22 -
Stuck on jammy, can't upgrade to noble
Domas replied to Domas's topic in Software, Applications, Userspace
Okay I gave up on it and done a fresh install.. Took me 5 hours to get it back up and running, to reconfig x11vnc and samba stuff. Starting a freshly baked image proved to be a nightmare - for whoever is interested I share my story; For some reason it did not detect wireless dongle for keyboard. So I could see it over hdmi but no input was possible. Did not have a wired keyboard at hand. at first run it did not became accessible over ssh. but an ip address was assigned to it by dhcp router; I could see a new ip when I'd start it up. but it would not respond to ssh requests. But serial connection saved the day. Luckily I did have a serial adapter. Created username/password and then it was accessible over ssh and I could ditch the crappy tv screen I was using Selected wrong locale on setup, was unable to get rid of it without commenting wrong locale lines in ~/.bashrc Then I spent some few hours to get vnc up and running with lightdm and crapload of other dependencies, packages. Thanks AI for assistance. When asking quality questions and sharing messages/outputs it was super useful (I dont keep anything confidential there) Manually created /home/domas/startxfve_headless.sh script, made it executable, the whole orderal Not to mention xfce was not installed by default on this debian/minimal image. It was fun one too. https://docs.armbian.com/User-Guide_Armbian-Software/Desktops/ - armbian-config --cmd XFCE01 just ran the script and nothing happened without any error Had to do it manually but I think it worked the first or second time. And the most fun one since it included multimeter and soldering iron: then it did not detect my disk over sata no matter what I do. Apparently measured 0v at hdd power connector. Not sure how I killed it. After some fiddling around I connected jst connector's for hard drive 5V power to one of gpio pins that supply 5v. HDD spins up - YAAAY. It was short-lived. Disk Still undetected. Probably usb to sata controller is not powered on since 5v regulator fried. (thanks AI for ideas) So then I jumped a wire from said gpio 5v pin to the back of what used to be 5V connector for hard drive so it both feeds the disk and backfeeds the boards 5v regulator with the needed usb to sata controller. I don't use gpio. ITS ALIVE. No, I did not believe it would work. But at this point I had nothing to lose. Sketchy? Yes. Have I ever pulled worse? Sure. Proud of myself? You bet. -
I understand this now. So autoinstalled flag does not cover base packages out of the box. I assumed that manually installed is something i have installed explicitly (as per apt install XXXX). Apparently autoinstalled is the flag that means "I was installed as a dependency only, please wipe me out whenever nothing depends on me" -
Yes, both via vnc and ssh (putty) -
This used to work perfectly after I found it, but yeah - point noted. Ok, I probably understand now whats happening. Thing is, this board is just used for very few simple tasks. From memory, I have manually installed x11vnc, samba, and something hp-printer related. All other stuff were either dependencies or something related to this. I still for some reason don't understand why marking font package as autoinstalled removed it. I have definately not installed it and it came from armbian at some point. See thats the issue. I did uninstall a font, that I shouldn't have. But again it is not something I installed manually. Weird situation. Also, desktop wallpaper disappeared. Technically I did everything correctly - fonts, among other things were not installed manually - and were marked as so after your advice. Maybe the question was why they are considered obsolete? Will check this tonight. -
And here goes aptitude search: orangepiplus:~:% aptitude search '~i !~M' i adduser - add and remove users and groups i adwaita-icon-theme - default icon theme of GNOME i alsa-utils - Utilities for configuring and using ALSA i anacron - cron-like program that doesn't go by time i apport-gtk - GTK+ frontend for the apport crash report i apt - commandline package manager i apt-transport-https - transitional package for https support i apt-utils - package management related utility program i aptitude - terminal-based package manager i armbian-bsp-cli-orangepiplus-cu - Armbian CLI BSP for board 'orangepiplus' b i armbian-config - Armbian config: The Next Generation i armbian-firmware-full - Armbian - Linux firmware-full i armbian-zsh - Armbian improved ZShell (oh-my-zsh...) i automake - Tool for generating GNU Standards-complian i avahi-autoipd - Avahi IPv4LL network address configuration i avahi-daemon - Avahi mDNS/DNS-SD daemon i base-files - Armbian base system miscellaneous files i base-passwd - Debian base system master password and gro i bash - GNU Bourne Again SHell i bash-completion - programmable completion for the bash shell i bc - GNU bc arbitrary precision calculator lang i bison - YACC-compatible parser generator i bleachbit - delete unnecessary files from the system i blueman - Graphical bluetooth manager i bluez - Bluetooth tools and daemons i bluez-cups - Bluetooth printer driver for CUPS i bluez-tools - Set of tools to manage Bluetooth devices f i bridge-utils - Utilities for configuring the Linux Ethern i brltty - Access software for a blind person using a i brltty-x11 - Access software for a blind person using a i bsdutils - basic utilities from 4.4BSD-Lite i btrfs-progs - Checksumming Copy on Write Filesystem util i build-essential - Informational list of build-essential pack i busybox-initramfs - Standalone shell setup for initramfs i bzip2 - high-quality block-sorting file compressor i ca-certificates - Common CA certificates i caffeine - prevent the desktop becoming idle in full- i cifs-utils - Common Internet File System utilities i clang - C, C++ and Objective-C compiler (LLVM base i console-setup - console font and keymap setup program i console-setup-linux - Linux specific part of console-setup i coreutils - GNU core utilities i cpio - GNU cpio -- a program to manage archives o i cpufrequtils - utilities to deal with the cpufreq Linux k i cracklib-runtime - runtime support for password checker libra i cron - process scheduling daemon i cups - Common UNIX Printing System(tm) - PPD/driv i cups-bsd - Common UNIX Printing System(tm) - BSD comm i cups-client - Common UNIX Printing System(tm) - client p i cups-filters - OpenPrinting CUPS Filters - Main Package i curl - command line tool for transferring data wi i dash - POSIX-compliant shell i dbus - simple interprocess messaging system (syst i dbus-x11 - simple interprocess messaging system (X11 i dconf-cli - simple configuration storage system - util i debconf - Debian configuration management system i debconf-utils - debconf utilities i debianutils - Miscellaneous utilities specific to Debian i device-tree-compiler - Device Tree Compiler for Flat Device Trees i dialog - Displays user-friendly dialog boxes from s i dictionaries-common - spelling dictionaries - common utilities i diffutils - File comparison utilities i dirmngr - GNU privacy guard - network certificate ma i dmsetup - Linux Kernel Device Mapper userspace libra i dmz-cursor-theme - Style neutral, scalable cursor theme i doc-base - utilities to manage online documentation i dosfstools - utilities for making and checking MS-DOS F i dpkg - Debian package management system i e2fsprogs - ext2/ext3/ext4 file system utilities i emacs - GNU Emacs editor (metapackage) i emacs-nox - GNU Emacs editor (without GUI support) i ethtool - display or change Ethernet device settings i evince - Document (PostScript, PDF) viewer i evince-common - Document (PostScript, PDF) viewer - common i evtest - utility to monitor Linux input device even i expect - Automates interactive applications i f2fs-tools - Tools for Flash-Friendly File System i f3 - test real flash memory capacity i fake-hwclock - Save/restore system clock on machines with i fbi - Linux frame buffer image viewer i fbset - framebuffer device maintenance program i fdisk - collection of partitioning utilities i figlet - Make large character ASCII banners out of i findutils - utilities for finding files--find, xargs i flex - fast lexical analyzer generator i fontconfig - generic font configuration library - suppo i fontconfig-config - generic font configuration library - confi i fonts-arphic-ukai - "AR PL UKai" Chinese Unicode TrueType font i fonts-arphic-uming - "AR PL UMing" Chinese Unicode TrueType fon i fonts-dejavu-core - Vera font family derivate with additional i fonts-freefont-ttf - Freefont Serif, Sans and Mono Truetype fon i fonts-guru - Meta package to install all Punjabi fonts i fonts-guru-extra - Free fonts for Punjabi language i fonts-kacst - KACST free TrueType Arabic fonts i fonts-kacst-one - TrueType font designed for Arabic language i fonts-khmeros-core - KhmerOS Unicode fonts for the Khmer langua i fonts-liberation - fonts with the same metrics as Times, Aria i fonts-nanum - Nanum Korean fonts i fonts-opensymbol - OpenSymbol TrueType font i fonts-stix - Scientific and Technical Information eXcha i fonts-symbola - symbolic font providing emoji characters f i foomatic-db-compressed-ppds - OpenPrinting printer support - Compressed i fping - sends ICMP ECHO_REQUEST packets to network i gcc-10-base - GCC, the GNU Compiler Collection (base pac i gdebi - simple tool to view and install deb files i geany - fast and lightweight IDE i gimp - GNU Image Manipulation Program i gir1.2-appindicator3-0.1 - Typelib files for libappindicator3-1. i git - fast, scalable, distributed revision contr i gnome-disk-utility - manage and configure disk drives and media i gnome-font-viewer - font viewer for GNOME i gnome-screenshot - screenshot application for GNOME i gnupg - GNU privacy guard - a free PGP replacement i gnupg-l10n - GNU privacy guard - localization files i gnupg-utils - GNU privacy guard - utility programs i gparted - GNOME partition editor i gpg - GNU Privacy Guard -- minimalist public key i gpg-agent - GNU privacy guard - cryptographic agent i gpg-wks-client - GNU privacy guard - Web Key Service client i gpgconf - GNU privacy guard - core configuration uti i gpgsm - GNU privacy guard - S/MIME version i gpgv - GNU privacy guard - signature verification i grep - GNU grep, egrep and fgrep i gstreamer1.0-plugins-base-apps - GStreamer helper programs from the "base" i gstreamer1.0-pulseaudio - GStreamer plugin for PulseAudio (transitio i gtk-update-icon-cache - icon theme caching utility i gtk2-engines - theme engines for GTK+ 2.x i gtk2-engines-murrine - cairo-based gtk+-2.0 theme engine i gtk2-engines-pixbuf - pixbuf-based theme for GTK 2 i gzip - GNU compression utilities i haveged - Linux entropy source using the HAVEGE algo i hdparm - tune hard disk parameters for high perform i hexchat - IRC client for X based on X-Chat 2 i hicolor-icon-theme - default fallback theme for FreeDesktop.org i hostname - utility to set/show the host name or domai i hplip - HP Linux Printing and Imaging System (HPLI i hplip-gui - HP