Protx
7 -
@darcyg What i meant was that you manually apply the uw5622-fix-adjust-for-rockchip-post-6.1.patch before ./compile command. Then after compilation check that : --> (15) INFO: * patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch is included in the log file. BTW: Do not mind the * applying patch/misc/wireless-uwe5622/w-wireless-fix-out-of-tree-build.patch That was a patch I saw was included in the ubuntu rockchip kernel. I do not think that is needed, does not seem to make a difference.
@darcyg First let me say that I am no expert on this. I have not tried to compile it lately, but I see that that commit does not longer exist on kwiboo's github. So I don't now if you need to revert to an older version of u-boot. And if you have an EmmC og SPI with u-boot, then it should work to boot from SC card with the new uboot anyway. My log was with debug enabled (and from uart), and I dont have that log anymore. mtty_probe+0x1e8/0x2b0 [sprdbt_tty] So I am not sure the error is the same wireless / bluetooth related error that I got . But I think it is. Make sure that the patch uw5622-fix-adjust-for-rockchip-post-6.1.patch got applied. Take a look in the /output/logs, If you have build the kernel several times it could be using a cached kernel and not included in the log!?, (look in the largest log files). And verify that uw5622-fix-adjust-for-rockchip-post-6.1.patch was included in your compilation: --> (15) INFO: Adding [ Drivers for Unisoc uwe5622 found on some Allwinner and Rockchip boards ] --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-allwinner.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-allwinner-bugfix.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-warnings.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-park-link-v6.1-post.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/uwe5622-v6.1.patch --> (15) INFO: * patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/wireless-uwe5622-Fix-compilation-with-6.7-kernel.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/wireless-uwe5622-reduce-system-load.patch --> (15) INFO: * applying patch/misc/wireless-uwe5622/w-wireless-fix-out-of-tree-build.patch --> (15) INFO: Preparing driver [ driver_rtl8723cs ]
@vbk Ok. I have been testing several different images. I got some progress, I now got the bookworm-minimal-vendor-kernel to boot. Link to my post @Ruslan Ilin Compiled with xunlong orangepis 6.6 kernel dts sources. I dont know if it works. 2 orangepi3b images
I now have the Armbian-unofficial_24.5.0-trunk_Orangepi3b_bookworm_vendor_6.1.43_minimal image booting on my orangpi3b. This is an unsupported board, and the images is built from trunk and bleeding edge, so I guess it is expected to have some issues. Anyway I post my findings in case other have the same problem. Iper3 works without any retries. So next is to install OMV7 and see the file transfer speed. orangepi@orangepi3b:~$ iperf3 -c 192.168.10.10 -f M Connecting to host 192.168.10.10, port 5201 [ 5] local 192.168.10.227 port 41766 connected to 192.168.10.10 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 114 MBytes 114 MBytes/sec 0 407 KBytes [ 5] 1.00-2.00 sec 112 MBytes 112 MBytes/sec 0 407 KBytes [ 5] 2.00-3.00 sec 113 MBytes 113 MBytes/sec 0 428 KBytes [ 5] 3.00-4.00 sec 112 MBytes 112 MBytes/sec 0 428 KBytes [ 5] 4.00-5.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 5.00-6.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 6.00-7.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 7.00-8.