xaja34
14 -
To follow up: I have 4 orange pi 3b boards - 3 version 1.1 and one version 2.1. The 6.12.1-edge-rockchip64 kernel didn't work on the 1.1 boards but worked on the 2.1 board Vendoe 6.1.75 worked on both.
Thanks Werner. 6.10.11-edge-rockchip64 worked fine. I guess there is no way to go back to this version. Unfortunately I didn't save an image. Bll
I've flashed the Armbian-unofficial_24.8.0 - trunk sweet potato bookwork current 6.6.44 to EMMC and it boots fine to EMMC. However when I insert a SD card, it still boots from EMMC. I've added "boot_targets=mmc1 mmc0" to Armbianext.txt with no luck Can anyone help? Thsnks
Werner Looks like it's just trixie. built an image with Bookworm (bookworm_edge_6.8.7_minimal) and works with no issues so far Bill
After first boot and initial setup and login, I can enable and start the openssh server with no problem. I'm not sure how generating a set of new keys would help. This happens with numerous images. Armbian_24.5.0-trunk.429_Orangepi5-plus_trixie_edge_6.8.6_minimal.img Armbian_24.5.0-trunk.429_Orangepi5-plus_trixie_vendor_6.1.43_minimal.img Among others. Legacy image with 5.10.160 kernel does not have this problem Regards Bill
Here is the partial boot log Starting ssh.service - OpenBSD Secure Shell server... sshd: no hostkeys available -- exiting. ssh.service: Control process exited, code=exited, status=1/FAILURE ssh.service: Failed with result 'exit-code'. Failed to start ssh.service - OpenBSD Secure Shell server. ssh.service: Scheduled restart job, restart counter is at 1. Starting ssh.service - OpenBSD Secure Shell server... sshd: no hostkeys available -- exiting. Not sure what to do as keys have not been generated yet. Thanks, Bill
Orange Pi 5 plus. It seems that in the 'edge' kernels, ssh is disabled by default. Since HDMI doesn't function this is a problem. I used the debugging UART and after setup I got the message "ssh.service is disabled" I enabled the service and all is well. Any reason why ssh would be disabled?
When I boot any variant with kernel 6..x.x from SD there is no problem with hdmi. When I flash the same variant to the nvme, it boots fine but there is no hdmi output. The orange pi logo appears for a second, then nothing. I can ssh in and everthing works fine. Any variant with 5.x.x kernel works fine from the nvme, with hdmi output. What I don't understand is that if I have output to hdmi when booting from sd, why not from nvme. What I think is relevent entries in the boot log is below. mmu fe043e00.iommu: Enable stall request timed out, status: 0x00030b Jan 30 09:38:22 orangepi3b kernel: rk_iommu fe043e00.iommu: Enable stall request timed out, status: 0x00001d Jan 30 09:38:22 orangepi3b kernel: rk_iommu fe043e00.iommu: Page fault at 0x00000000ee086d40 of type read Jan 30 09:38:22 orangepi3b kernel: rk_iommu fe043e00.iommu: iova = 0x00000000ee086d40: dte_index: 0x3b8 pte_index: 0x86> Jan 30 09:38:22 orangepi3b kernel: rk_iommu fe043e00.iommu: mmu_dte_addr: 0x00000001f4ffa000 dte@0x00000001f4ffaee0: 0x> Jan 30 09:38:22 orangepi3b kernel: rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 Jan 30 09:38:22 orangepi3b kernel: rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 Jan 30 09:38:22 orangepi3b kernel: rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 Jan 30 09:38:22 orangepi3b kernel: rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 Jan 30 09:38:22 orangepi3b kernel: rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at Thanks
Thanks Werner !!
Do the minimal versions of the distributions still support HDMI ? Specifically orange pi 3b kernel 6.7.2 Thanks
Thanks Werner, wiil do.
Armbian trixie 24.2.0-trunk.272 - kernel 6.7.0-rc7 Connecting over ssh. When I shutdown the pi (sudo poweroff) it disconnects the ssh session but does not shut down completely. Network and heartbeat leds still flashing. Works fine with the legacy kernel 5.10 What am I missing? thanks