Linux Printing and Imaging - GUI utilit i html2text - advanced HTML to text converter i htop - interactive processes viewer i humanity-icon-theme - Humanity Icon theme i hunspell-en-us - English_american dictionary for hunspell i i2c-tools - heterogeneous set of I2C tools for Linux i ifenslave - configure network interfaces for parallel i ifupdown - high level tools to configure network inte i indicator-printers - indicator showing active print jobs i init - metapackage ensuring an init system is ins i init-system-helpers - helper tools for all init systems i initramfs-tools - generic modular initramfs generator (autom i initramfs-tools-bin - binaries used by initramfs-tools i initramfs-tools-core - generic modular initramfs generator (core i inputattach - utility to connect serial-attached periphe i iotop - simple top-like I/O monitor i iozone3 - Filesystem and Disk Benchmarking Tool i iperf3 - Internet Protocol bandwidth measuring tool i iproute2 - networking and traffic control tools i iptables - administration tools for packet filtering i iputils-arping - Tool to send ICMP echo requests to an ARP i iputils-ping - Tools to test the reachability of network i isc-dhcp-client - DHCP client for automatically obtaining an i iw - tool for configuring Linux wireless device i jq - lightweight and flexible command-line JSON i kbd - Linux console font and keytable utilities i kerneloops - kernel oops tracker i keyboard-configuration - system-wide keyboard preferences i keyutils - Linux Key Management Utilities i klibc-utils - small utilities built with klibc for early i kmod - tools for managing Linux kernel modules i language-pack-gnome-de - GNOME translation updates for language Ger i language-pack-gnome-en - GNOME translation updates for language Eng i language-pack-gnome-es - GNOME translation updates for language Spa i language-pack-gnome-fr - GNOME translation updates for language Fre i language-pack-gnome-it - GNOME translation updates for language Ita i language-pack-gnome-pt - GNOME translation updates for language Por i language-pack-gnome-ru - GNOME translation updates for language Rus i language-pack-gnome-sl - GNOME translation updates for language Slo i laptop-detect - system chassis type checker i less - pager program similar to more i libacl1 - access control list - shared library i libapparmor1 - changehat AppArmor library i libargon2-1 - memory-hard hashing function - runtime lib i libasn1-8-heimdal - Heimdal Kerberos - ASN.1 library i libassuan0 - IPC library for the GnuPG components i libatk-adaptor - AT-SPI 2 toolkit bridge i libatk1.0-data - Common files for the ATK accessibility too i libattr1 - extended attribute handling - shared libra i libaudit-common - Dynamic library for security auditing - co i libaudit1 - Dynamic library for security auditing i libavahi-client3 - Avahi client library i libavahi-common-data - Avahi common data files i libavahi-common3 - Avahi common library i libblkid-dev - block device ID library - headers i libblkid1 - block device ID library i libbsd0 - utility functions from BSD systems - share i libbz2-1.0 - high-quality block-sorting file compressor i libc-bin - GNU C Library: Binaries i libc-dev-bin - GNU C Library: Development binaries i libc6 - GNU C Library: Shared libraries i libc6-dev - GNU C Library: Development Libraries and H i libcairo2 - Cairo 2D vector graphics library i libcap-ng0 - alternate POSIX capabilities library i libcap2 - POSIX 1003.1e capabilities (library) i libcap2-bin - POSIX 1003.1e capabilities (utilities) i libcom-err2 - common error description library i libcrack2 - pro-active password checker library i libcrypt-dev - libcrypt development files i libcrypt1 - libcrypt shared library i libcryptsetup12 - disk encryption support - shared library i libdatrie1 - Double-array trie library i libdbus-1-3 - simple interprocess messaging system (libr i libdconf1 - simple configuration storage system - runt i libdebconfclient0 - Debian Configuration Management System (C- i libdevmapper1.02.1 - Linux Kernel Device Mapper userspace libra i libdigest-sha-perl - Perl extension for SHA-1/224/256/384/512, i libdpkg-perl - Dpkg perl modules i libestr0 - Helper functions for handling strings (lib i libexpat1 - XML parsing C library - runtime library i libfastjson4 - fast json library for C i libfdisk1 - fdisk partitioning library i libffi-dev - Foreign Function Interface library (develo i libffi7 - Foreign Function Interface library runtime i libfont-afm-perl - Perl interface to Adobe Font Metrics files i libfontconfig1 - generic font configuration library - runti i libfontembed1 - OpenPrinting CUPS Filters - Font Embed Sha i libfontenc1 - X11 font encoding library i libfreetype6 - FreeType 2 font engine, shared library fil i libfribidi0 - Free Implementation of the Unicode BiDi al i libgail-common - GNOME Accessibility Implementation Library i libgcc-s1 - GCC support library i libgcrypt20 - LGPL Crypto library - runtime library i libgdk-pixbuf2.0-0 - GDK Pixbuf library (transitional package) i libgdk-pixbuf2.0-common - GDK Pixbuf library - data files i libglib2.0-bin - Programs for the GLib library i libglib2.0-data - Common files for GLib library i libglib2.0-dev - Development files for the GLib library i libglib2.0-dev-bin - Development utilities for the GLib library i libgmp10 - Multiprecision arithmetic library i libgpg-error0 - GnuPG development runtime library i libgraphite2-3 - Font rendering engine for Complex Scripts i libgsettings-qt1 - library to access GSettings from Qt (share i libgssapi-krb5-2 - MIT Kerberos runtime libraries - krb5 GSS- i libgssapi3-heimdal - Heimdal Kerberos - GSSAPI support library i libgtk2.0-bin - programs for the GTK graphical user interf i libgtk2.0-common - common files for the GTK graphical user in i libharfbuzz0b - OpenType text shaping engine (shared libra i libhcrypto4-heimdal - Heimdal Kerberos - crypto library i libheimbase1-heimdal - Heimdal Kerberos - Base library i libheimntlm0-heimdal - Heimdal Kerberos - NTLM support library i libhx509-5-heimdal - Heimdal Kerberos - X509 support library i libidn2-0 - Internationalized domain names (IDNA2008/T i libip4tc2 - netfilter libip4tc library i libjbig0 - JBIGkit libraries i libjpeg-turbo8 - libjpeg-turbo JPEG runtime library i libjpeg8 - Independent JPEG Group's JPEG runtime libr i libk5crypto3 - MIT Kerberos runtime libraries - Crypto Li i libkeyutils1 - Linux Key Management Utilities (library) i libklibc - minimal libc subset for use with initramfs i libkmod2 - libkmod shared library i libkrb5-26-heimdal - Heimdal Kerberos - libraries i libkrb5-3 - MIT Kerberos runtime libraries i libkrb5support0 - MIT Kerberos runtime libraries - Support l i libksba8 - X.509 and CMS support library i libldap-common - OpenLDAP common files for libraries i liblocale-gettext-perl - module using libc functions for internatio i liblz4-1 - Fast LZ compression algorithm library - ru i liblzma5 - XZ-format compression library i libmnl0 - minimalistic Netlink communication library i libmount-dev - device mounting library - headers i libmount1 - device mounting library i libncurses6 - shared libraries for terminal handling i libncursesw6 - shared libraries for terminal handling (wi i libnewt0.52 - Not Erik's Windowing Toolkit - text mode w i libnl-3-200 - library for dealing with netlink sockets i libnl-3-dev - development library and headers for libnl- i libnl-genl-3-200 - library for dealing with netlink sockets - i libnl-genl-3-dev - development library and headers for libnl- i libnotify-bin - sends desktop notifications to a notificat i libnss-myhostname - nss module providing fallback resolution f i libp11-kit0 - library for loading and coordinating acces i libpam-gnome-keyring - PAM module to unlock the GNOME keyring upo i libpam-modules - Pluggable Authentication Modules for PAM i libpam-modules-bin - Pluggable Authentication Modules for PAM - i libpam-runtime - Runtime support for the PAM library i libpam-systemd - system and service manager - PAM module i libpam0g - Pluggable Authentication Modules library i libpango-1.0-0 - Layout and rendering of internationalized i libpangocairo-1.0-0 - Layout and rendering of internationalized i libpangoft2-1.0-0 - Layout and rendering of internationalized i libpcre16-3 - Old Perl 5 Compatible Regular Expression L i libpcre2-16-0 - New Perl Compatible Regular Expression Lib i libpcre2-32-0 - New Perl Compatible Regular Expression Lib i libpcre2-8-0 - New Perl Compatible Regular Expression Lib i libpcre2-dev - New Perl Compatible Regular Expression Lib i libpcre3 - Old Perl 5 Compatible Regular Expression L i libpcre3-dev - Old Perl 5 Compatible Regular Expression L i libpcre32-3 - Old Perl 5 Compatible Regular Expression L i libpcrecpp0v5 - Old Perl 5 Compatible Regular Expression L i libpixman-1-0 - pixel-manipulation library for X and cairo i libpopt0 - lib for parsing cmdline parameters i libproc-processtable-perl - Perl library for accessing process table i i libprocps8 - library for accessing process information i libproxy1-plugin-gsettings - transitional package for libproxy GSetting i libproxy1-plugin-networkmanager - transitional package for libproxy NetworkM i libpython3-stdlib - interactive high-level object-oriented lan i libroken18-heimdal - Heimdal Kerberos - roken support library i librsvg2-2 - SAX-based renderer library for SVG files ( i librsvg2-common - SAX-based renderer library for SVG files ( i libsasl2-2 - Cyrus SASL - authentication abstraction li i libsasl2-modules-db - Cyrus SASL - pluggable authentication modu i libseccomp2 - high level interface to Linux seccomp filt i libselinux1 - SELinux runtime shared libraries i libselinux1-dev - SELinux development headers i libsemanage-common - Common files for SELinux policy management i libslang2 - S-Lang programming library - runtime versi i libsmartcols1 - smart column output alignment library i libsqlite3-0 - SQLite 3 shared library i libss2 - command-line interface parsing library i libssl-dev - Secure Sockets Layer toolkit - development i libstdc++6 - GNU Standard C++ Library v3 i libsystemd0 - systemd utility library i libtasn1-6 - Manage ASN.1 structures (runtime) i libthai-data - Data files for Thai language support libra i libthai0 - Thai language support library i libtiff5 - Tag Image File Format (TIFF) library i libtinfo6 - shared low-level terminfo library for term i libu2f-udev - Universal 2nd Factor (U2F) — transitional i libudev1 - libudev shared library i libunistring2 - Unicode string library for C i libuuid1 - Universally Unique ID library i libuv1 - asynchronous event notification library - i libwind0-heimdal - Heimdal Kerberos - stringprep implementati i libwmf0.2-7-gtk - Windows metafile conversion GTK pixbuf plu i libwrap0-dev - Wietse Venema's TCP wrappers library, deve i libx11-6 - X11 client-side library i libx11-data - X11 client-side library i libxau6 - X11 authorisation library i libxcb-render0 - X C Binding, render extension i libxcb-shm0 - X C Binding, shm extension i libxcb1 - X C Binding i libxcomposite1 - X11 Composite extension library i libxcursor1 - X cursor