Vincenzoernst1
29 -
Vincenzoernst1 replied to Hqnicolas's topic in Rockchip CPU Boxes
@Hqnicolas would it be possible to have the driver @guenter pointed out in the base image? -
@fevangelou nice guide. THX! but maybe it would be best to have the instruction in an separate topic! in best case it gets also pinned. so new users can find it much easier than scrolling though 18 pages (in this thread. there is also the 4gb thread) to find it...... -
@paradigman not to be unfair against OVPN but its very slow (high cpu load) and hard to configure/maintain ( i developed the opvn plugin in ddwrt for some years). you will be better off with Wireguard on this box (i bet it can push linespeed of the gig port). -
@tnt i also didnt get the the sd slot running. i soldered 3 NEW slots and none of them worked. since i ordered a 10 pack from china i didnt mind to dump them after unsoldering. i always got a dmesg error (logs somewhere above). there are 2 errors possible: bad china quality slots there is something on the board missing. also i dont think there was somthing wrong with the soldering since im an enineer and solder on daily basis. btw. i uses a hot air gun for solderding, therefor it i also should be working. if there are now 2 of us having problems i might thingk its no problem on my side.....
chip seems to be have driver support already. discussed here what says ip a? -
this unit has 8GiB of RAM so dont be greedy. you can share 512MiB or more of RAM 😉 -
Efforts to develop firmware for X96 X6 RK3566 (8G/64G)
Vincenzoernst1 replied to loi xin's topic in Rockchip CPU Boxes
do you have any pics of the pcb?! also this seems to be be similar to the h96-max-v56-rk3566 which also has a 8GB RAM version -
@Hqnicolas update -
@Hqnicolas seems to work ok! root@h96-max-v56-rk3566:~# uname -a Linux h96-max-v56-rk3566 6.11.2-edge-rockchip64 #1 SMP PREEMPT Fri Oct 4 14:38:57 UTC 2024 aarch64 GNU/Linux root@h96-max-v56-rk3566:~# ls -l /boot/dtb/rockchip/rk3566-h96-tvbox.dtb -rw-r--r-- 1 root root 114994 Oct 5 19:34 /boot/dtb/rockchip/rk3566-h96-tvbox.dtb root@h96-max-v56-rk3566:~# -
@Hqnicolas Last login: Tue Sep 17 14:41:52 2024 from 192.168.40.112 root@h96-max-v56-rk3566:~# uname -a Linux h96-max-v56-rk3566 6.10.10-edge-rockchip64 #1 SMP PREEMPT Thu Sep 12 09:13:13 UTC 2024 aarch64 GNU/Linux im running edge kernel without problems on existing dtb..... -
he! i also have no interest in fixing this, since my todo list is full of important real life problems to fix. so i literally already have work for years in my free time. so someone else should step in. -
so it should be fixed with our PR in 24.8.0-trunk.596, right? -
btw i personally never shorted any pins ever on my box. for me ALWAYS worked: while powercyle push an hold the reset button for 10 sec or so. then the bootloader comes up. maybe its not in mask rom mode then you have to switch to it via rockchip dev tool -
@xuandat09 i dont use windoze systems so I am not helpfull with the windows version of the devtools. on linux there is a command to switch boot modes.
