Pietro Mezzaroba
  1. ok sorry, we didn't understand each other, dietpi is based on armbian, I thought it was clear, I installed armbian on my board so maybe I will be taken into consideration, obviously by not paying I don't expect anything but I just want it to be taken into consideration I also remember that it hasn't worked for almost two months dietpi@192.168.1.35's password: ____ _ ____ __ _ _ | _ \ ___ ___| | _| _ \ _ __ ___ / /_ | || | | |_) / _ \ / __| |/ / |_) | '__/ _ \ | '_ \| || |_ | _ < (_) | (__| <| __/| | | (_) | | (_) |__ _| |_| \_\___/ \___|_|\_\_| |_| \___/ \___/ |_| Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64 System load: 2% Up time: 3 min Memory usage: 4% of 3.77G IP: 192.168.1.35 CPU temp: 40°C Usage of /: 6% of 29G Last login: Mon Oct 23 13:28:30 2023 from 192.168.1.12 dietpi@rockpro64:~$ dmesg -l 0,1,2,3 [ 2.461314] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 2.554637] dw-apb-uart ff180000.serial: Failed to create device link (0x180) with 0-001b [ 2.706293] dw-apb-uart ff180000.serial: Failed to create device link (0x180) with vcc3v3-sys [ 2.931269] phy phy-ff7c0000.phy.6: phy poweron failed --> -110 [ 2.931404] dwc3 fe800000.usb: error -ETIMEDOUT: failed to initialize core [ 2.967139] dw-apb-uart ff180000.serial: Failed to create device link (0x180) with 0-001b [ 4.127677] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [ 6.092866] (sd-execut[344]: /usr/lib/systemd/system-generators/netplan failed with exit status 1. [ 11.237351] Bluetooth: hci0: command 0x0c03 tx timeout [ 19.429381] Bluetooth: hci0: BCM: Reset failed (-110) dietpi@rockpro64:~$ uname -a Linux rockpro64 6.1.50-current-rockchip64 #3 SMP PREEMPT Wed Aug 30 14:11:13 UTC 2023 aarch64 GNU/Linux dietpi@rockpro64:~$ the problem at hand is this : dwc3 fe800000.usb: error -ETIMEDOUT: failed to initialize core here you can find more information about the tests https://dietpi.com/forum/t/rk3399-hdmi-output-and-usb-3-0-not-working-with-linux-6-1/17776/43 Thx for your time
  2. Hi, sorry, it's absurd that this thread isn't being taken into consideration, we're talking about thousands of rock devices no longer having USB 3.0 working....give us importance thanks @admin@Werner@Igor root@DietPi:~# uname -a Linux DietPi 6.1.53-current-rockchip64 #1 SMP PREEMPT Wed Sep 13 07:43:05 UTC 2023 aarch64 GNU/Linux Pietro