management library i libxdamage1 - X11 damaged region extension library i libxdmcp6 - X11 Display Manager Control Protocol libra i libxext6 - X11 miscellaneous extension library i libxfixes3 - X11 miscellaneous 'fixes' extension librar i libxi6 - X11 Input extension library i libxinerama1 - X11 Xinerama extension library i libxml2 - GNOME XML library i libxrandr2 - X11 RandR extension library i libxrender1 - X Rendering Extension client library i libxtables12 - netfilter xtables library i libzstd1 - fast lossless compression algorithm i lightdm - Display Manager i lightdm-settings - LightDM Settings Configuration Tool i linux-base - Linux image base package i linux-dtb-current-sunxi - Armbian Linux current DTBs in /boot/dtb-6. i linux-image-current-sunxi - Armbian Linux current kernel image 6.12.20 i linux-libc-dev - Armbian Linux support headers for userspac i linux-u-boot-orangepiplus-curre - Das U-Boot for orangepiplus i lm-sensors - utilities to read temperature/voltage/fan i locales - GNU C Library: National Language (locale) i login - system login tools i logrotate - Log rotation utility i logsave - save the output of a command in a log file i lsb-base - transitional package for Linux Standard Ba i lsof - utility to list open files i lxtask - LXDE task manager i lz4 - Fast LZ compression algorithm library - to i mawk - Pattern scanning and text processing langu i mc - Midnight Commander - a powerful file manag i meld - graphical tool to diff and merge files i mime-support - transitional package i mmc-utils - Userspace tools for MMC/SD devices i mount - tools for mounting and manipulating filesy i mousepad - simple Xfce oriented text editor i mousetweaks - mouse accessibility enhancements for the G i nano - small, friendly text editor inspired by Pi i ncurses-base - basic terminal type definitions i ncurses-bin - terminal-related programs and man pages i ncurses-term - additional terminal type definitions i net-tools - NET-3 networking toolkit i netbase - Basic TCP/IP networking system i netcat-openbsd - TCP/IP swiss army knife i network-manager - network management framework (daemon and u i network-manager-gnome - network management framework (GNOME fronte i network-manager-l2tp - network management framework (L2TP plugin i network-manager-openconnect - network management framework (OpenConnect i network-manager-openvpn - network management framework (OpenVPN plug i network-manager-pptp - network management framework (PPTP plugin i network-manager-ssh - network management framework (SSH plugin c i network-manager-vpnc - network management framework (VPNC plugin i nocache - bypass/minimize file system caching for a i notepadqq - Notepad++-like editor for Linux i ntfs-3g - read/write NTFS driver for FUSE i numix-gtk-theme - Numix GTK Theme i numix-icon-theme - modern icon theme from the Numix project i numix-icon-theme-circle - Circle icon theme from the Numix project i openprinting-ppds - OpenPrinting printer support - PostScript i openssh-server - secure shell (SSH) server, for secure acce i openssl - Secure Sockets Layer toolkit - cryptograph i orca - Scriptable screen reader i p7zip-full - transitional package i pamix - Pulseaudio terminal mixer based in pavucon i parted - disk partition manipulator i passwd - change and administer password and group d i pasystray - PulseAudio controller for the system tray i pavucontrol - PulseAudio Volume Control i pavucontrol-qt - Qt port of volume control pavucontrol i pavumeter - PulseAudio Volume Meter i pciutils - PCI utilities i perl - Larry Wall's Practical Extraction and Repo i perl-base - minimal Perl system i pinentry-curses - curses-based PIN or pass-phrase entry dial i pkg-config - manage compile and link flags for librarie i policykit-1 - transitional package for polkitd and pkexe i policykit-desktop-privileges - run common desktop actions without passwor i printer-driver-all - printer drivers metapackage i printer-driver-gutenprint - printer drivers for CUPS i procps - /proc file system utilities i profile-sync-daemon - Symlink and sync browser profile directori i psmisc - utilities that use the proc file system i pulseaudio-module-bluetooth - Bluetooth module for PulseAudio sound serv i putty - Telnet/SSH client for X i pv - Shell pipeline element to meter data passi i python3 - interactive high-level object-oriented lan i python3-apt - Python 3 interface to libapt-pkg i python3-lib2to3 - Interactive high-level object-oriented lan i python3-minimal - minimal subset of the Python language (def i qrencode - QR Code encoder into PNG image i readline-common - GNU readline and history libraries, common i redshift - Adjusts the color temperature of your scre i regexxer - visual search and replace tool using Perl i remmina - GTK+ Remote Desktop Client i rfkill - tool for enabling and disabling wireless d i rng-tools-debian - daemon to use a Hardware RNG (classic vers i rsync - fast, versatile, remote (and local) file-c i rsyslog - reliable system and kernel logging daemon i samba - SMB/CIFS file, print, and login server for i samba-common-bin - Samba common files used by both the server i screen - terminal multiplexer with VT100/ANSI termi i sed - GNU stream editor for filtering/transformi i sensible-utils - Utilities for sensible alternative selecti i shared-mime-info - FreeDesktop.org shared MIME database and s i simple-scan - Simple Scanning Utility i slick-greeter - Slick-looking LightDM greeter i smartmontools - control and monitor storage systems using i smbclient - command-line SMB/CIFS clients for Unix i spice-vdagent - Spice agent for Linux i stress - tool to impose load on and stress test a c i sudo - Provide limited super user privileges to s i sunxi-tools - tools for working with Allwinner (sunxi) A i sysfsutils - sysfs query tool and boot-time setup i sysstat - system performance tools for Linux i system-config-printer - graphical interface to configure the print i system-config-printer-common - backend and the translation files for syst i systemd - system and service manager i systemd-sysv - system and service manager - SysV compatib i sysvinit-utils - System-V-like utilities i tar - GNU version of the tar archiving utility i terminator - multiple GNOME terminals in one window i thunar-volman - Thunar extension for volumes management i toilet - display large colourful characters in text i transmission-remote-gtk - GTK+ interface for the Transmission BitTor i tzdata - time zone and daylight-saving time data i u-boot-tools - companion tools for Das U-Boot bootloader i ubuntu-drivers-common - Detect and install additional Ubuntu drive i ubuntu-keyring - GnuPG keys of the Ubuntu archive i ubuntu-mono - Ubuntu Mono Icon theme i ucf - Update Configuration File(s): preserve use i udev - /dev/ and hotplug management daemon i unattended-upgrades - automatic installation of security upgrade i unicode-data - Property data for the Unicode character se i unzip - De-archiver for .zip files i update-inetd - inetd configuration file updater i update-manager-core - manage release upgrades i update-notifier-common - Files shared between update-notifier and o i usbutils - Linux USB utilities i util-linux - miscellaneous system utilities i uuid-dev - Universally Unique ID library - headers an i viewnior - simple, fast and elegant image viewer i vim - Vi IMproved - enhanced vi editor i vlan - ifupdown integration for vlan configuratio i wamerican - American English dictionary words for /usr i wbrazilian - Brazilian Portuguese wordlist i wbritish - British English dictionary words for /usr/ i wfrench - French dictionary words for /usr/share/dic i wget - retrieves files from the web i whiptail - Displays user-friendly dialog boxes from s i wireguard-tools - fast, modern, secure kernel VPN tunnel (us i wireless-regdb - wireless regulatory database i wireless-tools - Tools for manipulating Linux Wireless Exte i witalian - Italian dictionary words for /usr/share/di i wpasupplicant - client support for WPA and WPA2 (IEEE 802. i wportuguese - European Portuguese wordlist i wspanish - Spanish dictionary words for /usr/share/di i wswiss - Swiss (German) orthography wordlist i x11-apps - X applications i x11-xserver-utils - X server utilities i x11vnc - VNC server to allow remote access to an ex i xbacklight - simple utility to set the backlight level i xcursor-themes - Base X cursor themes i xdg-user-dirs - tool to manage well known user directories i xdg-user-dirs-gtk - tool to manage well known user directories i xfce4 - Meta-package for the Xfce Lightweight Desk i xfce4-notifyd - simple, visually-appealing notification da i xfce4-screenshooter - screenshots utility for Xfce i xfce4-terminal - Xfce terminal emulator i xfonts-100dpi - 100 dpi fonts for X i xfonts-75dpi - 75 dpi fonts for X i xfonts-base - standard fonts for X i xfonts-encodings - Encodings for X.Org fonts i xfonts-scalable - scalable fonts for X i xfonts-utils - X Window System font utility programs i xinit - X server initialisation tool i xkb-data - X Keyboard Extension (XKB) configuration d i xorg-docs-core - Core documentation for the X.org X Window i xrdp - Remote Desktop Protocol (RDP) server i xscreensaver - Screensaver daemon and frontend for X11 i xserver-xorg-core - Xorg X server - core server i xserver-xorg-input-all - X.Org X server -- input driver metapackage i xterm - X terminal emulator i xtermcontrol - dynamic configuration of xterm properties i xtermset - change the characteristics of an xterm i xwallpaper - utility for setting image files as X wallp i zip - Archiver for .zip files i zlib1g - compression library - runtime i zlib1g-dev - compression library - development orangepiplus:~:% orangepiplus:~:% aptitude search '~i !