nexusguy59
1 Follower
  1. @Trinom I know this post is really old but I have to chime in on this. The instructions that @Igor gave you says to use Armbian to boot the device with then use the commands given to install Armbian. Raspbian is not Armbian. Just sayin' Just trying to figure out what or where you were reading.
  2. Hey Guys, I know this post is old but I have some questions. I was following @Jaybyrd's instructions and I have a question pertaining to the Plugin USB-C to the power on the device "I am assuming that is on The OPi5 device." Am I supposed to plug in something else? Because it says to open a terminal "what terminal? On what device?" Thank you for your time, Michael
  3. Hello Shad, I happen to have an Orange Pi 5 Plus as well and I thought I bricked it also but I was able to revive it. I have a couple of questions. 1 - Do you have an eMMC in yours? 2 - Are you trying to boot to SD Card, NVMe, or to the eMMC itself? Let me know and I have something I will post for you to try. Thanks, nexusguy59
  4. Has this issue been solved?
  5. I am not sure if you have fixed the problem with your raid. But here is a way to recover a raid using mdadm: https://recoverit.wondershare.com/harddrive-recovery/linux-raid-recovery.html I had to do this once and it worked flawlessly for me. Let me know if it helps. nexusguy59
