acdpsn
  1. I feel like I should mention I'm using an older version of Armbian because Colton's fix doesn't work on the last version. I'm using 24.2.1 Bookworm.
  2. I had the same issue. Not able to see an hdmi output unless i used a usb-c to hdmi dongle. I was able to restore hdmi output using the instructions in this post: Could be an issue with cheap displays only? The display I'm using is a RCA tv so I'm not really sure.
  3. I was having the same issue and used Colton's solution. Worked like a charm, thank you.
