2) Lime A10 image with kernel 3.4.108 and HW accelerated MATE desktop
It starts boot, but it hangs. Output from serial console is below:
U-Boot SPL 2015.04-dirty (Jul 14 2015 - 19:32:48)
DRAM: 512 MiB
CPU: 912000000Hz, AXI/AHB/APB: 3/2/2
U-Boot 2015.04-dirty (Jul 14 2015 - 19:32:48) Allwinner Technology
CPU: Allwinner A10 (SUN4I)
I2C: ready
DRAM: 512 MiB
MMC: SUNXI SD/MMC: 0
*** Warning - bad CRC, using default environment
HDMI connected: EDID: invalid EDID data
Setting up a 1024x768 dvi console
Error: no valid bmp image at 66000000
In: serial
Out: vga
Err: vga
SCSI: SUNXI SCSI INIT
SATA link 0 timeout.
AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net: emac
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... cannot reset port 1!?
1 USB Device(s) found
USB1: USB EHCI 1.00
scanning bus 1 for devices... cannot reset port 1!?
scanning usb for storage devices... 0 Storage Device(s) found
Hit any key to stop autoboot: 0
6944 bytes read in 192 ms (35.2 KiB/s)
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
1548 bytes read in 181 ms (7.8 KiB/s)
## Executing script at 43100000
** File not found /boot/.next **
43508 bytes read in 458 ms (91.8 KiB/s)
5605360 bytes read in 657 ms (8.1 MiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x5587f0 ]
Starting kernel ...
<6>Booting Linux on physical CPU 0
<6>Initializing cgroup subsys cpuset
<5>Linux version 3.4.108-lime (root@kitchen) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #14 SMP PREEMPT Sun Jul 12 16:43:47 CEST 2015
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: sun4i
<6>Memory Reserved:
<6> SYS : 0x43000000 - 0x4300ffff ( 64 kB)
<6> LCD : 0x44000000 - 0x44ffffff ( 16 MB)
Memory policy: ECC disabled, Data cache writeback
<6>sunxi: Allwinner A10 revision C (AW1623/sun4i) detected.
<7>On node 0 totalpages: 131072
<7>free_area_init_node: node 0, pgdat c0a7bb40, node_mem_map d0000000
<7> DMA zone: 512 pages used for memmap
<7> DMA zone: 0 pages reserved
<7> DMA zone: 65024 pages, LIFO batch:15
<7> Normal zone: 512 pages used for memmap
<7> Normal zone: 65024 pages, LIFO batch:15
<6>PERCPU: Embedded 8 pages/cpu @d0405000 s8256 r8192 d16320 u32768
<7>pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096<c>
<7>pcpu-alloc: <c>[0] <c>0 <c>
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
<5>Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1
<6>PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>allocated 1048576 bytes of page_cgroup
<6>please try 'cgroup_disable=memory' option if you don't want memory cgroups
<6>Memory: 512MB = 512MB total
<5>Memory: 489616k/489616k available, 34672k reserved, 0K highmem
<5>Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc09d1b00 (10023 kB)
.init : 0xc09d2000 - 0xc0a0b040 ( 229 kB)
.data : 0xc0a0c000 - 0xc0a842b8 ( 481 kB)
.bss : 0xc0a842dc - 0xc0c596b8 (1877 kB)
<6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
<6>Preemptible hierarchical RCU implementation.
<6> RCU dyntick-idle grace-period acceleration is enabled.
<6> Additional per-CPU info printed with stalls.
<6>NR_IRQS:192
<6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<6>Console: colour dummy device 80x30
<6>console [tty1] enabled
<6>Calibrating delay loop...
And A10 CPU was very hot.
And to you previous question: no, I don't check kernel 3.4.x before.
