Tera
  1. I'll try Nginx Proxy Manager add'on instead NGINX Home Assistant SSL proxy”. Thank you
  2. Hello, I am new in linux enviroment, so plese apologized me if I'll do stupid questions. i got a ondorid N2+ with Armbian 24.2.2 bookworm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.32-current-meson64 Architecture: arm64 and home assistant supervised preinstalled. All works fine and thank you for your great job. Inside home assistant I have installed Nginx plugin and Duckdns to manange communication in SSL with external services (like google assistant). Now I would like to install nginx manager as "normal" container directly outside of Homeassistant and not as homeassistant container: homeassistant/aarch64-addon-nginx_proxy:3.9.0 To do that I prefer to use docker compose (because the manage of parameter it's seem most easy to do). And now the question: It is possible to reverse "configuration" of preinstalled homeassistant to a yaml configuration? If yes, can you help me to find this information to recreating the yaml config? Or, I can manage only nginx manager container with docker compose (plugin) + config.yaml? Some note or advice about that? I hope not in OP. Thank you in advance.
