7 -
Opi5+ error omv7 install docker compose pgpkey
Manuel Carvajal replied to Manuel Carvajal's topic in Orange Pi 5 Plus
please check resolved I also leave the steps I found to solve this error in case another user has the same problem. the main thing about this error is that it does not connect to the server due to lack of gpg key. with this command we make the request for the gpg key to connect to the repository without error in my case the error gave that key 93D6889F9F0E78D5, it can change with other opi5+ the following command adds the response given by the repository and in this way we add the key to our registry to be able to connect to the repository run the command again from the console to check if it is correct or if there is an error. and after waiting about 5 minutes for everything to be checked and connected to the repository: finally the Opi5+ running without problem -
Hello everyone I was trying to look for information in the forum but I can't find any topic where this specific issue is discussed. I also looked for help in the omv forum and they told me it was a problem with the distribution, hopefully you can help me. My system running Armbian_24.5.1_Orangepi5-plus_bookworm_vendor_6.1.43_minimal Install OMV, omv extras, i try to configure the compose folders and i get the 500 internal server error, clear cache, update and reboot system but there is no change, a moderator asked me for the log by executing the following command "Your error output is incomplete. What is the output of: sudo omv-salt deploy run compose" < orangepi5-plus: ---------- ID: configure_compose_scheduled_backup Function: file.managed Name: /etc/cron.d/omv-compose-backup Result: True Comment: File /etc/cron.d/omv-compose-backup is in the correct state Started: 13:23:54.827198 Duration: 788.193 ms Changes: ---------- ID: configure_compose_scheduled_update Function: file.managed Name: /etc/cron.d/omv-compose-update Result: True Comment: File /etc/cron.d/omv-compose-update is in the correct state Started: 13:23:55.616066 Duration: 741.905 ms Changes: ---------- ID: configure_compose_scheduled_prune Function: file.managed Name: /etc/cron.d/omv-compose-prune Result: True Comment: File /etc/cron.d/omv-compose-prune is in the correct state Started: 13:23:56.358647 Duration: 830.032 ms Changes: ---------- ID: configure_etc_docker_dir Function: file.directory Name: /etc/docker Result: True Comment: The directory /etc/docker is in the correct state Started: 13:23:57.189369 Duration: 5.514 ms Changes: ---------- ID: /etc/docker/daemon.json Function: file.serialize Result: True Comment: File /etc/docker/daemon.json updated Started: 13:23:57.195458 Duration: 325.608 ms Changes: ---------- diff: --- +++ @@ -1,3 +1,3 @@ { - "data-root": "/docker" + "data-root": "/var/lib/docker" } ---------- ID: docker_install_packages Function: pkg.installed Result: False Comment: An error was encountered while installing package(s): W: GPG error: http://armbian.tnahosting.net/apt bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 E: The repository 'http://apt.armbian.com bookworm InRelease' is not signed. Started: 13:24:03.303368 Duration: 30382.731 ms Changes: ---------- ID: docker_compose_install_packages Function: pkg.installed Result: True Comment: All specified packages are already installed Started: 13:24:33.686899 Duration: 67.916 ms Changes: ---------- ID: docker_purged_packages Function: pkg.purged Result: True Comment: None of the targeted packages are installed or partially installed Started: 13:24:33.755621 Duration: 4.062 ms Changes: ---------- ID: docker Function: service.running Result: False Comment: Failed to start docker.service: Unit docker.service not found. Started: 13:24:33.835516 Duration: 673.894 ms Changes: ---------- ID: /etc/systemd/system/docker.service.d/waitAllMounts.conf Function: file.managed Result: True Comment: File /etc/systemd/system/docker.service.d/waitAllMounts.conf is in the correct state Started: 13:24:34.510203 Duration: 306.575 ms Changes: ---------- ID: systemd_daemon_reload_docker Function: cmd.run Name: systemctl daemon-reload Result: True Comment: State was not run because none of the onchanges reqs changed Started: 13:24:34.822264 Duration: 0.026 ms Changes: ---------- ID: create_usr_local_bin_dir Function: file.directory Name: /usr/local/bin Result: True Comment: The directory /usr/local/bin is in the correct state Started: 13:24:34.822649 Duration: 5.271 ms Changes: ---------- ID: /usr/local/bin/docker-compose Function: file.symlink Result: True Comment: Symlink /usr/local/bin/docker-compose is present and owned by root:root Started: 13:24:34.828399 Duration: 17.703 ms Changes: Summary for orangepi5-plus ------------- Succeeded: 11 (changed=1) Failed: 2 ------------- Total states run: 13 Total