sagt3k
  1. Hi, I need help to configure PINs of Orange PI One Plus with H6. I'm using official distribution Ubuntu 16.04. I view in /sys/class/gpio_sw only: PD6 PL4 PL7 normal_led standby_led but I need PC9 and others pins. Can You help me ? Thanks Antonio
  2. Hi to everybody When is there a first version of the armbian / debian for H6, Orange PIus H6? I'm already using the official linux version for several weeks, processor always at 1800Mhz with fan on and stable, about 42/45°C. In my opinion, an excellent board as a server or a computational system. Thanks sagt3k
  3. Hi lomady, I'm a newbie on this subject. I would be interested bringing the core freq to 1GHz or more. Could you explain how to do it? An example of how to handle DVFS? Thanks Antonio
  4. Hi to everyone, I'm using "Armbian_5.38_Orangepizeroplus_Debian_stretch_next_4.14.14" on a Orange Pi Zero Plus H5 I'd like to test this new board by working with processor overclocking. But it seems to me that it is leased at 816Mhz maximum. Can someone tell me how to take it to 1200Mhz or more? Thanks Antonio
  5. Hi gnash I read that in the first 1 or 2 minutes after the boot is very difficult to set the number of processors and frequency. Then in /etc/rc.local call a script and let the sleep for 2min after start the commands. It seems to work. Thanks If someone has a more elegant way to solve the problem is .... welcome !! #!/bin/bash sleep 120 echo 0 > /sys/devices/system/cpu/cpu3/online #disable CPU3 echo 0 > /sys/devices/system/cpu/cpu2/online #disable CPU2 echo 480000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq #set max frequency at 480MHz exit 0 Now after the reboot I have 65°c. My CPU has a heat sink compatible raspberry. In attached file You can see, immediately after booting I stress CPU with "stress -c 4". After 2 minutes start the script that set max 2CPU e max 480Mhz.
  6. Hi to everybody I'm using jessie legacy 3.4.x on NanoPi NEO. I need help... I need to set max 2 cores at startup and max 600MHz. How to do? Thanks Sagt3k
  7. Thanks for your fast reply. I can wait for the neo NanoPI. However I am using the most stable versions also on a OrangePI one. I need a stable version on NanoPI neo. I take this opportunity to also make a note of this problem: root@nanopineo:/sys/class/leds# ls orangepi:green:pwr orangepi:red:status On NanoPi NEO on /sys/class/leds there is' something of orange and NanoPI Neo has green and blue leds. Don't worry great job !! Thanks
  8. Hi I'm newbie Congratulations for ARMBIAN. Then ... I have a NanoPI NEO 512mb, and I have installed on uSD a image of "Armbian_5.17_Nanopineo_Debian_jessie_4.6.7" OK, after the boot I insert a wifi-dongle RTL8192cu, but i don't see nothing .. root@nanopineo:~# lsusb Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub What I'm wrong? Thanks sagt3k