~M' i adduser - add and remove users and groups i adwaita-icon-theme - default icon theme of GNOME i alsa-utils - Utilities for configuring and using ALSA i anacron - cron-like program that doesn't go by time i apport-gtk - GTK+ frontend for the apport crash report i apt - commandline package manager i apt-transport-https - transitional package for https support i apt-utils - package management related utility program i aptitude - terminal-based package manager i armbian-bsp-cli-orangepiplus-cu - Armbian CLI BSP for board 'orangepiplus' b i armbian-config - Armbian config: The Next Generation i armbian-firmware-full - Armbian - Linux firmware-full i armbian-zsh - Armbian improved ZShell (oh-my-zsh...) i automake - Tool for generating GNU Standards-complian i avahi-autoipd - Avahi IPv4LL network address configuration i avahi-daemon - Avahi mDNS/DNS-SD daemon i base-files - Armbian base system miscellaneous files i base-passwd - Debian base system master password and gro i bash - GNU Bourne Again SHell i bash-completion - programmable completion for the bash shell i bc - GNU bc arbitrary precision calculator lang i bison - YACC-compatible parser generator i bleachbit - delete unnecessary files from the system i blueman - Graphical bluetooth manager i bluez - Bluetooth tools and daemons i bluez-cups - Bluetooth printer driver for CUPS i bluez-tools - Set of tools to manage Bluetooth devices f i bridge-utils - Utilities for configuring the Linux Ethern i brltty - Access software for a blind person using a i brltty-x11 - Access software for a blind person using a i bsdutils - basic utilities from 4.4BSD-Lite i btrfs-progs - Checksumming Copy on Write Filesystem util i build-essential - Informational list of build-essential pack i busybox-initramfs - Standalone shell setup for initramfs i bzip2 - high-quality block-sorting file compressor i ca-certificates - Common CA certificates i caffeine - prevent the desktop becoming idle in full- i cifs-utils - Common Internet File System utilities i clang - C, C++ and Objective-C compiler (LLVM base i console-setup - console font and keymap setup program i console-setup-linux - Linux specific part of console-setup i coreutils - GNU core utilities i cpio - GNU cpio -- a program to manage archives o i cpufrequtils - utilities to deal with the cpufreq Linux k i cracklib-runtime - runtime support for password checker libra i cron - process scheduling daemon i cups - Common UNIX Printing System(tm) - PPD/driv i cups-bsd - Common UNIX Printing System(tm) - BSD comm i cups-client - Common UNIX Printing System(tm) - client p i cups-filters - OpenPrinting CUPS Filters - Main Package i curl - command line tool for transferring data wi i dash - POSIX-compliant shell i dbus - simple interprocess messaging system (syst i dbus-x11 - simple interprocess messaging system (X11 i dconf-cli - simple configuration storage system - util i debconf - Debian configuration management system i debconf-utils - debconf utilities i debianutils - Miscellaneous utilities specific to Debian i device-tree-compiler - Device Tree Compiler for Flat Device Trees i dialog - Displays user-friendly dialog boxes from s i dictionaries-common - spelling dictionaries - common utilities i diffutils - File comparison utilities i dirmngr - GNU privacy guard - network certificate ma i dmsetup - Linux Kernel Device Mapper userspace libra i dmz-cursor-theme - Style neutral, scalable cursor theme i doc-base - utilities to manage online documentation i dosfstools - utilities for making and checking MS-DOS F i dpkg - Debian package management system i e2fsprogs - ext2/ext3/ext4 file system utilities i emacs - GNU Emacs editor (metapackage) i emacs-nox - GNU Emacs editor (without GUI support) i ethtool - display or change Ethernet device settings i evince - Document (PostScript, PDF) viewer i evince-common - Document (PostScript, PDF) viewer - common i evtest - utility to monitor Linux input device even i expect - Automates interactive applications i f2fs-tools - Tools for Flash-Friendly File System i f3 - test real flash memory capacity i fake-hwclock - Save/restore system clock on machines with i fbi - Linux frame buffer image viewer i fbset - framebuffer device maintenance program i fdisk - collection of partitioning utilities i figlet - Make large character ASCII banners out of i findutils - utilities for finding files--find, xargs i flex - fast lexical analyzer generator i fontconfig - generic font configuration library - suppo i fontconfig-config - generic font configuration library - confi i fonts-arphic-ukai - "AR PL UKai" Chinese Unicode TrueType font i fonts-arphic-uming - "AR PL UMing" Chinese Unicode TrueType fon i fonts-dejavu-core - Vera font family derivate with additional i fonts-freefont-ttf - Freefont Serif, Sans and Mono Truetype fon i fonts-guru - Meta package to install all Punjabi fonts i fonts-guru-extra - Free fonts for Punjabi language i fonts-kacst - KACST free TrueType Arabic fonts i fonts-kacst-one - TrueType font designed for Arabic language i fonts-khmeros-core - KhmerOS Unicode fonts for the Khmer langua i fonts-liberation - fonts with the same metrics as Times, Aria i fonts-nanum - Nanum Korean fonts i fonts-opensymbol - OpenSymbol TrueType font i fonts-stix - Scientific and Technical Information eXcha i fonts-symbola - symbolic font providing emoji characters f i foomatic-db-compressed-ppds - OpenPrinting printer support - Compressed i fping - sends ICMP ECHO_REQUEST packets to network i gcc-10-base - GCC, the GNU Compiler Collection (base pac i gdebi - simple tool to view and install deb files i geany - fast and lightweight IDE i gimp - GNU Image Manipulation Program i gir1.2-appindicator3-0.1 - Typelib files for libappindicator3-1. i git - fast, scalable, distributed revision contr i gnome-disk-utility - manage and configure disk drives and media i gnome-font-viewer - font viewer for GNOME i gnome-screenshot - screenshot application for GNOME i gnupg - GNU privacy guard - a free PGP replacement i gnupg-l10n - GNU privacy guard - localization files i gnupg-utils - GNU privacy guard - utility programs i gparted - GNOME partition editor i gpg - GNU Privacy Guard -- minimalist public key i gpg-agent - GNU privacy guard - cryptographic agent i gpg-wks-client - GNU privacy guard - Web Key Service client i gpgconf - GNU privacy guard - core configuration uti i gpgsm - GNU privacy guard - S/MIME version i gpgv - GNU privacy guard - signature verification i grep - GNU grep, egrep and fgrep i gstreamer1.0-plugins-base-apps - GStreamer helper programs from the "base" i gstreamer1.0-pulseaudio - GStreamer plugin for PulseAudio (transitio i gtk-update-icon-cache - icon theme caching utility i gtk2-engines - theme engines for GTK+ 2.x i gtk2-engines-murrine - cairo-based gtk+-2.0 theme engine i gtk2-engines-pixbuf - pixbuf-based theme for GTK 2 i gzip - GNU compression utilities i haveged - Linux entropy source using the HAVEGE algo i hdparm - tune hard disk parameters for high perform i hexchat - IRC client for X based on X-Chat 2 i hicolor-icon-theme - default fallback theme for FreeDesktop.org i hostname - utility to set/show the host name or domai i hplip - HP Linux Printing and Imaging System (HPLI i hplip-gui - HP Linux Printing and Imaging - GUI utilit i html2text - advanced HTML to text converter i htop - interactive processes viewer i humanity-icon-theme - Humanity Icon theme i hunspell-en-us - English_american dictionary for hunspell i i2c-tools - heterogeneous set of I2C tools for Linux i ifenslave - configure network interfaces for parallel i ifupdown - high level tools to configure network inte i indicator-printers - indicator showing active print jobs i init - metapackage ensuring an init system is ins i init-system-helpers - helper tools for all init systems i initramfs-tools - generic modular initramfs generator (autom i initramfs-tools-bin - binaries used by initramfs-tools i initramfs-tools-core - generic modular initramfs generator (core i inputattach - utility to connect serial-attached periphe i iotop - simple top-like I/O monitor i iozone3 - Filesystem and Disk Benchmarking Tool i iperf3 - Internet Protocol bandwidth measuring tool i iproute2 - networking and traffic control tools i iptables - administration tools for packet filtering i iputils-arping - Tool to send ICMP echo requests to an ARP i iputils-ping - Tools to test the reachability of network i isc-dhcp-client - DHCP client for automatically obtaining an i iw - tool for configuring Linux wireless device i jq - lightweight and flexible command-line JSON i kbd - Linux console font and keytable utilities i kerneloops - kernel oops tracker i keyboard-configuration - system-wide keyboard preferences i keyutils - Linux Key Management Utilities i klibc-utils - small utilities built with klibc for early i kmod - tools for managing Linux kernel modules i language-pack-gnome-de - GNOME translation updates for language Ger i language-pack-gnome-en - GNOME translation updates for language Eng i language-pack-gnome-es - GNOME translation updates for language Spa i language-pack-gnome-fr - GNOME translation updates for language Fre i language-pack-gnome-it - GNOME translation updates for language Ita i language-pack-gnome-pt - GNOME translation updates for language Por i language-pack-gnome-ru - GNOME translation updates for language Rus i language-pack-gnome-sl - GNOME translation updates for language Slo i laptop-detect - system chassis type checker i less - pager program similar to more i libacl1 - access control list - shared library i libapparmor1 - changehat AppArmor library i libargon2-1 - memory-hard hashing function - runtime lib i libasn1-8-heimdal - Heimdal Kerberos - ASN.1 library i libassuan0 - IPC library for the GnuPG components i libatk-adaptor - AT-SPI 2 toolkit bridge i libatk1.0-data - Common files for the ATK accessibility too i libattr1 - extended attribute handling - shared libra i libaudit-common - Dynamic library for security auditing - co i libaudit1 - Dynamic library for security auditing i libavahi-client3 - Avahi client library i libavahi-common-data - Avahi common data files i libavahi-common3 - Avahi common library i libblkid-dev - block device ID library - headers i libblkid1 - block device ID library i libbsd0 - utility functions from BSD systems - share i libbz2-1.0 - high-quality block-sorting file compressor i libc-bin - GNU C Library: Binaries i libc-dev-bin - GNU C Library: Development binaries i libc6 - GNU C Library: Shared libraries i libc6-dev - GNU C Library: Development Libraries and H i libcairo2 - Cairo 2D vector graphics library i libcap-ng0 - alternate POSIX capabilities library i libcap2 - POSIX 1003.1e capabilities (library) i libcap2-bin - POSIX 1003.1e capabilities (utilities) i libcom-err2 - common error description library i libcrack2 - pro-active password checker library i libcrypt-dev - libcrypt development files i libcrypt1 - libcrypt shared library i libcryptsetup12 - disk encryption support - shared library i libdatrie1 - Double-array trie library i libdbus-1-3 - simple interprocess messaging system (libr i libdconf1 - simple configuration storage system - runt i libdebconfclient0 - Debian Configuration Management System (C- i libdevmapper1.02.1 - Linux Kernel Device Mapper userspace libra i libdigest-sha-perl - Perl extension for SHA-1/224/256/384/512, i libdpkg-perl - Dpkg perl modules i libestr0 - Helper functions for handling strings (lib i libexpat1 - XML parsing C library - runtime library i libfastjson4 - fast json library for C i libfdisk1 - fdisk partitioning library i libffi-dev - Foreign Function Interface library (develo i libffi7 - Foreign Function Interface library runtime i libfont-afm-perl - Perl interface to Adobe Font Metrics files i libfontconfig1 - generic font configuration library - runti i libfontembed1 - OpenPrinting CUPS Filters - Font Embed Sha i libfontenc1 - X11 font encoding library i libfreetype6 - FreeType 2 font engine, shared library fil i libfribidi0 - Free Implementation of the Unicode BiDi al i libgail-common - GNOME Accessibility Implementation Library i libgcc-s1 - GCC support library i libgcrypt20 - LGPL Crypto library - runtime library i libgdk-pixbuf2.0-0 - GDK Pixbuf library (transitional package) i libgdk-pixbuf2.0-common - GDK Pixbuf library - data files i libglib2.0-bin - Programs for the GLib library i libglib2.0-data - Common files for GLib library i libglib2.0-dev - Development files for the GLib library i libglib2.0-dev-bin - Development