run time: 34.149 s [ERROR ] Command 'apt-get' failed with return code: 100 [ERROR ] stdout: Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Hit:6 http://deb.debian.org/debian bookworm InRelease Get:7 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB] Get:8 http://deb.debian.org/debian bookworm-backports InRelease [56.5 kB] Get:9 http://security.debian.org bookworm-security InRelease [48.0 kB] Get:10 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB] Get:11 http://httpredir.debian.org/debian bookworm-backports InRelease [56.5 kB] Hit:12 https://download.docker.com/linux/debian bookworm InRelease Hit:13 https://openmediavault.github.io/packages sandworm InRelease Hit:14 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease Hit:16 http://packages.openmediavault.org/public sandworm InRelease Get:15 http://armbian.tnahosting.net/apt bookworm InRelease [53.3 kB] Err:15 http://armbian.tnahosting.net/apt bookworm InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 Reading package lists... [ERROR ] stderr: W: GPG error: http://armbian.tnahosting.net/apt bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 E: The repository 'http://apt.armbian.com bookworm InRelease' is not signed. [ERROR ] retcode: 100 [ERROR ] An error was encountered while installing package(s): W: GPG error: http://armbian.tnahosting.net/apt bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 E: The repository 'http://apt.armbian.com bookworm InRelease' is not signed. [ERROR ] The named service docker is not available [ERROR ] Command '/usr/bin/systemd-run' failed with return code: 5 [ERROR ] stderr: Running scope as unit: run-r49a37263aed24bcf951c96199f63b03d.scope Failed to stop docker.service: Unit docker.service not loaded. [ERROR ] retcode: 5 [ERROR ] Command '/usr/bin/systemd-run' failed with return code: 5 [ERROR ] stderr: Running scope as unit: run-r56af566a7663456985ec54392976e370.scope Failed to start docker.service: Unit docker.service not found. [ERROR ] retcode: 5 [ERROR ] Failed to start docker.service: Unit docker.service not found. root@orangepi5-plus:~# > *****"the plugin can't fix this. Your armbian repos are broken because either the gpg key is missing or your system time is off. I don't know how it could the former on a fresh install."****** and he mentions to me that the repo is having problems due to lack of a gpg key and that he doesn't know how to fix it; I tested kernel 6.8 I could configure the docker compose well, but the USB and HDD fans had failures randomly if someone could guide me to find a solution because so far it is the only kernel that has worked with all the hardware available in the sbc. 👀
@royk I will try another ISO that has the kernel you mention Armbian 24.5.1 bookworm vendor 6.1.43 minimal. Thanks Can I suggest some guide showing which isos are working or the ones that have less problems with this type of sbc?
And when changing kernel to 5.1 or the other you mention, is there any known error in the Orange pi5+? Since I installed open media vault 7 and with the previous isos with other kernel could not run docker compose 🥲
@royk Hello Edit the file back to: verbosity=1 bootlogo=false console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=2c94c41f-b026-4717-82a6-3c0d968e559e rootfstype=ext4 overlays=sata1 sata2 user_overlays=orangepi-5-plus-pwmfan usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x0bc2:0xab45:u,0x0bc2:0xab44:u #overlays=pwm0-m0 pwm0-m1 pwm0-m2 pwm1-m0 pwm1-m1 pwm1-m2 sata1 sata2 And also I attach a picture of how the fan is connected. Rebooted the system without showing any change 🥲 Thanks for your help
@royk thanks for answering, My system is: <Armbian 24.5.1 Bookworm with bleeding edge Linux 6.8.11-edge-rockchip-rk3588> I moved the file to /boot then run the command in terminal so that the line was added to the armbianEnv file, then I gave the poweroff order and when I restarted the system there was no change, the fan continued at 100% and kept the chip below 35°, is there anything else I can try? ArmbianEnv.txt GNU nano 7.2 verbosity=1 bootlogo=false Console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdey=UUID=2 c94c41f-b026-4717-82a6-3c0d968e559e rootfstype=ext4 user_overlays=orangepi-5-plus-pwmfan overlays=pwm0-m0 pwm0-m1 pwm0-m2 pwm1 -m0 pwm1-m1 pwm1-m2 sata1 sata2 usbstoragequirks=0x2537:0x1 066:u,0x2537:0x1068:u, 0x0bc2:0xab45:u, 0x0bc2:0xab44:u
Hello, I bought the op5+ with the normal fan with 2 pin, but when starting the SBC, it starts at 100% speed keeping the chip at 32°C, is there a way to program the fan to only turn on from 45° ? I understand that it is not a programmable fan, just a simple one, I read earlier other posts about changing the stb file and editing the armbianenv file, is anything else needed? Thanks for the help
