This is the output of my board:
DDR version 1.16 20190528
In
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
ddrconfig:14
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 248
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15216MB
FwPartOffset=2000 , 0
StorageInit ok = 24008
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x337a9f0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xb3690
RunBL31 0x40000
01INFO: Preloader serial: 2
NOTICE: BL31: v1.3(debug):403e0b816
NOTICE: BL31: Built : 14:13:08, Aug 11 2020
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2022.07-armbian (Jan 13 2024 - 14:06:57 +0000)
Model: FriendlyElec NanoPi R2S
DRAM: 1022 MiB
PMIC: RK8050 (on=0x40, off=0x01)
Core: 231 devices, 23 uclasses, devicetree: separate
MMC: mmc@ff500000: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
Net: eth0: ethernet@ff540000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
3548 bytes read in 8 ms (432.6 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1:1
176 bytes read in 7 ms (24.4 KiB/s)
196677074 bytes read in 8585 ms (21.8 MiB/s)
35713536 bytes read in 1561 ms (21.8 MiB/s)
64562 bytes read in 16 ms (3.8 MiB/s)
2698 bytes read in 13 ms (202.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Unknown command 'kaslrseed' - try 'help'
Moving Image from 0x2080000 to 0x2200000, end=44b0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 196677010 Bytes = 187.6 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... Bad Data CRC
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
1b7 1b[r 1b[999;999H 1b[6n 1b8No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
MMC Device 0 not found
no mmc device at slot 0
starting USB...
Bus usb@ff5c0000: ehci_generic usb@ff5c0000: Failed to get clocks (ret=-19)
Port not available.
Bus usb@ff5d0000: USB OHCI 1.0
Bus usb@ff580000: USB DWC2
scanning bus usb@ff5d0000 for devices... 1 USB Device(s) found
scanning bus usb@ff580000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@ff540000
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-22-19-a0-37-f6-ff
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-rk3328-evb_rk3328
Config file not found
