_Rick
  1. Hi Igor, I understand, I agree, this forum is for the Armbian, not the board. Thank you again for your time, for what is working now, it is waaaayyy faster than my Pi3b !!! In any case, a big thank you for your time! Richard.
  2. Hi Igor, if this can help or you might already know this: AppArmor issues: "The solution: If the AppArmor is not enabled on your host, add this to the Linux kernel boot parameters: apparmor=1 security=apparmor and then reboot your operating system." CGroup version: "The solution: In a supervised installation if you have switched to CGroup v2 you will need to revert what you did. Or you can re-run the supervised installer to fix it. Please be sure to reboot the system after the installation is done. You should never see this issue on Home Assistant OS as all versions of the OS ship with a supported CGroup version." If that help you, have a great one! Richard.
  3. Hi Igor, the image: "Armbian_24.2.2_Khadas-edge2_bookworm_vendor_6.1.43-homeassistant_minimal.oowow.img.xz" work and after few mins I have access as regular HA. There are few warnings: Unsupported system - AppArmor issues : System is unsupported because AppArmor is working incorrectly and add-ons are running in an unprotected and insecure way. Unsupported system - CGroup version: System is unsupported because the wrong version of Docker CGroup is in use. Is it something you can fix in the image and I'll wait or I can upgrade and it will be fixed ? You did a great job man! I'll try to fix it for now, again thank you ! Richard.
  4. Hi Igor, great work on this HA supervised image for the Edge2 oowow. I install it and all fine, but no access to the usual http:ip:8123 and when I try to list the services or the actual "gdbus introspect --system --dest io.hass.os --object-path /io/hass/os" error: "The name io.hass.os was not provided by any .service files" If I can update or re-install the HA would be nice to know. System: Khadas Edge2 Pro, Install "Armbian_24.2.2_Khadas-edge2_bookworm_legacy_5.10.160.oowow.img.xz" from ooWOW All working fine, I can connect with SSH as usual, can do updates or install; but nothing else for Home Assistant. Any comment is apreciated, have a good one. Richard.
