yi li
  1. The hint has been given on the LOG, and you should try again as suggested above "Error: Partition(s) 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64 on /dev/loop0 have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes."
  2. That's my mistake, these two are not the same wifi model, my firmware should not work
  3. @firepower hey ,I remember you had a T95ZPLUS where I made a firmware with wifi bt based on nick a's build, you can try it T95Z PLUS H618 - Allwinner CPU Boxes - Armbian Community Forums https://github.com/LYU4662/t95zplus-h618-build.git
  4. Has anyone used it, please give me feedback😀
  5. T95zPlus-h618 eth ---ok usb0&1 ---ok wifi&bt ---ok 3.5mm headphone ---ok hdmi&hdmi codec ---ok ir ---ok https://github.com/LYU4662/t95zplus-h618-build.git
