Flops
22 -
Anyway, as it turns out I didn't have "local access" enabled in the access point settings. LOL
When scanning the network via arp-scan it still writes (Unknown: locally administered).
Is there anything else I need to check?
And yes, that log I sent you is without the cable connected.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 2a:77:33:98:ba:5a brd ff:ff:ff:ff:ff:ff inet 192.168.0.108/24 brd 192.168.0.255 scope global dynamic noprefixroute end1 valid_lft 7145sec preferred_lft 7145sec inet6 fe80::8a87:d850:159c:a59e/64 scope link noprefixroute valid_lft forever preferred_lft forever This is what the ip a gave me when I plugged in the cable.
When I connected to cable and uart it was able to update and download packages. I will try to copy the log again today. And I'll also check ifconfig
Here are the notes after the command log
Could you tell me how to conveniently transfer logs to a text file, because the terminal floats when scrolling?
I tried rebooting the router. Nothing changed in the end. The router does not respond to ping, but the board works properly via uart. Please help
It can work via uart, sshd works and yet it does not respond to a ping or ssh connection. At the same time it can connect to the internet and download packets by itself.
The system boots from the sd card and correctly. sshd is also active. Strange...
No, it was just me being stupid and mixing up the wires.
Saw this in the logs: INFOx4000001 != 0xfead0003 ERROR: INFO: BL31: Initializing Excervices WARNING: No OPTEE providon. SMC`s destined for OPTEE wil (eMMC) Maybe it means something?
I bought a uart and connected it as indicated in the video. The text is already readable, but sometimes it underwrites and moves away. What should I do next? Modified: it does not output correctly what I enter. Is there any way to improve it?
I bought it. I'll wait a month