utilities for the GLib library i libgmp10 - Multiprecision arithmetic library i libgpg-error0 - GnuPG development runtime library i libgraphite2-3 - Font rendering engine for Complex Scripts i libgsettings-qt1 - library to access GSettings from Qt (share i libgssapi-krb5-2 - MIT Kerberos runtime libraries - krb5 GSS- i libgssapi3-heimdal - Heimdal Kerberos - GSSAPI support library i libgtk2.0-bin - programs for the GTK graphical user interf i libgtk2.0-common - common files for the GTK graphical user in i libharfbuzz0b - OpenType text shaping engine (shared libra i libhcrypto4-heimdal - Heimdal Kerberos - crypto library i libheimbase1-heimdal - Heimdal Kerberos - Base library i libheimntlm0-heimdal - Heimdal Kerberos - NTLM support library i libhx509-5-heimdal - Heimdal Kerberos - X509 support library i libidn2-0 - Internationalized domain names (IDNA2008/T i libip4tc2 - netfilter libip4tc library i libjbig0 - JBIGkit libraries i libjpeg-turbo8 - libjpeg-turbo JPEG runtime library i libjpeg8 - Independent JPEG Group's JPEG runtime libr i libk5crypto3 - MIT Kerberos runtime libraries - Crypto Li i libkeyutils1 - Linux Key Management Utilities (library) i libklibc - minimal libc subset for use with initramfs i libkmod2 - libkmod shared library i libkrb5-26-heimdal - Heimdal Kerberos - libraries i libkrb5-3 - MIT Kerberos runtime libraries i libkrb5support0 - MIT Kerberos runtime libraries - Support l i libksba8 - X.509 and CMS support library i libldap-common - OpenLDAP common files for libraries i liblocale-gettext-perl - module using libc functions for internatio i liblz4-1 - Fast LZ compression algorithm library - ru i liblzma5 - XZ-format compression library i libmnl0 - minimalistic Netlink communication library i libmount-dev - device mounting library - headers i libmount1 - device mounting library i libncurses6 - shared libraries for terminal handling i libncursesw6 - shared libraries for terminal handling (wi i libnewt0.52 - Not Erik's Windowing Toolkit - text mode w i libnl-3-200 - library for dealing with netlink sockets i libnl-3-dev - development library and headers for libnl- i libnl-genl-3-200 - library for dealing with netlink sockets - i libnl-genl-3-dev - development library and headers for libnl- i libnotify-bin - sends desktop notifications to a notificat i libnss-myhostname - nss module providing fallback resolution f i libp11-kit0 - library for loading and coordinating acces i libpam-gnome-keyring - PAM module to unlock the GNOME keyring upo i libpam-modules - Pluggable Authentication Modules for PAM i libpam-modules-bin - Pluggable Authentication Modules for PAM - i libpam-runtime - Runtime support for the PAM library i libpam-systemd - system and service manager - PAM module i libpam0g - Pluggable Authentication Modules library i libpango-1.0-0 - Layout and rendering of internationalized i libpangocairo-1.0-0 - Layout and rendering of internationalized i libpangoft2-1.0-0 - Layout and rendering of internationalized i libpcre16-3 - Old Perl 5 Compatible Regular Expression L i libpcre2-16-0 - New Perl Compatible Regular Expression Lib i libpcre2-32-0 - New Perl Compatible Regular Expression Lib i libpcre2-8-0 - New Perl Compatible Regular Expression Lib i libpcre2-dev - New Perl Compatible Regular Expression Lib i libpcre3 - Old Perl 5 Compatible Regular Expression L i libpcre3-dev - Old Perl 5 Compatible Regular Expression L i libpcre32-3 - Old Perl 5 Compatible Regular Expression L i libpcrecpp0v5 - Old Perl 5 Compatible Regular Expression L i libpixman-1-0 - pixel-manipulation library for X and cairo i libpopt0 - lib for parsing cmdline parameters i libproc-processtable-perl - Perl library for accessing process table i i libprocps8 - library for accessing process information i libproxy1-plugin-gsettings - transitional package for libproxy GSetting i libproxy1-plugin-networkmanager - transitional package for libproxy NetworkM i libpython3-stdlib - interactive high-level object-oriented lan i libroken18-heimdal - Heimdal Kerberos - roken support library i librsvg2-2 - SAX-based renderer library for SVG files ( i librsvg2-common - SAX-based renderer library for SVG files ( i libsasl2-2 - Cyrus SASL - authentication abstraction li i libsasl2-modules-db - Cyrus SASL - pluggable authentication modu i libseccomp2 - high level interface to Linux seccomp filt i libselinux1 - SELinux runtime shared libraries i libselinux1-dev - SELinux development headers i libsemanage-common - Common files for SELinux policy management i libslang2 - S-Lang programming library - runtime versi i libsmartcols1 - smart column output alignment library i libsqlite3-0 - SQLite 3 shared library i libss2 - command-line interface parsing library i libssl-dev - Secure Sockets Layer toolkit - development i libstdc++6 - GNU Standard C++ Library v3 i libsystemd0 - systemd utility library i libtasn1-6 - Manage ASN.1 structures (runtime) i libthai-data - Data files for Thai language support libra i libthai0 - Thai language support library i libtiff5 - Tag Image File Format (TIFF) library i libtinfo6 - shared low-level terminfo library for term i libu2f-udev - Universal 2nd Factor (U2F) — transitional i libudev1 - libudev shared library i libunistring2 - Unicode string library for C i libuuid1 - Universally Unique ID library i libuv1 - asynchronous event notification library - i libwind0-heimdal - Heimdal Kerberos - stringprep implementati i libwmf0.2-7-gtk - Windows metafile conversion GTK pixbuf plu i libwrap0-dev - Wietse Venema's TCP wrappers library, deve i libx11-6 - X11 client-side library i libx11-data - X11 client-side library i libxau6 - X11 authorisation library i libxcb-render0 - X C Binding, render extension i libxcb-shm0 - X C Binding, shm extension i libxcb1 - X C Binding i libxcomposite1 - X11 Composite extension library i libxcursor1 - X cursor management library i libxdamage1 - X11 damaged region extension library i libxdmcp6 - X11 Display Manager Control Protocol libra i libxext6 - X11 miscellaneous extension library i libxfixes3 - X11 miscellaneous 'fixes' extension librar i libxi6 - X11 Input extension library i libxinerama1 - X11 Xinerama extension library i libxml2 - GNOME XML library i libxrandr2 - X11 RandR extension library i libxrender1 - X Rendering Extension client library i libxtables12 - netfilter xtables library i libzstd1 - fast lossless compression algorithm i lightdm - Display Manager i lightdm-settings - LightDM Settings Configuration Tool i linux-base - Linux image base package i linux-dtb-current-sunxi - Armbian Linux current DTBs in /boot/dtb-6. i linux-image-current-sunxi - Armbian Linux current kernel image 6.12.20 i linux-libc-dev - Armbian Linux support headers for userspac i linux-u-boot-orangepiplus-curre - Das U-Boot for orangepiplus i lm-sensors - utilities to read temperature/voltage/fan i locales - GNU C Library: National Language (locale) i login - system login tools i logrotate - Log rotation utility i logsave - save the output of a command in a log file i lsb-base - transitional package for Linux Standard Ba i lsof - utility to list open files i lxtask - LXDE task manager i lz4 - Fast LZ compression algorithm library - to i mawk - Pattern scanning and text processing langu i mc - Midnight Commander - a powerful file manag i meld - graphical tool to diff and merge files i mime-support - transitional package i mmc-utils - Userspace tools for MMC/SD devices i mount - tools for mounting and manipulating filesy i mousepad - simple Xfce oriented text editor i mousetweaks - mouse accessibility enhancements for the G i nano - small, friendly text editor inspired by Pi i ncurses-base - basic terminal type definitions i ncurses-bin - terminal-related programs and man pages i ncurses-term - additional terminal type definitions i net-tools - NET-3 networking toolkit i netbase - Basic TCP/IP networking system i netcat-openbsd - TCP/IP swiss army knife i network-manager - network management framework (daemon and u i network-manager-gnome - network management framework (GNOME fronte i network-manager-l2tp - network management framework (L2TP plugin i network-manager-openconnect - network management framework (OpenConnect i network-manager-openvpn - network management framework (OpenVPN plug i network-manager-pptp - network management framework (PPTP plugin i network-manager-ssh - network management framework (SSH plugin c i network-manager-vpnc - network management framework (VPNC plugin i nocache - bypass/minimize file system caching for a i notepadqq - Notepad++-like editor for Linux i ntfs-3g - read/write NTFS driver for FUSE i numix-gtk-theme - Numix GTK Theme i numix-icon-theme - modern icon theme from the Numix project i numix-icon-theme-circle - Circle icon theme from the Numix project i openprinting-ppds - OpenPrinting printer support - PostScript i openssh-server - secure shell (SSH) server, for secure acce i openssl - Secure Sockets Layer toolkit - cryptograph i orca - Scriptable screen reader i p7zip-full - transitional package i pamix - Pulseaudio terminal mixer based in pavucon i parted - disk partition manipulator i passwd - change and administer password and group d i pasystray - PulseAudio controller for the system tray i pavucontrol - PulseAudio Volume Control i pavucontrol-qt - Qt port of volume control pavucontrol i pavumeter - PulseAudio Volume Meter i pciutils - PCI utilities i perl - Larry Wall's Practical Extraction and Repo i perl-base - minimal Perl system i pinentry-curses - curses-based PIN or pass-phrase entry dial i pkg-config - manage compile and link flags for librarie i policykit-1 - transitional package for polkitd and pkexe i policykit-desktop-privileges - run common desktop actions without passwor i printer-driver-all - printer drivers metapackage i printer-driver-gutenprint - printer drivers for CUPS i procps - /proc file system utilities i profile-sync-daemon - Symlink and sync browser profile directori i psmisc - utilities that use the proc file system i pulseaudio-module-bluetooth - Bluetooth module for PulseAudio sound serv i putty - Telnet/SSH client for X i pv - Shell pipeline element to meter data passi i python3 - interactive high-level object-oriented lan i python3-apt - Python 3 interface to libapt-pkg i python3-lib2to3 - Interactive high-level object-oriented lan i python3-minimal - minimal subset of the Python language (def i qrencode - QR Code encoder into PNG image i readline-common - GNU readline and history libraries, common i redshift - Adjusts the color temperature of your scre i regexxer - visual search and replace tool using Perl i remmina - GTK+ Remote Desktop Client i rfkill - tool for enabling and disabling wireless d i rng-tools-debian - daemon to use a Hardware RNG (classic vers i rsync - fast, versatile, remote (and local) file-c i rsyslog - reliable system and kernel logging daemon i samba - SMB/CIFS file, print, and login server for i samba-common-bin - Samba common files used by both the server i screen - terminal multiplexer with VT100/ANSI termi i sed - GNU stream editor for filtering/transformi i sensible-utils - Utilities for sensible alternative selecti