12 -
i find it is very convenient now, not only able to choose boot from nvme or sata ssd. but can also install the image from armbian-config. last time im installing armbian i need to dd the image manualy into nvme. very nice work for armbian team
so today im finally reinstall my opi5, and when choose mtd to flash i got two option, i guess the sata version is if im using sata ssd instead of nvme ssd?
ok, i guess i just dd new image then. have you read github release a few minutes ago? orangepi5: bump u-boot to v2026.04-rc3
how about armbian 26.2.1 but still using vendor kernel? did we still have this problem?
oops when I restart - works fine if I shut down and cold boot.
xsetiadi replied to jondowd's topic in Orange Pi 5
how do you solve this man? im also have this issue using v25.11.2 for Orange Pi 5 running Armbian Linux 6.1.115-vendor-rk35xx im using official power adapter. so i guess nothing wrong with my power. can we fix this without reinstalling the entire os? i have several running container and services. -
@Anderson Castro i try. with docker container. but you need to change a little bit. since the docker run cli command on official use net=host I cannot access the jellyfin. so I just delete that line and add this line and work fine for me: -e JELLYFIN_PublishedServerUrl=192.168.0.55 `#optional` \ -p 8096:8096 \ -p 8920:8920 `#optional` \ -p 7359:7359/udp `#optional` \ -p 1900:1900/udp `#optional` \
hai, im planning to upgrade my local media server to use an external hard drive attached using hard drive docking on USB 3.0 what I'm confused about is. what is the best FileSystem format for my hard drive? I'm not planning to unmount and use the hard drive to another PC (for example: windows PC) So I'm ready to format it with FileSystem that fully optimizes on Linux (I'm using armbian noble) so ext4 or xfs? I hear xfs is better for copying large file sizes. my casual use is downloading movies, and watching it on jellyfin. or maybe I'm just using ext4?
in case someone still not know. jellyfin now support official RK3588/3588S HWA. here the official steps https://jellyfin.org/docs/general/administration/hardware-acceleration/rockchip/
why not try jellyfin. im mean jellyfin is free and support hw acceleration for orange pi5 now.
@leeson just have time to try now. but on web browser and jellyfin media client the play method is direct playing. not transcode. is it allright? from what i feel. now i can play HEVC video on web browser. on my old jellyfin this won't happen.
so we use jellyfin server from github, and jellyfin desktop client from docker right? @leeson i will try when my setup complete. currently waiting for custom desk.
does this version of jellyfin able to play h265 smoothly? @leeson because jjm2473/jellyfin-mpp build is having hard time to play h265. and also what transcoding method you use
