Hi all,
First post here. I have been running Armbian on my original Bananapi Pro for a long while now, and thought that it's time to upgrade from Bullseye to Bookworm finally. There were some complications with UsrMerge that I had to resolve manually (I think some boot files from the original Buster installation were both in /lib and /usr/lib), but apart from that the upgrade appears to have worked: All userspace stuff is on Bookworm.
# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Armbian 24.5.0-trunk.530 bookworm
Release: 12
Codename: bookworm
However, the kernel seems to be stuck on 5.15:
# uname -a
Linux bananapi 5.15.43-sunxi #22.05.1 SMP Sat May 28 08:17:47 UTC 2022 armv7l GNU/Linux
This version number appears to be inconsistent with the contents of armbian-image-release:
# cat /etc/armbian-image-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=bananapipro
BOARD_NAME="Banana Pi Pro"
BOARDFAMILY=sun7i
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=85080ff3
VERSION=5.99.191113
LINUXFAMILY=sunxi
BRANCH=dev
ARCH=arm
IMAGE_TYPE=nightly
BOARD_TYPE=eos
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=zImage
IMAGE_UUID=1b7fd79e-803f-4438-8b4c-5e9287a7b86c
I saw on the download page that a current download of Armbian Bookwork for the Bananapi Pro would include Kernel 6.6.29, so there should be a newer kernel available.
Can you help me troubleshooting what is holding my system back from upgrading to a newer kernel? Various posts on the forum suggest anything from "apt-get upgrade will update your kernel" to "use armbian-config". Using the latter, I tried switch between nightly and stable, which didn't offer any updated kernel to apt. The "Switch to other kernels" option retrieves some files, then shows the "Yes, I understand" screen but then immediately goes back to the main "System settings" screen, which makes me think that something is broken here. How can I find out what exactly is broken?