i shared-mime-info - FreeDesktop.org shared MIME database and s i simple-scan - Simple Scanning Utility i slick-greeter - Slick-looking LightDM greeter i smartmontools - control and monitor storage systems using i smbclient - command-line SMB/CIFS clients for Unix i spice-vdagent - Spice agent for Linux i stress - tool to impose load on and stress test a c i sudo - Provide limited super user privileges to s i sunxi-tools - tools for working with Allwinner (sunxi) A i sysfsutils - sysfs query tool and boot-time setup i sysstat - system performance tools for Linux i system-config-printer - graphical interface to configure the print i system-config-printer-common - backend and the translation files for syst i systemd - system and service manager i systemd-sysv - system and service manager - SysV compatib i sysvinit-utils - System-V-like utilities i tar - GNU version of the tar archiving utility i terminator - multiple GNOME terminals in one window i thunar-volman - Thunar extension for volumes management i toilet - display large colourful characters in text i transmission-remote-gtk - GTK+ interface for the Transmission BitTor i tzdata - time zone and daylight-saving time data i u-boot-tools - companion tools for Das U-Boot bootloader i ubuntu-drivers-common - Detect and install additional Ubuntu drive i ubuntu-keyring - GnuPG keys of the Ubuntu archive i ubuntu-mono - Ubuntu Mono Icon theme i ucf - Update Configuration File(s): preserve use i udev - /dev/ and hotplug management daemon i unattended-upgrades - automatic installation of security upgrade i unicode-data - Property data for the Unicode character se i unzip - De-archiver for .zip files i update-inetd - inetd configuration file updater i update-manager-core - manage release upgrades i update-notifier-common - Files shared between update-notifier and o i usbutils - Linux USB utilities i util-linux - miscellaneous system utilities i uuid-dev - Universally Unique ID library - headers an i viewnior - simple, fast and elegant image viewer i vim - Vi IMproved - enhanced vi editor i vlan - ifupdown integration for vlan configuratio i wamerican - American English dictionary words for /usr i wbrazilian - Brazilian Portuguese wordlist i wbritish - British English dictionary words for /usr/ i wfrench - French dictionary words for /usr/share/dic i wget - retrieves files from the web i whiptail - Displays user-friendly dialog boxes from s i wireguard-tools - fast, modern, secure kernel VPN tunnel (us i wireless-regdb - wireless regulatory database i wireless-tools - Tools for manipulating Linux Wireless Exte i witalian - Italian dictionary words for /usr/share/di i wpasupplicant - client support for WPA and WPA2 (IEEE 802. i wportuguese - European Portuguese wordlist i wspanish - Spanish dictionary words for /usr/share/di i wswiss - Swiss (German) orthography wordlist i x11-apps - X applications i x11-xserver-utils - X server utilities i x11vnc - VNC server to allow remote access to an ex i xbacklight - simple utility to set the backlight level i xcursor-themes - Base X cursor themes i xdg-user-dirs - tool to manage well known user directories i xdg-user-dirs-gtk - tool to manage well known user directories i xfce4 - Meta-package for the Xfce Lightweight Desk i xfce4-notifyd - simple, visually-appealing notification da i xfce4-screenshooter - screenshots utility for Xfce i xfce4-terminal - Xfce terminal emulator i xfonts-100dpi - 100 dpi fonts for X i xfonts-75dpi - 75 dpi fonts for X i xfonts-base - standard fonts for X i xfonts-encodings - Encodings for X.Org fonts i xfonts-scalable - scalable fonts for X i xfonts-utils - X Window System font utility programs i xinit - X server initialisation tool i xkb-data - X Keyboard Extension (XKB) configuration d i xorg-docs-core - Core documentation for the X.org X Window i xrdp - Remote Desktop Protocol (RDP) server i xscreensaver - Screensaver daemon and frontend for X11 i xserver-xorg-core - Xorg X server - core server i xserver-xorg-input-all - X.Org X server -- input driver metapackage i xterm - X terminal emulator i xtermcontrol - dynamic configuration of xterm properties i xtermset - change the characteristics of an xterm i xwallpaper - utility for setting image files as X wallp i zip - Archiver for .zip files i zlib1g - compression library - runtime i zlib1g-dev - compression library - development orangepiplus:~:% -
Stuck on jammy, can't upgrade to noble
Domas replied to Domas's topic in Software, Applications, Userspace
No, thank you for trying to sort this out Yes, it was first installed as focal image; later updated release to jammy. I do run sudo armbian-upgrade which is a fancy way of doing apt update/upgrade. Saves an extra command. At this moment it says "all packages are up to date" using both armbian-upgrade and using classic apt update/upgrade commands. At this moment I am not sure why there are so many manual packages... I have for sure not installed that many lol. Some could have been installed as a dependency, but would this then be shown as installed manually? I have done just that, 19 packages were removed. Not sure why there were so many manually installed packages. Yes, probably the reason was that it was accidentally disconnected (it has a weak physical link to the board when messing around lol). But I will keep an eye on it after primary problem is solved. I did try updating after cleaning the packages. Same problem, attaching as screenshot. During update attempt all went to shite, GUI decided to commit a sudoku, see attached screenshot. Probably I have uninstalled something, I shouldnt. Restarted the system. Fonts are now back but it looks very different Probably this was not manually installed font package. I will share my aptitude output in next message so I don't lose track. -
Hi there, thanks for trying to solve this, Here it goes: orangepiplus:~:% aptitude search '~o' i A apport-core-dump-handler - Kernel core dump handler for Apport i armbian-focal-desktop-xfce - Armbian desktop for Ubuntu focal i A at-spi2-common - Assistive Technology Service Provider In i A clang-10 - C, C++ and Objective-C compiler i A clang-18 - C, C++ and Objective-C compiler i A cpp-13 - GNU C preprocessor i A cpp-13-arm-linux-gnueabihf - GNU C preprocessor for arm-linux-gnueabi i A cpp-arm-linux-gnueabihf - GNU C preprocessor (cpp) for the armhf a i crda - wireless Central Regulatory Domain Agent i A cron-daemon-common - process scheduling daemon's configuratio i A dbus-bin - simple interprocess messaging system (co i A dbus-daemon - simple interprocess messaging system (re i A dbus-session-bus-common - simple interprocess messaging system (se i A dbus-system-bus-common - simple interprocess messaging system (sy i A dhcpcd-base - DHCPv4 and DHCPv6 dual-stack client (bin i A dracut-install - dracut is an event driven initramfs infr i A fonts-dejavu-mono - Vera font family derivate with additiona i fonts-ubuntu-font-family-conso - console version of the Ubuntu Mono font i A g++-13 - GNU C++ compiler i A g++-13-arm-linux-gnueabihf - GNU C++ compiler for arm-linux-gnueabihf i A g++-arm-linux-gnueabihf - GNU C++ compiler for the armhf architect i A gcc-13 - GNU C compiler i A gcc-13-arm-linux-gnueabihf - GNU C compiler for the arm-linux-gnueabi i A gcc-13-base - GCC, the GNU Compiler Collection (base p i A gcc-14-base - GCC, the GNU Compiler Collection (base p i A gcc-arm-linux-gnueabihf - GNU C compiler for the armhf architectur i A gcr4 - GNOME crypto services (daemon and tools) i A gir1.2-girepository-2.0 - Introspection data for GIRepository libr i hddtemp - hard drive temperature monitoring utilit i A keyboxd - GNU privacy guard - public key material i A libamd3 - approximate minimum degree ordering libr i A libappstream5 - Library to access AppStream services i A libapt-pkg6.0t64 - package management runtime library i A libarchive13t64 - Multi-format archive and compression lib i A libasound2t64 - shared library for ALSA applications i A libatk-bridge2.0-0t64 - AT-SPI 2 toolkit bridge - shared library i A libatk1.0-0t64 - ATK accessibility toolkit i A libatopology2t64 - shared library for handling ALSA topolog i A libatspi2.0-0t64 - Assistive Technology Service Provider In i A libavcodec60 - FFmpeg library with de/encoders for audi i A libavutil58 - FFmpeg library with functions for simpli i A libblockdev-crypto3 - Crypto plugin for libblockdev i A libblockdev-fs3 - file system plugin for libblockdev i A libblockdev-loop3 - Loop device plugin for libblockdev i A libblockdev-mdraid3 - MD RAID plugin for libblockdev i A libblockdev-nvme3 - NVMe plugin for libblockdev i A libblockdev-part3 - Partitioning plugin for libblockdev i A libblockdev-swap3 - Swap plugin for libblockdev i A libblockdev-utils3 - Utility functions for libblockdev i A libblockdev3 - Library for manipulating block devices i A libboost-iostreams1.83.0 - Boost.Iostreams Library i A libbpf1 - eBPF helper library (shared library) i A libcamd3 - symmetric approximate minimum degree lib i A libcanberra-gtk3-0t64 - GTK+ 3.0 helper for playing widget event i A libcanberra0t64 - simple abstract interface for playing ev i A libcbor0.10 - library for parsing and generating CBOR i A libccolamd3 - constrained column approximate library f i A libcholmod5 - sparse Cholesky factorization library fo i A libclang-common-10-dev - Clang library - Common development packa i A libclang-common-18-dev - Clang library - Common development packa i A libclang-cpp10 - C++ interface to the Clang library i A libclang-cpp14t64 - C++ interface to the Clang library i A libclang-cpp18 - C++ interface to the Clang library i A libclang1-10 - C interface to the Clang library i A libclang1-14t64 - C interface to the Clang library i A libclang1-18 - C interface to the Clang library i A libcodec2-1.2 - Codec2 runtime library i A libcolamd3 - column approximate minimum degree orderi i A libcups2t64 - Common UNIX Printing System(tm) - Core l i A libcupsfilters2-common - OpenPrinting libcupsfilters - Auxiliary i A libcupsfilters2t64 - OpenPrinting libcupsfilters - Shared lib i A libcurl3t64-gnutls - easy-to-use client-side URL transfer lib i A libcurl4t64 - easy-to-use client-side URL transfer lib i A libdav1d7 - fast and small AV1 video stream decoder i A libdb5.3t64 - Berkeley v5.3 Database Libraries [runtim i A libdv4t64 - software library for DV format digital v i A libdw1t64 - library that provides access to the DWAR i A libelf1t64 - library to read and write ELF files i A libevdocument3-4t64 - Document (PostScript, PDF) rendering lib i A libevent-2.1-7t64 - Asynchronous event notification library i A libevent-core-2.1-7t64 - Asynchronous event notification library i A libevview3-3t64 - Document (PostScript, PDF) rendering lib i A libext2fs2t64 - ext2/ext3/ext4 file system libraries i A libflac12t64 - Free Lossless Audio Codec - runtime C li i A libfuse2t64 - Filesystem in Userspace (library) i A libgail18t64 - GNOME Accessibility Implementation Libra i A libgcc-13-dev - GCC support library (development files) i A libgcc-14-dev - GCC support library (development files) i A libgck-2-2 - Glib wrapper