I built armbian using the branch 23.11 with legacy-kernel 5.10.160 for use as a Nextcloud server.
Version: Armbian-unofficial 23.11.0-trunk Bullseye \l . 5.10.160-legacy-rk35xx
After running sudo apt upgrade there were a few packages which were being upgraded successfully from 23.11.0-trunk to 23.11.1.
Unfortunately the package armbian-bsp-cli-orangepi5-plus-legacy cannot be upgraded to 23.11.1 due to the base-files still being on 23.11.0-trunk. The system is running fine though.
$ sudo apt update && sudo apt list --upgradable
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
Hit:5 http://security.debian.org bullseye-security InRelease
Hit:6 https://packages.sury.org/php bullseye InRelease
Hit:1 http://mirrors.dotsrc.org/armbian-apt bullseye InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
Listing... Done
armbian-bsp-cli-orangepi5-plus-legacy/bullseye 23.11.1 arm64 [upgradable from: 23.11.0-trunk]
$ sudo apt install --only-upgrade armbian-bsp-cli-orangepi5-plus-legacy
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
armbian-bsp-cli-orangepi5-plus-legacy : Depends: base-files (>= 23.11.1) but 23.11.0-trunk-11.1+deb11u8-bullseye is to be installed
E: Unable to correct problems, you have held broken packages.
$ apt-cache policy base-files
base-files:
Installed: 23.11.0-trunk-11.1+deb11u8-bullseye
Candidate: 23.11.0-trunk-11.1+deb11u8-bullseye
Version table:
*** 23.11.0-trunk-11.1+deb11u8-bullseye 100
100 /var/lib/dpkg/status
23.8.1-bullseye 500
500 http://apt.armbian.com bullseye/main arm64 Packages
11.1+deb11u9 500
500 http://deb.debian.org/debian bullseye/main arm64 Packages
How do I fix this issue?
Is there a safe way to upgrade the base-files to 23.11.1? I cannot rebuild the system!
Any help is appreciated:)
