Saam27
  1. Your instructions have solved my problem, thank you very much Regards
  2. Hello, thanks for the suggestions! I would upgrade my kernel to 6.6.39 and then install the kernel headers for 6.6.3.9 or downgrade my kernel. I have now tried changing my kernel to "Linux 6.6.16-current-rockchip64" in armbian-config and then installing the headers. Then I tried to install zfs-dmks, unfortunately with the same result I probably need a different kernel than the one suggested in armbian-config which variant would be better for my Helios64 or does it not matter? I've never done anything like this before and I'm not that familiar with Linux to install an additional kernel or header afterwards. Which commands do I need? Regards Saam27
  3. Hello, I have a problem, when I enter "sudo apt install zfs-dkms" on my Helios64, I get this error message: "Module build for kernel 6.6.36-current-rockchip64 was skipped because the kernel headers for this kernel do not appear to be installed." I also made sure to install the kernel header in armbian-config and also rebooted. When I type "apt list --installed | grep linux-headers", I get this listing: WARNING: apt does not have a stable CLI interface. Use it with caution in scripts. linux-headers-current-rockchip64/bookworm,now 24.5.1 arm64 [installed] omv7 itself is installed and running. The image "Armbian_24.5.3_Helios64_bookworm_current_6.6.36_minimal.img.xz" has been installed. apt update and apt upgrade were run after installing the image The plan is to get OMV7 running with zfs on my Helios64 I hope someone can help me with this Regards Saam27