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 8.00-9.00 sec 112 MBytes 112 MBytes/sec 0 451 KBytes [ 5] 9.00-10.00 sec 113 MBytes 113 MBytes/sec 0 451 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.10 GBytes 112 MBytes/sec 0 sender [ 5] 0.00-10.04 sec 1.10 GBytes 112 MBytes/sec receiver iperf Done. I did not know that the bootloader/u-boot on the SPI and EMMC could have impact on booting of SD card, because all images with edge kernel booted just fine from SD card. I have an EMMC with armbian-bookworm-edge-minimal installed, and have flashed the SPI with the u-boot version installed on the EMMC. Error when trying to boot a vendor image from SD card: [ 9.413438] rockchip-pm-domain fdd90000.power-management:power-controller: failed to get ack on domain 'npu', target_idle = 0, target_ack = 0, val=0x6 [ 9.413543] Kernel panic - not syncing: panic_on_set_idle set ... Then I tried other images, armbian with legacy kernel and ubuntu24.04beta-6.1 kernel. Both with the same error. I then flashed the ubuntu's u-boot on the SPI and removed the EMMC. Then the both images booted. But the armbian-bookworm-vendor-mininal still would not boot. But this time it stopped with another error: [ 23.575850] mtty_probe init device addr: 0x000000004f52d231 [ 23.576178] -->rfkill_bluetooth_init [ 23.576456] <--rfkill_bluetooth_init [ 23.577060] sysfs: cannot create duplicate filename '/devices/virtual/tty/ttyBT0' [ 23.577107] CPU: 1 PID: 381 Comm: systemd-modules Not tainted 6.1.43-vendor-rk35xx #1 [ 23.577127] Hardware name: Rockchip RK3566 OPi 3B (DT) [ 23.577141] Call trace: [ 23.577153] dump_backtrace+0xe4/0x108 Next I erased the SPI, and with no EMMC the only bootloader on the SBC was on the SD card. Then the armbian-bookworm-vendor-mininal image stopped with the first kernel panic again: [ 9.413438] rockchip-pm-domain fdd90000.power-management:power-controller: failed to get ack on domain 'npu', target_idle = 0, target_ack = 0, val=0x6 [ 9.413543] Kernel panic - not syncing: panic_on_set_idle set ... So I made changes and reverted to an older version of uboot: BOOTBRANCH="commit:63073b4af636146d26a7f0f258610eed060c8f34" # specific commit, from "branch:rk3568-2023.10" BOOTDIR="u-boot-${BOARD}" # do not share u-boot directory BOOTPATCHDIR="v2023.10-orangepi3b" # empty, patches are already in Kwiboo's branch:rk3568-2023.10 revert-u-boot-orangepi3b.patch Again booting from SD card I got the "duplicate filename" bluetooth error again. So after scratching my head and poking around I noticed that not all the UW5622 patches was applied?: # Apply patches that adjust the driver only for rockchip platforms if [[ "$LINUXFAMILY" == rockchip* ]]; then if linux-version compare "${version}" le 6.1; then process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-pre-6.1.patch" else process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch" fi fi Since the vendor kernel is defined as "$LINUXFAMILY" == rk35xx ? this part of the patch does not get applied. And since the vendor kernel is 6.1.43, it should use the post version of the patch?, aka the "le" won't work.? I changed the script to: # Apply patches that adjust the driver only for rockchip platforms if [[ "$LINUXFAMILY" == rockchip* || "$LINUXFAMILY" == "rk35xx" ]]; then if linux-version compare "${version}" ge 6.1; then process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-post-6.1.patch" else process_patch_file "${SRC}/patch/misc/wireless-uwe5622/uwe5622-adjust-for-rockchip-pre-6.1.patch" fi uw5622-fix-adjust-for-rockchip-post-6.1.patch Compiled, now it boots from SD and seems to work just fine.
@vbk Can you verify that this image works on your orangepi3b?
@vbk My English is not the best. It seems like you can boot Armbian_community_24.5.0-trunk.250_Orangepi3b_bookworm_vendor_6.1.43_minimal.img.xz ? I made a post that I can't boot my homebuilt bookworm minimal with the vendor kernel. I was curious it my home built image was bad. So I downloaded the above mentioned image and burned it to a sd card, and I got exactly the same kernel panic!. (Kernel panic - not syncing: panic_on_set_idle set). Then I thought that it maybe was an issue with the u-boot I have flashed to spi. (I got another image on emmc) So I erased the spi, and booted from sd card again, it booted further, but got another kernel panic: sysfs: cannot create duplicate filename '/devices/virtual/tty/ttyBT0' and kobject_add_internal