Hi folks,
I had an old install of armbian which worked. I wanted a new install to start fresh all over.
My problem is that i don't het any HDMI signal form the board.
What i've done so far:
- Downloaded ISO from armbian (nanopim4 with DE)
- flashed iso to sd 8GB SD card
- ssh to the board and did the first install
- with `armbian-install` installed to 32GB emmc
- enabled RDP for remote access but i was not able to get this to work either -.-'
System:
_ _ ____ _ __ __ _ _
| \ | | _ \(_) | \/ | || |
| \| | |_) | | | |\/| | || |_
| |\ | __/| | | | | |__ _|
|_| \_|_| |_| |_| |_| |_|
Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64
No end-user support: community creations
System load: 2% Up time: 4 min
Memory usage: 6% of 3.77G IP: 192.168.0.102
CPU temp: 33°C Usage of /: 28% of 29G
RX today: 4.3 GiB
Board starts with no issue, ssh works perfectly but i dont have any HDMI output.
this is the `armbianmonitor - u` output: https://paste.armbian.com/akovewakud
If you need log from the old installation i can provide the logs also.
Thanks for your help!
