Ian Coelho
722 profile views
  1. nice work @Eks Ma thanks for sharing!
  2. Hello @Eks Ma, how are you? Unfortunately not. I gave up trying. The TV box is just sitting here at home.
  3. I really appreciate your help! Couldn't the information provided by the user in this post be a possible solution?
  4. aml-s9xx-box:~:# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sda 8:0 0 223.6G 0 disk └─sda1 8:1 0 223.6G 0 part sdb 8:16 1 0B 0 disk mmcblk0 179:0 0 116.1G 0 disk ├─mmcblk0p1 179:1 0 512M 0 part /boot └─mmcblk0p2 179:2 0 114.4G 0 part / zram0 251:0 0 1.4G 0 disk [SWAP] zram1 251:1 0 50M 0 disk /var/log zram2 251:2 0 0B 0 disk aml-s9xx-box:~:# --- one more thing, tried dmesg: [ 3.780393] mmc1: tuning execution failed: -5 [ 3.783045] mmc1: error -5 whilst initialising MMC card [ 3.788366] mmc1: Failed to initialize a non-removable card --- This is the post I mentioned that talks about modifying the max-frequency:
  5. Apologies for my lack of basic information! - I'm using the latest build from August 29th, specifically the server image for Ubuntu 24.04 Noble (Armbian_community_24.11.0-trunk.66_Aml-s9xx-box_noble_current_6.6.47.img). - I'm using the DTB specific to the box I'm working with, which is the "meson-gxm-t95z-plus.dtb" for the T95z Plus. - In addition to using the DTB I mentioned above, I also tried the only other available DTB in the DTB folder for the s912, which is the "meson-gxm-s912-libretech-pc.dtb". My third attempt was to do what I mentioned in the initial post: I unpacked the "meson-gxm-t95z-plus.dtb", edited the "meson-gxm-t95z-plus.dts", and changed the max-frequency of the "mmc@74000" block to another hex number, and then I compiled it and tried again. All three options allowed the T95z Plus box to boot Armbian normally, recognize the network, and everything seemed fine. However, the eMMC isn't recognized in any of these cases. - I'm trying to install on the eMMC using the command ./install-aml.sh, and the message I'm getting is the one I mentioned in the initial post. Thank you!
  6. Hello guys! I have a T95Z Plus TV BOX with 3GB RAM, 32GB ROM, and an arm S912 CPU. I can run Armbian just fine from the SD card, but when I try to install it on the eMMC, I get an error message saying something like, "You're already running from eMMC, or the eMMC was not found." And, obviously, I'm not running from eMMC, so it seems like the system just isn't detecting it. I did some research, and it seems like there might be different eMMC manufacturers for the same T95Z Plus model. So, I might need to adjust the "Max frequency" parameter in the .DTB file for the T95Z Plus in order for Armbian to recognize the eMMC on my device. Does that sound right? If so, where should I start? Should I randomly change that parameter, or is there a table of parameters I can use to try different values until it works? Thanks!