failed for ttyBT0 with -EEXIST, don't try to register things with the same name in the same directory. I have no idea what it is, but seems like Bluetooth is registering twice. If you can boot the vendor kernel image that my Orangepi3b board has some issues Or my powersupply(s). But the edge kernel images boots fine. Regards the hardware options/overlays, I do not think is built any overlays with the image and/or the overlay name is wrong. Check the overlay_prefix= in /boot/armbianEnv.txt. The overlay prefix name must match with the first name (before the -)of your overlays in: /boot/dtb/rockchip/overlay/ If your overlays has name like this: rk356x-i2c2-m1.dtbo. Then your overlay_prefix should be: overlay_prefix=rk356x But maybe it is none for the orangepi3b. What I did was downloading a xunlong orangepi3b image to an sd card, or you can loop mount it. Then copy out the overlays, use filezilla and sftp it over to your orangepi3b, place them in your overlay folder and edit armbianEnv.txt to the right overlay name. I have red that it should not work if it was not compiled with the kernel, but I use one overlay and it works. My overlays
Hi. I testing out different images for my DIY NAS project. My plan is to use the Orangepi3b board with armbian bookworm and OMV. I have built images from armbian github, (main,trunk) the edge 6.7.10 kernel is working great. But I do get some Iperf3 retries when sending from Opi3b. From Opi3b 60-70MB/s To Opi3b 110MB/s. With Orangepi own bookworm image I have 110/110 and no retries. The same with Joshua Riek's Ubuntu server image, no retries and 110/110. Orangepi3b armbian with 6.7.10 kernel orangepi@orangepi3b:~$ iperf3 -c 192.168.10.197 -f M Connecting to host 192.168.10.197, port 5201 [ 5] local 192.168.10.155 port 56514 connected to 192.168.10.197 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 74.5 MBytes 74.5 MBytes/sec 217 19.8 KBytes [ 5] 1.00-2.00 sec 75.9 MBytes 75.9 MBytes/sec 218 11.3 KBytes [ 5] 2.00-3.00 sec 79.1 MBytes 79.1 MBytes/sec 200 25.5 KBytes [ 5] 3.00-4.00 sec 73.3 MBytes 73.3 MBytes/sec 225 29.7 KBytes [ 5] 4.00-5.00 sec 79.1 MBytes 79.1 MBytes/sec 210 33.9 KBytes [ 5] 5.00-6.00 sec 77.8 MBytes 77.8 MBytes/sec 211 86.3 KBytes [ 5] 6.00-7.00 sec 77.4 MBytes 77.4 MBytes/sec 202 36.8 KBytes [ 5] 7.00-8.00 sec 76.1 MBytes 76.1 MBytes/sec 207 73.5 KBytes [ 5] 8.00-9.00 sec 75.0 MBytes 75.0 MBytes/sec 222 12.7 KBytes [ 5] 9.00-10.00 sec 73.3 MBytes 73.3 MBytes/sec 239 11.3 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 761 MBytes 76.1 MBytes/sec 2151 sender [ 5] 0.00-10.04 sec 760 MBytes 75.7 MBytes/sec receiver Orangepi3b Ubuntu with 6.1 kernel ubuntu@ubuntu:~$ iperf3 -R -c 192.168.10.197 -f M Connecting to host 192.168.10.197, port 5201 Reverse mode, remote host 192.168.10.197 is sending [ 5] local 192.168.10.154 port 42888 connected to 192.168.10.197 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 112 MBytes 112 MBytes/sec [ 5] 1.00-2.00 sec 112 MBytes 112 MBytes/sec [ 5] 2.00-3.00 sec 112 MBytes 112 MBytes/sec [ 5] 3.00-4.00 sec 112 MBytes 112 MBytes/sec [ 5] 4.00-5.00 sec 112 MBytes 112 MBytes/sec [ 5] 5.00-6.00 sec 112 MBytes 112 MBytes/sec [ 5] 6.00-7.00 sec 112 MBytes 112 MBytes/sec [ 5] 7.00-8.00 sec 112 MBytes 112 MBytes/sec [ 5] 8.00-9.00 sec 112 MBytes 112 MBytes/sec [ 5] 9.00-10.00 sec 112 MBytes 112 MBytes/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.04 sec 1.10 GBytes 112 MBytes/sec 1 sender [ 5] 0.00-10.00 sec 1.10 GBytes 112 MBytes/sec receiver So to see if the vendor kernel was different I built with the new 6.1.43-vendor-rk35xx kernel, but It will not boot. build command: ./compile.sh build BOARD=orangepi3b BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=bookworm J=4 It seems to be something with power to the NPU. ? "rockchip-pm-domain fdd90000.power-management:power-controller: failed to get ack on domain 'npu', target_idle = 0, target_ack = 0, val=0x6" uart log attachment kernelpanic.log
