octal8
  1. Is there an overlay or any other way of getting the Orange Pi 5 Plus to work with a 1024x600 display?
  2. Installed: Armbian_23.11.1_Orangepi5-plus_bookworm_edge_6.7.0-rc1 The analog device is visible, but there's no sound from the headphone jack. The hdmi device is not visible. aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Analog [Analog], device 0: fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0] Subdevices: 1/1 Subdevice #0: subdevice #0 There is no sound when I play a test file: aplay -D hw:0,0 /usr/share/sounds/alsa/Noise.wav Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono aplay: set_params:1358: Channels count non available I've looked in the journal log but nothing stands out to me. Sound doesn't appear to be muted, I added amixer output below. What do I do next? amixer output: Simple mixer control 'PCM',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 192 Front Left: 192 [100%] [0.00dB] Front Right: 192 [100%] [0.00dB] Simple mixer control 'Mic PGA',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 8 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] Simple mixer control 'Capture Digital',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 192 Front Left: 0 [0%] [-96.00dB] Front Right: 0 [0%] [-96.00dB] Simple mixer control 'Capture Polarity',0 Capabilities: enum Items: 'Normal' 'L Invert' 'R Invert' 'L + R Invert' Item0: 'Normal' Simple mixer control 'Capture ZC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Deemphasis',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Differential Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' Item0: 'Line 1' Simple mixer control 'Left Line Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'PGA' 'Differential' Item0: 'Line 1' Simple mixer control 'Left Mixer',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Mixer Left Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 0 [0%] [-15.00dB] Playback [off] Simple mixer control 'Left Mixer Right',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Mixer Right Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 2 [29%] [-9.00dB] Playback [off] Simple mixer control 'Left PGA Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'Line 3' 'Differential' Item0: 'Line 1' Simple mixer control 'Output 1',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 36 Mono: Front Left: Playback 0 [0%] [-30.00dB] Front Right: Playback 0 [0%] [-30.00dB] Simple mixer control 'Output 2',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 36 Mono: Front Left: Playback 0 [0%] [-30.00dB] Front Right: Playback 0 [0%] [-30.00dB] Simple mixer control 'Right Line Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'PGA' 'Differential' Item0: 'Line 1' Simple mixer control 'Right Mixer',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Mixer Left',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Mixer Left Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 2 [29%] [-9.00dB] Playback [off] Simple mixer control 'Right Mixer Right Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 0 [0%] [-15.00dB] Playback [off] Simple mixer control 'Right PGA Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'Line 3' 'Differential' Item0: 'Line 1' Simple mixer control 'Route',0 Capabilities: enum Items: 'Stereo' 'Mono (Left)' 'Mono (Right)' 'Digital Mono' Item0: 'Stereo'
  3. My apologies to all, especially Efe. I missed the obvious. I need some sleep.
  4. Since I want to use an official Armbian image, I would say that the problem isn't solved until they make one available that works.
  5. On the Armbian website, all three OP5 hardware versions are lumped together on the same page. There are two images available on the page, the cli version that I'm using, and a Gnome version. https://www.armbian.com/orangepi-5/ There is also a link for older versions, but since the OPI5+ is new, something tells me they would not be better. What am I missing?
  6. Sorry, I thought I posted that info: Armbian_23.11.1_Orangepi5_bookworm_legacy_5.10.160.img
  7. Update: -Still no USB3 - Still no Ethernet - Parted doesn't recognize the nvme M.2 card installed. - Installing the OS to the emmc chip remains a mystery. - No sound
  8. On the Armbian website, they only have one image that combines all three hardware versions Orange Pi 5 / 5B / 5 Plus. https://www.armbian.com/orangepi-5/
  9. NicoD, has this situation improved since then?
  10. I switched to the official Orange Pi installation and it works fine. So it's not a hardware issue. Since an Orange Pi 5 worked fine in the same setup, I was suspecting that and am glad because I didn't want to return it. Based on the symptoms, it seems like a driver/configuration issue. The problem is I don't want to use the official Orange Pi installation since it is run by Huawei with servers in China. For one, I'd much rather use an organization run by volunteers (Armbian) than one run by a corporation. Also, with the way things are going between the USA and China, who knows what may happen in the future with respect to sanctions, etc... Marco, I tried your suggestion and it didn't work. Still no USB3 and Ethernet. Werner, I'm going to try your suggestion next to see if it narrows down what I need to do to make Armbian work.
  11. New OPI5+, unable to finish install because ethernet doesn't work. I haven't been able to figure it out and my searches turned up nothing. journalctl has the following messages: - hpptx phy lane locked! - rk_gmac-dwmac fe1c0000.ethernet error: no phy at addr -1 - stmmac_open: cannot attach to phy (error -19) I've checked power supply, cables, edited the interfaces file, and more , with no success. I have an Orange Pi 5 that I can swap as is in its place and everything works. Coupled with the fact that I couldn't find mention of the errors, I'm hoping that someone can help me before I give up and return the OPI5+.
