Good evening,
i have a box which was running a Android TV variant as I bought it, but I missed to much features for my planed Kodi box. So I setup your image - thank you for your work - and basically it works quite nice. The Box is as follows:
RUPA Android TV Box, 4K TV Box 11.0 RAM 8GB ROM 64GB RK3318 Quad-Core CPU WiFi 2.4/5.8Ghz BT4.0 3D 4K 1080P10/100M Ethernet HD2.0 Smart TV Box
Spezifikationen
Betriebssystem: Android 11.0
Chipsatz: RK3318 Quad-Core 64bit Cortex-A53
GPU: Penta-Core Mali-450
FLASH: EMMC 64 GB
RAM: DDR 4 GB
USB: 1 x USB 3.0, 1 x USB 2.0
LAN: Ethernet 10/100M Standard-RJ-45
Kabellos: 2,4 G / 5 G Dualband-WLAN 802.11 a/b/g/n
Bluetooth: 4.1
Kartenleser: Micro-SD-Karten, maximale Unterstützung 64G
DisplayPort: HDMI (HDMI 2.0a für 4k@60Hz)
Betriebsanzeige (LED): Eingeschaltet: blau; Standby: Rot
Stromversorgung: EINGANG: 100-240 V 50/60 HZ AUSGANG: DC 5 V/2,5 A
AV: Unterstützung
My main problem is, that Mesa does not find a 1920x1080 mode for the FullHD Monitor connected to the box HDMI
2023-12-01 12:24:32.501 T:1770 info <general>: RetroPlayer[RENDER]: Registering renderer factory for DMA
2023-12-01 12:24:32.501 T:1770 info <general>: RetroPlayer[RENDER]: Registering renderer factory for OpenGL
2023-12-01 12:24:32.746 T:1770 info <general>: CDRMUtils::FindConnector - using connector: HDMI-A-1
2023-12-01 12:24:32.992 T:1770 info <general>: Skipped 1 duplicate messages..
2023-12-01 12:24:32.992 T:1770 info <general>: CDRMUtils::FindEncoder - using encoder: 41
2023-12-01 12:24:32.993 T:1770 info <general>: CDRMUtils::FindPlanes - using crtc: 37
2023-12-01 12:24:37.038 T:1770 info <general>: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2023-12-01 12:24:37.039 T:1770 info <general>: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2023-12-01 12:24:37.039 T:1770 info <general>: Found resolution 800x600 with 800x600 @ 56.000000 Hz
2023-12-01 12:24:37.039 T:1770 info <general>: Found resolution 848x480 with 848x480 @ 60.000000 Hz
2023-12-01 12:24:37.039 T:1770 info <general>: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2023-12-01 12:24:37.045 T:1770 info <general>: EGL_VERSION = 1.4
2023-12-01 12:24:37.045 T:1770 info <general>: EGL_VENDOR = Mesa Project
2023-12-01 12:24:37.105 T:1770 warning <general>: Your OpenGL drivers do not support OpenGL 3.2 core profile. Kodi will run in compatibility mode, but performance may suffer.
2023-12-01 12:24:37.128 T:1770 info <general>: Checking resolution 16
2023-12-01 12:24:37.166 T:1770 info <general>: CRenderSystemGL::InitRenderSystem - Version: 2.1 Mesa 22.3.6, Major: 2, Minor: 1
2023-12-01 12:24:37.167 T:1770 info <general>: GL_VENDOR = lima
2023-12-01 12:24:37.167 T:1770 info <general>: GL_RENDERER = Mali450
2023-12-01 12:24:37.167 T:1770 info <general>: GL_VERSION = 2.1 Mesa 22.3.6
2023-12-01 12:24:37.167 T:1770 info <general>: GL_SHADING_LANGUAGE_VERSION = 1.20
I tried lot of things I found in the forum, but always ended up with 1024x768. Setting:
extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin video=HDMI-A-1:1920x1080@60
into /boot/armbianEnv.txt ends up in a black screen but system runs and ssh works. I have enabled auto login on tty and start kodi --standalone from .profile. Even there are a few other problems, like needing another kodi-inputstream-adaptive package, because 64 bit needs 20.3.5 ++ the resolution is my main problem. If finished the box will be connected to a 55" tv set where it was already running with Kodi.
Any hint tho get the resolution fixed would be greatly appreciated.
Edit: I added https://paste.armbian.com/emagamaxiw
Edit2: I already moved to nigthly for testing
