12 -
Efforts to develop firmware for H96 MAX M9 RK3576 TV Box 8G/128G
gen ha replied to Hqnicolas's topic in Rockchip CPU Boxes
In China, this 8+128GB only costs less than $75 -
@ Hqnicolas The network card is still unable to receive data, and the reason is unclear. In the past, connecting the network port was a simple task, but now it seems very difficult😂 [ 25.313329] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 25.318206] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [Generic PHY] (irq=POLL) [ 25.321898] dwmac4: Master AXI performs any burst length [ 25.324480] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found [ 25.327033] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported [ 25.329956] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock [ 25.333601] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rmii link mode
Can anyone tell me how to repair the Ethernet port? The error log is as follows: [ 26.619270] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 26.621884] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed [ 26.624545] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Hw setup failed [ 26.769290] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 26.774068] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [Generic PHY] (irq=POLL) [ 26.777878] dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state [ 26.780446] dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state [ 26.784638] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [ 26.788899] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [ 26.791572] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [ 26.796881] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo [ 26.880900] platform mtd_vendor_storage: deferred probe pending [ 26.881880] dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state [ 26.886026] dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state [ 26.888690] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [ 26.891380] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [ 26.893932] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [ 26.896371] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo [ 27.776978] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 27.779377] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed [ 27.781771] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Hw setup failed
CPU : RK3566 / Mali-G52 GPU RAM : 2GB/4GB LPDDR4 ROM : eMMC 16G/32G/64G Bluetooth : BT 5.0 DC In : DC 5V/2A USB Host : 2 High speed USB 2.0, 1 USB 3.0 Card Reader : TF Card reader Lan : RJ45 Ethernet port 1GiB Wifi : Built-in Wifi, 802.1.1b/g/n/ac ; 2.4G/5G SPDIF : Coaxial(Optical) DTB: rk3566-slzn.dtb
@Hqnicolas Could you please test the DTS that originally supported NPU? HDMI and WIFI are not working. Thank you. rk3566-h96max-npu.dts -
vendor_6.1.43_minimal,directly using the one you modified can run WIFI normally, but I need to run NPU, so I modified it according to your DTB, but WIFI cannot run. Take a look at DTS, what's wrong? rk3566-h96max-npu.dts -
I found that using your DTB can run WiFi, but I referred to your DTS to modify my NPU supported DTB. WiFi is not working properly. Can you help me check where the error is? rk3566-h96max-npu.dts -
Efforts to develop firmware for H96 MAX V56 RK3566 4G/32G
I seem to have noticed the problem. I have two boxes, one old and one new. The old one can set the CPU frequency normally, but the new one does not work. No firmware works, and the desktop firmware for station M2 has become invalid. The picture shows that the hardware sizes of EMMC are different. I think hardware changes are the root cause. The error message is shown in the figure. -
Why can't the CPU frequency be adjusted in the armbian-config settings? -
Tanix TX66 RK3566 4GB/32GB 8K 2.4/5WIFI 1GiB BT USB2/3 SD IR SPDIF
gen ha replied to realcam's topic in Rockchip CPU Boxes
I used this method to test the DTB of this box, but in the end, it could only be partially started. Modifying the DTS requires professional expertise
