Norbert Kett
9 -
install bookworm 6.6.63 on x96q pro+ h728
Norbert Kett replied to hamidreza h's topic in Allwinner CPU Boxes
i also want to know it -
GPU driver installation problem on Rock5B (Armbian Bookworm Minimal)
Norbert Kett replied to Norbert Kett's topic in Rockchip
@fraz0815 - thanks, i read this news on https://linuxgizmos.com/ -
@amazingfate This is it!!! You solved my root problem Thank you! I modified the EGL code, and now with device #1 works well. root@ubuntu:~/egl_example# ./egl_example dev1 Explicit device selection: 1 Loaded EGL 1.4 after reload. GL_VENDOR=Panfrost GL_RENDERER=Mali-G610 (Panfrost) GL_VERSION=3.3 (Compatibility Profile) Mesa 23.0.0-devel GL_SHADING_LANGUAGE_VERSION=3.30 root@ubuntu:~/egl_example# ./egl_example dev1 es2 Explicit device selection: 1 Loaded EGL 1.4 after reload. GL_VENDOR=Panfrost GL_RENDERER=Mali-G610 (Panfrost) GL_VERSION=OpenGL ES 3.1 Mesa 23.0.0-devel GL_SHADING_LANGUAGE_VERSION=OpenGL ES GLSL ES 3.10 -
@amazingfate and is there any solution? i don't need the npu at all. -
@amazingfate Thank for your responses I tried the latest Radxa ubuntu server build (kernel 5.x) , and successfully installed mali g610 drivers. with glxinfo i see everything ok. but.... when im trying to create an opengl context for headless rendering, i getting a very strange error. rknpu_dri.so is missing. this is my initial problem, that is why i gave a try with Armbian. rknpu_dri.so issue (github) do you have any clue, which package contains this driver? so far no one could figure it out. -
@amazingfate Thank you, i'm sorry about my clumsiness... finally i could install the mali g610 firmware, but now 'startx' can't start: X.Org X Server 1.21.1.7 X Protocol Version 11, Revision 0 Current Operating System: Linux rock-5b 6.8.0-rc1-edge-rockchip-rk3588 #1 SMP PREEMPT Sun Jan 21 22:11:32 UTC 2024 aarch64 Kernel command line: root=UUID=fb37e203-0f28-4a83-8200-4d1b92192ca3 rootwait rootfstype=ext4 splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=dbfff1e9-1afa-704c-8661-c1a273d2de36 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 xorg-server 2:21.1.7-3+deb12u5 (https://www.debian.org/support) Current version of pixman: 0.42.2 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 2 15:45:43 2024 (==) Using config directory: "/etc/X11/xorg.conf.d" (==) Using system config directory "/usr/share/X11/xorg.conf.d" free(): double free detected in tcache 2 (EE) (EE) Backtrace: (EE) 0: /usr/lib/xorg/Xorg (OsLookupColor+0x188) [0xaaaae1ffb7e8] (EE) unw_get_proc_info failed: no unwind info found [-10] (EE) (EE) Fatal server error: (EE) Caught signal 6 (Aborted). Server aborting (EE) (EE) Please consult the The X.Org Foundation support at http://wiki.x.org for help. (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. (EE) (EE) Server terminated with error (1). Closing log file. i gave up at this point 😕 -
@amazingfate i followed the guide, but getting this: root@rock-5b:~# apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Ign:4 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./ InRelease Hit:5 http://deb.debian.org/debian bookworm-backports InRelease Err:6 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./ Release 404 Not Found [IP: 195.135.223.221 443] Hit:7 http://fi.mirror.armbian.de/beta bookworm InRelease Reading package lists... Done E: The repository 'https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./ Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. my sources.list: root@rock-5b:~# cat /etc/apt/sources.list deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware # deb-src http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware # deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware deb http://deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware # deb-src http://deb.debian.org/debian bookworm-backports main contrib non-free non-free-firmware deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware # deb-src http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware deb [signed-by=/etc/apt/keyrings/obs-home-amazingfate.gpg] https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa ./ -
@amazingfate thanks, meanwhile i realized, bookworm is debian can you help me how to i add that linked repo? log: root@rock-5b:~# add-apt-repository https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa Repository: 'deb https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm main' Description: Archive for codename: bookworm components: main More info: https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa Adding repository. Press [ENTER] to continue or Ctrl-c to cancel. Adding deb entry to /etc/apt/sources.list.d/archive_uri-https_build_opensuse_org_project_show_home_amazingfate_panfork-mesa-bookworm.list Adding disabled deb-src entry to /etc/apt/sources.list.d/archive_uri-https_build_opensuse_org_project_show_home_amazingfate_panfork-mesa-bookworm.list Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Ign:5 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm InRelease Err:6 https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm Release 404 Not Found [IP: 195.135.223.221 443] Hit:7 http://fi.mirror.armbian.de/beta bookworm InRelease Reading package lists... Done E: The repository 'https://build.opensuse.org/project/show/home:amazingfate:panfork-mesa bookworm Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. -
Hello, I would like to install Mali-G610 drivers on my Rock5B, but getting error during adding PPA: root@rock-5b:~# add-apt-repository ppa:liujianfeng1994/panfork-mesa PPA publishes dbgsym, you may need to include 'main/debug' component Repository: 'deb https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu/ bookworm main' Description: https://gitlab.com/panfork/mesa You need to install mali-g610-firmware if you don't have file /lib/firmware/mali_csffw.bin More info: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/panfork-mesa Adding repository. Press [ENTER] to continue or Ctrl-c to cancel. Adding deb entry to /etc/apt/sources.list.d/liujianfeng1994-ubuntu-panfork-mesa-bookworm.list Adding disabled deb-src entry to /etc/apt/sources.list.d/liujianfeng1994-ubuntu-panfork-mesa-bookworm.list Adding key to /etc/apt/trusted.gpg.d/liujianfeng1994-ubuntu-panfork-mesa.gpg with fingerprint 0B2F0747E3BD546820A639B68065BE1FC67AABDE Hit:1 http://security.debian.org bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Ign:6 https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm InRelease Err:7 https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release 404 Not Found [IP: 185.125.190.80 443] Hit:5 http://fi.mirror.armbian.de/beta bookworm InRelease Reading package lists... Done E: The repository 'https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. I had to install python3-launchpadlib to get add-apt-repository work, which is not documented, i found it in the forums. HW: Rock5B (boot from: eMMC 32GB) OS: Armbian Bookworm Minimal (Feb 29, 2024) Followed the guide here: https://www.armbian.com/rock-5b/ How to fix this error?
