264281] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000 [ 5.322899] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 5.322909] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.322917] usb usb4: Product: Generic Platform OHCI controller [ 5.322924] usb usb4: Manufacturer: Linux 5.10.160-rockchip ohci_hcd [ 5.322931] usb usb4: SerialNumber: fc8c0000.usb [ 5.325536] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 5.325546] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.325553] usb usb5: Product: xHCI Host Controller [ 5.325561] usb usb5: Manufacturer: Linux 5.10.160-rockchip xhci-hcd [ 5.325568] usb usb5: SerialNumber: xhci-hcd.7.auto [ 5.326646] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.326812] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 5.326822] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.326829] usb usb6: Product: xHCI Host Controller [ 5.326836] usb usb6: Manufacturer: Linux 5.10.160-rockchip xhci-hcd [ 5.326843] usb usb6: SerialNumber: xhci-hcd.7.auto [ 5.327939] usbcore: registered new interface driver cdc_acm [ 5.328155] usbcore: registered new interface driver uas [ 5.328305] usbcore: registered new interface driver usb-storage [ 5.330000] usbcore: registered new interface driver usbtouchscreen [ 5.505827] typec_fusb302 6-0022: Looking up vbus-supply from device tree [ 5.694438] usbcore: registered new interface driver uvcvideo [ 5.759866] usbcore: registered new interface driver usbhid [ 5.759870] usbhid: USB HID core driver [ 5.766752] usbcore: registered new interface driver snd-usb-audio
I have same problem - but with an OrangePi 5 board (not Plus) - the two blue colored USB ports are not working. I tried OrangePi's Ubuntu OS and that didn't fix the issue. Wondering if my board has hardware fault