library for PKCS#11 - runti i A libgcr-4-4 - Library for Crypto related tasks i A libgdbm-compat4t64 - GNU dbm database routines (legacy suppor i A libgdbm6t64 - GNU dbm database routines (runtime versi i A libgegl-0.4-0t64 - Generic Graphics Library i A libgeoip1t64 - non-DNS IP-to-country resolver library i A libgimp2.0t64 - Libraries for the GNU Image Manipulation i A libgirepository-2.0-0 - GLib runtime library for handling GObjec i A libglib2.0-0t64 - GLib library of C routines i A libglibmm-2.4-1t64 - C++ wrapper for the GLib toolkit (shared i A libgnome-desktop-3-20t64 - Utility library for the GNOME desktop - i A libgnutls30t64 - GNU TLS library - main runtime library i A libgpgme11t64 - GPGME - GnuPG Made Easy (library) i A libgphoto2-6t64 - gphoto2 digital camera library i A libgphoto2-port12t64 - gphoto2 digital camera port library i A libgs-common - interpreter for the PostScript language i A libgs10 - interpreter for the PostScript language i A libgs10-common - interpreter for the PostScript language i A libgtk-3-0t64 - GTK graphical user interface library i A libgtk2.0-0t64 - GTK graphical user interface library - o i A libgtkmm-2.4-1t64 - C++ wrappers for GTK+ 2 (shared librarie i A libgtkmm-3.0-1t64 - C++ wrappers for GTK+ (shared libraries) i A libgts-0.7-5t64 - library to deal with 3D computational su i A libgxps2t64 - handling and rendering XPS documents (li i A libheif-plugin-aomdec - ISO/IEC 23008-12:2017 HEIF file format d i A libheif-plugin-libde265 - ISO/IEC 23008-12:2017 HEIF file format d i libhogweed5 - low level cryptographic library (public- i A libhogweed6t64 - low level cryptographic library (public- i A libhwy1t64 - Efficient and performance-portable SIMD i A libical3t64 - iCalendar library implementation in C (r i libicu66 - International Components for Unicode i A libicu74 - International Components for Unicode i A libieee1284-3t64 - cross-platform library for parallel port i A libimath-3-1-29t64 - Utility libraries from ASF used by OpenE i A libiw30t64 - Wireless tools - library i libjson-c4 - JSON manipulation library - shared libra i A libjxl0.7 - JPEG XL Image Coding System - "JXL" (sha i A libldap2 - OpenLDAP libraries i A liblerc4 - Limited Error Raster Compression library i A libllvm10 - Modular compiler and toolchain technolog i A libllvm14t64 - Modular compiler and toolchain technolog i A libllvm18 - Modular compiler and toolchain technolog i A libllvm19 - Modular compiler and toolchain technolog i A libmagic1t64 - Recognize the type of data in a file usi i A libminizip1t64 - compression library - minizip library i libmpdec2 - library for decimal floating point arith i A libmpg123-0t64 - MPEG layer 1/2/3 audio decoder (shared l i A libmtdev1t64 - Multitouch Protocol Translation Library i A libnetplan1 - Declarative network configuration runtim i libnettle7 - low level cryptographic library (symmetr i A libnettle8t64 - low level cryptographic library (symmetr i A libnpth0t64 - replacement for GNU Pth using system thr i A libntfs-3g89t64 - read/write NTFS driver for FUSE (runtime i A libnvme1t64 - NVMe management library (library) i A libobjc-13-dev - Runtime library for GNU Objective-C appl i A libopenexr-3-1-30 - runtime files for the OpenEXR image libr i A liborc-0.4-0t64 - Library of Optimized Inner Loops Runtime i A libparted-fs-resize0t64 - disk partition manipulator - shared FS r i A libparted2t64 - disk partition manipulator - shared libr i A libpcap0.8t64 - system interface for user-level packet c i libpcre2-posix2 - New Perl Compatible Regular Expression L i A libperl5.38t64 - shared Perl library i A libpkcs11-helper1t64 - library that simplifies the interaction i A libpng16-16t64 - PNG library - runtime (version 1.6) i A libpoppler-cpp0t64 - PDF rendering library (CPP shared librar i A libpoppler-glib8t64 - PDF rendering library (GLib-based shared i A libpoppler134 - PDF rendering library i A libppd2 - OpenPrinting libppd - Shared library i A libppd2-common - OpenPrinting libppd - Auxiliary files i A libproc2-0 - library for accessing process informatio i A libpskc0t64 - OATH Toolkit Libpskc library i A libpsl5t64 - Library for Public Suffix List (shared l i A libpython3.12-minimal - Minimal subset of the Python language (v i A libpython3.12-stdlib - Interactive high-level object-oriented l i A libpython3.12t64 - Shared Python runtime library (version 3 i libpython3.8-minimal - Minimal subset of the Python language (v i A libqpdf29t64 - runtime library for PDF transformation/i i A libqt5core5t64 - Qt 5 core module i A libqt5dbus5t64 - Qt 5 D-Bus module i A libqt5gui5t64 - Qt 5 GUI module i A libqt5network5t64 - Qt 5 network module i A libqt5printsupport5t64 - Qt 5 print support module i A libqt5sql5t64 - Qt 5 SQL module i A libqt5test5t64 - Qt 5 test module i A libqt5widgets5t64 - Qt 5 widgets module i A libqt5xml5t64 - Qt 5 XML module i A librav1e0 - Fastest and safest AV1 encoder - shared i A libraw23t64 - raw image decoder library i A libre2-10 - efficient, principled regular expression i A libreadline8t64 - GNU readline and history libraries, run- i A libreiserfscore0t64 - ReiserFS core library i libsepol1 - SELinux library for manipulating binary i A libsframe1 - Library to handle the SFrame format (run i A libsharpyuv0 - Library for sharp RGB to YUV conversion i A libsmbclient0 - shared library for communication with SM i A libsnapd-glib-2-1 - GLib snapd library i A libsnmp40t64 - SNMP (Simple Network Management Protocol i A libssh2-1t64 - SSH2 client-side library i libssl1.1 - Secure Sockets Layer toolkit - shared li i libssl3t64 - Secure Sockets Layer toolkit - shared li i A libstdc++-13-dev - GNU Standard C++ Library v3 (development i A libstoken1t64 - Software Token for cryptographic authent i A libsuitesparseconfig7 - configuration routines for all SuiteSpar i A libsvtav1enc1d1 - Scalable Video Technology for AV1 (libsv i A libswresample4 - FFmpeg library for audio resampling, rem i A libsystemd-shared - systemd shared private library i A libtevent0t64 - talloc-based event loop library - shared i A libtiff6 - Tag Image File Format (TIFF) library i A libtirpc3t64 - transport-independent RPC library i A libtss2-esys-3.0.2-0t64 - TPM2 Software stack library - TSS and TC i A libtss2-mu-4.0.1-0t64 - TPM2 Software stack library - TSS and TC i A libtss2-sys1t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-cmd0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-device0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-libtpms0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-mssim0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-spi-helper0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tcti-swtpm0t64 - TPM2 Software stack library - TSS and TC i A libtss2-tctildr0t64 - TPM2 Software stack library - TSS and TC i A libumfpack6 - sparse LU factorization library i A libunistring5 - Unicode string library for C i A libv4l-0t64 - Collection of video4linux support librar i A libv4lconvert0t64 - Video4linux frame format conversion libr i A libvpx9 - VP8 and VP9 video codec (shared library) i libwebp6 - Lossy compression of digital photographi i A libx264-164 - x264 video coding library i A libxmlsec1t64 - XML security library i A libxmlsec1t64-openssl - Openssl engine for the XML security libr i A libxt6t64 - X11 toolkit intrinsics library i A libzvbi0t64 - Vertical Blanking Interval decoder (VBI) i A llvm-18-linker-tools - Modular compiler and toolchain technolog i A mesa-libgallium - shared infrastructure for Mesa drivers i A netplan-generator - Declarative network configuration for va i numix-blue-gtk-theme - Variant of the Numix theme with blue hig i perl-modules-5.30 - Core Perl modules i A perl-modules-5.38 - Core Perl modules i A pkgconf-bin - manage compile and link flags for librar i A python3-netplan - Declarative network configuration Python i A python3-rlpycairo - plugin for the ReportLab PDF Toolkit. i A python3.12 - Interactive high-level object-oriented l i A python3.12-minimal - Minimal subset of the Python language (v i python3.8-minimal - Minimal subset of the Python language (v i A systemd-dev - systemd development files i systemd-resolved - systemd DNS resolver i ttf-ubuntu-font-family - sans-serif font set from Ubuntu (transit orangepiplus:~:% Here: orangepiplus:~:% apt-cache policy | grep http | awk '{print $2" "$3}' | sort -u http://apt.armbian.com jammy/jammy-desktop http://apt.armbian.com jammy/jammy-utils http://apt.armbian.com jammy/main http://ports.ubuntu.com/ubuntu-ports jammy/main http://ports.ubuntu.com/ubuntu-ports jammy/multiverse http://ports.ubuntu.com/ubuntu-ports jammy/restricted http://ports.ubuntu.com/ubuntu-ports jammy-security/main http://ports.ubuntu.com/ubuntu-ports jammy-security/multiverse http://ports.ubuntu.com/ubuntu-ports jammy-security/restricted http://ports.ubuntu.com/ubuntu-ports jammy-security/universe http://ports.ubuntu.com/ubuntu-ports jammy/universe http://ports.ubuntu.com/ubuntu-ports jammy-updates/main http://ports.ubuntu.com/ubuntu-ports jammy-updates/multiverse http://ports.ubuntu.com/ubuntu-ports jammy-updates/restricted http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe https://github.armbian.com/configng stable/main Do release upgrade downloads the updater package (noble.tar.gz) and then I think it has update link insides, or it just seems so. It tries to download files even if I comment out all of the /sources.list.d/ which is strange in my view.. This is probably my external hard drive that I actually use for data backups (primary use of this whole system). It is fstab and is automounted on every start. It could be that it was actually disconnected when doing armianmonitor 😉 But this is to be sorted later. Thanks for pointing that out Any ideas? This is really too complicated for me to solve on my own at this point. -
Okay, where do I start.... Armianmonitor: https://paste.armbian.com/oletimumob I have this ancient Opi+. AND I KNOW THOSE TYPES OF UPDATES ARE NOT SUPPORTED. Yet, they often succeeds and I want to upgrade my system via do-release-upgrade For last six months I am stuck on this, attaching output from putty login screen AND lsb_release as a printscreen My sources.list.d look like this orangepiplus:sources.list.d:% dir armbian-config.sources armbian.list ubuntu.sources orangepiplus:sources.list.d:% cat armbian-config.sources Types: deb URIs: https://github.armbian.com/configng Suites: stable Components: main Signed-By: /usr/share/keyrings/armbian.gpg orangepiplus:sources.list.d:% cat armbian.list deb [arch=armhf signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com jammy main jammy-utils jammy-desktop orangepiplus:sources.list.d:% cat ubuntu.sources Types: deb URIs: http://ports.ubuntu.com/ubuntu-ports/ Suites: jammy jammy-updates jammy-security Components: main restricted universe multiverse Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg orangepiplus:sources.list.d:% Update package noble.tar.gz is downloaded and run, but then it results in this, not sure why? Updating repository information No valid mirror found While scanning your repository information no mirror entry for the upgrade was found. This can happen if you run an internal mirror or if the mirror information is out of date. Do you want to rewrite your 'sources.list' file anyway? If you choose 'Yes' here it will update all 'jammy' to 'noble' entries. If you select 'No' the upgrade will cancel. Continue [yN] y Generate default sources? After scanning your 'sources.list' no valid entry for 'jammy' was found. Should default entries for 'noble' be added? If you select 'No', the upgrade will cancel. Continue [yN] I agree to this but then it results in buttload of Hit/Err 404 errors, for some reason, it is a small part of it: n http://archive.ubuntu.com/ubuntu noble/universe armhf Packages Err http://archive.ubuntu.com/ubuntu noble/restricted armhf Packages 404 Not Found [IP: 91.189.91.81 80] Err http://archive.ubuntu.com/ubuntu noble/main armhf Packages 404 Not Found [IP: 91.189.91.81 80] Err http://archive.ubuntu.com/ubuntu noble/multiverse armhf Packages 404 Not Found [IP: 91.189.91.81 80] Err http://archive.ubuntu.com/ubuntu noble/universe armhf Packages 404 Not Found [IP: 91.189.91.81 80] Ign http://archive.ubuntu.com/ubuntu noble/restricted armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/main armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/multiverse armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/universe armhf Packages Err http://archive.ubuntu.com/ubuntu noble/restricted armhf Packages 404 Not Found [IP: 91.189.91.81 80] Ign http://archive.ubuntu.com/ubuntu noble/main armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/multiverse armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/universe armhf Packages Fetched 508 kB in 6s (84.5 kB/s) It ends like this: es 404 Not Found [IP: 185.125.190.82 80], E:Failed to fetch http://security.ubuntu.com/ubuntu/dists/noble-security/main/binary-armhf/Packages 404 Not Found [IP: 91.189.91.82 80], E:Some index files failed to download. They have been ignored, or old ones used instead. Restoring original system state Aborting Reading package lists... Done Building dependency tree... Done Reading state information... Done === Command detached from window (Wed Apr 30 22:07:17 2025) === By trial and error I managed to overcome this by fully commenting out ubuntu sources (whole file) like this: #Types: deb #URIs: http://ports.ubuntu.com/ubuntu-ports/ #Suites: jammy jammy-updates jammy-security #Components: main restricted universe multiverse #Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg Then it does not ask me twice about generating default sources. And this way today it updated around 240 packages, asked for a restart too. But the system remained on 22 jammy. Not sure why it worked. After I run this again i get a buttload of "no candidate ver" errors and it just aborts - this is not a full output. No candidate ver: libpython3.10-minimal No candidate ver: libqt5core5a No candidate ver: libqt5gui5 No candidate ver: libssl3 No candidate ver: python3.10-minimal No candidate ver: resolvconf No candidate ver: rng-tools Restoring original system state Aborting Reading package lists... Done Building dependency tree... Done Reading state information... Done After this, now the system's time is approx 30 min late. Cant seem to fix it either. Unable to systemd-timesyncd because some missing dependency but I will not go into details at this moment. The same happens both on beta releases and stable. Fully updated via armbian-upgrade Where do I start? Clean install would be my LAST effort. I'd hate to do this Where do I begin
Rolling updates: nearly daily 9 "base" packages
I see. For last six months or so I had a hard time upgrading to noble. But this probably needs a separate thread with separate story since it is not really related. -
Hey - just reopening this question. I have a related issue. This continues updating whenever I run the updates (at least once a week) I have noticed that it receives 9-12 of the same updates very often as stated in original post. But it seems that none of the other software is being updated. Is this normal? I remember back in the day if I run apt updates rarely, like once a month there would be a 40-ish packages to be updated. What happened was I did a lot of fiddling around ir sources.list.d and I probably broke something there. Or this is normal with beta on? This is my sources content: orangepiplus:~:% grep -Erh '^deb ' /etc/apt/sources.list* deb [arch=armhf signed-by=/usr/share/keyrings/armbian.gpg] http://beta.armbian.com jammy main jammy-utils jammy-desktop deb [arch=armhf signed-by=/usr/share/keyrings/armbian.gpg] http://beta.armbian.com jammy main jammy-utils jammy-desktop deb [signed-by=/usr/share/keyrings/armbian.gpg] https://github.armbian.com/configng stable main deb http://ports.ubuntu.com/ focal main restricted universe multiverse deb http://ports.ubuntu.com/ focal-security main restricted universe multiverse deb http://ports.ubuntu.com/ focal-updates main restricted universe multiverse deb http://ports.ubuntu.com/ focal-backports main restricted universe multiverse orangepiplus:~:% This is my apt-cache policy output: orangepiplus:~:% apt-cache policy Package files: 100 /var/lib/dpkg/status release a=now 100 http://ports.ubuntu.com jammy-backports/universe armhf Packages release v=22.04,o=Ubuntu,a=jammy-backports,n=jammy,l=Ubuntu,c=universe,b=armhf origin ports.ubuntu.com 100 http://ports.ubuntu.com jammy-backports/main armhf Packages release v=22.04,o=Ubuntu,a=jammy-backports,n=jammy,l=Ubuntu,c=main,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-security/multiverse armhf Packages release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=multiverse,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-security/universe armhf Packages release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=universe,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-security/restricted armhf Packages release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=restricted,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-security/main armhf Packages release v=22.04,o=Ubuntu,a=jammy-security,n=jammy,l=Ubuntu,c=main,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-updates/multiverse armhf Packages release v=22.04,o=Ubuntu,a=jammy-updates,n=jammy,l=Ubuntu,c=multiverse,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-updates/universe armhf Packages release v=22.04,o=Ubuntu,a=jammy-updates,n=jammy,l=Ubuntu,c=universe,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-updates/restricted armhf Packages release v=22.04,o=Ubuntu,a=jammy-updates,n=jammy,l=Ubuntu,c=restricted,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy-updates/main armhf Packages release v=22.04,o=Ubuntu,a=jammy-updates,n=jammy,l=Ubuntu,c=main,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy/multiverse armhf Packages release v=22.04,o=Ubuntu,a=jammy,n=jammy,l=Ubuntu,c=multiverse,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy/universe armhf Packages release v=22.04,o=Ubuntu,a=jammy,n=jammy,l=Ubuntu,c=universe,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy/restricted armhf Packages release v=22.04,o=Ubuntu,a=jammy,n=jammy,l=Ubuntu,c=restricted,b=armhf origin ports.ubuntu.com 500 http://ports.ubuntu.com jammy/main armhf Packages release v=22.04,o=Ubuntu,a=jammy,n=jammy,l=Ubuntu,c=main,b=armhf origin ports.ubuntu.com 500 http://beta.armbian.com jammy/jammy-desktop all Packages release o=Armbian,a=jammy,n=jammy,l=Armbian,c=jammy-desktop,b=all origin beta.armbian.com 500 http://beta.armbian.com jammy/jammy-desktop armhf Packages release o=Armbian,a=jammy,n=jammy,l=Armbian,c=jammy-desktop,b=armhf origin beta.armbian.com 500 http://beta.armbian.com jammy/jammy-utils all Packages release o=Armbian,a=jammy,n=jammy,l=Armbian,c=jammy-utils,b=all origin beta.armbian.com 500 http://beta.armbian.com jammy/jammy-utils armhf Packages release o=Armbian,a=jammy,n=jammy,l=Armbian,c=jammy-utils,b=armhf origin beta.armbian.com 500 http://beta.armbian.com jammy/main all Packages release o=Armbian,a=jammy,n=jammy,l=Armbian,c=main,b=all origin beta.armbian.com 500 http://beta.armbian.com jammy/main armhf Packages release o=Armbian,a=jammy,n=jammy,l=Armbian,c=main,b=armhf origin beta.armbian.com 500 https://github.armbian.com/configng stable/main armhf Packages release o=armbian.github.io/configurator,n=stable,l=armbian.github.io/configurator,c=main,b=armhf origin github.armbian.com Pinned packages: orangepiplus:~:% Also attaching putty home screen to show what I am on now, also showing update window where I get those reocurring updates. -
Wow, unbelievable. But happy to see it is so actively maintained. I don't mind being on beta for time being and I am fine with updating this often. I actually enjoy receiving updates, since I decided to switch to beta and keep the kernel unfrozen. Worst case scenario - if some beta breaks my back, I will just restore whole SD card to a few month old backup and update to latest stable. I do not have anything useful on my board that changes over time. Lets consider this topic closed. -
Hello, not sure if this should go under beginners, or this section but trying here. I have now set my armbian-config to rolling updates so I get the good beta stuff. Situation: I have no hard evidence of how often this actually happens, but it seems that every time i go and do armbian-upgrade, which I have performed yesterday and today, but also few days ago, I get the same 9 updates every time, armbian-bsp-cli-orangepiplus-current armbian-config armbian-firmware-full armbian-zsh base-files linux-dtb-current-sunxi linux-headers-current-sunxi linux-image-current-sunxi linux-u-boot-orangepiplus-current Is this normal with rolling updates? or my apt somehow loses the version information and reinstalls the new packages. Of course it does not happen if I run -upgrade twice. It compiles kernel etc, so a bit lengthy upgrade but no big deal. I am asking this because I was also performing a userspace upgrade unsuccessfully recently (also in same frequency as I do this armbian-upgrade) which fails for some reason. Just trying to find out if this is related. But this is not a part of this thread.
So it was a success. Version information updated too now But it did want to both uninstall and update armbian-bsp-cli-orangepiplus after updating armbian.list file and running apt update/upgrade Do you think it is safe to autoremove them if the system is up and running? I am so happy I managed to fix my junk from 2015.... It is probably a $30 board from china. But there is just something about making old hardware work for as long as possible. Thank you all!
Will attempt tonight.
Ok, upgraded successfully. I said no to removing obsolete stuff in the end and it seemed to want to delete armbian stuff. I did not freeze the kernel this time one thing is a bit weird Now it says Armbian 23.02.2 Jammy shouldn't the version be 24. something? I am nearly done, let me know if I can safely run apt update/upgrade? I'd really hate to start over. My /etc/apt/sources.list.d/armbian.list file contents - the directory was a bit different Thank you all so far!
